suzu
Vezi pt primul cod: 16726:
http://wiki.ross-tech.com/index.php/16726/P0342/000834
Senzorul G40 se pare ca e problema. Vezi poate te ajuta linkul asta:
http://www.agthompsonfamily.com/vw/Bentley...itionSensor.pdf
G40 e un senzor magnetic care se bazeaza pe efectul Hall si trimite informatii la ECM despre viteza de rotatie a axului motor.
Pe baza acestor informatii se decide cat combustibil ajunge la injectoare. Verifica acest senzor.
Cat despre al doilea cod...exista cred o intrerupere pe fir la acea boxa.
Bafta!
G40 e un senzor magnetic care(...) decide cat combustibil ajunge la injectoare.
Cred ca acesta "mai spune" si la care piston se va injecta combustibilul in momentul pornirii motorului.
Haideti sa nu dezinformam. G40 NU "decide cat combustibil ajunge la injectoare".
salut.poate ma ajuta si pe mine cineva.nu pot sa imi dau seama care ar putea fi problemele la mine.motor AQY 2.0i 115 cp model 2000
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 06A 906 018 ED
Component: 2.0l R4/2V MOTR HS V04
Coding: 00031
Shop #: WSC 01317
5 Faults Found:
17987 - Throttle Actuator (J338): Adaptation Not Started
P1579 - 35-10 - - - Intermittent
17952 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Large
P1544 - 35-10 - - - Intermittent
16505 - Throttle Position Sensor (G69): Implausible Signal
P0121 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16556 - Fuel Trim: System Too Rich: Bank 1
P0172 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 01317
37-10 - Faulty - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 822 A
Component: KOMBI+WEGFAHRS. BOO V27
Coding: 01142
Shop #: WSC 43401
Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1503551
01176 - Key
07-10 - Signal to Low - Intermittent
daca ma poate ajuta cineva as fi recunoscator.mersi
Data viitoare, te rog sa postezi doar adresele cu probleme. Multumesc.
Modificat de xxnelu
ady1981
17987, 17952, 16505- cred ca trebuie sa-ti adaptezi clapeta de acceleratie. Posibil ca acele contacte(cred ca 6 pini), mufe din corpul clapetei sa fie oxidate. Resetarea adaptarilor: in grupul engine-01 / adaptation-10 / in canalul 00 se salveaza valoarea 00.
sau
http://wiki.ross-tech.com/index.php/Thrott..._Alignment_(TBA
17978- probabil nu se "intelege" cheia cu IMMO(o posibila rezolvare=incearca sa scoti borna minus de la baterie pentru 1 minut, dar atentie la cod cass)
16556-sunt mai multe cauze posibile:
-presiune mare in alimentarea cu combustibil
-injector(oare) cu probleme
-pierderi de aer dupa MAF
-pierderi pe circuitul de vacuum
01176-aceasta eroare este posibil sa fie "mana in mana" cu 17978. Verifica si bateria de la cheie.
mersi mult.uite chiar acum am fost sa adaptez clapeta de acc.sper sa nu imi mai faca probleme.eroarea aia cu fuel trim o am de ceva vreme.nici nu stiu de ce sa ma apuc sa schimb ca sa scap de ea.motorul merge binisor.are ceva oscilatii de turatie la ralanti 760 - 800 rpm.am schimbat de curand bujiile si fisele.daca accelerez pe loc se aud ceva rateuri in esapament.din cate am inteles poate fi o supapa care nu inchide bine.am sa verific ce mi-ai scris.sa vedem poate ii dau de cap.mersi :D
Variante:
1. Rateurile in esapament sunt (pot fi) legate de "16556 - Fuel Trim: System Too Rich" si generate (de regula) de probleme la aprindere. Cum nu ai nicio eroare de genul "miss fire", ma gandesc daca nu poate fi din cauza distributiei. Ai schimbat cumva (recent)distributia?
2. Dupa adaptarea clapetei, ai verificat ce erori mai ai? In special 16556.
da am schimbat distributia de curand,dar si inainte imi facea la fel.am crezut ca e din cauza la fise sau la bujii pe care le-am schimbat deodata cu distributia.sincer ma cam deranjeaza mersul neregulat si rateurile alea.nu sunt meserias in asa ceva si nu prea stiu ce poate fi.adaptarea clapetei am facut-o azi.o sa mai circul putin si sa vedem ce zice vag-comu'.o sa va tin la curent cu ce se intampla.sper sa gasesc problema(ele).sigur o sa mai am nevoie de ajutorul vostru.mersi
poate imi spuneti si mie ce inseamna FUEL TRIM si MAF.nu imi pot da seama ce inseamna.mersi
Modificat de ady1981
FUEL TRIM= cred ca intr-o traducere libera ar insemna combustibil curat :icon_thumright: deci posibil se refera la filtru de benzina
MAF=tot in traducere libera debitmetru de aer
Modificat de cuiuda
FUEL TRIM= cred ca intr-o traducere libera ar insemna combustibil curat :) deci posibil se refera la filtru de benzina
mersi.bine de stiut :Driver: :lol:
17700 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit
P1292 - 35-00 - -
in iunie a acestui an am schimbat termostatul cu tot ansamblul caci a venit capsat. ce sa fie?
Salut! Am si eu urmatoarele erori.E un golf benzinar de 1.6, 16v:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 036 906 034 CN
Component and/or Version: MARELLI 4MV 4251
Software Coding: 00031
Work Shop Code: WSC 01391
Additional Info: WVWZZZ1JZ2W493695 VWZ7Z0A4598655
2 Faults Found:
16786 - EGR System: Excessive Flow
P0402 - 35-00 - -
17566 - Manifold Pressure Sensor (G71): Implausible Signal
P1158 - 35-10 - - - Intermittent
Ce poate fi?Va multumesc!
sal
am si eu cateva erori poate ma ajuta cineva
am 8000 km in tara cu ea de la aceste erori, am luato la 91000, am facut 2000 din germania
imi face probleme dimineata, cand e rece afara, tremura la relanti { merge in trei uneori}, cam 1 min sta la 1100 ture, dupa isi revine, si are un mic tremurat { aproape insesizabil} la relanti
Erori: Inainte de a curata clapeta de acceleratie
1. 5 Faults Found: 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-00 - - 16685 - Shareware Version. To Decode all DTCs P0301 - 35-00 - Please Register/Activate 16688 - Shareware Version. To Decode all DTCs P0304 - 35-00 - Please Register/Activate 16686 - Shareware Version. To Decode all DTCs P0302 - 35-00 - Please Register/Activate 17414 - Shareware Version. To Decode all DTCs P1006 - 35-00 - Please Register/Activate VAG-COM Version: Release 311.2
Erori : Dupa ce am curatat clapeta de acceleratie
2. 8 Faults Found: 17414 - Torque Difference Cylinder 3 Limit Value Exceeded P1006 - 35-10 - - - Intermittent 16684 - Shareware Version. To Decode all DTCs P0300 - 35-10 - Please Register/Activate - Intermittent 16685 - Shareware Version. To Decode all DTCs P0301 - 35-10 - Please Register/Activate - Intermittent 16686 - Shareware Version. To Decode all DTCs P0302 - 35-10 - Please Register/Activate - Intermittent 16688 - Shareware Version. To Decode all DTCs P0304 - 35-10 - Please Register/Activate - Intermittent 16486 - Shareware Version. To Decode all DTCs P0102 - 35-10 - Please Register/Activate - Intermittent 17951 - Shareware Version. To Decode all DTCs P1543 - 35-10 - Please Register/Activate - Intermittent 17580 - Sh merge
Am mai schimbat si bujiile dupa ce am curatat clapeta de acceleratie.
In rest masina fuge de rupe, trage f bine, nu da in nas, consuma un pic cam mult dar asa am intales ca au consumul motoarele FSI, dau in ea, si imi ia de la 10 in sus in oras - acceptabil zic eu.
Niste info in leg cu erorile astea daca se poate, un mecanic a zis ca sunt bobinele de inductie duse, 2- 3 ????
Mrs mult anticipat.
Baiete,
Pe wiki.ross-tech.com se gasesc pentru unele coduri de eroare simptome si cauze. Astfel pentru codurile pe care le-ai postat tu ai:
Fiecare cod de mai jos este un link la pagina de wiki corespunzatoare.
1. Inaintea curatarii clapetei:
este corelata cu urmatoarele trei erori:
16685 - 16685/P0301/000769 - Cylinder 1 Misfire Detected
16688 - 16688/P0304/000772 - Cylinder 4 Misfire Detected
16686 - 16686/P0302/000770 - Cylinder 2 Misfire Detected
Cauze posibile conform ross-tech:
* Ignition system * Fuel injectors * Fuel pressure * Running out of fuel * EVAP canister purge valve * Evaporative emission system * Low compression * Base engine problems * Controle Module damaged
This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression.
Urmatoarea eroare (17414) se pare ca mai limiteaza lista de cauze posibile de mai sus:
17414 - 17414/P1006/004102 - Torque Difference Cylinder 3: Limit Value Exceeded
Cauze posibile:
* Injector(s) leaky/dirty * Compression loss
De aici trag concluzia ca trebuie sa masori compresia si sa verifici injectoarele. Bobinele cand pica se duc complet. Ce bujii ai pus pe ea?
2. Dupa ce ai curatat clapeta au mai aparut urmatoarele erori:
16486 - 16486/P0102/000258 - Mass Air Flow (MAF) (G70): Signal too Low
Care tine de Air Intake System mentionat la Possible Solutions la eroarea 16684.
Exista si aceasta posibilitate sa fie MAF-ul bulit si sa dea informatii aiurea ecu-ului care la randul lui comanda prost injectoarele.
Deci verifica si MAF-ul. Se poate face cu VAG_COM asta! Dar cu unul inregistrat si nu cu toate versiunile shareware ....
