suzu
mihaighimpu
Desi am sters ieri erorile,azi am plecat cu ea si martorul check engine sa aprins instantaneu cand am pornit motorul.Vad ca are si mici trepidatii la relanti.
Si cand te ganesti ca abia am luat-o,de nici o luna,de la cineva din Colentina,m-am bucurat ca are km putini(ce-i drept reali) si ca e cumparata de noua de la Avia.
Buna, acel fasait vine de la clapeta de acc., dar pana acum nu facea asa, dupa curatire clapeta nu am adaptato, cel cu diagnoza m-ia zis ca se adapteaza singura, rog ajutor. Multumesc.
Cel cu diagnoza poate nu a stiut el sa o adapteze!
ionutandrei
   Sunt nou in diagnosticarea cu VCDS si as vrea sa stiu ce meniu/submeniu trebuie sa accesez pentru a diagnostica de ce nu imi merge reglajul oglinzilor electrice. Mersi mult!
A aparut un nou beta: 15.5.0. :)
Ce noutati are?
Beta 15.5  includes the following  improvements:
  • Auto-Scans will now be saved automatically
    We got tired of hearing, "Yeah, I did an Auto-Scan but I didn't save it!"
  • Added code to support e-Golf with Micro-CAN interfaces.
  • Fix for multi-character UDS sub-channel Adaptations
    such as those often used for battery serial numbers in UDS Gateways.
  • Fix for missing addresses in Gateway Installation List
    sometimes seen when Gateways have duplicate addresses and one doesn't talk.
  • Improved (but not perfect) DTC retrieval at address 31
    on multi-ECU cars.
  • New Version 1.0.6.16 of Long Coding Helper
  • Support for Transport Mode in new Phaetons.
  • Fixed a bug on PID#133 in generic OBD-II
  • Soft reset available after UDS Adaptation and Long Coding
  • Fix for missing address 5F in optical loop test result.
  • Almost 70 new or improved label files.
  • Numerous other "behind the scenes" improvements
    but still nothing needing graphical documentation in the form of a screen-shot.
N-am remarcat nimic deosebit in urma update-ului. O sa testez insa pe un navi RMC de la un Audi. Sa vad daca imi arata ceva in plus la bitii din codare.
Modificat de pronet
LA versiunea veche beta, cand intrai pe o centrala de G6 aparea too many SRI jobs si nu incarca labelul?
CA la mine asafacea, sper ca asta sa nu faca asa.
Va salut domnilor. As dori sa modific intervalul service(VW Touran) de la 15.000 la 10.000 km, am imprumutat un tester, am ajuns la 17-instrumente si care sunt urmatorii pasi de facut? Cu respect
Vezi ca sunt descrisi pe forum toti pasii ce trebuie urmati .
Foloseste search (jos in stanga paginii)
La scanarea unui Golf 5 1.6 benzina, mi-a dat urmatoarea eroare.
Mentionez ca "Check engine-ul" este aprins in bord. Ce este de facut?
                Address 01: Engine       Labels: 06A-906-033-BGU.lbl
Control Module Part Number: 06A 906 033 EM
  Component and/or Version: SIMOS71 1.6l 2VG    8715
           Software Coding: 0000071
            Work Shop Code: WSC 00046 412 00000
                      VCID: 6ED5B8E37915D76E76F-803B
19058 - Linear Oxygen (Lambda) Sensor B1 S1 Pump Current Trim Circuit
            P2626 - 008 - Open - Intermittent
             Freeze Frame:
                    RPM: 1856 /min
                    Mass Air / Rev.: 92.7 mg/str
                    Voltage: 5.100 V
                    Bin. Bits: 00000100
                    RPM: 2048 /min
                    Voltage: 5.100 V
                    Bin. Bits: 00000100
Sonda lambda.
va rog o parere pentru
Address 01: Engine        Labels: Redir Fail!
   Part No: 036 906 034 CN
   Component:  MARELLI 4MV        5164
   Coding: 00031
   Shop #: WSC 00000
   VCID: 60CF460BE0B6781EF43-4A9C
   WVWZZZ1JZ2W    VWZ6Z0
16786 - EGR System
            P0402 - 35-10 - Excessive Flow - Intermittent
Readiness: 0000 0000
F l o r i n
incearca o curatare, dar e foarte posibil ca in timp sa necesite inlocuirea EGR-ului.
Curatarea la benzinare e cam frectie la picior de lemn....
   Stie cineva unde e pozitionat senzorul?Se mai poate face ceva la el sau trebuie nou?E posibil ca din cauza lui sa consume curent sa nu mai porneasca masina?E un Audi A8 .2006.
