Golf 6 - CAN Gateweay Incorrectly Coded
tuchbr
Buna ziua,
am nevoie de ajutor in a depista o problema.
Descriu prima data ce am facut:
am demontat modulul de climatronic de pe masina, dupa ce l-am remontat a aparut eroarea Airbags Service, pentru ca am uitat sa reconectez LED-ul indicator Passanger airbag off.
Am imprumutat un Laptop pentru a sterge eroarea aparuta, ce am si reusit.
Problema este ca nu mai pot sa intru la Central Electr. de loc.
Am facut o scanare pe module si la unele module apar erori ciudate.
  Citat:
Saturday,29,December,2012,18:59:35:37412
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: WVWZZZ1KZ9P
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 MC HW: 03L 907 309
Component: R4 2,0L EDC G000SG 3593
Revision: 13H01--- Serial number:
Coding: 0000071
Shop #: WSC 10133 599 181496
VCID: 72E1AB6C6DB43EE
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 113B200D09220001881304E5901C00423500
Shop #: WSC 00028 028 00001
VCID: 75EB9070DCDA296
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 AK HW: 5K0 907 044 AK
Component: Climatronic 130 0303
Revision: 00002001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_VW36.rod
VCID: 74EDAD74DFA030E
Address 09: Cent. Elect.
Cannot be reached
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 D HW: 1T0 919 475
Component: PARKHILFE PLA H07 0012
Revision: -------- Serial number: 45230823203153
Coding: 10000A
VCID: 3C7D4554BF70B8E
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 020 0507
Serial number: 003C2D03866A
Coding: 00003135
Shop #: WSC 00028 028 00011
ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
VCID: F7F71A784ED6DB6
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V U01 ----
Serial number: 4106463FZZZZZZZZZZZZ
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V U01 ----
Serial number: 2556133EZZZZZZZZZZZZ
Component: S.Sens.Fahr.H --- ----
Serial number: 1E230B5FZZZZZZZZZZZZ
Component: S.Sens.Beif.H --- ----
Serial number: 020D094EZZZZZZZZZZZZ
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 853 0111
Coding: 0000034
VCID: 830F7EA8C20E876
5 Faults Found:
00576 - Terminal 15
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 870 CX HW: 5K0 920 870 CX
Component: KOMBI H21 0030
Serial number: 00000000000000
Coding: 170F00
Shop #: WSC 21243 142 95265
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 850B60B0043AB96
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 020908F1000953
Coding: E9A07F060002020002
VCID: 356B50705C5A696
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Mileage: 144357 km
Time Indication: 0
Date: 2021.14.19
Time: 18:48:52
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H21 0030
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 AG HW: 1K0 959 701 AG
Component: Tuer-SG 008 2033
Coding: 0004278
VCID: 73EFAE6812AE376
01706 - Switch for Mirror-Adjust (E43)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
VCID: 2A51730C85E436E
2 Faults Found:
16353 - Control Module - Internal Malfunction
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 6
Fault Frequency: 1
Reset counter: 184
Mileage: 142882 km
Time Indication: 0
Date: 2019.14.08
Time: 12:16:10
Freeze Frame:
Battery Volts: 12.7 V
DU
Temperature: 39.0°C
Error Code: 15491
Torque: -6.6 Nm
Torque: 0.412 Nm
RPM: -558 /min
16355 - Control Module - Watchdog Timer
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 6
Fault Frequency: 1
Reset counter: 100
Mileage: 142882 km
Time Indication: 0
Date: 2019.14.08
Time: 12:16:10
Freeze Frame:
Voltage: 12.88 V
DU
Temperature: 39.0°C
Count: 0
Count: 0
Count: 60
Count: 0
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 AG HW: 1K0 959 702 AG
Coding: 0004534
VCID: 74EDAD7417A030E
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 036 0130
Revision: 00000001 Serial number: VWZ1Z3H3348756
Coding: 0500040004
VCID: E5CB4030EC7A596
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 13
