suzu
[12:08, 12.10.2016] Fuel pressure sensor G247 - P0191 - implausible signal
[12:09, 12.10.2016] Valve for fuel metering (N290) - P0091 - short to ground
Astea sunt codurile de eroare pe care le.am avut la scanare.
Rog, daca poate cineva sa ma ajute cu vreun sfat, as fi recunoscator
în urmă cu 10 ore, F l o r i n a scris:
posteaza eroarea in intregime - nu doar codul - asa ne putem da seama mai usor, unde este problema
Am revenit cu codul intreg al erorilor
-Fuel pressure sensor G247-P0191-implausible signal
-valve for fuel metering (N290)-P0091-short to ground
Ce anume ar trebui sa verific inainte de a schima ceva?
Chiar nu ma poate ajuta nimeni cu vreun sfat legat de postarea de mai sus? Sunt disperat si nu mai stiu ce sa fac, este atat de enervanta treaba cu opritul masinii.
Ma poate ajuta cineva cu cele doua erori?
2 Faults Found:
16556 - Fuel Trim; Bank 1
            P0172 - 35-10 - System Too Rich - Intermittent
16804 - Catalyst System; Bank 1
            P0420 - 35-00 - Efficiency Below Threshold
Readiness: 0000 0101
16556/P0172 - System Too Rich, Bank 1
Possible Symptoms
Irregular behavior
Possible Causes
Fuel system
Excessive fuel pressure
Leaking or contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Air leaks after the MAF
Vacuum leaks
Improper seated engine oil dipstick
Stuck EGR valve
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near HO2Ss.
16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
Possible Causes
Leakage in Intake and/or Exhaust System
Catalyst faulty
Oxygen Sensor(s) faulty
Oxygen Sensor(s) Control faulty
Possible Solutions
Check Intake and Exhaust System for Leaks
Check Catalyst
Check Oxygen Sensor(s)
Check Oxygen Sensor(s) Control
Perform Oxygen Sensor(s) Aging Check
Buna ziua, la un prieten cu Polo 6N2 apar urmatoarele erori:
Address 01: Engine       Labels: 030-906-032-AUD.lbl
Control Module Part Number: 030 906 032 CG
  Component and/or Version: ME7.5.10            3622
           Software Coding: 00031
            Work Shop Code: WSC 00788
                      VCID: 51A9B7279B69FFCA63-5140
3 Faults Found:
16523 - Oxygen (Lambda) Sensor B1 S2
            P0139 - 35-10 - Response too Slow - Intermittent
17574 - Long Term Fuel Trim Additive Air; Bank 1; Range 2
            P1166 - 35-00 - System too Rich
18011 - Internal Control Module
            P1603 - 35-00 - Failed Self-Test
Readiness: 0000 0001
Ultima eroare nu a mai aparut dupa stergere, daca incarcarea e ok atunci posibil ECU sa fie pe duca?
La a doua eroare nu-i dam de capat... pe canalul 32 doar in campul 2 scade sub -20% (multiplicative trim), pareri?
Asta e sonda lambda 1sau 2?Sau poate fi oricare din cele doua?
posteaza eroarea asa cum apare pe tester.
17972 - Throttle Actuator (J338)
            P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
17588 - Linear O2 Sensor; Pump Current
            P1180 - 35-10 - Short to Plus - Intermittent
Sa fie din cauza bateriei fiindca e pe duca?
la ce sa refera codurile?
mersi !
Sterge codurile-fiind intermitente- incarca/schimba acumulatorul,verifica incarcarea.
Salut, legat de erorile de mai jos m.am hotarat astazi sa ma uit la mufe/cabluri alimentare "Fuel pressure sensor G247 - P0191 - implausible signal
Valve for fuel metering (N290) - P0091 - short to ground"
Zis si facut, am plecat de acasa pana la parinti la garaj, masina a mers bine mersi, am ajuns si am inceput sa scot mufele de la fiecare senzor, m.am uitat la cablaje, le.am izolat am curatat cu spray de contacte si le.am montat inapoi, nu am gasit nimic defect.
Dupa montarea lor am incercat sa pornesc masina si....surpriza..nu a vrut sa mai porneasca deloc.
Motorul invarte da nu vrea sa porneasca, oare am gresit undeva? Tot ce am desfacut/curatat am montat inapoi. Pompa se aude cand pun contactul, nu stiu ce sa mai fac..
