Sistemul de climatizare - probleme, teste, setari...
alex
Ok. Credeam ca faci o confuzie cu vascocuplajul.
Deoarece am achizitionat o interfata originala sper ca acum o sa reusesc sa rezolv problemele legate de instalatia de climatizare (passat 3c5 fabricatie 11.08.2008).
Erorile stocate sunt urmatoarele :
Tuesday,26,June,2018,20:40:48:31824
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WVWZZZ3CZ9E023094 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ9E023094 Mileage: 239040km-148532miles
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
  Part No SW: 3C0 907 044 AJ HW: 3C0 907 044 AJ
  Component: ClimatronicPQ46 050 0505
  Revision: 00050005 Serial number: 00000000000000
  Shop #: WSC 00000 000 00000
  VCID: 698F4188757E274FC69-803C
3 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
  000 - -
  Freeze Frame:
  Fault Status: 01110000
  Fault Priority: 3
  Fault Frequency: 5
  Reset counter: 129
  Mileage: 238993 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 02:40:22
00716 - Air recirculation Flap Positioning Motor (V113)
  000 - -
  Freeze Frame:
  Fault Priority: 3
  Fault Frequency: 5
  Reset counter: 129
  Mileage: 238993 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 02:40:22
  000 - -
  Freeze Frame:
  Fault Priority: 3
  Fault Frequency: 5
  Reset counter: 129
  Mileage: 238993 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 02:40:22
Legat de V159 am rezolvat problema cu basic settings. V71 (V425)  l-am inlocuit dar nu reusesc sa-l fac sa functioneze.
Banuiala mea este ca panoul climatronicului meu nu este compatibil cu sistemul montat pe masina (in vcds vad 2 actuatoare pe clapetele de recirculare aer dar in realitate eu am montat doar 1 singur).
In etka daca introduc codul panoului climatronic ma trimite la masini cu fabricatie 2006 sau 2007. Sa se fi inlocuit panoul pana sa ajunga masina in proprietatea mea cu unul mai vechi?
MAi mult ca sigur.
1 hour ago, Al Bundy said:
MAi mult ca sigur.
Ma puteti ajuta sa identific codul corect pentru panoul climatronic pe care ar trebui sa il montez. Masina nu are incalzire auxiliara, nu stiu daca are senzor de calitate aer. Nu am incalzire in scaune si nici parbriz incalzit.
Modificat de juice_kk
cumpara un panou de facelift, daca tot il schimbi. Modifici cateva fire in mufele de la panou si va merge ok
Despre senzorul de calitate aer, cum aflu daca il am montat pe masina sau nu.
daca il ai sau nu, cu ce infuenteaza problema actuala ?
Influenteaza doar achizitia viitorului panou de climatizare. M-am saturat sa am erori la fiecare diagnoza. As vrea ca totul sa fie functional, citisem ca in cazul in care masina nu are montat senzor de calitate iar panoul de climatronic stie de senzor o sa am in continuare eroare pe acest senzor.
Florin, aveti pe stoc un panou de clima facelift functional?
cred ca da, dar trebuie sa verific diseara - ma suni si iti zic - dar asta discutam pe privat sau la telefon, nu aici.
Senzorul, chiar daca nu-l ai...se rezolva din cablaj - macar treci la panoul nou, cu afisare pe radio/navigatie
On 22.04.2018 at 16:06, Al Bundy a scris:
Compresorul merge tot timpul, deci nu are ce sa cupleze.
CAt este cuplul dezvoltat de compresor, cat este curentul cerut si cet este cel consumat ?
Am depistat problema ..... era de la motarasul din partea stanga de langa pedala de acceleratie.
Salut Florin,
Am gasit panou climatronic cu codul 5G1907044, este compatibil cu ce am eu sau e prea nou?
Pret 200 ron cu trimul aferent inclus.