Mileage: 139479 km
Time Indication: 0
Date: 2016.14.00
Time: 12:03:44
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
Component: Tuer-SG 007 2009
Coding: 0000144
Shop #: WSC 00028 028 1012545
VCID: 7AF1834C35C446E
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Part No SW: 1K0 937 086 HW: 1K0 937 086
Component: RDK 020 0517
Coding: 000000
Shop #: WSC 131071 1023 2097151
VCID: EDDB3810348A616
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Mileage: 139479 km
Time Indication: 0
Date: 2016.14.00
Time: 11:56:26
01521 - Sensor for Tire Pressure
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Mileage: 139511 km
Time Indication: 0
Date: 2016.14.02
Time: 09:27:40
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AL HW: 1K0 959 704 AL
Coding: 0000144
VCID: 7BFF86483AFE7F6
End ---------------------------------------------------------------------
cel mai tare ma deranjeaza :
CAN Gateweay 01044 - Control Module Incorrectly Coded
si
Cannot be reached
Presupun ca Address 09: Cent. Elect. Cannot be reached este cauzat de Address 19 CAN Control Module Incorrectly Coded
Va rog sa ma sfatuiti in a rezolva aceste probleme la masina (este destul de urgent, deoarece laptopul il am numai pana maine)
Va multumesc!
EDIT: am uitat sa mentionez ca vara am mai activat cateva functii pe masina (washerfluid warning,teerdrop,comming home, TPMS, etc, de cand am pus cauciucurile de iarna TPMS sta aprins) , atunci am reusit sa intru la 09 Cent. Elect.
Modificat de tuchbr
ai defecte la switch-ul electric al contactului...
La servodirectie si TPM trebuie sa faci setariel de baza si pe urma vezi ce mai apare...
teoretic daca VCDS incearca sa scaneze 09-central electronics, dar nu o gaseste, nu ar trebui sa fie de vina codarea gateway-ului.
incearca sa refaci codarea gateway. Intri pe modul, mergi la Coding, Long Coding - si te apuci si bifezi dotarile pe care le are masina ta
Modificat de andrei_221
La servodirectie si TPM - cum se fac setarile de baza ?
Codarea gateway cu Long Coding am incercat insa nu stiu ce dotari sa bifez.
Coding II pe CAN arata asa, este normal ?
Nu stiu de cand am aceste erori, abia azi am observat, nu am observat functionare defectioasa la masina.
Modificat de tuchbr
trebuie sa ajungi la o reprezentanta VW, nu se pot face toate cu VCDS-ul.. Bafta!
Am sters erorile si am mai facut o scanare.
Au ramas urmatoarele:
65-Tire Pressure -- Status: Not registered 0001
  Citat:
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Component: BCM PQ35 M 020 0358
Revision: 00020000
Coding: 40180A3A98251AC0C0080080550081E447010088725D8D60288000000000
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 04090 21 0501
Coding: 009F95
00907 - Intervention load Management
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 20
Mileage: 144357 km
Time Indication: 0
Date: 2021.14.19
Time: 20:48:01
Freeze Frame:
Term 15 On
Voltage: 11.65 V
ON
ON
Term 50 Off
OFF
OFF
  Citat:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 144357 km
Time Indication: 0
Date: 2021.14.19
Time: 20:42:14
  Citat:
Revision: 00H15000
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 184
Mileage: 142882 km
Time Indication: 0
Date: 2019.14.08
Time: 12:16:10
Freeze Frame:
DU
Temperature: 39.0°C
Error Code: 15491
Torque: -6.6 Nm
Torque: 0.412 Nm
RPM: -558 /min
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 100
Mileage: 142882 km
Time Indication: 0
Date: 2019.14.08
Time: 12:16:10
Freeze Frame:
Voltage: 12.88 V
DU
Temperature: 39.0°C
Count: 0
Count: 0
Count: 60
Count: 0
Daca masina functioneaza fara probleme, trebuie neaparat rezolvate aceste erori ? (poate le-am avut de cand am cumparat masina, si nici nu stiam, avand in vedere ca in bord nu apare nici o eroare - daca nu aveam cablu VCDS, nici nu aflam de erorile astea)
Modificat de tuchbr
Eu cred ca tu ai gresit cand te-ai apucat sa codezi anumite chestii.
