zorg
mai exact e in partea dreapta a masinii,prin spatele farului, e prins in 2 suruburi de o partea si alta a senzorului
Mi-a aparut o eroare si nu stiu ce este :
01516 - Terminal 30; Left
011 - Open Circuit
- de la ce poate fi? (mi-a murit bateria si am reponit masina cu cabluri)
La o scanare ulterioara de dimineata am mai descoperit ceva erori :
                Address 09: Cent. Elect.       Labels: 3C0-937-049-30-H.lbl
Control Module Part Number: 3C8 937 049 E    HW: 3C8 937 049 E
  Component and/or Version: Bordnetz-SG     H54 2602
           Software Coding: FF8A8F0700041A00470000000F000000001B5D4332000120000000000000
            Work Shop Code: WSC 05124 123 12345
           Additional Info: 3C1955419A  Wischer 171008 004  0206   1K0955559AH RLS     080109 054  0402
                      VCID: 336F6E68522E776
4 Faults Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.15 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01496 - Bulb for Fog-Lamps; Left (L22)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.45 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
00978 - Lamp for Low Beam; Left (M29)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.75 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
01064 - Terminal 58d; Interior Dimming
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.75 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
Problema e ca eroarea cu terminal 30 nu vrea sa se stearga deloc, daca o sterg revine instantaneu innapoi.Vreo idee ceva?
Cu restul aproape ca inteleg : e de schimbat bec xenon, bec de ceata, si ultimul cu interior dimming terminal 58 nu stiu ce sa cred, s-a ars vreo siguranta sau chiar terminalul, habar nu am cum sa le interpretez.
Sunt cumva legate pe acelasi circuit sau depind una de alta? (poate fi si bateria cu voltaj scazut problema acestor erori?)
Situatie sta cam asa :
Bec xenon stanga - defect
Bec ceata stanga - defect
Bec pozitie dreapta - defect
Bec pozitie spate stanga - defect
Semnalizare stanga - defect (merge doar cea de pe oglinda)
Frana dreapta - defect
Frana de pe haion - defect
Becuri iluminare numere - defecte
Toate acestea sunt inspectii vizuale efectuate azi noapte la lumina lunii :))
Modificat de skorpyon_83
verifica sigurantele in ebox langa baterie. Am intalnit de multe ori aceasta eroare (era pe partea dreapta in majoritatea cazurilor) - si era siguranta respectiva topita, stricand si ebox-ul...
Simptome -  nu mergea niciun bec pe dreapta fata si spate....
post-17228-0-98639300-1380563512_thumb.p
intotdeauna siguranta cu problema a fost cea incercuita.  Avand in vedere ca nu am gasit-o arsa in niciunul din cazuri, am concluzionat ca de la un contact imperfect s-a manifestat asa.
Configuratia Ebox-ului variaza, sunt mai multe modele.
Modificat de andrei_221
Din câte observ la tine e diferită cutia de sigurante fata de ce am eu. Oricum am
Masurat toate sigurantele si nu e niciuna arsa. Tind sa cred ca am bulit centrala electrica.
Cand ai ramas fara baterie.....si i-ai dat curent de la alta masina..... daca ai verif sigurantele, etc.... probeaza cu alta centrala
Salut... de ceva timp imi da aceste erori... apareau destul de rar, o data la 2-3 luni... acum vad ca au inceput sa apara mai des, o data pe saptamana... ma puteti ajuta va rog de la ce ar putea fi?? Va multumesc!!
   Address 01: Engine       Labels: 03G-906-018-BMN.clb
Control Module Part Number: 03G 906 018 EM    HW: 03G 906 018 EM
  Component and/or Version: R4 2.0l PPD1.2 G    0420
           Software Coding: 0000072
            Work Shop Code: WSC 00028 028 00001
                      VCID: 74EC6BBA17A00E9
2 Faults Found
012600 - Intake Manifold Runner Control
               P3138 - 006 - Regulation Deviation - Intermittent
             Freeze Frame
                    Fault Status: 00000001
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 38
                    Mileage: 162313 km
                    Time Indication: 0
                    Date: 2013.09.29
                    Time: 20:16:40
             Freeze Frame
                    RPM: 2272 /min
                    Torque: 48.0 Nm
                    Speed: 55.0 km/h
                    Mass Air / Rev.: 594.1 mg/str
                    Mass Air / Rev.: 659.5 mg/str
                    Lambda: -25.8 %
                    Text: Kein Messwert verfuegbar
001137 - Exhaust Pressure Sensor 1 (G450)
               P0471 - 006 - Implausible Signal - Intermittent
             Freeze Frame
                    Fault Priority: 1
                    Fault Frequency: 4
                    Reset counter: 33
                    Mileage: 162229 km
                    Time Indication: 0
                    Date: 2013.09.27
                    Time: 13:39:20
             Freeze Frame
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Pressure: 0.0 mbar
                    Text:       21    mbar
                    Text:  304    C
                    Temperature: 18.0°C
Poate fi de la senzorul G450 . Daca e made in USA schimba-l fara ezitare.
post-74110-0-29429900-1380627251_thumb.j
Si unde gasesc acest senzor?? Am passat motor bmr. Mersi. Si prima eroare tot de la senzorul asta?
salut Florin, zimi si mie cat ma costa  scanare, adaptare clapeta, adaptare EGR, Kit Tempomat+ montaj, si switch pt. 3 usi astept un mesaj
Smile2me
Il gasesti la motor ,in partea stanga a actuatorului de la turbina.E la vedere nu ai cum sa-l ratezi.