Urmatoarea eroare:
17951 - 17951/P1543/005443 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Small
Dupa cum spune in titlu se pare ca ai deranjat ceva la clapeta de acceleratie cand ai curatat-o. Daca reapare s-ar putea sa fie nevoie sa schimbi clapeta,
adica ala ca ti-a curatat-o ti-a bulit-o!
Ultima eroare:
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
Nu am gasit nimic despre ea.
Ultimile doua erori tin de clapeta de acceleratie si au putut aparea in momentul in care s-a decuplat bateria sau daca clapeta de acceleratie a fost desfacuta fara sa se decupleze bateria.
Avand in vedere ca sunt intermitent ar trebui sa nu mai apara dupa stergerea lor si adaptarea clapetei. Ai facut adaptare la clapeta dupa ce ai deconectat-o?
Ti-am raspuns si pe alt topic la intrebarile tale dar nu am vazut niciun fel de reactie din partea ta. Daca esti interesat sa rezolvi problema aici pe forum
ar fi bine sa raspunzi la diversele intrebari "ajutatoare" puse de colegii de forum ...
LEDIT: Valabil pt toti colegii de forum: dupa ce reusiti sa rezolvati o problema va rog sa postati care a fost cauza si cum s-a rezolvat. multumesc!
numai bine.
Modificat de abuwz
Dupa cum spunea si "abuwz" uite si aici:
http://wiki.ross-tech.com/index.php/16786/P0402/001026
http://wiki.ross-tech.com/index.php/17566/P1158
Ultima eroare:
Este aceeasi problema ca si in cazul 17951 doar ca, este vorba despre cel de al II-lea senzor al clapetei.
Cum ai spus si tu, cauza ar putea fi, pozitionare incorecta (dupa curatare)- daca nu exista vreun scurtcircuit . :lol:
salut.am revenit.se pare ca la mine s-au rezolvat problemele.cred ca erau din cauza clapetei de acc.am adaptat acum 2 zile clapeta si vad ca nu mai da nici-o eroare.sper sa o tina tot asa.mersi de ajutor.salut :P
Mrs mult pt info, o sa mai verific o data clapeta , intr-adevar clapeta am demontat-o fara sa scot bornele de la baterie, iar resetarea am facut-o doar cu scoaterea bornei de la baterie, fara sa o fac si cu wagcom-ul.
Tocmai am scos masina din service. Gata cu problemele:)
Am sa dau si solutiile la probleme si codurile de erori care le aveam.
Baietii mi-au schimbat unitatea de comanda la electroventilator (sub capota, deasupra ventilatorului principal e o chestie cu un radiator gigantic) si releul principal (219) care comanda ECM-ul.
Erorile astea doua au disparut:
18080 - Coolant Fan Control 1: Open or Short to Ground-------->unitatea de comanda la electroventilator
P1672 - 004 - No Signal/Communication
17072 - ECM Power Relay Load Circuit: (J271): Open-----------> releul 219
P0688 - 004 - No Signal/Communication
Sa auzim numai de bine !
chestia cu schimbare nr de km e tare de tot...daca ai fi citit manualul de la ross-tech,ai fi aflat ca nu se poate cu vag-com...
pentru a schimba nr de km trebuie un vagtaho 2.2
cu vag com 704.... sau alte variante 805 sau mai vechi poti face diagnoze la multe module.
In general daca faci rost de 704 in limba romana la fiecare cod de eroare pe care o gasesti este si o posibila cauza.
daca te pot ajuta cu ceva da-mi un mesaj. Am folosit pana acum o mare parte din vag com-uri.
Nu-s expert dar ce nu stiu pot intreba.
Numai bine.
Uite ca la ALTII se pot realiza filmulete despre folosirea vag-com-ului.
Eu propun ca fiecare cand gasim pe undeva pe forum descrisa vreo procedura sa o postam aici ca sa ne fie mai usor sa le gasim si astfel prin incercarea/folosirea lor sa ne formam deprinderi in utilizarea vag-com-ului si sa nu fim nevoiti ca pentru orice mizilic de eroare sa mergem sa aruncam cu zeci de roni la "experti".
De exemplu :
Schimbarea limbii computerului de bord:
[select]
[17 - Instruments]
[Adaptation - 10]
introduceti valoarea numarului canalului ales:
canalul 4 : limba aleasa pentru afisaj cu urmatorile valori
00001 Germana
00002 Engleza
00003 Franceza
00004 Italiana
00005 Spaniola
00006 Portugheza
[Test]
Observati cum se modifica limba afisata pe display.
[save]
Imi da si mie cam acceasi eroare la un g4 tdi cu climatronic.
P1672 - 35-10 - - - Intermittent
La fel face, raman pornite electroventilatoarele dupa ce scot contactul.
La tine era "no signal/comm".. sa se fi dus si la mine comanda de electroventilatoare?
Modificat de Phoenix
  • Aerofan pinned this topic
    • bogdan_vw_11