Daca te uiti la erori, sunt date la un anumit nr. de km, care de obicei sunt cei reali la care a survenit eroarea.
Asa poti sa-ti dai seama daca tu ai gresit sau a fost asa mai de mult.
Suna-l pe Florin sau pe Al Bundy si cere-le sa te ajute.
Am trimis PM lui Al Bundy, sper ca ma poate ajuta.
Pe masina am codat doar 09 centr. si 17 instr.
La 19 gateway nu am umblat deloc.
Ai dreptate cu nr. de Km/ masina era deja de ceva vreme la mine. Insa eroarea la gateway nu se stie cand a aparut prima data, pt. ca nu m-am uitat cand l-am sters.
Ce anume ai codat? Pentru ca unele chestii trebuie codate si in Can ca sa mearga. Altfel ori nu merg deloc ori merg dar nu 100% perfect si cu erori...
@Rave
am activat urmatoarele:
Breakpad warning
Washer fluid warning
Emergency Brake Flashing
Comfort Turn Signal Count la 5
Coming Home Lights
Tear Drop Wiping on Front Wiper
Tear Drop Wiping on Rear Wiper
Driver Seat Heater Memory
TPMS (fara buton SET,nu am buton)
Hill Hold Control
Doar la astea am umblat.
EDIT:
Eroarea CAN Gateway rezolvata cu ajutorul lui Al Bundy. :icon_thumleft:
Modificat de tuchbr
Spune si ce anume ai avut gresit pe acolo.. sa fie un fel de "ASA NU!!"
Am activat TPMS , fara sa-l bifez in Instalation list in CAN, la mine se pare ca asta a fost buba, dupa ce l-am bifat am mai facut 2 scanari si nu mai apare "Control Module Incorrectly Coded" :icon_thumleft:
Restul erorilor le mai am, se pare ca trebuie sa schimb "ignition switch"-ul. (daca nu gasesc un DIY , voi apela la reprezentata, cand buzunarul imi va permite, masina nu da nici un semn de boala, aceste erori apar doar la scanare)
Dupa schimbarea electronici de la contact, urmatoarele erori au ramas,
5 Faults Found:
00576 - Terminal 15
Cica erorile pot fi cauzate de Alarma AM Viper ???
Daca era doar pe unul sau 2 contacte DA, dar asa NU. Alarma e si cu pornire motor?
Fara pornire motor
*edit: interesant e, ca masina porneste fara rateuri...
Modificat de tuchbr
Atunci schimba partea electrica a contactului.
A fost schimbat , sau nu la chestia asta te referi ?
Daca poza e de la masina ta, atunci nu a fost schimbat. Codul e cu B si mai nou cu C.
Poza e veche, demontez maine daca am timp , sa vad ce este acum pe masina...
Salutare, vad ca s-a mai discutat aici de eroarea 16353 - Control Module - Internal Malfunction, asadar postez si eu un log al unui G6 2009, 2.0 TDI, DSG cu aceste doua erori la adresa 44.
