lancelott
Ca sa scot volanul de pe jetta am nevoie de vreo presa ceva, sau iese ușor dacă rezolv șurubul ala cu cheie spline M21?
Nu ai nevoie de nicio presa
F l o r i n
  On 14.05.2017 at 18:48, th3utz a scris:
Expand
cu mentiunea ca este M12 nu M21
Salut
Am cumparat modul coloana 5K0953569AH.
Nu vrea sa-mi ieie codarea pentru Steereing Angle Sensor G85.
5K0953569AH este inlocuitorul lui 5K0953569H, care este Highline si care apare pe tabel la Rosstech ca ar avea steering sensor.
Se poate face ceva?
Va trimit si advanced id, poate ma poate ajuta careva:
Wednesday,31,May,2017,20:30:21:49450
VCDS Version: Release 16.8.0
                Address 16: Steering wheel
Control Module Part Number: 5K0 953 521 DQ
  Component and/or Version: LENKS.MODUL   016 0140
           Software Coding: 1082140000
            Work Shop Code: WSC 00020
                      VCID: 7EF3949EE1365FB2D2-802A
Advanced Identification/FAZIT
     Serial number: 20140418300999
     Identification: ATW-001
     Revision: FF010042
     Date: 19.04.14
     Manufacturer number: P1TC
     Test stand number: 2800
Flash Status
     Programming Attempts(application): 1/1/1
     Successful Attempts(application): 1/1/1
     Programming Attempts(data): 0
     Successful Attempts(data): 0
     Programming Status: 00000000
     Flash Date: 10.06.01
     Flash Tool Code(data): 00000 000 00000
Software
     UDS: 00.00.01
     UDS: 12.07.00
     Theft prot.: 01.02.12
     Diag: 00.0E.01
     Diag: 00.09.00
     Generic Net Mgt: 04.07.01
     OSEK Net: 00.1E.03
     Unknown: 03.0C.00
     Generic Net Mgt: 04.07.03
     LIN 2.0: 00.00.02
     KWP2000: 07.04.00
     Generic Net Mgt: 02.04.06
Misc.
     Hardware number: 5K0 953 569 AH
     Workshop System Name: J527
     Equipment/PR Code: 3030303030303030
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset: EV_SMLSNGVOLWSXS
     ASAM Dataset Revision: A01004
VCDS Info:
       Labels: 5K0-953-569.clb
       ROD: EV_SMLSNGVOLWSXS.rod
Cum adica nu ia codarea?
Despre ce masina vorbim?
Ce coloana avea inainte?
Modificat de spido
E un Tiguan din 2014.
Cand incerc sa codez modulul cu Steereing Angle Sensor G85. zice coding not accepted.
Masina a iesit din fabrica cu modulul asta:
Wednesday,31,May,2017,22:10:15:49450
Control Module Part Number: 5K0 953 501 DE
  Component and/or Version: LENKS.MODUL   016 0162
           Software Coding: 5180040000
            Work Shop Code: WSC 01357
                      VCID: 70EFBAA6AB6239C250-8024
     Serial number: 20141210300331
     Revision: FF010042
     Date: 10.12.14
     Test stand number: 1986
Flash Status
     Programming Attempts(data): 0/0
     Successful Attempts(data): 0/0
     Flash Date: 11.09.02
Software
     UDS: 00.00.01
     UDS: 12.07.00
     Diag: 00.0E.01
     Diag: 00.09.00
     OSEK Net: 00.1E.03
     Unknown: 03.0C.00
     LIN 2.0: 00.00.02
     KWP2000: 07.04.00
Misc.
     Hardware number: 5K0 953 569 AM
     ASAM Dataset: EV_VW360SteerWheelUDS
     ASAM Dataset Revision: A03004
VCDS Info:
       ROD: EV_VW360SteerWheelUDS.rod
Se poate scoate capacul cu butoanele de volum, prev next track de pe volanul in 3 spite? Acum cateva zile nu mai puteam apasa pe vol down, acum merge - s-a deblocat insa s-a blocat cel de prev track.
As vrea sa il desfac fara sa il stric, poate stie cineva cum. Daca nu se poate, o sa cumpar un alt volan.
