Emission Workshop aprins - limitare pedala acceleratie.
Cretul
asta este inainte sa desfac toate cele:
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Control Module Part Number: 03G 906 021 LB HW: 03G 906 021 AN
Component and/or Version: R4 1,9L EDC G000SG 9251
Software Coding: 0050071
Work Shop Code: WSC 73430 790 00000
VCID: 6AD0475E3C17
4 Faults Found:
000258 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Mileage: 71436 km
Time Indication: 0
Date: 2000.00.00
Time: 11:32:44
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 95.1 %
Bin. Bits: 00101100
Mass Air / Rev.: 240.0 mg/str
Mass Air / Rev.: 0.0 mg/str
000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 71441 km
Time Indication: 0
Date: 2000.00.00
Time: 11:47:00
Freeze Frame:
RPM: 2856 /min
Speed: 101.0 km/h
Load: 100.0 %
Voltage: 14.67 V
Bin. Bits: 00101000
Absolute Pres.: 2029.8 mbar
Absolute Pres.: 2529.6 mbar
012545 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
P3101 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 71443 km
Time Indication: 0
Date: 2000.00.00
Time: 12:02:43
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00101000
Torque: 158.6 Nm
Torque: 0.0 Nm
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 71443 km
Time Indication: 0
Date: 2000.00.00
Time: 12:02:43
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00101000
Torque: 158.6 Nm
Torque: 0.0 Nm
Readiness: 1 1 0 0 0
Thursday,30,December,2010,17:22:38:60804
VCDS Version: Release 10.6.0 (x64)
Data version: 20100630
VCID: 6AD0475E3C17
P0234 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 71533 km
Time Indication: 0
Date: 2000.00.00
Time: 17:15:04
Freeze Frame:
RPM: 3780 /min
Speed: 133.0 km/h
Load: 100.0 %
Voltage: 14.29 V
Bin. Bits: 00101000
Absolute Pres.: 2019.6 mbar
Absolute Pres.: 2325.6 mbar
Readiness: 0 0 0 0 1
Thursday,30,December,2010,17:30:09:60804
Address 01: Engine Labels: 03G-906-016-BKC.LBL
VCID: 6AD0475E3C17
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 71533 km
Time Indication: 0
Date: 2000.00.00
Time: 17:15:04
Freeze Frame:
RPM: 3780 /min
Speed: 133.0 km/h
Load: 100.0 %
Voltage: 14.29 V
Bin. Bits: 00101000
Specific ca mecanicul care a desfacut masina( ca nu lasam pe oricine sa-si bage nasul), a reparat: iveco, renault, peugeot,ford, mercedes(firma unde lucrez este una de distributie, firma avand peste 200 de auto atat mari cat si mici)
Modificat de dany08
Debitmetrul sper sa nu gresesc este scos si apoi ai plecat cu ea sa vezi daca face la fel cu el fara , avad in vedere km si turatia de relanti la care apare.
Eu cred ca face asa d ela comanda turbo acuma trebuie verificat sau incercat cu una de la un prieten.
Uite ce spune pe ross tech despre erorile tale.
Este important este de verificat daca nu sunt cumva sunt inversate furtunasele daca iti aduci aminte ca a umblat vreunu pe acolo cauta un posesor de o2 cu motorul tau la intalnirea din bucuresti si vezi cum sunt puse ca e usor.
Trebuie verificat daca si face treaba comanda turbo, are 2 fire si 2 furtunase.
Asta daca ma iau dupa ce ai spus egr bun lucreaza , turbo bun geometrie variabila nu se blocheaza si merge ok , capsula de pe turbo nu e sparta si merge ok, cu toate ca trebuia sa dea alta eroare atunci.
Possible Causes
Hoses incorrect connected, disconnected, blocked or leaking
Malfunction N75
Possible Solutions
Check charge pressure control
Check Solenoid Valve for Boost Pressure Control (N75)
Salut si merci,
Debitmetru nu era scos iar la cele 6 furtune care sunt pe vacum nu a umblat nimeni daca la ele te referi! Furtunele de la turbi le-am verificat.
