zorg
ok mc de raspuns dar acest regulator se poate schimba/repara?ai mai intampinat problema asta?
Salut, pe un golf 5 am si eu urmatoarea eroare, daca ma poate lamuri si pe mine cineva. Multumesc.        Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 GR    HW: 028 101 264 1
   Component: R4 1,9L EDC 0000SG  7282
   Revision: 12345678    Serial number: VWZBZ0E0212029
   Coding: 0000071
   Shop #: WSC 01392 785 00200
   VCID: 79F3F33D30C2731
4 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 46.4 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 11000100
                    Temperature: 16.2°C
                    Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
            P0672 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 46.4 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 11000100
                    Temperature: 16.2°C
                    Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 46.4 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 11000100
                    Temperature: 16.2°C
                    Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
            P0674 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 46.4 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 11000100
                    Temperature: 16.2°C
                    Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Sa ma uit cum? Vizual pe sub volan..? As aprecia daca mi-ai spune mai detaliat, ca la un necunoscator; gen cum arata si unde mai exact sa ma uit. Ms :D
NUUU, pe motor in dreapta masinii, inspre panoul ignifug, unde e amortizorul din dreapta.
@sharky, ai presiune prea mare in rampa de injectie. Posibil regulatorul sa nu functioneze cum trebuie.
daca e ala, e f. scump.....
Ms frumos, cand ajung la garaj ma uit.
Dar, daca aceste erori continua sa fie prezente in vag, de ce in bord nu mi se mai aprinde martorul de motor ca inainte de a curata mufele?
E made in malaysia.
Chiar si asa, daca mai apare, il schimbi.
Nu pot scapa de niste erori, ma puteti ajuta va rog?
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 B
   Component: RNS-MID       H03 2680
   Revision: AB001001    Serial number: VWZ6Z7K7493812
   Coding: 000004000400008200
   Shop #: WSC 10176 599 12332
   ASAM Dataset: ------------------------- ------
   VCID: 2E59654D79F2E868830
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 18
                    Mileage: 128416 km
                    Time Indication: 0
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 18
                    Mileage: 128416 km
                    Time Indication: 0
Nu am avut niciodata probleme cu receptia radio dar cu toate astea vad ca tot apar erorile.
Golf 4 1.9TDI ASZ 2003!
Scaneaza pana la adresa 19 CAN-GateWay unde da urmatoarea eroare:
01336 - Data Bus for Comfort System
            80-10 - Single-Wire Operation - Intermittent
Pe restul adreselor nu se poate conecta! Nici pe Auto-Scan, nici manual pe fiecare! Im zice "No comunication with controller"
Am vrut sa intru pe 46-Central conv.   si la fel!  De la adresa 19 in sus nu se conecteaza pe nimic!
Mentionez ca asta vara in urma unor ploi torentiale am avut foarte multa apa in masina infiltrata pe la capacul ala de sub stergatoare, pe partea soferului, pe unde ies firele din habitaclu spre motor!!
Daca mai apare, unde? In vag, sau martorul de motor in bord?
oricare
O  eroare poate sa ramana in calculator si abia cand se manifesta de mai multe ori se aprinde becul in bord.
Modificat de andrei_221
Dupa ce-am curatat mufele la cei doi senzori si am sters eroarea o data, in bord nu s-a mai aprins deloc. Pe cand in vag, indiferent de cate ori o sterg, ea revine. In fine, o s-o las asa. Cand se mai manifesta prin aprinderea martorului de motor, il schimb atunci. Multumesc pt informatii.
Sa nu fie prea tarziu, cand DPF este infundat si nu mai poti face regenerarea.
