Codari VCDS - probate si functionale
borat
Activare HHC ( Hill Hold Control )
1. 03- ABS Brakes
2. Coding-07
Long Coding
Se modifica valoarea Byte 25  din 20->23
___________________________________________
Modificare logo Skoda
1. 17- Instruments
2. STG Adaptation -> function 10
APK Displaydarstellung
-> Varianta 1 Skodalogo
-> Varinata 2 Skodalogo
-> Varianta 3 Skoda V/RS Logo
Activare TPM ( Tyre pressure monitor - monitorizare presiune roti)
1. 03 ABS Brakes
3. Choose Tire pressure monitoring display
4. verified Store value is 2
5. the same value stored is on Tire pressure monitoring display;tire selection
ATENTIE !
In Long Coding: the latest 3 Bytes on my side was 004002 and I changed with 70C002
To see the menu in bolero : ( vizualizare meniu in Bolero)
1. 5F Information
3. Choose (13) - Vehicle function list BAP-tire_pressure_system_0x07
4. Set value to active
verified if (14)-Vehicle function list BAB-tire_pressure_system_0x07_msg_bus have value: Suspension data bus
1. 5F Information
3. Choose (56)-Vehicle menu operation-menu_display_rdk
verified if this option is actiated: (58)- Vehicle menu operation-menu_display_rdk_over_threshold_high
1. 17 Instruments
2. STG Long Coding -> function 7
3. Byte 04
4. Enable bit 0 -> Indirect Tire Pressure Monitoring System(TPMS) instaled.
Activare memorie pentru scaune incalzite
1. Controller 08 - HVAC
2. 10 - Adaptation
Choose 'Retention of passenger's seat heater level'
Change to 'active' (the setting it was on when the ignition was turned off will remain next time you start the car) or 'active for 10 minutes' (if you return to the car within 10 minutes the seat heater level will be retained).
Pentru scaunul pasagerului
Do the same for 'Retention of driver's seat heater level'
Dezactivare centura de siguranta / Disable Seatbelt Warning
1. Go into [17] Instruments
2. Adaptation Channels -> function 10
Select disable seatbelt warning (Gurtwarner deaktivieren)
change to "yes" (default: none)
Coborare oglinda pasager la mersul inapoi/Passenger mirror dip on reverse
1. Select STG 52 (Türelektr. Pass.)
2. Long STG coding -> function 07
Byte 04
Enable bit 2
Enable bit 3
3. Select STG 09 (wiring)
4. STG access permissions -> Function 16
Enter Unlock Code 31347
5. STG adjustment -> function 10
(15) Select Access control 2 Spiegelabsenkung bei Rueckwaertsfahrt auswählen
Set value to active (active)
Additionally possible: Hide menu item in Radio-/Navigationssystem, so you are even viable in the future to enable the feature on or off
(20) Select Access control 2-Menuesteuerung Spiegelabsenkung auswählen
______________________________________________
Activare staging / Enable Needle Sweep / Staging
2. Coding -> Function 10
Byte 1
Enable Bit 0
Activare laptimer
1. STG 17 (Schalttafeleinsatz) auswählen
2. STG Lange Codierung -> Funktion 07
Byte 1
Bit 3 aktivieren
Numar de semnalizari confort / Adjust Comfort Turn Signals
1. Go into [09] Central electronic
2. Go to Security Access and enter 31347
3. Go into Adaptation
Select (2) - Turn Signal Controls-Komfortblinken Blinkzykien
Type 5 in New Value (Default is 3)
Afisare pe maxidot cu cati l trebuie sa alimentezi / Display Gallons Consumed
2. Long Coding - (Function 07)
Go to Byte 10
Enable bit 4
Activare RainClosing / Automatic rain closing
1. Go into [09] Central Electronics
2. Go into Secuity Access and enter 31347
3. Go to adaptation channels and set the following:
- (15) Access Control 2 - Regenschliessen_ein aus (Rain Closing on / off) - Select Active
- (16) Access Control 2 - Regenschliessen_art (Rain closing Type) set to Permanent
- (28) Access Control 2 - Menuesteuerung Regenschliessen (Menu Control Rain close) – Set  to Active (enables the menu in the ifotainment screen)
ATENTIE ! Mai trebuie codat senzorul RFLS ( din fabrica are valoarea 02805D ) - se modifica cu 06885D
Marire interval activare spalare faruri / To extend the interval cycles that the headlight washers will activate to a) prevent the front of your clean car being sprayed, and b) to reduce the amount of screen wash usage.