Proba la capsula care deschide turbo am facut-o prin "sugerea" din furtunul care plimba tija din partea opusa. Acum nu stiu daca la o presiune mare ea sa faca alte probleme, egr era putin murdar dar nu excesiv, turbo mergeau mai greu "cili" aia dar nu erau blocati.
Deci parerea ta este sa incerc sa schimb si sensorul N75?
Modificat de dany08
nicureddogsflo
mi s-a aprins si mie si mi-a aparut mesajul pe maxi-dot emmision workshop in mers ,mentionez ca masina trage bine merge si cu 140km/h si chiar mai mult , mentionez ca motorul este 1,9 tdi BJB .
aveti vreo idee pentru ca nu sunt in bucuresti sunt plecat la mare ,se poate intimpla ceva pina ajung inapoi acasa ca sa fac o diagnoza.
sugesti ce sa veific va rog.
Nu stiu ce e cu martorul asta un lucru e sigur la mine se aprinde si se stinge cand vrea muschiul lui.
Masina merge OK.Prima data cand mi s-a aprins (acum vreo 2 ani) m-am dus imediat la service, au sters eroarea din memorie si aia a fost tot.Acum iar face figuri.Nici nu-mi mai bat capul cu el.Cand o sa ajung in service (de fapt am ajuns pt. revizie dar n-au avut timp si de problema asta) cu prima ocazie o sa fac o diagnoza dar cred ca iarasi e vorba de o eroare care trebuie stearsa si atat.
Salutare la toata lumea! Sunt posesorul unei O2 an de fabricatie 2007 si am experimentat si eu timp de o luna si inca mai experimentez aceasta problema cu "Emissions Workshop" si lipsa de reactie a masinii la apasarea pedalei de acceleratie practic motorul nu se tureaza mai mult de 2500 rpm. Am citit mai multe forumuri si mai toti spuneau ca ar fi valva EGR, drept urmare am demontat-o si am curatat-o vreau sa va zic ca era super imbacsita de funingine amestecata cu ulei; in acelasi timp am curatat si galeria de admisie si throttle-ul care erau in aceiasi conditie. Am ansamblat totul la loc si am plecat la drum totul foarte bine masina reactiona super bine si la un moment dat becul martorului s-a stins. La o saptamana am iesit cu masina pe autostrada si sa dau talpa cand surpriza motorul a intrat iar in Limp Mode ceea ce m-a enervat la culme, am oprit-o am deconectat mufa de la debitmetrul de aer si am plecat inapoi pe autostrada si da-i pedala totul perfect masina reactiona bine. Ajuns acasa primul lucru pe care l-am facut: am comandat un debitmetru de aer nou crezand ca asta va rezolva problema. Cateva ore mai tarziu a trebuit sa plec iar cand am pus contactul beep, beep si Emission Workshop am simtit ca innebunesc. A doua zi am dus-o la tester sa vad ce poate diagnostica testerul si mi-au dat urmatoarele:
*Mass or volume Air Flow Circuit "A"-low input
*Fuel temperature Sensor A circuit high input
*Turbo Supercharger overboost
*Intake Flap Motor V157 open circuit/short circuit to ground
*Intake Flap Motor V157 No signal
Poate cineva sa imidea o idee ce poate cauza aceste manifestari ale masinii si ce ar trebui sa mai schimb la ea. Dupa ce am strers erorile din ECU am plecat la drum si dupa 2-3 km de pedala motorul iar a intrat in Limp Mode, m-am intors inapoi la garaj sa o pun iar pe tester sa vad ce erori ar putea aparea din nou, din toate cele enumerate mai sus doar una a aparut din nou : Turbo supercharger overboost.....????
Te rog daca reusesti sa depistezi ce anume e in neregula cu masina ta si ce trebuie sa schimbi la ea sa ma anunti si pe mine ca aceiasi citire mi-a iesit si mie pe tester ca si la tine si nu reusesc sa ii dau de cap. Multam mult.