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZA (sters de mine restul)
02-Auto Trans -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CBD)       Labels: None
   Part No SW: 03L 906 022 LK    HW: 03L 906 022 G
   Component: R4 2,0L EDC G000AG  3142
   Revision: 13H02---    Serial number:
   Coding: 0000078
   Shop #: WSC 83968 427 535272
   VCID: 79F39C4030C24D6
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1919
   Revision: 04844002    Serial number: 00000905111400
   Coding: 0000020
   VCID: D1A384E048F2A56
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 113B200D092300FD880E04E6901F0042B100
   VCID: 800571A413189CE
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 H    HW: 3C8 907 336 H
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   Shop #: WSC 00028 028 00318
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_Climatic_VW36.rod
   VCID: 32616B6C65347EE
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0537
   Revision: 00103 AC
   Coding: 40180A3A90251AC040000080100081E443010088524D8960648000200000
   VCID: 3065616463384CE
   Component: Wischer 03060  21  0501
   Coding: 009795
   Component: AirbagVW10    033 0604
   Serial number: 003C2D0BB55J
   Coding: 00003139
   Shop #: WSC 00028 790 00012
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360_VW36.rod
   Crash sensor for side airbag; driver side:
   Serial number: 05193448ZZZZZZZZZZZZ
   Crash sensor for side airbag; passenger side:
   Serial number: 7D302148ZZZZZZZZZZZZ
   Crash sensor for side airbag; rear driver side:
   Serial number: 08412D3DZZZZZZZZZZZZ
   Crash sensor for side airbag; rear passenger side:
   Serial number: 182E2F48ZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001034
   VCID: 82017BACDD148EE
   Part No SW: 5K0 920 860 G    HW: 5K0 920 860 G
   Component: KOMBI         H06 0206
   Coding: 170B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   VCID: 306561646B384CE
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 040609F2001019
   Coding: ED807F06000202000002
   VCID: 66C9C73C517CD2E
   Component: IMMO          H06 0206
   Serial number:
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2123
   Coding: 0000180
   VCID: 336F6E68522E776
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 70     2901
   Revision: 00H15000
   VCID: 2F676218BE06536
2 Faults Found:
            014 - Defective
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 143
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Battery Volts: 0.0 V
                        PD
                    Temperature: -70.0°C
                    Error Code: 0
                    Torque: 0.0 Nm
                    Torque: 0.000 Nm
                    RPM: 0 /min
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 0.00 V
                        PD
                    Count: 0
                    Count: 0
                    Count: 0
                    Count: 0
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Coding: 0000180
   VCID: 346D6D74572070E
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 156 B    HW: 1K0 035 156 B
   Component: Radio         509 0521
   Revision: R0509004    Serial number: VWZ5Z1I0096995
   Coding: 0000020002
   VCID: 22419B2C3DD4EEE
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
Masina merge normal, niciun martor aprins in bord, dar totusi la scanare apar aceste 2 erori. Am incercat sa le sterg, desigur ca au oparut imediat...
Din pacate nici pe google nu am gasit prea multe, desi mai sunt utilizatori de G6/Jetta care au aceata problema cu aceleasi simpotome, si anume ca masina functioneaza corect.
E vorba de un defect hardware sau  ar trebui resoftata caseta, sau ceva de genul.
O zi buna,
Alex.
Din cate am inteles aceasta eroare apare la masinile care au parcare automata, si inregistreaza eroarea daca in timpul parcarii intervine o eroare. (daca nu e asa imi cer scuze... nu sunt 100% sigur)
La mine asa s-a intamplat, in timp ce demonstram sistemul de parcare automat la un prieten, masina din fata a dat cu spatele si spatiul s-a facut mai mic... a aparut pe afisaj "System Error...bla bla bla"
Eu am reusit sa sterg cu "erase DTC" ... (sau cum se numeste...nu am VCDS momentan) din VCDS, si nu mai apare.
Aceasta masina nu are parcare automata, nici senzori de parcare macar...
Si nici nu a mers cu "erase all DTC" :( Am intrat si separat pe adresa 44 si am sters de acolo, acelasi rezultat.. apare la loc imediat eroarea.
sigur ca da - trebuie verificat si vazut de ce este incodat corect. Se reface codarea si va disparea eroarea.
El are alta eroare la modulul 44-Steering Assist -- Status: Malfunction 0010
Am vazut.... nu-i de bine.
Acum, am raspuns de o codare gresita pe CAN... dar cred ca am/s-au ametit postarile