1. Go to [09] Central Electronics
2. STG access permissions -> Function 16
3. Enter access code 31347
4. Go to adaptation channels (Function 10)
5. Select channel 1 - Select "Number of operations front windsceen wiper washer per SRA activation" (in German - Frontscheibenwischer Anzahl Betätigungen Frontwaschanlage pro SRA Aktivierung auswählen)
6. Adjust value to preference (no of times you can operate the windscreen washer stalk before the headlight washer activate).
7. Select channel 3, and adjust the activate time for folding the switch to enable headlight washers in the first place.
Activare / dezactivare DLR din Bolero
Selectati canalul (2) Tagfahrlicht- Tagfahrlicht Aktivierung durch BAP oder Bedienfolge möglich auswählen
Selectati ACTIV
Mod scoala de soferi / Driving school mode
1. STG 5F (Infotainment) auswählen
2. STG Anpassung -> Funktion 10
Kanal (11)- Fahrzeug Funktionsliste CAN-driving school auswählen
Wert auf verfügbar anpassen
Kanal (171)- Fahrzeug Menü Bedienung - menu_display_driving_school auswählen
Wert auf aktiviert setzen
Kanal (173)- Fahrzeug Menü Bedienung - menu_display_driving_school_over_threshold_high auswählen
Activare al doilea stop de ceata
1. 09 - Central Electric
2. 16 - Security Access - enter 31347
3. 10 - Adaptations
- inainte de modificare
(4)-Leuchte26NSL LA72-Lichtfunktion A 26 - Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr
(4)-Leuchte27NSL RC6-Lichtfunktion A 27 - Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr
- dupa modificare
Afisare viteza ventilator pe auto / Blower Status Display in AUTO
1. STG 08 (Klima) auswählen
Byte 11
Bit 6 - Blower Status Display in AUTO-mode active aktivieren
Pe un toledo din 2014, se pot activa unele functii mai sus mentionate?
Buna postarea. Unde as putea sa fac si eu cateva din ele mai aproape de Pitesti? :)
Merg sigur la Seat Leon..la Toledo nu stiu. Se poate testa :)
In Brasov este cineva capabil si cu 'instrumentele' necesare?
Aditu in Valcea daca ajungi ...te pot ajuta
O activare utila ar fi si Intelligent light Assistant. Poate fi activata si pe masinile fara camera pentru Lane assist?
Elegance-ul meu a venit cu Light Assistant. Senzorul de lumina din oglinda poate fi util pentru activare?
Eu am ILA si nu am Lane Assist (indisponibil pe VRS la comanda), deci ar trebui sa se poata cumva.
Modificat de TudorM
Salut, mi-am cumparat un cablu de diagnosticare pt vw-ul din semnatura si intampin urmatoarele probleme: port ok, interface not found. Am incercat diverse versiuni vcds si nu reusesc sa-l fac sa functioneze. Nu stiu ce sa mai incerc...
Multumiri anticipate
Daca e clona ( adica ai dat 100-150 ron pe el ) nu merge cu versiunile oficiale. Poti sa folosesti numai softul "pregatit" pentru el. ( vine in general pe CD odata cu cablul ). E posibil daca ai folosit o versiune oficiala de soft sa nu mai poti folosi interfata respectiva.
Da, e clona si nu mi-a venit cu cd. Mi-am luat eu diverse versiuni de pe net. Deci pot sa-mi iau adio de la el sau mai am ceva sanse?
kidmanis eu stiam ca pentru Intelligent light Assistant este nevoie de o camera ( nu foloseste senzorul de lumina ) si alta camera pentru Lane Assist
Era o treaba buna, ca e una din activarile folositoare comparativ cu staging, lap time etc. Parerea mea.