Se pot desface si curata.Au niste suruburi pe partea din spate..
@spidom-am uitat pe partea din spate a volanului in dreptul lor dar nu este nici un surub.. toata portiunea din spate este acoperita cu piele. nici in spatele capacului de airbag nu observ nimic. sau te referi la altceva cand spui pe spate? volanul e cel obisnuit, asa.
trebuie scos airbag-ul ca sa poti vedea suruburile de care zicea spido
Da,se scoate airbagul,se demonteaza comenzile din locasurile lor si pe spate au cateva suruburi micute..-se scot...apoi iese capacul,placa cu circuite si butoanele..se curata si se monteaza in ordine inversa.
salutare,
eu am comenzi volan pe golf dar am observat ca luminile nu se aprind, nu le-am vazut aprinse niciodata de cand am masina;  trebuie activate sau alta sa fie problema?
Sunt functionale?
Nu se pot activa separat..posibil o incompatibilitate coloana/comenzi.
Trebuie vazut ce volan ai,identificate coduri calculator volan si coloama.Daca ai cumva o scanare a masinii mi-o dai sa ma uit pe ea..si vedem ce se poate face.
  On 07.10.2017 at 18:08, imads a scris:
Expand
ti-am incercuit suruburile de fixare, in poza
  • 6 months later...
Salut, am un Golf 6 2011 trendline dar cu Xenon de fabrica, si cruise control. Calculatorul de coloana este 5K0953549B. Am montat un volan Golf 7 R. Intrebarea este, pot face adaptare cu vcds-ul sa imi functioneze comenzile de pe volan? Inainte masina nu avea comezi pe volan. Mersi.
Nu,nu merge cu Vcds...si nici cu alta interfata.Necesita modificari hardware.
Mersi. Credeam ca poti functionale, doar o parte.
  • 5 weeks later...
Salutare si aici :)
cum aflu daca senzorul g85 este pe coloana sau pe caseta?
Pe caseta la tine..
am gasit si volanul. Il cumpar complet, fiindca este model HL si il vand pe al meu la un pret mai mic....sa scap repede de el :)
Fiind masina sotiei, nu are nevoie de volan GTI sau R...cred ca este de passat, avand modulul de comenzi, in butoanele din partea stanga....astept poze cu detaliile astea in wknd
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 20 25 2B 2E 37 42 44 46 52 55
          56 62 72
VIN: WVWZZZ1KZBW156473   Mileage: 183480km-114009miles
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 BS    HW: 5K0 953 569 E
   Component: LENKS.MODUL   009 0136
   Revision: FF010038    Serial number: 20100927300573
   Coding: 5000140000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7EF348FAE1F773B46A-802A
No fault code found.
Cam asta am pe masina acum.
din ce am cautat, dupa cod, am gasit asa:
Part Number     Variant    Steering Angle Sensor       MFD      CCS/ACC       MFSW       AT
5K0-953-569-E  Highline              No                              Yes           Yes                Yes          Yes
am si confirmarea colegului spido ca este ce trebuie
Am adaugat si volanul...l-am codat si este perfect functional :)
a trebuit sa anulez comenzile de pe maneta de stergatoare, ca sa functioneze corect.
Multumesc tuturor pentru ajutor!
Va salut, de curand am inlocuit si eu volanul de plastic cu unul de piele de pe Polo 6R (cod 6R0419091F). Acest volan are comenzi doar pe partea stanga (cod comenzi 6R0419685G, comenzi stanga+capac dreapta).
As dori sa montez si comenzile din partea dreapta. Imi poate confirma cineva daca se potriveste piesa cu codul 5C0959538B ? Comenzile de pe stanga sunt compatibile cu calculatorul de comenzi de Golf 6 sau trebuie inlocuite si acestea? Volanul a venit cu calculator cod 5K0959542C.
Mersi.
1304012d1414639988-vw-polo-steering-chan
Modificat de vwmkv
  • R_a_z_v_a_n changed the title to Retrofit MFSW pe Jetta MK6 facelift 2015+ PQ35
  • loghy locked şi pinned this topic
  • loghy unlocked şi locked this topic
  • loghy a deschis acest topic