Mai revin si eu cu priblema mea, din cate am inteles este o valva de expansiune pe radiatorul de clima din masina, e posibil sa am probleme cu acesta? Mentionez ca se aude un suierat in masina cand merge clima
23 hours ago, juice_kk said:
Salut Florin,
Pt Passat b6 - nu, nu merge.
Am reușit sa rezolv in final problema sistemului de climatizare prin schimbarea panoului Climatronic cu unul care știe ca am un singur actuator pe recirculare.
Prima data de cand am interfața si nu am nici o eroare pe scan.?
Va salut , dupa ani de zile cu probleme la clima, acum de vreo 2 luni imi merge ok, doar ca acum cu temperaturile astea de 33+ nu imi mai raceste asa tare si am sesizat ca nu merge ventilatorul de la clima pe treapta a doua (zic eu, ar trebui sa se auda vajaitul ala puternic cand porneste treapta a doua,nuh ? ). Intrebarea mea e daca se poate verifica/testa cumva cu VCDS-ul ?
se poate testa pe direct.
Ok, pe direct daca il pun trebuie sa porneasca la turatia maxima (treapta 2 ) ?
Pornirea pe treapta 2 nu e conditionata de anumiti factori, gen temperatura exterioara ridicata ?
kosmyn_aurel89
Daca il pui direct pleaca pe turatie maxima, adica pe treapta a 2 a.
Cand e pe masina, treptele 1 si 2 le foloseste in functie de cum ii comanda calculatorul de clima, dupa semnalul primit de sonda de presiune de pe radiatoru ac
Ok, sonda aia de pe radiatorul AC , unde se afla mai exact, e diagnosticabila cu VCDS, da vreo eroare daca nu merge treapta 2 sa zicem ?
Mentionez inca odata , clima merge bine , doar ca acum cu temperaturile astea de 33+ simt ca nu raceste cum trebuie si nu aud ventilatorul turat( zgomotul ala specific) , de aici si suspiciunea ca nu porneste pe treapta 2.
nu, nu o poti diagnostica cu VCDS.
cum te uiti la radiator, pe partea soferului, jos
serbanviorel86
Va salut cu respect. Ma adresez tuturor celor care ar putea sa ma ajute cu problema mea. Pe scurt am pasatul b6 din semnătura și am următoarea problema. Mai exact când pornesc clima se aude un zornăit care se amplifica pe măsură ce creste turația la motor. Nu îmi dau seama de unde ar fi. Se aude de undeva de sub bord cam din dreptul volanului. Menționez ca instalația funcționează adică baga rece dar e deranjant acel zgomot care dispare imediat ce decuplez clima. Am introdus freon acum 3 luni. Am făcut scanare cu VCDS și nici o eroare. Aeroterma nu este pentru ca nu se modifica zgomotul dacă dau mai tare sau mai încet aeroterma. Ma gândeam sa nu fie de la rola de la întinzătorul curelei de accesorii. Ce as mai putea verifica? Sa fie de la compresor ceva defect? Sincer nu mai am idei și nu as vrea sa ma apuc sa schimb ceva care nu ar fi defect.
Aceeasi pb o am si eu la masina mea (passat 1.9tdi 131 cp avf) cand pornesc clima se aude un huruit care creste in intensitate odata cu turatia motorului...in rest baga rece si totul e ok..o sa merg saptamana asta la service sa vad care e pb si revin cu amanunte!
taner.mustafa
Salut! Îmi apare codul de eroare 4f9 00, adică aeroterma blocată sau care nu primește curent. Când pornesc mașină și climatronicul, nu baga rece, deși are freon. Am observat că nu pornește nici ventilatorul de la radiator și nici compresorul. Când conectez compresorul la 12V, pornesc amândouă și baga și aer rece. Deci problema este că nu primește compresorul curent. De asemenea, senzorul de temperatura exterioara este stricat și treb sa pun unul nou.
Care ar putea fi rezolvarea? Merci!
incearca sa schimbi inainte senzorul de temp exterioara, are legatura cu clima
    • cristy2009