Masina este golf 5 1.4fsi
Salut,stie cineva in baza la aceasta scanare de unde vine problema??este un passat b7 ,2012 dsg ,.Am parcat masina seara in garaj era totul ok ,iar dimineata nu mai pornea,nu invarte nici electromotorul iar pe bord apare eroare ESP si cheia ,mersi
On 12/10/2016 at 12:04, Razvan_raz a scris:
Log-WVWZZZ3CZCE009231-122150km-75900mi.txt
Nimeni nu ma poate ajuta o parere ,sau o solutie de unde vin toate  aceste erori,mersi
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4C 4F 52 53 56 61
          62 72 77
VIN: WVWZZZ3CZCE009231   Mileage: 122150km-75900miles
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 1010
04-Steering Angle -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
25-Immobilizer -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 1010
4C-Tire Pressure II -- Status: Sporadic communication error 1000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 1010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Sporadic communication error 1000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2708
   Revision: 05351113    Serial number: 00001105281679
   Coding: 0000020
   Shop #: WSC 05311 000 00000
   VCID: 1724DC47BF8D51BACE8AD51-8042
5 Faults Found:
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 40
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:35:24
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 40
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:35:24
01196 - Engine-Transmission Data Bus
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 0
                    Reset counter: 40
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:35:24
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Reset counter: 40
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:03:03
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 40
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:03:03
Address 03: ABS Brakes        Labels: 3AA-614-109.clb
   Part No SW: 3AA 614 109 AC    HW: 3AA 614 109 AC
   Component: J104   C2 450M VDCD 0022
   Revision: --H07---    Serial number: 00000004302650
   Coding: 0007603
   VCID: 6ECAD9A3E097F072FD2C68D-803A
4 Faults Found:
01314 - Engine Control Module
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 65
                    Reset counter: 205
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:37:28
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 220
                    Hex Value: 0x0000
01325 - Control Module for Tire Pressure Monitoring (J502)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 32
                    Reset counter: 205
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:37:37
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
01315 - Transmission Control Module
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:02:30
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 217
                    Hex Value: 0x0000
00576 - Terminal 15
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:03:15
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00111110
                    Count: 128
                    Hex Value: 0x0000
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00001003
   Coding: 0000000003
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_VW36.rod
   VCID: 6ECAD9A3E097FCF2FD2C68D-803A
3 Faults Found:
13701376 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 19
                    Reset counter: 205
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 07:32:49
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:01:47
9481748 - High Pressure Sensor
          B10AE 14 [008] - Open or Short to Ground
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:03:25
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 D    HW: 3AA 937 087 D
   Component: BCM PQ47 H    413 0455
   Revision: BB413001
   Coding: 000000000000000000180080540081E403710088426D85606480C7200041
   Shop #: WSC 05311 123 08193
   VCID: 3B6C20F7E36559DA0A32591-806E
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 17051  10  0603
   Coding: 00B795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 140611 05  54  0403
   Coding: 02302A
9 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 02:19:19
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.15 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
00473 - Control Module for Elect. Park/Hand Brake (J540)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:03:27
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.00 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
00778 - Steering Angle Sensor (G85)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:03:04
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.00 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 205
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:38:28
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.05 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:02:31
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.00 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
01316 - ABS Control Module
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:03:27
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.00 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
01321 - Control Module for Airbags (J234)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:03:15
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.05 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
01516 - Terminal 30; Left
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:00:37
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.25 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
03266 - Control Circuit for Signal Horn
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 02:19:27
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.15 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 77631115200933
   Coding: 108102
   Shop #: WSC 99999 1023 2097151
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 7CEEE3EBA6EB9E6243B8825-8028
5 Faults Found:
12656928 - Databus
          U1121 00 [008] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:01:45
12658720 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:01:45
12718592 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:03:03
12648736 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:02:29
12670224 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:15:00
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PB7XA8V
   Coding: 0012337
   VCID: 4C8E732BB6CBE262B398925-8018
   Subsystem 1 - Serial number: 6332MTS610311411
   Subsystem 2 - Serial number: 6342MTS656641421
   Subsystem 3 - Serial number: 6351HTS6JBR15AKJ
   Subsystem 4 - Serial number: 6361HTS6L3OE5AKR
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:15:00
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:46
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C9 953 501 BG    HW: 5K0 953 569 T
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110612200076
   Coding: 199A250000
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   ROD: EV_VW360SteerWheelUDS.rod
   VCID: 6FF4C4A7E79DF5FAF63A1D1-803A
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H06 0022
   Coding: E30000
3 Faults Found:
0516 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:02:30
332644 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:02:04
336900 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:01:46
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 870 D    HW: 3AA 920 870 D
   Component: KOMBI         H03 0607
   Coding: 161D01
   Shop #: WSC 05314 115 12345
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 337C08D7CB35911AD262E11-8066
9 Faults Found:
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:00:27
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 205
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 07:32:48
12648704 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:02:30
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:01:46
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:02:20
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 02:19:18
12658688 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:01:46
12674816 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:02:00
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Date: 2016.10.20
                    Time: 00:02:01
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 030611F1001760
   Coding: 462006
   Shop #: WSC 05314 000 00000
   VCID: 38663FFBD25372C2E750BE5-806C
15 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 205
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:00:31
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:02:31
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:46
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:03:04
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:02:20
00381 - Databus Instrument Cluster
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:15:00
00474 - Control Module for Immobilizer
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:02:00
01330 - Central Control Module for Central Convenience (J393)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:02:01
01331 - Door Control Module; Driver Side (J386)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:18
01333 - Door Control Module; Rear Left (J388)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:18
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:03:04
01320 - Control Module for Climatronic (J255)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:33
01303 - Telephone Transceiver (R36)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:00:06
03109 - Tire Pressure Monitoring Control Module 2 (J793)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:50
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:46
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.310 0802
   Revision: 1AH03729    Serial number: 00111480173601
   Coding: 0000258
   VCID: 3B6C20F7E36555DA0A32591-806E
7 Faults Found:
            004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 4
                    Fault Frequency: 52
                    Reset counter: 205
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 07:32:48
             Freeze Frame:
                        Term 15 On
                    RPM: 1500 /min
                    Speed: 0.0 km/h
                    (no units): 7.0
                    Voltage: 12.20 V
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:15:00
             Freeze Frame:
                        Term 15 On
                    RPM: 1500 /min
                    Speed: 0.0 km/h
                    (no units): 7.0
                    Voltage: 12.00 V
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:46
             Freeze Frame:
                        Term 15 On
                    RPM: 1500 /min
                    Speed: 50.0 km/h
                    (no units): 7.0
                    Voltage: 11.90 V
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:46
             Freeze Frame:
                        Term 15 On
                    RPM: 1500 /min
                    Speed: 50.0 km/h
                    (no units): 7.0
                    Voltage: 11.90 V
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:02:00
             Freeze Frame:
                        Term 15 On
                    RPM: 1500 /min
                    Speed: 0.0 km/h
                    (no units): 7.0
                    Voltage: 12.00 V
00576 - Terminal 15
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:02:38
             Freeze Frame:
                        Term 15 Off
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    (no units): 12.0
                    Voltage: 12.00 V
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:03:03
             Freeze Frame:
                        Term 15 On
                    RPM: 1500 /min
                    Speed: 0.0 km/h
                    (no units): 7.0
                    Voltage: 12.00 V
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    KSG PQ47 ELV 043 0634
   Revision: 00043000    Serial number: VWZCZ000000000
   Coding: 1891020052834E7630041F1FFC084F0E607801
   Shop #: WSC 05311 123 12345
   VCID: 76FAF1C398C7C8B235FCC0D-8022
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
6 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:21
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:21
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:36
00625 - Vehicle Speed Signal
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:01:46
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 5
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 00:02:21
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 122159 km
                    Time Indication: 0
                    Date: 2016.10.20
                    Time: 02:19:22
Nu e nevoie sa repeti..in masura posibilitatii te vom ajuta.
Verifica tensiunea acumulatorului
Scoate borna 5 minute
Verifica sigurantele din compartimentul motor.
Sterge toate erorile si vezi daca porneste
Verifica cu atentie cablajele..in special in zona motorului...rozatoarelor le place gustul firelor...din pacate.
@Razvan_raz
Citeste aici/verifica pompa benzina
http://wiki.ross-tech.com/wiki/index.php/P0091/000145
Modificat de spido
în urmă cu 23 ore, Razvan_raz a scris:
Masina este golf 5
Are idee cineva cam ce ar trebui sa fac legat de postul de mai sus?
47 minute în urmă, spido a scris:
@Razvan_raz
Salut, am schimbat si pompa de benzina si unitatea de comanda de pe pompa , dar nu am mai reusit sa o pornesc dupa ce m.am uitat la cablaje/izolat/curatat mufe.
Nu inteleg de ce nu mai porneste deloc, am pus totul la loc si montate bine..
pompa primeste comanda, la pornire sau nu... ?
Da primeste comanda, se aude de fiecare data cand pun contactul
 -Fuel pressure sensor G247 - P0191 - implausible signal
-Valve for fuel metering (N290) - P0091 - short to ground
Astea erau codurile pe care le afisa la fiecare scanare cand se oprea motorul la schimbarea treptei din a1-a in a2-a.
Iar dupa ce m.am uitat la senzori/izolat cablaje si curatat mufe, schimbat pompa carnurant si unitate de comanda nu am mai reusit sa o pornesc deloc, astazi ma duc sa fac din nou o scanare sa vad ce apare
Are idee ce cod are pompa de inalta presiune la 1.4fsi cod motor BKG?
Ca nu am gasit nimic pe pompa de pe masina....
          62 72 77
 Rezolvat problema la service vw,au gasit un fir sub baterie intrerupt,practic era puscat inauntru in izolatie firul si nu alimenta un releu (nu au specificat care releu)
Ma poate ajuta cineva cu o informatie, vreau sa cumpar o pompa de inalta presiune de 1.4 fsi cod motor BKG si nu gasesc, insa, am gasit o pompa de 1.6 fsi cod BAG. Oare este compatibila, ca sa nu dau banii degeaba pe ea
Buna seara,Ma ajuta si pe mine cineva cu aceste coduri de eroare? Am fluctuatii  de turatii la relanti.Daca scot mufa EGR,fluctuatiile dispar,merge bine.Egr-ul este nou,clapeta acceleratie si traseul la Egr,curatat si adaptat.S-a curatat si orificiul care merge la chiulasa.Nu dam de cap ce ar putea fii aceste fluctuatii de turatie.Va rog,daca ma poate ajuta si pe mine cineva.Multumesc!
Golf 4 variant,an 2003,1,6 benzina, cod motor BCB,16 valve
PS.eroarea de la senzor temperatura,nu o luati in considerare,deoarece era scos senzorul!
Modificat de romeo77
  • Aerofan pinned this topic