Si apropo de cele utile, am inteles ca rain closing-ul ar putea afecta bateria din cauza ca ramane activat senzorul de ploaie tot timpul. E adevarat?
Eu am incercat sa activez functia la cineva care se pricepe dar nu am reusit decat sa vad in infotaiment fara a fi insa si functional.
nu, nu descarca bateria, stai linistit.
Ramane activ maxim 24 ore, dupa care geamurile se inchid si functia devine inactiva.
@Al Bundy Multam fain de lamurire. Nu am VCDS dar in iulie cand am incercat activarea, expertului ii mai trebuia ceva suplimentar (RLFS - codare cu VCP). Acum prin updaturile aparute la VCDS e posibil?
Scuze de offtopic. Promit ca ma opresc aici cu intrebarile.
da, cu ultima versiune de VDCS se poate coda si rain closing
rain closing ramane activ mai putin de 24 ore...din cate imi aduc aminte....6 ore
functia Coborare oglinda pasager la mersul inapoi/Passenger mirror dip on reverse e utila si nu prea in sensul ca dupa un timp oglinda e mai jos fata de setarea initala, nu cred ca se ridica pe cat a fost coborata
Datorita faptului ca nu ai scaune cu memorie. Aceasi pb este si A4 B8- calculatorul executa functia dar nu in poz initiala.
Oglinda nu se mai ridica inapoi unde trebuie pentru ca motorasului ii lipseste un senzor de feedback, care sa-i transmita date microcontroller-ului despre amplitudinea exacta a miscarii. Acest senzor apare d-abia la modelele cu scaune/oglinzi cu memorie, asa cum a mentionat si Pronet.
ciudat ca au pastrat dependenta mirror down de scaunele electrice (ca la Passat B6) avand in vedere ca la mine merge fara..
Activation of the fog lights (NSW) and Cornering
In the onboard supply control unit gives you the option when Skoda Octavia III 5E fog lights (NSW) to activate additionally as cornering. When active, the corresponding low beam fog lamps is thus controlled in accordance with the steering angle and thus provides additional illumination when turning.
The following code is used:
  1. Select STG 09 (Central electronic)
  3. Enter the unlock code 31347
  4. STG adjustment -> Function 10
  5. Select a channel (5) Leuchte12NL LB45-light function B12
  6. Adjust Value on cornering left
  7. Select a channel (5) Leuchte13NL RB5 light function B13
  8. Adjust Value on cornering right
post-83705-0-40704600-1418203114_thumb.p
post-83705-0-15691300-1418203121_thumb.p
Modificat de dj.martzian
In configurator am vazut ca se poate bifa optiunea, dar intreb ca sa-mi fie clar: HHC actioneaza si la masinile cu cutie manuala? Ca si cum ai avea frana de mana activa 1-2 secunde, timp in care sa muti piciorul de pe frana pe acceleratie, cu ambreiajul calcat. Si daca-i asa, ce difera fata de frana de mana clasica? Comoditatea sau/si lipsa de indemanare a unora? OK, poate ca-i mai comod asa, si merita codarea pentru activare. Rau ar fi sa te obisnuiesti si apoi sa te muti pe o masina care nu are HHC...
In fine, m-ar interesa si pe mine cateva activari, in zona mea geografica. De exemplu: semnalizare de convenienta x 5, hhc (daca merge la M6), drl dimming, memorie incalzire in scaune. Anybody?
Modificat de adig
Eu am cutie manuala pe un 1.4 TSI si HillHoldControl din fabrica. Initial am gandit HHC mai mult pentru sotie, ca deh e orasul celor 7 coline si cum masina e destul de mare, sa ii fie de folos. Pentru cel care e obisnuit fara, acest sistem nu face diferenta in uzul zilnic (parerea mea). Ma ajuta cand trebuie sa parchez cu spatele intro rampa de exemplu, si nu trebuie sa mai abuzez de "motoras".
    • eldyablos