   Part No SW: 4E0 910 401 S    HW: 4E0 907 401 C
   Component: 3.0L V6TDI  A000AG  0010
   Revision: --H01---    Serial number: AUX3Z0E2361274
   Coding: 0011973
   Shop #: WSC 02313 785 00200
   VCID: 2B5F7608F1C5
006248 - Transmission Mount Valve 1 (N262): Short to Plus
               P1868 - 001 - Upper Limit Exceeded
e unul din suportii motorului, verifica firele de la el. MAsoara cat are electrovalva din el. fa comparatie cu celalalt.
Nu se repara, se schimba. Nu are treaba cu pornirea.
La ultimele doua-trei scanari mi-au aprut urmatoarele coduri de eroare:
Adresa 01: Motor       Eticheta: ROJ\036-906-034-AZD.clb
                    Numar VAG: 036 906 034 BH
   Componenta si/sau versiune:  MARELLI 4MV G     3773
                  Codare soft: 00031
                Numar atelier: WSC 01317
                      VCID: 59B26397C38974D0069
3  coduri de defecte
17560 - Bank1:adaptare amestec/aditiv aer treapta 2
            P1152 - 35-00 - sistem prea sãrac
17586 - Sonda lambda lineara:generator de curent
            P1178 - 35-10 - circuit întrerupt - intermitent
17834 - Supapa aerisire rezervor-N80-  circuit întrerupt
            P1426 - 35-10 -  - intermitent
Gata de functie: 0010 0001
Sterg erorile si o perioada merge ok masina (singura eroare care nu se sterge este valva N80 de pe canistra carbon),dupa care,fluctuatii la relantii si plecat in suturi de pe loc.
Mentionez ca masina are GPL de Olanda .
incearca in prima faza sa faci un reglaj al instalatiei de Gpl si o revizie, de aici s.ar putea sa fie eroarea cu amestec sarac si lipsa putere
Vezi si ce se intampla cu prima sonda lambda si cu canistra de carbon - fire, sigurante.
Modificat de andrei_221
New Beta 15.6.0 cu firmware update la 1.94.
Cristi, unde ai gasit update-ul?
Ca RT nu-l listeaza nicaieri pe pagina de beta si nici VCDS-ul nu il gaseste sa faca update.
Ultimul listat e 15.5.0.
Eu am avut o problema cu anumite labeluri de la unele centrale elctrice, am schimbat emailuri cu Dana Smetanick si mi-a trimis un link de download.
Salutare, cand m-am pornit spre servici cu masina, dupa aproximativ 1km mergand in viteza a 3-a si aproximativ 2500 rpm a intrat in frana de motor si a inceput sa clipeasca becul de check engine. Dupa 3-4 secunde si-a revenit si a disparut si becul de check engine.
Passat 2.0 TFSI BWA
La o scanare am primit urmatoarele erori
4 Faults Found:
008521 - Supply Voltage for Fuel Injector Group B
               P2149 - 001 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 141205 km
                    Time Indication: 0
                    Date: 2015.06.07
                    Time: 08:06:55
             Freeze Frame:
                    RPM: 2427 /min
                    Load: 42.3 %
                    Speed: 84.0 km/h
                    Temperature: 46.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.478 V
000768 - Random/Multiple Cylinder Misfire Detected
               P0300 - 001 -
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 141205 km
                    Time Indication: 0
                    Date: 2015.06.07
                    Time: 08:06:57
             Freeze Frame:
                    RPM: 2461 /min
                    Load: 41.6 %
                    Speed: 84.0 km/h
                    Temperature: 47.0°C
                    Temperature: 17.0°C
                    Voltage: 14.478 V
000771 - Cylinder 3
               P0303 - 001 - Misfire Detected
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 141205 km
                    Time Indication: 0
                    Date: 2015.06.07
                    Time: 08:06:57
             Freeze Frame:
                    RPM: 2461 /min
                    Load: 41.6 %
                    Speed: 84.0 km/h
                    Temperature: 47.0°C
                    Temperature: 17.0°C
                    Voltage: 14.478 V
000770 - Cylinder 2
               P0302 - 001 - Misfire Detected
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 141205 km
                    Time Indication: 0
                    Date: 2015.06.07
                    Time: 08:06:57
             Freeze Frame:
                    RPM: 2461 /min
                    Load: 41.6 %
                    Speed: 84.0 km/h
                    Temperature: 47.0°C
                    Temperature: 17.0°C
                    Voltage: 14.478 V
Stima !
Modificat de proteus
Vezi contacte imperfecte /
Sterge erorile si vezi daca iti mai face.
Nute apuca sa umbli la masina deocamdata.
  • Aerofan pinned this topic