Geometrie variabile, lipsa vacuum sau bloc electrovalve dus.
scaneaza si tu masina cu un VCDS sa vedem si conditiile cand a aparut eroarea.
Modificat de Al Bundy
Nu te supara pe mine da m-ai pierdut cu VCDS poti fi mai explicit daca nu e deranj. Apropos inca astept sa imi vina debitmetrul de aer sa il montez dar nu cred ca va fi vreo modificare in comportament banuiesc.
VCDS (fost vag-com) scula de diagnoza dedicata grupului VAG.
Multam mult de informatie. Am sa incerc si cu VCDS sa vad ce alte erori mi-ar putea citi.
Dupa ce spui acolo, trebuie investigat un pic, du-o la service nu mai merge cu ea asa, tocmai ce am gasit o octavia 2 cu turbo care nu lucra de aproape 1 an jumate zicea baiatul respectiv, au curatat unii turbo si au zis ca e ok, au mers cu ea in probe, a luat-o pe ulei pentru ca intercoolerul era plin de ulei din cauza nefunctionarii geometriei variabile si deci nu facea presiune turbo, uleiul de pe traseu s-a acumulat in intercooler.Trebuia verificat sau mers putin cu ea cu furtunul de la intercooler scos sa scuipe uleiul nu sa il suga turbo dar na...
Rezultat in mare: piston, biela, turbo, chiulasa, etc..Se va pune motor nou .
La tine poate fi si un furtunas scos, crapat dar totusi cred ca e de demontat turbo.
salve daca scoti borna - de la baterie pentru 15 min ce-o fi???si vezi a 2-zi cum merge :offtopic:
Salutare tuturor,
Ieri in urma unui drum de aproximativ 100 km, mi s-a aprins martorul de la bujii in mers, intermitent, in timpul regenerarii DPF-ului.
Dupa ce am facut o scanare cu VCDS-ul me-a aparut aceasta eroare:
7335-Mass Air Flow during Regeneration too High
P145F 00 [096]-Short to Ground
Freeze Frame:
Fault Status:00000001
Fault Priority:2
Fault Frequency:1
Mileage:27450 km
Cod luat din controlerul motorului
Mentionez ca dupa ce am oprit si am pornit masina martorul s-a stins.
Masina mea [O2 1.9 TDi] are fix 40k km si mi-a aparut emission workshop in bord.
Mi-a scanat-o un prieten cu vcds si se pare ca e de la EGR (o sa fac rost si de raport), dar masina trage si nu e limitata la o anumita turatie.
Intrebarea ar fi daca e normal/relativ des intalnit pentru numarul de km pe care il am. In general merg sportiv tocmai sa nu acumulez fumingine.
Control Module Part Number: 03G 906 021 TB HW: 03G 906 021 AN
Component and/or Version: R4 1,9l EDC G000SG 2047
Work Shop Code: WSC 10165 599 74373
001025 - EGR System: Insufficient Flow
P0401 - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 39993 km
Time Indication: 0
Date: 2000.00.00
Time: 14:32:59
Freeze Frame:
RPM: 1827 /min
Speed: 46.0 km/h
Load: 24.3 %
Duty Cycle: 14.6 %
Duty Cycle: 100.2 %
Mass Air / Rev.: 235.0 mg/str
Mass Air / Rev.: 535.0 mg/str
e intalnit....si la B6. Probleme la EGR.
16785/P0401/001025 - Exhaust Gas Recirculation (EGR) System: Insufficient Flow Detected
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
  • Reduced Exhaust Gas Recirculation (EGR)
  • Reduced Power Output/Engine running rough
  • Increased Emissions
Possible Causes
  • Exhaust Gas Recirculation (EGR) Flow restricted/clogged
  • Exhaust Gas Recirculation (EGR) Valve stuck closed/leaking/faulty
  • Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve faulty
  • Exhaust Gas Recirculation (EGR) System faulty
Possible Solutions
  • Check/Clean Exhaust Gas Recirculation (EGR) System
  • Check/Replace Exhaust Gas Recirculation (EGR) Valve
  • Check Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve
Fratilor eu am rezolvat problema cu Emission Workshop si pedala limitata, foarte simplu, am schimbat debitmetrul de aer si de atunci masina este OK.
