Upgrade/Probleme la geamuri electrice....
negraruovidiu
negraruovidiu
Salut la primare scanare dupa ce am legat si plusul de la contact cum a zis Florin a reesit lista asta:
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 1E Komfortgerát HLO 0003
   Coding: 00065
   Shop #: WSC 01317
   VCID: 36693801125C5C9
   Subsystem 1 - Part No: 1U4959801D
   Component: 3X Tõrsteuer.FS KLO 0009
   Subsystem 2 - Part No: 1U4959802D
   Component: 3X Tõrsteuer.BF KLO 0009
18 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
            53-10 - Supply Voltage Too Low - Intermittent
01336 - Data Bus for Comfort System
            80-10 - Single-Wire Operation - Intermittent
            37-10 - Faulty - Intermittent
01131 - Control Circuit for Turn Signals
            25-10 - Unknown Switch Condition - Intermittent
01332 - Door Control Module; Passenger Side (J387)
01331 - Door Control Module; Driver Side (J386)
01299 - Diagnostic Interface for Data Bus (J533)
            49-00 - No Communications
00849 - S-contact at Ignition/Starter Switch (D)
00953 - Interior Light Time limit
01134 - Alarm Horn (H12)
            25-00 - Unknown Switch Condition
00932 - Electric Window Motor; Drivers Side (V147)
            62-00 - No or Incorrect Adjustment
01034 - Electric Window Thermal Protection Active; Driver
            35-10 -  -  - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            27-00 - Implausible Signal
00943 - Heated Exterior Mirror; Driver Side (Z4)
            35-00 -  -
01359 - Internal Central Locking Switch; Passenger Side (E198)
00933 - Electric Window Motor; Passenger Side (V148)
dupa ce le-am sters ca poate erau stocate din momentul lucrarii si am maiumblat cu masina a ramas una singura:
care nu stiu la ce se refera, la ceva modul de comunicatie, eu am pe skoda din 2001 asa ceva?
in rest geamurile tot asa merg cu butonul apasat,in vcds arata manual open  si auto open cand apesi mai tare pe buton dar degeaba cum iei mana se opresc, am facut si ce a zis Florin cu sus jos la geamuri si tinut 2 secunde dar  tot degeaba, daca aveti idei sau pareri astept cu placere.
acum vad ca in vcds motorasele geamurilor se vad ca si cod 1U4959801D si 1U4959802D, is k asa sau trebuiau alt cod sa fie?
Modificat de negraruovidiu
20 hours ago, F l o r i n said:
alarma oem - nu ai sincronizat inca telecomanda....banuiesc.....
Vorbim romaneste, ne intelegem ioc....
Modulul care l-ai cumparat este cu alarma oem si receptie telecomanda - tu descui mecanic si incepe alarma (integrata in modul) si de aceea auzi acele click-uri in el, pana se pune contactul
negraruovidiu
Asa da modulul e cu alarma oem,,k, si nu pot dezactiva functia sa nu mai click-ie?  In rest cu geamurile mai avet idei?
multumesc ca ai inteles ce tot incerc sa iti explic :banghead:
nu poti dezactiva cu VCDS-ul - numai cu vds pro sau programator, modificare eeprom, etc.
Normal - cumperi telecomanda aferenta/cheia briceag compatibila si o sincronizezi - descui cu ea si automat dezarmeaza alarma oem
negraruovidiu
Daca  o las asa are ceva? Sau o pot dezactiva la reprezentanta skoda?
Am facut procedura care ai zis cu geamurile sus jos, dar nu merge si ramane eroarea stocata
nu, nu va merge la reprezentanta - doar cum ti-am scris mai sus
negraruovidiu
Eroarea de la ce vine?
46 confort nu comunica cu gateway
negraruovidiu
k, si unde caut sa remediez, ? printre altele am facut oglinzile sa mearga
trage firele de can in ceasuri
negraruovidiu
Pe schemele mele nu apar de nu le-am tras, sau le gasesc pe alte scheme?
da, nu apare pe scheme, ai doar k line la modelul acesta.
intra pe can gateway si recodeaza cu 00006 sau cat ai tu acum
salut revin cu problema cu geamurile electrice, pe care nu am reusit sa le termin de instalat, si am ramas la stadiul de:
- merge geam stanga sus-jos, merge geam dreapa sus jos dar doar din comenzile de pe geamul din dreapta nu si de pe usa sofer
- amandoua geamuri merg doar la coborare pas cu pas, nu si roll down cred a ii zice la functie
- inchidere centralizata incuie toate usile daca bagi cheia la sofer sa incui, daca descui...descuie doar usa sofer, daca descui din usa dreapta se descuie toate mai putin usa sofer
si am urmatoarele erori:
            80-00 - Single-Wire Operation
Cum ma puteti ajuta cu informatii sa pot termina instalarea va rog, si referitor la postul lui Florin tot nu am inteles ce sa codez cu 06.
can gateway.... modulul 19.... cum sa ii mai spun ?
Dupa masa  ma duc cu laptop la masina, si te sun Florin daca poti vorbi, stiu unde este can gateway nu am inteles ce sa fac, multumesc deocamdata
sa-l recodezi/codezi cu 00006
am recodat cu 0006 si nimic nou acleasi errori le da adica astea:
Ce altceva ii pot face?
Sa revezi toate legaturile electrice facute sa fie conform cu schema.
Salut am verificat toata instalatie electrica din nou, si totul este ok, am schimbat si CCM-ul cu altul si la fel aceleasi probleme, mai ramane sa schimb si motorasul din usa cu electronica de pe el, sau pe el il pot verifica cumva ?  altceva as mai avea de verificat pe undeva ?
nu ai cum sa il verifici, daca e o problema pe can - de fapt ai cum, dar nu ai tu cu ce, nu stii mesajele care trebuie sa le trimita, etc
Salut, am o intrebare se poate ca un calculator confort in cazul meu 1c0959799b de pe masina de anglia sa se potriveasca pe masina de europa, si sa functioneze totul normal, geamuri, trapa, lumini interioare, etc???
Trebuie facute ceva adaptari sau iei de masina de anglia si pui pe masina de europa plug and play si gata va merge ca cel original?
Daca provine de pe o masina identica - caroserie, model, marca - il montezi dupa care adaptezi telecomenzile - acest lucru este valabil, deoarece nu ai ceasuri cu display maxidot, pe masina ta.
La cele cu maxidot, arata invers usile pe fata - caz in care trebuie modificat eepromul modulului confort. Aceelasi lucru trebuie facut, daca nu vine de pe o masina identica, ca varianta caroserie/model
