Tuning 1.8T
toni
asa merge?
http://i42.tinypic.com/105qi45.gif
sau
<a href="http://tinypic.com" target="_blank"><img src="http://i42.tinypic.com/105qi45.gif" border="0" alt="Image and video hosting by TinyPic"></a>
http://tinypic.com/view.php?pic=105qi45&s=5
  • Replies 840
  • Bogdan_wrc
    156
  • Jacku
    64
  • Nautilus
    48
  • insanity
    46
codul pt Ko4 de la Audi TT ,S3, 225ps e 06A 145 704 0
merge asa. mersi
later edit: numai ca sincer nu prea inteleg ce reprezinta axele, si ce-s liniile ~orizontale
poate cineva se pricepe mai bine si ma (ne) invata si pe mine (noi) :Driver:
Modificat de 4EST
stabilim o intalnire atunci cei cu 1.8 t in cluj, sa povestim de una alta??
Modificat de roby200487
nautilus, de ce nu pui si aici linkurile cu informatii?:)
http://www.formulatwo.com/f2carthef2car.aspx
http://forums.vwvortex.com/zerothread?cmd=...&id=4073245
The F2 car is powered by an Audi 1.8 litre turbo engine with a target 400bhp on standard boost and 450bhp on overboost. The engines on all cars will have identical power within 1.5% of the target. The overboost facility is actuated by a steering wheel button which increases maximum power by 50bhp for a duration as specified on the set-Up sheet, typically six seconds. Overboost may not be used except in the second practice session and in each of the races, when the number of shots will be specified on the set-up sheet but typically eight shots are available for races and four available for tests.
pai si eu sunt curios ce vor folosi ca piese, dar 450 de cai din 1.8T se pot obtine si azi :D
ce interesant? :rolleyes:
"I am not sure that you can achieve 340hp without using nitrous. Additionally, I feel fairly confident that if you do you will significantly shorten the life of your Jetta; and perhaps yourself and others.
Whatever you do is your business but... just please respect yourself, others and your Jetta."
"I have to ask this question:
Why do you want to increase your Jetta's hp / torque? Are you planning to race it? At even highway speeds your stock Jetta should have more than sufficient hp / torque to just about go faster than anybody else and certainly faster than is safe for you and others."
intrebarea mea era o gluma :blah:, sunt si chestii interesante pe acolo.
poti mai mult, dar cu alta turbina :Driver: cea de la avzatar :(
stiu asta..tocmai de aia am postat.
si biennteles, dupa toate cele, adica turbina, injectoare, pompa, tzevi+ intercooler, eventual pistoane, axe, si arbore, si o garnitura de chiulasa, daca vrei performante de peste 400 cp, cel mai important e softul, ceeace aici in romania, nu prea ai unde sa tzil faci k-lumea, cand te bagi mai adanc.... eu ma tot gandesc, oare unde sa fac soft dupa ce pun bestia pe masina .... ca sa nu imi distrug internele, sa o limitez acolo unde trebuie :D, acuma sunt in cautare de serpi, dar downpipeu va fi custom, ca nu gasesc
sunt si aici firme care fac softuri custom, chiar f bine.
de ce nu-ti descrii masina in aria speciala? :icon_thumright:
o sa o descriu, dar inca nu pot face new topic :), sunt inca elev pe forum :) .... ia zi o firma de soft klumea :):icon_thumright:, care ar fi aceea??... sincer nu am incredere :) superchips? master tuner.....????...... sincer mai bine ma duc in ungaria ... si acolo stiu o treaba, am o cunostinta care a fost.... si nu se compara, credema :)
superchips, revo, jabba.. chiar si la kisslorand as incerca in Cluj.
in mastertuner nici eu nu am incredere.
unele din alea de mai sus chiar au facut softuri custom pentru romani si au iesit ff bine. cum ti se pare 1.8t cu turbina IHI?
nu stiu ce fac ungurii, dar banuiesc ca si ei sunt tari, dar ce zic eu, sunt facute in afara, si sunt decat puse aici pe masini. si am vazut masini ff reusite.
ihi de mitsu.. din cate amauzit, si stiu, sunt foarte foaret bune.... dar daca te referi la a mea, dinpoza, nu e ihi ci kkk.
din cate am observat pot face new topic la masina mea, acuma scriu istoria, o sa vezi, si o sa gasesti acolo :icon_thumright:
IHI e de subaru. mitsu au turbinele lor.
nu, nu la tine. ci la alte 1.8T.
de aia zic, hai sa nu aruncam cu pietre in ai nostrii (ca ei nu pot, nu stiu...blah blah), si sa laudam pe altii, daca nu stim toate datele :icon_thumright: acum stii si poate vei afla mai multe si vei intelege de ce nu cred ca e nevoie sa trecem granita pentru un soft.
hai ungure ca iti fac eu softu cu vag-comu :(
on topic: stie cineva de ce tot apare eroarea asta : 16487/P0103/000259 - Mass Air Flow (MAF) (G70): Signal too High ?
dar numai o data pe luna imi apare,din cate am vazut pe rosstech poate fi debitmetrul stricat,desi l-am schimbat acum vreo 8 luni.
incearca sa-l verifici, fa niste loguri, vezi daca functioneaza totusi.
poate s-a stricat iar intre timp..
Am mai verificat intre timp si nu a mai aparut eroarea.Cred ca era din cauza unei pierderi de vacuum,de la un furtun de sub admisie care era putin crapat.
Nu stii daca potriveste volant de G60 si ambreiaj de VR6 ?Din cate am auzit cam asta ar fi o combinatie buna.
Modificat de Dodo89
  Deceunink a scris:
Atunci ai o problema legata de boost. N75 sau o supapa de sens ca sunt destule. Sau un furtunas fisurat dar mai putin probabil. Coduri de eroare n-ai? E unul celebru care se refera la clapeta de acceleratie dar ar fi bine sa nu fie ala.
Ar putea fi si de la mapa cu care rulezi. N-am retinut daca ai tuning sau nu.
Deceunik, la ce eroare legata de clapeta te referi? Ii stii codul?
PS
Are cineva de vanzare arc galben pt DV Forge? Sau.. vreun tuning-shop care sa-l aiba pe stoc?
Valva ai luat-o de la Forge direct sau de la altcineva? Fiindca eu am luat-o direct de la ei, cu arc verde, si cand am vazut ca nu e suficient le-am zis si mi-au trimis unul galben pe gratis (nici macar costuri de shipping) :D
  jmf a scris:
Valva ai luat-o de la Forge direct sau de la altcineva? Fiindca eu am luat-o direct de la ei, cu arc verde, si cand am vazut ca nu e suficient le-am zis si mi-au trimis unul galben pe gratis (nici macar costuri de shipping) ;)
Aha!
E luata de la ei, da, insa prin PitStop Tuning. Am specificat Leon AUQ si au trimis-o cu arc albastru.
In mers mi se pare cam tare.
O sa sun si pe la Nick sa vad.. Dar ma gandeam sa mai strang "idei" :ceuameni:
