suzu
Thursday,27,October,2016,21:13:39:37412
VCDS Version: Release 11.11.0 (x64)
                Address 19: CAN Gateway       Labels: 1K0-907-530.lbl
Control Module Part Number: 1K0 907 530 E    HW: 1K0 907 951
  Component and/or Version: Gateway         H09 0110
           Software Coding: 3D3F0B40070002
            Work Shop Code: WSC 00046 412 1589248
                      VCID: 29538C0080E23D6
2 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 9
                    Reset counter: 11
                    Mileage: 144725 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:02
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 12
                    Reset counter: 11
                    Mileage: 144725 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:05
Va salut. va rog un ajutor. problema se manifesta astfel. nu porneste radio-ul. modelul este rcd 300. cand ajunge la scanare pe radio se inchid si becurile care ilumineaza butoanele de la el. dupa cateva secunde se reaprind. doar ledurile de la butoane se aprinde...nu display nu sunet. ma puteti ajuta cu o parere. a mai intalnit cineva problema asta? este enervant fara un pic de muzica. multumesc
Foarte probabil o problema interna a RCD-ului.Pina ajungi cu el la ,,doctor" verifica daca are alimentare pe cele 2 fire rosu/galben din conectorul Iso al aparatului si masa pe cel maro.Vezi ca are si o siguranta linga acel conector-verific-o..
Daca totul e ok-un electronist priceput poate rezolva problema..
La un A4 B6 2.0i ce solutii vedeti la urmatoarele erori ?
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
   Part No: 8E0 820 043
   Component:   A4 Klimaautomat   0711
   Coding: 00000
   Shop #: WSC 63351
2 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
            41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
            30-10 - Open or Short to Plus - Intermittent
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 930 KX
   Component: KOMBI+WEGFAHRS. RB8 D30
   Coding: 00101
   Shop #: WSC 00000
   WAUZZZ8E42A091477     AUZ6Z0A0192633
2 Faults Found:
01303 - Telephone Transceiver (R36)
            49-00 - No Communications
01302 - Control Module for Telematic (J499)
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 AD
   Component: Komfortgerát T85    0315
   Coding: 00064
   Shop #: WSC 43087
   Part No: 8E1959801B
   Component: Tõrsteuer.FS BRM 4.11
   Part No: 8E1959802B
   Component: Tõrsteuer.BF BRM 4.11
7 Faults Found:
01562 - Right Rear Door
            59-10 - Can't Unlock - Intermittent
            61-10 - Won't De-Safe - Intermittent
01331 - Door Control Module; Driver Side (J386)
            53-10 - Supply Voltage Too Low - Intermittent
01559 - Drivers Door
00932 - Electric Window Motor; Drivers Side (V147)
            62-10 - No or Incorrect Adjustment - Intermittent
01560 - Passenger Door
01035 - Electric Window Thermal Protection Active; Passenger
            35-10 -  -  - Intermittent
Ma intereseaza:
Auto HVAC: care motorase ar fi vorba ca eu am vazut 4 in spatele la torpedo
Instruments: unde pot face recodare incat sa nu imi mai recunoasca ca masina a fost echipata cu telefon.
Central conv: nu am nici o idee ce poate genera toate acele erori.
Salut detin un golf 6 variant 1.6 tdi si la o recenta scanare am gasit urmatoarele erori:
Duminica,30,Octobrie,2016,11:29:41:53699
VCDS -- Emulator VAG/VAS bazat pe Windows. Editie în Româna Ruleaza pe Windows 7 x64
Versiune VCDS: ROJ 15.7.1.1
Versiune date: 20150904
www.vcds.ro
Numar VIN: WVWZZZ1KZBM683699   Nr.înmatriculare: GOLF6
rulaj: GOLF6   Numar foaie de lucru: GOLF6
Tip sasiu: 1K (7N0)
Adrese de scanat: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 55 56 62 72
01-Motor -- Status: OK 0000
03-ABS frâne -- Status: OK 0000
04-Senzor unghi volan -- Status: OK 0000
08-Clima automata -- Status: OK 0000
09-Electr. centrala -- Status: OK 0000
10-Asist.direct./parc. -- Status: OK 0000
15-Airbaguri -- Status: OK 0000
16-Electronica volan -- Status: OK 0000
17-Instrumente bord -- Status: OK 0000
19-Poarta CAN  -- Status: Malfunctie 0010
25-Blocare pornire -- Status: OK 0000
37-Navigatie -- Status: Neautorizat 0011
42-Usa electr. sofer -- Status: OK 0000
44-Asistenta directie -- Status: OK 0000
46-Confort -- Status: OK 0000
52-Usa electr.pasager -- Status: OK 0000
55-Bataie far -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Usa SS -- Status: OK 0000
72-Usa DS -- Status: OK 0000
Adresa 01: Motor (J623-CAYC)       Eticheta: ROJ\03L-906-023-CAY.clb
   Numar VAG SW: 03L 906 023 ML    HW: 03L 907 425 C
   Componenta: 1,6l R4 CR td H43 9970
   Revizie: --H43---    Numar serial: 00000000000000
   Codare: 10114016030400080000
   Atelier: WSC 00066 000 00198
   Pachet ASAM: EV_ECM16TDI02103L906023ML 003010
   ROD: EV_ECM16TDI02103L906023MK_SE36.rod
   VCID: 7CFC244EF73AA4DE00-8028
Nu a gasit coduri.
Gata de functie: 1110 1000
Adresa 03: ABS frâne (J104)       Eticheta: ROJ\1K0-907-379-60EC1F.clb
   Numar VAG SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Componenta: ESP MK60EC1   H31 0121
   Revizie: 00H31001
   Codare: 113B200D092A00FD881104ED90220041310000
   Atelier: WSC 00066 000 00000
   VCID: 7BFE2752FA34A3E609-802E
Nu a gasit coduri.
Adresa 08: Clima automata (J255)       Eticheta: ROJ\5K0-907-044.clb
   Numar VAG SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Componenta: Climatronic   H17 1010
   Revizie: 00003001
   Codare: 0000000002
   Atelier: WSC 00066 000 00148
   Pachet ASAM: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_VW36.rod
   VCID: 6ED81E06B146C64EBE-803A
Nu a gasit coduri.
Adresa 09: Electr. centrala (J519)       Eticheta: ROJ\1K0-937-08x-09.clb
   Numar VAG SW: 5K0 937 087 M    HW: 5K0 937 087 M
   Componenta: BCM PQ35 H    011 0046
   Revizie: BE011001
   Codare: 00180E3A982D02C040000080740008E443740008737D0560E48000200040
   VCID: 3F869342AEAC7FC665-806A
   Subsistem 1 - Numar VAG: 5K1 955 119   Eticheta: ROJ\1KX-955-119.CLB
   Componenta: Wischer 09031  26  0512
   Codare: 009795
   Subsistem 2 - Numar VAG: 1K0 955 559 AH  Eticheta: ROJ\1K0-955-559-AG.CLB
   Componenta: RLS 190211 05  54  0403
   Codare: 0330AD
Nu a gasit coduri.
Adresa 10: Asist.direct./parc. (J446)       Eticheta: ROJ\3C8-919-475.clb
   Numar VAG SW: 1K9 919 475 A    HW: 5K0 919 475 E
   Componenta: PARKHILFE 8K  H01 0004
   Revizie: --------    Numar serial: 12591101863203
   Codare: 108003
   VCID: 3972FD5AB08851F65B-806C
Nu a gasit coduri.
Adresa 15: Airbaguri (J234)       Eticheta: 5K0-959-655.clb
   Numar VAG SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Componenta: AirbagVW10    013 0613
   Numar serial: 003G6D04BAU7
   Codare: 00003536
   Pachet ASAM: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: 3260CA7665FEA2AE9A-8066
   Senzor impact airbag DF:
   Subsistem 1 - Numar VAG SW: 1KM 955 557     HW: 1KM 955 557
   Componenta: S.Sens.Fahr.V  H01 ----
   Numar serial: 3572MSME5124345AZZZR
   Senzor impact airbag  lateral DF:
   Subsistem 2 - Numar VAG SW: 1KM 955 557     HW: 1KM 955 557
   Componenta: S.Sens.Beif.V  H01 ----
   Numar serial: 3582MSME3242525BZZZS
   Senzor impact airbag lateral SS:
   Componenta: S.Sens.Fahr.H  --- ----
   Numar serial: 3511HSME455E1F23ZZZU
   Senzor impact airbag  lateral DS:
   Componenta: S.Sens.Beif.H  --- ----
   Numar serial: 3521HSME38161323ZZZ9
Nu a gasit coduri.
Adresa 16: Electronica volan (J527)       Eticheta: ROJ\5K0-953-569.clb
   Numar VAG SW: 5K0 953 507 AS    HW: 5K0 953 549 C
   Componenta: Lenks.Modul   008 0080
   Revizie: --------    Numar serial:  90440KAD000IR
   Codare: 5080040000
   Pachet ASAM: EV_SMLSNGKUDS A05001
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 010255BA90D8C93653-8054
Nu a gasit coduri.
Adresa 17: Instrumente bord (J285)       Eticheta: ROJ\5K0-920-xxx-17.clb
   Numar VAG SW: 5K0 920 861 A    HW: 5K0 920 861 A
   Componenta: KOMBI         H21 0204
   Revizie: X0021007    Numar serial:
   Codare: 170F00
   Pachet ASAM: EV_KombiUDSMM9RM10 A04203
   ROD: EV_KombiUDSMM9RM10_VW36.rod
   VCID: 2B5ED71242D4F366D9-807E
Nu a gasit coduri.
   Codare: 170F00
Nu a gasit coduri.
Adresa 19: Poarta CAN  (J533)       Eticheta: ROJ\7N0-907-530-V2.clb
   Numar VAG SW: 7N0 907 530 C    HW: 1K0 907 951
   Componenta: J533  Gateway H37 0614
   Revizie:   H37       Numar serial: 09031101210354
   Codare: 352002
   VCID: 3064C07E63F290BEEC-8064
1 cod a gasit:
01044 - Modul de comanda: codare incorectã
            000 - -
             înprejurari cod:
                    Stare defect: 01100000
                    Priorit.defect: 1
                    Frecv. defect: 1
                    Resetare contor: 255
                    rulaj: 162572 km
                    Indicator de timp: 0
                    Data: 2011.03.23
                    timp: 00:38:41
Adresa 25: Blocare pornire (J334)       Eticheta: 5K0-920-xxx-25.clb
   Numar VAG SW: 5K0 953 234     HW: 5K0 920 861 A
   Componenta: IMMO          H21 0204
   Codare: 000000
   Atelier: WSC 00000 000 00000
   Pachet ASAM: EV_ImmoUDSMM9RM10 A01200
   ROD: EV_ImmoUDSMM9RM10_SE25.rod
   VCID: 6AD012168DAE2A6EE2-803E
Nu a gasit coduri.
Adresa 37: Navigatie (J794)       Eticheta: ROJ\1K0-035-27x-37.clb
   Numar VAG SW: 3C0 035 279 N    HW: 3C0 035 279 N
   Componenta: RNS315-EU   H55 0319
   Numar serial: VWZAZ2M5505054
   Codare: 0000041104000F0000011301
   Atelier: WSC 00015 115 00000
   Pachet ASAM: EV_RNS315EUV2UDS 001705
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2E58DE0671C6864EFE-807A
   Suport de date:
   Subsistem 1 - Numar VAG: 3AA 919 866
   Componenta: EUR_W_0038  0038
9  coduri de defecte:
1048595 - Difuzor joase SS
          B1065 13 [009] - întrerupt(ã)
          Confirmat - Testat deLa stergere de memorie
             înprejurari cod:
                    Stare defect: 00000001
                    Priorit.defect: 5
                    Frecv. defect: 1
                    Resetare contor: 58
                    rulaj: 162572 km
                    Data: 2016.10.30
                    timp: 00:38:40
1048596 - Difuzor joase DS
          B1067 13 [009] - întrerupt(ã)
             înprejurari cod:
                    Priorit.defect: 5
                    Frecv. defect: 1
                    Resetare contor: 58
                    rulaj: 162572 km
                    Data: 2016.10.30
                    timp: 00:38:40
1048599 - Difuzor înalte SS
          B1066 13 [009] - întrerupt(ã)
             înprejurari cod:
                    Priorit.defect: 5
                    Frecv. defect: 1
                    Resetare contor: 58
                    rulaj: 162572 km
                    Data: 2016.10.30
                    timp: 00:38:42
1048600 - Difuzor înalte DS
          B1068 13 [009] - întrerupt(ã)
             înprejurari cod:
                    Priorit.defect: 5
                    Frecv. defect: 1
                    Resetare contor: 58
                    rulaj: 162572 km
                    Data: 2016.10.30
                    timp: 00:38:42
1048632 - Antenã 1 radio
          B1119 13 [009] - întrerupt(ã)
             înprejurari cod:
                    Priorit.defect: 5
                    Frecv. defect: 1
                    Resetare contor: 58
                    rulaj: 162572 km
                    Data: 2016.10.30
                    timp: 00:38:39
1048582 - Antenã GPS;scurt la masã
          B1054 13 [009] - întrerupt(ã)
             înprejurari cod:
                    Priorit.defect: 5
                    Frecv. defect: 1
                    Resetare contor: 58
                    rulaj: 162572 km
                    Data: 2016.10.30
                    timp: 00:38:39
1048647 - Antenã GSM
          B1053 13 [009] - întrerupt(ã)
             înprejurari cod:
                    Priorit.defect: 5
                    Frecv. defect: 1
                    Resetare contor: 58
                    rulaj: 162572 km
                    Data: 2016.10.30
                    timp: 00:38:39
1048650 - Suport telefon mobil;scurt la masã
          B1051 13 [009] - întrerupt(ã)
             înprejurari cod:
                    Priorit.defect: 5
                    Frecv. defect: 1
                    Resetare contor: 58
                    rulaj: 162572 km
                    Data: 2016.10.30
                    timp: 00:38:39
1048652 - Microfon pentru telefon;scurt la masã
          B1048 13 [009] - întrerupt(ã)
             înprejurari cod:
                    Priorit.defect: 5
                    Frecv. defect: 1
                    Resetare contor: 58
                    rulaj: 162572 km
                    Data: 2016.10.30
                    timp: 00:38:39
Adresa 42: Usa electr. sofer (J386)       Eticheta: ROJ\3C0-959-70X-GEN4.clb
   Numar VAG SW: 561 959 701 A    HW: 3C0 959 793 C
   Componenta: TUER-SG FT    002 0501
   Revizie: 12110009    Numar serial: 0001997611
   Codare: 0010B6
   Atelier: WSC 01383 790 50316
   Pachet ASAM: EV_TSGFPQ35BRFVW46X A04001
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 1C3C04CE177A04DEA0-8048
   Slave ºofer:
   Subsistem 1 - Numar VAG SW: 1K0 959 703 AG    HW: 1K0 959 795 R  Eticheta: ROJ\1K0-959-70X-GEN4.CLB
   Componenta: J388__TSG-HL  006 1401
   Numar serial: 00000005535052
   Codare: 000090
Nu a gasit coduri.
Adresa 44: Asistenta directie        Eticheta: ROJ\1Kx-909-14x-44.clb
   Numar VAG: 1K0 909 144 M
   Componenta: EPS_ZFLS Kl. 69     3201
   Revizie: 00H20000
   Atelier: WSC 02069 000 90108
   VCID: 346CCC6E57EAAC9E88-8060
Nu a gasit coduri.
Adresa 52: Usa electr.pasager (J387)       Eticheta: ROJ\3C0-959-70X-GEN4.clb
   Numar VAG SW: 561 959 702 A    HW: 3C0 959 792 C
   Componenta: TUER-SG BT    002 0501
   Revizie: 14110009    Numar serial: 0002203575
   Codare: 0011B6
   Pachet ASAM: EV_TSGBPQ35BRFVW46X A04001
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 1D3A09CA0C600DD657-8048
   Slave pasager:
   Subsistem 1 - Numar VAG SW: 1K0 959 704 AG    HW: 1K0 959 794 R  Eticheta: ROJ\1K0-959-70X-GEN4.CLB
   Componenta: J389__TSG-HR  006 1401
   Numar serial: 00000005572664
   Codare: 000090
Nu a gasit coduri.
Adresa 55: Bataie far        Eticheta: ROJ\5M0-907-357-V2.clb
   Numar VAG SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Componenta: AFS-Steuergeraet    0148
   Revizie: 00H04000    Numar serial:
   Codare: 1442892
   Subsistem 1 - Numar VAG: 7L6 941 329 B  Eticheta: 3D0-941-329.CLB
   Componenta: AFS-Lst.-Modul l    0004
   Codare: 00000022
   Subsistem 2 - Numar VAG: 7L6 941 329 B  Eticheta: 3D0-941-329.CLB
   Componenta: AFS-Lst.-Modul r    0004
   Codare: 00000022
Nu a gasit coduri.