La o scanare cu VagCom am obtinut urmatoarea diagnoza:
Chassis Type: 5P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: VSSZZZ5PZ7R017736   Mileage: 64160km/39867miles
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 DJ    HW: 03G 906 018 DJ
   Component: R4 2.0l PPD1.2 G    0065
   Revision: --H22---    Serial number: SEZ7Z0F3410815
   Coding: 0050072
   Shop #: WSC 06401 785 00200
   VCID: 70EF322E63B04F9E643-8025
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0006898
   Shop #: WSC 06402 785 00200
   VCID: 73E53D2212A67486991-8026
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 5P0 907 044 B
   Component: ClimatronicPQ35 010 0502
   Shop #: WSC 00000 000 00000
   VCID: 2F6DF152BE0E10663D9-807A
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004294477
   Coding: 81880F2700041000001E00000100000000017F0B5C
   VCID: 2B55E5428A166C46111-807E
   Subsystem 1 - Part No: 5P0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer SE359  012  0402
   Coding: 00056272
   Shop #: WSC 06402
3 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 60199 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.65 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 63060 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 60534 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.20 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: S7 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0N1XS5
   Coding: 0021303
   Shop #: WSC 10152 428 16445
   VCID: 3D71DB1A6462F2F6BF5-8068
   Subsystem 1 - Serial number: 6332MSME1226370D5
   Subsystem 2 - Serial number: 6342MSME125A37145
   Subsystem 3 - Serial number: 6351HSME0A630D548
   Subsystem 4 - Serial number: 6361HSME0A635A439
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           035 0070
   Coding: 0002042
   VCID: 8109E7EAD81AD6161BD-80D4
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           005 0060
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 5P0 920 825 A
   Component: KOMBIINSTRUMENT VO3 0422
   Coding: 0002101
   Shop #: WSC 10152 428 94724
   VCID: 306FF22EA3300F9E243-8065
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 310010672485D4
   Coding: 3D3F0B4007008202
   VCID: 2C57E65E8F186B7E18B-8079
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VO3 0422
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1123
   Revision: 31008001    Serial number: 00000007478206
   Coding: 0000176
   VCID: 3B75D5027A76FCC6811-806E
2 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
             Freeze Frame:
                    Fault Status: 00100101
                    Fault Priority: 3
                    Fault Frequency: 15
                    Reset counter: 88
                    Mileage: 64132 km
                    Time Indication: 0
01034 - Electric Window Thermal Protection Active; Driver
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 7
                    Fault Frequency: 8
                    Reset counter: 88
                    Mileage: 64132 km
                    Time Indication: 0
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.142 H07 1806
   VCID: 3467FE3E572833BE40B-8061
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 198000005183CC7F0006050560084F01207C80
   VCID: 8305EDE2C206C406091-80D6
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
2 Faults Found:
00896 - Trunk Lock Unit (F256)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 67
                    Mileage: 63889 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:54:29
00893 - Switch for Trunk Handle (E234)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 87
                    Mileage: 64073 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:34:03
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1125
   Revision: 11006001    Serial number: 00000507768616
   Coding: 0000176
   VCID: 3C77D61E7F78FBFE88B-8069
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 5P1 035 186 B
   Component: Radio BVX           0006
   Coding: 0040484
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 M    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1107
   Revision: 11004001    Serial number: 00000000315780
   Coding: 0000144
   VCID: 3A7BD006754CC5CE9A7-806F
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 M    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1107
   Revision: 11004001    Serial number: 00000000347476
   Coding: 0000144
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D51EB5AB40262760F5-8078
End   ---------------------------------------------------------------------
Singurele probleme vizibile sunt macaraua de la geamul stanga fata care s-a intepenit (din nou) si 3 becuri arse pe care le-am schimbat.
Nu inteleg erorile legate de portbagaj si eroarea Electric Window Thermal Protection.
salut,am o problema la climatronic ce demult ma sacaie si a cam sosit momentul sa o rezolv.
