Probleme servodirecție electromecanica
kalu
andrei_221
da-i pace, asa va ramane eroarea, dar nu te afecteaza.
e din cauza unor diferente de soft intre caseta noua si masina.
Nu afecteaza functionarea.
@Stefan91, mergi la service si pune-i sa rezolve, ai platit toata operatiunea, n-a fost gratis, sigur exista solutie, daca nu, sa deschida ticket la fabrica.
Se rezolva din adaptari in ABS sau caseta
Salutari, un ajutor daca se poate va rog. Din senin mi s-a aprins becul rosu la volan. iar din cand in cand clipeste galben pentru 1 secunda. Mecanicul a zis direct caseta de directie, parca n-as crede ca asa deodata a picat. Am verificat mufa ovala cu 6 pini ovala de sub filtru de aer, pare in regula cablurile in zona aia. Am pus tester propriu si mi-a afisat urmatoarele erori :
Citat:
Saturday,04,October,2025,15:35:53:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.4.2.0 (x64)
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ1KZ7M039676   License Plate:
Mileage: 375030km-233032mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ7M039676   Mileage: 375030km-233032miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 1010
7D-Aux. Heat -- Status: OK 0000
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 043     HW: 02E 927 770 AE
   Component: GSG DSG         070 1106
   Revision: 04507000    Serial number: 00000606300584
   Coding: 0000020
   Shop #: WSC 00066 000 00000
   VCID: 51A32886C8E9330ECC-8004
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0021121
   VCID: 73EF820E12B5211E1E-8026
01309 - Power Steering Control Module (J500)
            004 - No Signal/Communication
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000000441592
   Coding: F5010E0700041000470A00000F00000041395D03410000
   Shop #: WSC 80093 222 69422
   VCID: 3777761E464D8D3EE2-8062
   Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 310806 020  0501
   Coding: 00038805
   Shop #: WSC 80093
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     130606 014  1201
   Coding: 00208933
   Shop #: WSC 80093
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 247
                    Mileage: 375030 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0012001
   VCID: 77F7B61E06CD4D3E22-8022
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K0 920 873 B    HW: 1K0 920 873 B
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0F4592064
   Coding: 0016103
   VCID: 2B5F5A6E8A0539DE96-807E
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 10
                    Reset counter: 247
                    Mileage: 375030 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:37:06
Address 19: CAN Gateway        Labels:. 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001067041097
   Coding: 3F3F0B4007001002
   Shop #: WSC 00066 123 12345
   VCID: 2C5D59728F0B3EE69F-8078
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 247
                    Mileage: 375030 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:37:07
Address 44: Steering Assist
Cannot be reached
End-------------------------(Elapsed Time: 02:06)--------------------------
Modificat de hydr0xygen
caseta sau firel;e ce merg la ea. Lipsa alimentare, sau can
Am dezactivat din can gateway - 44- steering assist, a disparut eroare, dar a ramas cea de abs, cu aceeasi cod 01309 - Power Steering Control Module (J500) , deci ma gandeam ca poate a cazut vreun modul mai important. Sigurantele le-am verificat pe cele de la motor + cele 6 sau 7 de amperaj mare si cele de langa volan. Orice as activa sau dezactiva asta tot ramane 44-Steering Assist -- Status: Cannot be reached 1100. Am mai verificat si mufa de pe contact.
faptul ca ai dezactivat din gateway, e o prostie.
Caseta nu mai functioneaza / comunica cu gateway . Nu te mai agita cu atatea verificari dupa ureche, ca nu te ajuta sa depistezi problema.
Refa codarile si du-te la mecanic sa verifici rapid firele de pe caseta.
Mufa cu 2 fire groase (+ si -) permanent
mufa cu 3 fire subtiri : plus pe contact, si cele 2 de fire de CAN.
Si da, asa dintr-o data se strica casetele. Nu e prima caseta electrica care se strica...
Multumesc. Pentru mine a fost cam sec raspunsul, doar din faptul ca s-a aprins un bec rosu, dupa ce ieri mi-a schimbat tamponul motor de pe partea soferului. Voi cauta un electrician sa-mi verifice cablajele.
S-au verificat alimentarile, ajunge curent la caseta a zis electricianul. Volanul merge usor chiar si fara contactul pus, dupa care se face putin rigid ; cand pun contactul deja se misca usor. Dar tot nu revine pe pozitie dupa un viraj. Am vorbit si la reconditionari, RTM Service Iasi, mi-au zis ca nu e normal, am mai reconditionat-o acum 3 ani la ei.
Astea sunt erorile care au aparut in urma aprinderii becului rosu.
Ca si concluzie, am fost astazi la reconditionat caseta, dupa ce am vorbit ieri si mi-a comunicat ca se poate face atat mecanic cat si electronic, dupa demontare s-a pus o alta caseta identica pentru proba, gata reconditionata cred, si tot nu a functionat, tot rosu becul, dupa cateva masuratori s-a schimbat cablajul si a aparut galben. A ramas acea caseta, a mea mi-a zis ca este in scurt; iar pe manunchiul ala gros de fire era un fir intrerupt. Total manopera 1.800 de lei fara tva.
pai normal, doar nu era sa pleci de acolo fara caseta 😁
Cu detaliile suplimentare date de tine (volanul mergea relativ usor, deci aveai asistenta) = firele de putere OK
- ramaneau firele de CAN ( ca si truc, se pot scurtcircuita intre ele cu contactul pus si primesti niste bipuri speriate de la ceasurle de bord, plus erori pe multe module) si firul de plus contact.. care se masoara clasic cu lampa de test...
daca au schimbat si cablajul.. ( care cablaj.. nu stim, ca nu ne spui) si pe urma a mers caseta... as zice ca.... problema era din acel cablaj...
Cablajul cu multe fire, o parte cuprinde cele 2 mufe de pe caseta iar in cealalta e mufa ovala cu 6 pini, un cablu care duce la impamantare si unul la siguranga mare din fata tabloului de sigurante, iar undeva sub baterie se intalnesc aceste cabluri intr-un manunchi mai gros, unde se vedea 1 singur fir intrerupt. Iar volanul mergea usor si fara contactul pus, doar deblocat fiind.
Sfaturile tale cu masuratul firelor a fost util, pacat ca n-am gasit electricianul potrivit.
DA, ai schimbat caseta degeaba.