O cauza foarte frecventa la supapa EGR este ruperea membranei care o actioneaza. Membrana se poate verifica relativ usor. EGR este dispus cf sagetii rosii post-42726-0-64503500-1317738963_thumb.j. Se scoate furtunul de vacuum care intra in "ciuperca metalica" (sageata rosie)post-42726-0-63615300-1317738983_thumb.j, se introduce un furtun mai scurt astfel incat sa ajungem cu gura la el si se trage / sufla aer. Daca se poate trage / sufla aer, atunci membrana e rupta, iar variantele sunt urmatoarele: 1. Se schimba supapa EGR (aprox 500 lei), fie se anuleaza supapa EGR (dar asta implica mai multe).
Pe masura ce trece timpul, vad din ce in ce mai multe scanari facute cu CLONE si care dau erori care nu au ce cauta pe anumite masini.
De exemplu, in scanarile de mai sus, pe motorul BXE NU exista Coolant pump for intercooler si nici boost senzor 2, deci ultimele 3 erori de pe motor nu au ce cauta acolo.
In scanarea 2 iar nu are ce cauta eroarea 2 acolo.
DAca celelalte erori sunt corecte, atunci trebuie schimbat senzorul de temp si presiune de pe conducta dintre turbina si intercooler.
DECI , ATENTIE ce interfete CLONA folositi.
Am schimbat senzorul ala, dar nu e nici o schimbare.
Eu ce am zis mai inainte.... posteaza un scan al masinii cu o interfata BUNA.
Pfai, asta am zis si eu cand am vazut erorile. Am stat vreo 15-20 de secunde gura casca sa-mi revin, nu-mi venea sa cred ce citesc.
Omule, ce senzor ai schimbat?
Te-ai uitat si tu in canalul 11 sa vezi ce presiune iti cere calculatorul de motor si cat iti debiteaza turbina? Eu am vaga impresie ca ai geometria la turbo intepenita sau ... spre intepenire. Cel putin asa judec eu incercand sa folosesc ceva bun din erorile alea alan-dala.
  • 9 months later...
salut baietzi.....am urmarit si eu acest topic ca m-am regasit in problema asta...Limitarea pedalei de acceleratie dupa 90 km/h......aceasta problema am avuto la 2 Skoda...Skoda octavia 2 2L..140 cp..an 2007....si Skoda Superb 2L...140 Cp..2008
Sa incepem cu Skoda octavia2 am pus-o prima oara pe un tester la un service autorizat dar nu stiu ce tester aveau aia...si mi-au gasit Eroare de Presiune..si mi-au dat o gramada de variante..EGR..furtun murdar/spart..ETC...am inceput cu EGR...era curat...apoi am incercat alt service cu un tester mai performant si mecanic mai bun....mi-a testat masina in mers cu testerul pornit si a depistat ca turbina nu lucreaza cum trebuie am demontat turbina si intradevar era foarte murdara mi-a zis ceva de geometria gazelor...masina este foarte ok acum...la Skoda superb murea pedala de acceleratie in viteze mici...si mi-a gasit un senzor legat de vacum..care se afla deasupra motorului ....mentionez ca masina mea OC 2 nu a fost folosita cam 4 luni...si am si alimentat cu combustibil din port....sper sa va ajute cu ceva acest reply
Modificat de Gihan
La o O2 BXE mi-a aparut eroarea asta
16621/P0237/000567 - Manifold Pressure / Boost Sensor (G31): Signal too Low
S-a schimbat MAP-ul si a ramas eroarea. Pe ross tech imi indica verificarea a Manifold Pressure / Boost Sensor (G31) Power Supply faulty. Care este acesta? Merci