Am un passat b6 2.0tdi140cp,celebrul `bkp` cu urmatoarele  eroari:
                Address 08: Auto HVAC       Labels: 3C0-907-044.lbl
Control Module Part Number: 3C0 907 044 J    HW: 3C0 907 044 J
  Component and/or Version: ClimatronicPQ46 041 0101
           Software Coding:
            Work Shop Code: WSC 00000 000 00000
                      VCID: 285F1E229B53165EFC3-807D
7 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 162
                    Mileage: 212283 km
                    Time Indication: 0
                    Date: 2014.02.22
                    Time: 08:18:27
01272 - Positioning Motor for Central Flap (V70)
            000 - -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 162
                    Mileage: 212283 km
                    Time Indication: 0
                    Date: 2014.02.22
                    Time: 08:18:27
00716 - Air recirculation Flap Positioning Motor (V113)
            000 - -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 162
                    Mileage: 212283 km
                    Time Indication: 0
                    Date: 2014.02.22
                    Time: 08:18:27
01809 - Actuating Motor for Temperature Flap; Left (V158)
            000 - -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 162
                    Mileage: 212283 km
                    Time Indication: 0
                    Date: 2014.02.22
                    Time: 08:18:30
00710 - Defroster Flap Positioning Motor (V107)
            000 - -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 162
                    Mileage: 212283 km
                    Time Indication: 0
                    Date: 2014.02.22
                    Time: 08:18:30
            000 - -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 162
                    Mileage: 212283 km
                    Time Indication: 0
                    Date: 2014.02.22
                    Time: 08:18:30
00041 - Indirect Ventilation Flap Motor (V213)
            000 - -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 162
                    Mileage: 212283 km
                    Time Indication: 0
                    Date: 2014.02.22
                    Time: 08:18:30
Dat fiind ca nu a bagat caldura toata iarna pe partea pasagerului in dreapta,vreau neaparat sa rezolv problema.Are cineva idee ce trebuie schimbat si cam pe unde se afla?Nu de alta dar nu as vrea sa dau din lac in put :)
prima data stergi erorile si faci un basic setting.
pe urma determini exact ce clapeta nu isi face treaba.
01810 - Actuating Motor for Temperature Flap; Right (V159)  - asta e clapeta ce modifica temperatura in partea dreapta.
Insa tu ai multe clapete care par a avea probleme.
salut sunt nou pe aici si sper sa postez unde trebuie..Am o problema la Tiguan 2008 , 2.0tdi 140cp. Apare cateodata,nu tot timpul in bord robinetul insotit de spirala si mesajul motorfail workshop,daca merg in turatii mici pana in 2500r.Apare mesajul in bord iar masina pica deodata in `nas` nu mai are demaraj.Daca pastrez turatiile vitezelor la 2500/3000 mesajul apare mai rar.Chestia e ca trebuie oprita si pornita de fiecare data la aparitia erorii sa imi pot continua drumul normal.Am facut si o scanare poate ma ajuta cineva.Multumesc!
1 Fault Found
000136 - Fuel Rail/System pressure: Too High
                P0088 - 000 - - - MIL ON
               Freeze Frame:
                      Fault status:  11100000
                      Fault Priority:   2
                      Fault Frequency:  64
                      Mileage:  220814 km
                      Time Indication:  0
Freeze Frame:
        RPM:  1357 /min
        Inj. Quantity:  10,2mg/str
        (no units):  5.0
        Pressure: 392.0 bar
        Pressure: 704.0 bar
        Temperature: 14.4 C
        Tank Cont:  32.5l
-Verifica si curata regulatorului de debit de pe pompa de inalta presiune,cred ca sita regulatorului este plina de span
-Verifica regulatorul de presiune: la ralantiu trebuie sa ai presiunea in rampa intre 230-300Bar iar regulatorul sa fie deschis intre 17%-20% iar rezistenta regulatorului 2-4 ohm
-Verifica senzorul de presiune: la ralantiu aproximativ 1,32V          si pedala de acceleratie in podea 3,77V +
ok multumesc pentru ajutor gctinvalentin! zilele astea am sa verific,nu am masina acasa..revin cu ce am rezolvat
am sters eroarile am dat basic settings andrei_221,insa eroarile apar...vreau sa desfac bordul si sa sa schimb(repar)clapetele si motorasele,insa nu am cunostinta despre pozitia lor si cum ajung la ele.Chestia e ca undeva intr-un service de cartier mi-a cerut in jur de 1000 lei doar ptr a-mi demonta bordul fara reparatii sau inlocuiri:( :tuktuk:
Modificat de sharky87
e foarte mult 10 mil doar D/R bord.
Daca reapar erori la toate acele clapete, mi se pare cam ciudat sa se strice toate....
nu baga aer cald partea dreapta parbriz,centru si partea dreapta fatza si nici la picioare dreapta,intr-un cuvant jumatea soferului e functionala jumatea pasagerului defecta :icon_confused:
poate fi o chestie din sigurante ceva daca eu am eroarile de mai sus mentionate?
nu e din sigurante...
Pe VCDS se vede cum functioneaza clapetele ( in blocurile de valori)...
Trebuie facuta o verificare, dar mai degraba as suspecta un cablaj sau unitatea de climatronic....
  • Aerofan pinned this topic
    • albinaru
