suzu
E cam 700 de lei un injector nou, insa iti recomand sa incerci o curatare sau chiar unul sh (postezi o cerere pe pieseauto.ro si astepti).
nu cred ca e 700 de ron un injector benzina 1.2...dar caut sa vad ce e mai rentabil
Salut, am un golf 6 , 1.6 benzina, 102 hp si am vazut ceva fluctuatii la lumini asa ca am facut o scanare si  a dat ceva erori si anume :
Monday,26,September,2016,12:10:59:62939
VCDS Version: Release 12.12.0 (x64)
                Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 1K0 937 086     HW: 1K0 937 086
  Component and/or Version: BCM PQ35  M   020 0358
           Software Coding: 46180A3A90251AC040080080500081E445010088724D8D60648000000000
            Work Shop Code: WSC 00028 028 00001
                      VCID: EDD1AF3F3464A576CF5-80B8
4 Faults Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 146
                    Mileage: 105678 km
                    Time Indication: 0
                    Date: 2023.14.29
                    Time: 15:11:41
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.70 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 103
                    Mileage: 105935 km
                    Time Indication: 0
                    Date: 2024.14.12
                    Time: 11:20:19
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 142
                    Mileage: 106362 km
                    Time Indication: 0
                    Date: 2025.14.03
                    Time: 13:08:17
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00907 - Intervention load Management
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 106372 km
                    Time Indication: 0
                    Date: 2025.14.03
                    Time: 14:55:07
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Cam care ar fi problema... merci!
Cam descarcata bateria ta..trebuie facuta o verificare a acumulatorului.
Salutare!
La 1.8 tsi BZB, de cateva saptamani imi tot apare eroare intermitenta de underboost (P0299 Control range not reached - underboost). Masina nu trage cum ar trebui. Am tot cautat cam ce grupuri ar trebui accesate pentru un log in mers (poate ma ajuta cineva cu mai multe detalii). Am incercat sa fac unul in treapta a 3-a, de la 1500 rpm pana la 4000 rpm, cu pedala calcata de tot. Daca stie cineva exact in ce grupuri trebuie facut logul la benzina, il rog sa imi zica si mie. Eu am ales maf, charge pressure control si n75 duty cycle.
Ma poate ajuta cineva cu o interpretare? Multumesc!
1.8tsi-boost.xls
On 9/26/2016 at 0:43 PM, FCS said:
incarca cu 13,5-13,7 v iar bateria are 11,7v in ea
De incarcat nu este ok cum incarca un 14.1 - 14.2 este ok...ideal 14.4-14.5....cred ca ai o problema cu alternatorul-releul de incarcare...verifica cat ai la alternator si cat ai la baterie si asa vezi de unde este problema.
verifica si bucsele in care sta rotorul si rul;mentii...la mine incarca la fel si dupa ce am schimbat rulment si o bucsa,no problem
salut cine imi explica si mie de ce nu pot sterge eroarea asta
                Address 08: Auto HVAC       Labels: 5K0-907-044.clb
Control Module Part Number: 5K0 907 044 FH    HW: 5K0 907 044 FH
  Component and/or Version: Climatronic   H18 1112
           Software Coding: 0000000009
            Work Shop Code: WSC 12345 123 12345
              ASAM Dataset: EV_Climatronic A01010 (VW36 *)
                       ROD: EV_ClimaAutoBasis_VW36.rod
                      VCID: 76FB06AF98C7C43235FCC0D-8022
3 Faults Found:
13701376 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 254
                    Reset counter: 236
                    Mileage: 193806 km
                    Date: 2000.00.00
                    Time: 18:33:20
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 236
                    Mileage: 193806 km
                    Date: 2000.00.00
                    Time: 18:33:20
9601329 - Humidity sensor
          B1281 31 [009] - No Signal
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 236
                    Mileage: 193806 km
                    Date: 2000.00.00
                    Time: 18:33:20
3 Faults Found:
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 236
                    Mileage: 193806 km
                    Date: 2000.00.00
                    Time: 18:33:20
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 236
                    Mileage: 193806 km
                    Date: 2000.00.00
                    Time: 18:33:20
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 236
                    Mileage: 193806 km
                    Date: 2000.00.00
                    Time: 18:33:20
primele doua nu ai cum sa scapi de ele - e o problema de comunicatie intre module, din cauza diferentele dintre ele.
ultima - codeaza unitatea fara senzor de umiditate
nu, dar nu ai asa ceva pe masina ta
Mă poate ajuta și pe mine cineva cu o părere?
Cam așa arată graficul pentru boost 1.8 tsi, cu eroare p0299 underboost. Logul a fost facut in treapta a 3a, de la 1500-4000 rpm.
Am schimbat PCV si valva DV.
Va salut! Daca postez unde nu trebuie, rog un moderator sa-mi mute postarea...
Este vreun coleg de forum in zona Roman care ma poate ajuta cu o diagnoza ?
Ultimele doua erori ce inseamna? Ca e dusa o Sonda Lambda, dar care? Inainte sau dupa catalizator? Trebuie s-o schimb?
Modificat de csm_1
Inainte de catalizator.E vb de circuitul de incalzire a sondei.Verifica cablajele..si..daca sunt ok,schimba sonda.
Care este modulul de control J538 la golf 5? Este cel de pe pompa de benzina? Poate fi de la el, la scanare cu vag.com mi.a dat eroare 16475/p0091/n290
posteaza eroarea in intregime - nu doar codul - asa ne putem da seama mai usor, unde este problema
  • WooZie changed the title to Octavia 2 2011 motor CGGA
  • Aerofan pinned this topic
    • S.Adrian