Sfârsit------------------------(Timp scurs: 02:32)-------------------------
Din ce vad eu eroarea Can are prioritate nr.1 adica daca citesc manualul spune ca nu se mai poate circula pana nu se remediaza? si mai este pb cu difuzoarele, microfon , antena etc...mentionez ca masina are navigatia ei originala...ms
cum a reusit sa ajunga in halul acesta?? s=a umblat la el??este eroare grava?? cum fac sa citesc km reali ai masinii cu interfata vcds? ms mult
Astazi, ma opresc la semafor si vad ca de sub capota iese fum(deschis la culoare) .
Dupa ce am tras pe dreapta, fumul s-a oprit, am avut impresia ca vine de undeva din spatele motorului, dar de jos.
Erori aparute la Polo :
16686 - Cylinder 2
            P0302 - 35-10 - Misfire Detected - Intermittent
16804 - Catalyst System; Bank 1
            P0420 - 35-00 - Efficiency Below Threshold
Sa aiba una din cele doua erori vreo legatura?
Modificat de GinelSB
salut am cumparat de curand un a4 b8 cu martorul de airbag aprins permanent in bord.La scanare cu vcds apare ce se vede in poza .Ce trebuie sa fac sa scap de eroarea din bord ? multumesc.
Igniterul bateriei sarit(posibil ca masina sa fi fost lovita) si au incercat sa-l ,,lucreze" din rezistente.Trebuie vazut daca e la locul lui..daca are circuitul intreg sau lucrat cu rezistente..
http://workshop-manuals.com/audi/a4_mk3/body/general_body_repairs_interior/passenger_protection/battery_isolation_igniter/removing_and_installing_battery_isolation_ignitern253/
Modificat de spido
intr-adevar masina a fost destul de usor lovita in spate,dar porneste si functioneaza perfect.Unde e situat acest " igniter al bateriei " cum ii spui tu ? sa il inlocuiesc ,ca sa rezolv problema ? nici macar nu stiu cum arata :(
Vezi linkul postat..este un izolator al bateriei in caz de accident.Decupleaza bateria..
Modificat de spido
nu cred ca e la locul lui.Lipseste ceva de acolo.
Buna ziua,
Am un golf 4(lung) din 2001,motor 1,6 16v AZD si de cateva luni se tot aprinde martorul EPC in bord.Masina functioneaza bine insa martorul se aprinde si se stinge fara o regula anume.
Am facut o scanare cu vcds-ul si am gasit mai multe erori.Vad mai multe erori pe la motor insa nu stiu exact ce ar fi defect ca sa stiu cum se pot rezolva problemele.
Niste informatii de la cunoscatori sunt bine venite.Multumesc.
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
VIN: WVWZZZ1JZ2W242398   Mileage: 189460km/117724miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 036 906 034 CN
   Component:  MARELLI 4MV       3957
   Coding: 00031
   Shop #: WSC 01317
   VCID: 60CF460BE0B6781EF43-4A3A
   WVWZZZ1JZ2W242398     VWZ6Z0A3770692
2 Faults Found:
16786 - EGR System
            P0402 - 35-00 - Excessive Flow
17566 - Manifold Pressure Sensor (G71)
            P1158 - 35-10 - Implausible Signal - Intermittent
Readiness: 0010 0101
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 E
   Component: ESP FRONT MK60      0104
   Coding: 0011266
   Shop #: WSC 01317 785 00200
   VCID: 2C57E23B8CFEEC7E18B-5072
01314 - Engine Control Module
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01     02
   Coding: 12855
   Shop #: WSC 01317
   VCID: 224B0C03AE3A2A0EA27-5000
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J0 920 806 B
   Component: KOMBI+WEGFAHRS. RB8 V10
   Coding: 01113
   Shop #: WSC 00000
   VCID: 26431013C212D62ECEF-5072
2 Faults Found:
01304 - Radio
01176 - Key
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01317
   VCID: F0EFB64BB056489EE43-5072
01304 - Radio
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799
   Component: 1F Komfortgerát HLO 0001
   Coding: 00259
   Shop #: WSC 01317
   VCID: F4E7BA5BC44E74BE00B-4A3A
   Subsystem 1 - Part No: 1C1959801A
   Component: 1F Tőrsteuer.FS KLO 0002
   Subsystem 2 - Part No: 1C1959802A
   Component: 1F Tőrsteuer.BF KLO 0002
   Subsystem 3 - Part No: 1C0959811A
   Component: 1F Tőrsteuer.HL KLO 0002
   Subsystem 4 - Part No: 1C0959812A
   Component: 1F Tőrsteuer.HR KLO 0002
2 Faults Found:
01141 - Luggage Compartment Unlocking Switch (E165)
00930 - Locking Module for Central Locking; Rear Left (F222)
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 195
   Component: Radio DE2           0005
   Coding: 0000401
   Shop #: WSC 00000 000 00000
   VCID: E3C5C90721A0E306691-5000
   Subsystem 1 - Part No: 3B7 035 195
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
End
Log-WVWZZZ1JZ2W242398-189460km-117724mi.txt
Probleme EGR-incearca sa-l cureti..dar nu prea cred ca se rezolva.Verifica senzorul de presiune  G71.Probleme cu cititorul cipului din cheie/cablajul lui sau lipituri reci pe placa ceasurilor.Un switch la portbagaj, broasca usa stg spate de reconditionat(daca cablajul e ok).
buna seara, azi am reusit sa intru in posesia unui vw touran, pe care mil adusese un prieten din germania, azi am facut  o autoscanare touranului, dar nu pricep prea mult din rezultatele scanului,deaceea cer ajutorul cuiva de aici daca poate sa le descifreze pentru mine, mam cam speriat la vederea atator erori, multumesc deocamdata
Log-01-WVGZZZ1TZ6W040438-267140km-165993mi-adi.txt
Salut, revin cu o problema pe care am obtinut-o dupa demontarea casetofonului. Eroarea este de :Infotainment Databus in Single Wire Operation. Puteti sa imi spuneti unde este localizat CAN Gateway-ul pe skoda din semnatura? Inteleg din eroare ca este un fir intrerupt ,asa pare, sper sa fie usor! Eroarea cu radio inca nu am rezolvat-o.  Va multumesc!
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001062030391
   Coding: 7D0F0B40071302
   Shop #: WSC 12345 012 32131
   VCID: 2A5B76FD85C6F412DE-807E
3 Faults Found:
00469 - Infotainment Databus in Single Wire Operation
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 124
                    Mileage: 429823 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:38:45
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 48
                    Reset counter: 164
                    Mileage: 429823 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:52:50
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 44
                    Reset counter: 164
                    Mileage: 429823 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:53:02
Mikutzu-ce radio ai? De regula,eroarea apare cand aparatul original al masinii este inlocuit cu unul generatie mai noua.Se rezolva prin inlocuirea modulului can.
sub bord, pe partea soferului - deasupra pedalei de acceleratie, un pic in stanga.
Ady - sunt multe erori - sterge erorile si scaneaza iar.
Salut, va multumesc de raspuns. Am radio original dar am avut ceva probleme la contact(puneam contactulsi nu facea nimic) si am fost la niste "mecanic electronist" bun recomandat si au furat un plus de la casetofon si au pus la contact si a rezolvat problema. Acum cand pun contactul nu se aprinde radiuol trebui pornit manual.
Este intrerupta comunicatia intre can si radio...undeva pe traseul infotainment.Trebuie verificat cablajul,dar,la fel de bine poate fi o problema cu aparatul radio.Nu mai comunica cu can-ul..
Din pacate, mecanicul bun nu a rezolvat problema cum trebuie, ca la carte - ci a facut o improvizatie.... trebuie cautat defectul, remediat si adus circuitul la starea initiala... nu asa cum e facut la tine.
Stiu, dar nu am avut timp sa ma intalnesc cu electrictianul de service skoda sa o faca . A nascut nevasta lui si este lautar part time!! Am discutat si in topicul probleme contact! Nu am avut timp sa il rezolv. Trebuie sa il fac cumva stiu! Va multumesc.
Salut. Am si eu p problema cu un passat b6 2006 1.6 fsi si anume oscileaza usor motoru la relanti. Am facut o testare si nu apare nici o eroare, dar imi indica un singur lucru care nu stiu ce inseamna exact.
         TID; $01 CID:$20
         Rich to Lean sensor threshold voltage (constant)
         min :4.096
        Current:1.917
Asta apare , din ce m-am documentat cica ar fi de la un senzor de aer ceva de genu. A mai intanlit cineva asa ceva?  Repet oscileaza foarte usor la relanti. aproape insesizabil.
Multumesc frumos.
  • Aerofan pinned this topic
