Alarma originala
al3xisos
Golf IV , an 2005 , motor AXR, modul comfort 1C0 959 799.Atasez si un scan mai vechi de-al meu!
VCDS Version: Release 908.0
Data version: 20090830
Monday,20,December,2010,12:20:45:63170
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: WVWZZZ1JZ5W036097 Mileage: 168920km/104962miles
Address 01: Engine Labels: 038-906-019-AXR.lbl
Part No: 038 906 019 KP
Component: 1,9l R4 EDC G000SG 4902
Coding: 00002
Shop #: WSC 01266
WVWZZZ1JZ5W036097 VWZ7Z0D0574754
No fault code found.
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Shop #: WSC 01266 785 00200
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 16 AIRBAG VW61 0108 0003
Coding: 12598
Shop #: WSC 01266
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 846 C
Component: KOMBI+WEGFAHRSP VDO V22
Coding: 18112
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01266
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799
Component: 1F Komfortgerát HLO 0002
Coding: 00259
Shop #: WSC 01266
Part No: 1C1959801A
Component: 1F Tõrsteuer.FS KLO 0202
Part No: 1C1959802A
Component: 1F Tõrsteuer.BF KLO 0202
Part No: 1C0959811A
Component: 1F Tõrsteuer.HL KLO 0202
Part No: 1C0959812A
Component: 1F Tõrsteuer.HR KLO 0202
Address 56: Radio Labels: 1J0-035-15x-56.lbl
Part No: 1J0 035 152 E
Component: Radio PHO 0003
Coding: 00001
Shop #: WSC 01063
End ---------------------------------------------------------------------
Nu are nimeni eaglemaster e8 pe masina?Este cam singura care sa nu depaseasca bugetul meu.
Viper 330V se activeaza din cheia masinii 550 lei la care se mai adauga daca doresti-senzor perimetru,senzor geam spart,senzor antiridicare sau indicator electroluminiscent ,senzori pe care alarma originala a masinii nu ii are.Am eu alarma originala din fabrica fix un c - - - t si a mai costat si destul de mult.
salutare am si eu o problema mica la bora inainte cand inchideam masina din telecomanda cheii (cheie briceag) si la inchidere si la deschidere palpaiau avariile de 2 ori la deschidere si 1 la inchidere astazi am observat ca la inchidere nu se mai aprind e putin aiurea pentru ca nu reusesc sa imi dau cu seama daca sa inchis sau nu trebuie sa ma apropii sa verific
precizez ca alarma este aia stas cu claxon multumesc
Modificat de mvcosmin
Claxonul (Beep-ul) se aude cand apesi sa se incuie masina? Daca nu se aprind nici avariile si nici beep-ul nu se aude ai lipituri reci in broasca si\sau switch-ul din portiera soferuilui e defect.
mai mult ca sigur..... si mai ales, daca semnalele se aprind la descuiat.
salut deci beepul nu sa auzit de cand am luat masina nu stiu daca are dar ieri si-a revenit clipeste di nou si la inchidere singura fara sa ii fac nimic dar nici un beep
Beep-ul nu se aude pentru ca nu este activat(Lock/Unlock Horn) Avariile si-au revenit doar pentru moment ca in viitorul apropiat vor face la fel.Ca nu ai scapat de problema.Lipituri reci in broasca si\sau switch-ul din portiera soferului e defect 100%
nu stiu daca fac bine ca scriu aici, daca as vrea si eu cheie briceag doar pentru incuierea/descuierea masinii in afara de cheia briceag mai am nevoie de ceva ?
La alarma originala din fab.este activat si beep-ul sau numai sa clipeasca avariile la inchidere-deschidere?eu cand am cumparato imi clipeau doar avarile.tare as vrea sa se auda si beep-ul.cum pot sa-l activez?
Modificat de radusb23
Daca ai comandat masina cu alarma, intri cu VCDS in 46 confort si la adaptari pui BEEP la inchis/deschis/
salut eu am un golf 4 cum vad daca am alarma sau ceva asemanator
asa face la mine la golf 4 da nu se aude beep cum ii dau drumul
incuie din telecomanda, cu geamul de la sofer lasat jos si deschide capota - daca switch-ul de la capota e bun si ai alarma, trebuie sa inceapa sa faca galagie.
salutare
dupa un an de la achizitionarea masinii ( G4 , variant )  , am constatat ca nu semnalizeaza la inchidere.am citit ca poate fi nush ce siguranta de sub bord.nu ma deranjat.dupa 3 luni de acest efect , am vazut cu stupoare nu numai ca face clip la inchidere , dar mai si merge goarna ( bip scurt ) .ok , am citit aici , are alarma de la mama ei.. .intrebarile mele sunt : 1 daca nu a mers si a apucat-o mersul , inseamna ca are vreun contact oxidat  ( daca da , unde ? ) ?
:  2 trebuie sa faca bip si la dezarmare ?
multam pt un raspuns ...
depinde ce si cum s-a activat ... adica, se poate activa sa faca la descuiat, incuiat sau amandoua.
nu iti luminau semnalele la inchidere, din cauza unei probleme la yale - switch sau lipituri reci. Acum, pt moment si-a revenit.... monitorizeaza problema.
salutare...a mers alarma 3 ore ( o zi de shoping prin oras..)..akm iara tace....am obs ca atunci knd ,mergea , mergeau si semnalizarile la armare...?
vreo idee in brasov unde as putea lamuri / rezolva problema asta ?
multumesc !
da, in Brasov vb cu Hremus - cauta-i nr la Prestari servicii.
Intrebare - la alarma originala fara senzori de volum (si implicit fara buton de dezactivare pe stalp) se pot monta senzorii doar (adica plafonierele spate cu senzori) ?
are cineva un pinout al alarmei care indica unde se leaga acei senzori?
Se pot monta si fara acel buton?
se pot monta si fara buton.... butonul ajuta la dezactivarea senzorilor, daca lasi pe cineva in masina dar vrei sa incui din telecomanda.
Pin out-ul....  in primul rand, posteaza PN-ul confortului tau
Senzorii - se leaga intre ei si la confort. Dupa aia, trebuie modificate cateva adrese in eeprom-ul modulului confort, ca sa mearga.
Deci technically speaking sunt plug-n-play. Butonul stiu ce face, teoretic inseamna ca se poate monta, pana gasesc buton oem si orice pus-button cu revenire. dar nu e musai.
Sa vad daca reusesc un pret ok la senzori - si apoi incep sa sap. Recunosc, nici nu am idee unde e modulul de confort, dar voi da fara probleme de el.
Multumesc de informatii, Florin
modulul la G4 este sub bord, in partea stanga la sofer.
salut.cum fac si eu sa se aprinda pozitia cand deschid masina.ma gandisem ceva de pe la plafoniera sau din alarma.se poate asa ceva?alarma o am originala.mai am o intrebare,in  panoul de sigurante am un buton care am vazut ca are 2 fire care nu mai sunt conectate cu nimic.stiti ceva ce sunt cu ele.
Modificat de miky2003adr
din alarma mai greu... din plafoniera - iar o sa fie ciudat - chiar daca faci un montaj pe baza semnalului de la plafoniera - s-ar aprinde pozitiile si ar sta aprinse atata timp cat ai plafonera aprinsa... sau usa deschisa.
asa cum ti-am mai zis, vb cu Bobby si cumpara un modul coming home - si o sa ai ce vrei tu.