2 Faults Found
             Freeze Frame
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 38
                    Mileage: 162313 km
                    Time Indication: 0
                    Date: 2013.09.29
                    Time: 20:16:40
             Freeze Frame
                    RPM: 2272 /min
                    Torque: 48.0 Nm
                    Speed: 55.0 km/h
                    Lambda: -25.8 %
este o problema la clapetele din galeria de admisie, trebuie verificata capsula vacuumatica ce actioneaza axul clapetelor sau furtunul de vacuum de la aceasta
Revin odata cu frigul de afara cu una din erorile (re)aparute:
18009 - releu pentru tensiune de alimentare +30; semnal improbabil; permanent
Dau la cheie si cat timp "invarte" motorul se aprind ABS si ESP insotite de 3 bipuri prelungi.
Aceasta eroare am avut-o si in februarie a.c., dar cum a venit caldura am si uitat de ea. Acum a revenit.
Daca peste zi este cald, la plecarea de la munca nu mai face, azi destul de frig (4 grade) a facut si la plecare spre casa.
Daca cineva stie ceva, macar de unde sa incep sapaturile, va rog sa nu va abtineti.
Multumesc si drumuri bune.
Verifica bateria, bornele de la baterie, cablul de plus si cel de masa de la baterie.
Verificat baterie, borne si cabluri. Totul e ok. Releul J317 ce face ? Bujii sau alimentare computer ?
Multumesc AL Bundy pentru raspuns.
se poate curata galeria de admisie la motorul asta??
La toate se poate curata.....
sti de ce intreb... ca la reprezentanta au zis ca nu se pot curata ca sunt din plastic...
are cineva un tutorial cum se curata si cum se desface??
Am schimbat centrala electrica cu alta cu acelasi cod, am copiat vechiul LC dar acuma nu mai porneste, am inlocuit din nou cu centrala veche si tto nu vrea sa mai porneasca,Acestea sunt erorile pe care mi le de indiferent de cate ori le sterg :
Chassis Type: 3C0
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 53 55 56 62 6C
          72 77
VIN: XXXXXXXXXXXXXXXXX
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 T    HW: 3C0 614 109 T
   Component: J104    C4 440 V2   0013
   Revision: --025---    Serial number: 00000786473192
   Coding: 0002346
   Shop #: WSC 05311 000 00000
   VCID: 2F676218BE06536
2 Faults Found:
01314 - Engine Control Module
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:23:29
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Voltage: 9.75 V
                    Bin. Bits: 00011110
                    Count: 154
                    Hex Value: 0x0000
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:23:29
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 DK    HW: 3C0 907 044 DK
   Component: ClimatronicPQ46 133 0909
   Revision: 00133024    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 6DDBB810748AE16
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:23:29
   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000009192070
   Coding: EB8A8F0700041A00470A00000F000000000B5D435C000120000000000000
   Shop #: WSC 05124 123 12345
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 171008 004  0206
   Coding: 00046997
   Shop #: WSC 05124
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     080109 054  0402
   Coding: 00479274
   Shop #: WSC 05124
3 Faults Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 10.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 10.15 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 9.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 10: Park/Steer Assist (J791)       Labels: 1T0-919-475.clb
   Part No SW: 1T0 919 475 L    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0021
   Revision: --------    Serial number: 06530835207275
   Coding: 300006
   Shop #: WSC 05314 000 00000
   VCID: 448D3DB4C780C0E
No fault code found.
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__04A VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPR6XBA6
   Coding: 0013377
   VCID: FAF1034CB5C4C6E
Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
   Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507CP
   Coding: 0000112
   Shop #: WSC 05314 002 00002
   VCID: 6FE7A2187E86136
   Part No: XXXXXXXXXXX
   Component: E0221           002 0030
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 871 T    HW: 3C0 920 871 T
   Component: KOMBI         H04 0107
   Coding: 160F00
   Shop #: WSC 05314 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
   VCID: 356B5070945A696
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Date: 2053.14.09
                    Time: 00:23:27
Address 19: CAN Gateway        Labels: 3C0-907-530.lbl
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P08C150693
   Coding: F9A17F06404602002002
   Shop #: WSC 05314 123 12345
   VCID: 2A51730C85E436E
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:23:28
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: 7AF1834C35C446E
   Part No: 3C0 905 861 G
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 B
   Component: RNS-MID       H11 1300
   Revision: AB001001    Serial number: VWZ6Z7K5207129
   Coding: 060104000100008300
   Shop #: WSC 52175 142 04882
   ASAM Dataset: ------------------------- ------
   VCID: 2E597F1C790C5AE
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:24:47
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1517
   Revision: 72009005    Serial number: 00000513989119
   Coding: 0000245
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.082 0502
   Revision: 1AH02240    Serial number: 00083350046902
   Coding: 0000258
   VCID: 39735C4070428D6
5 Faults Found:
00566 - Steering Assistance Operation
            008 - Implausible Signal - MIL ON
             Freeze Frame:
                    Fault Status: 11101000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:23:27
             Freeze Frame:
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x7301
            004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:23:27
             Freeze Frame:
                        Term 15 On
                    RPM: 1500 /min
                    Speed: 0.0 km/h
                    (no units): 7.0
                    Voltage: 10.20 V
            005 - No or Incorrect Basic Setting / Adaptation - MIL ON
             Freeze Frame:
                    Fault Status: 11100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:23:27
             Freeze Frame:
                    (no units): 7.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 8
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 146
                    Time Indication: 0
             Freeze Frame:
                    (no units): 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:24:47
             Freeze Frame:
                    Voltage: 4.80 V
                    Voltage: 9.50 V
                    Voltage: 9.50 V
                        Not Occup.
                        Not Occup.
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 043 0612
   Coding: 0091020051030E763004941570084FCE707C01
   Shop #: WSC 05311 123 12345
   Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Part No: 3C0 951 171 C
   Component: Neigungssensor  004 0611
   Component: Innenraumueberw.004 0611
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1517
   Revision: 72009005    Serial number: 00000628489117
   Coding: 0000244
   VCID: 70E5A16463B80CE
Address 53: Parking Brake        Labels: 5N0-907-801.clb
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000218049
   Coding: 0000057
   VCID: 285589049BE804E
2 Faults Found:
03182 - Clutch Position Sensor (G476)
            010 - Open or Short to Plus - MIL ON
             Freeze Frame:
                    Fault Status: 11111010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:23:28
             Freeze Frame:
                    Voltage: 9.80 V
                    Count: 57
                    Speed: 0.0 km/h
                    Hex Value: 0x1261
                    Hex Value: 0x0001
                    Hex Value: 0x1010
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:23:28
             Freeze Frame:
                    Voltage: 9.80 V
                    Count: 73
                    Speed: 0.0 km/h
                    Hex Value: 0x1271
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0136
   Revision: 00H04000    Serial number:
   Coding: 2311169
   VCID: 346D6D74572070E
   Subsystem 1 - Part No: 7L6 941 329 A
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000035
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:23:28
             Freeze Frame:
                    Voltage: 10.08 V
                    Speed: 0.0 km/h
                        ABS 1
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
                    Date: 2117.14.09
                    Time: 00:24:47
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000753882
   Coding: 0000208
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 3C0 907 441     HW: 3C0 907 441
   Component: J772__Rearview      0042
   Revision: 00H05000    Serial number:    PA8 J990274
   Coding: 0000007
   Shop #: WSC 34789 142 999999
   VCID: DFC752D80E26036
            013 - Check DTC Memory
             Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192061 km
                    Time Indication: 0
             Freeze Frame:
                        Term 15 On
                        Reverse OFF
                    Count: 3
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000758505
   Coding: 0000208
   VCID: 71E3A46068B2056
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668104046
   Coding: 0200000000010110
   Shop #: WSC 73430 031 00999
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA_VW52.rod
   VCID: 32616B6C65347EE
End   ---------------------------------------------------------------------
Ceva pareri? Am schimbat si bateria si nimic, efectiv nu mai vrea sa porneasca, si imi scrie de fiecare data depress clutch si AFS, esp erorr si restul de la lumini (ceata, faza scurta etc).Habar nu am ce mai pot face.
nu comunica cu calc de motor. Vezi in Gateway sa fie codat calc de motor.
Pana la urma sa rezolvat erau 3 sigurante care nu functionau dar erau neintrerupte si le-am schimbat pe toate dar pe toate, si ce sa vezi...a pornit din prima fara erori fara nimic doar pozitia e arsa atata tot.
Sent from my GT-I9100 using Tapatalk 2
nu ai vazut la ochi, ca erau intrerupte..... altfel nu au cum sa fie bune dar sa nu functioneze.
acum, intrebare - baterie buna, centrala noua /sh , sigurante schimbate - merge totul ok ?
Am gasit la un Golf 6 1.6 tdi urmatoarea eroare : 14355 - p242a - exhaust gas temperature sensor circuit bank 1 sensor 3.Nu am gasit nimic pe forum legat de aceasta eroare.Imi puteti spune unde este pozitionat pentru a-l verifica ?
senzorul de temperatura dupa filtrul de particule
  • Aerofan pinned this topic
    • FeriM
