Erori nedocumentate
diaconuliviu
Polo 9N 1,9 l SDI. S-a oprit si am citit cu Vag com 409.1:
VAG-COM Version: Release 409.1-S
Control Module Part Number: 038 906 012 HL
Component and/or Version: 1,9l R4 EDC 0000SG 4892
Software Coding: 00002
Work Shop Code: WSC 00788
Additional Info: WVWZZZ9NZ5Y056025 VWZ7Z0D9883659
5 Faults Found:
18027 - Unknown Error Code
P1619 - 35-10 - Unknown Error Elaboration - Intermittent
17946 - Unknown Error Code
P1538 - 35-10 - Unknown Error Elaboration - Intermittent
19557 - Unknown Error Code
P3101 - 35-10 - Unknown Error Elaboration - Intermittent
17849 - Unknown Error Code
P1441 - 35-10 - Unknown Error Elaboration - Intermittent
17660 - Unknown Error Code
P1252 - 35-10 - Unknown Error Elaboration - Intermittent
Le-am sters, a pornit, am facut o tura masurind diversi parametri care erau in limite, dupa care am citit din cele 5, 4 coduri:
4 Faults Found:
P1538 - 35-00 - Unknown Error Elaboration
P3101 - 35-00 - Unknown Error Elaboration
P1441 - 35-00 - Unknown Error Elaboration
P1619 - 35-00 - Unknown Error Elaboration
Am dedus ca eroarea care face motorul sa nu porneasca ar fi
Ma poate ajuta cineva?
Va multumesc...
18027/P1619/005657 - Glow Plug Relay (J52): Open or Short to Ground
Possible Symptoms
Glow Plug Relay (J52) faulty
Possible Solutions
Check Glow Plug Relay (J52)
Perform Output Test
asta am reusit sa o gasesc numai
incearca sa citesti cu o interfata mai noua
Am gasit aici:
http://www.obd-codes.com/trouble_codes/volkswagen/
P1441 EGR Vacuum Regulator Solenoid Valve Open/Short To Ground
P1538 Fuel Cut-off Valve Open/Short To Ground
P1619 Glow Plug Relay Open/Short To Ground
P1252 Start Of Cold Start Injector Open/Short To Ground
Ramine P3101 si...interpretarea caree cea mai grea...
@RRS: e singura interfata pe care o am... din citi au mai citit erorile cu interfete mai destepte, doar au sters erorile si atit...ca atare, ma gindesc ca mai degraba aici gasesc un raspuns mai corect..
Modificat de diaconuliviu
19559/P3103 - Motor for Intake Manifold Flap (V157), Malfunction
Verifica siguranta SB14 de 10A.
Toate electrovalvele la care apar erori sunt pe aceasta siguranta.
Sa dai un semn daca siguranta era de vina.
Modificat de Al Bundy
am gasit-o, e buna...
Apoi, ai gasit 3103, la mine e 3101
Da mai multe detalii, an fabricatie tip motor. Ce alte simptome mai are?
Polo 1,9 SDI, 2005. Asa numitul "Polo editia de vara"....
In mers, dai sa accelerezi, incepe sa se reduca turatia. daca mentii acceleratia turatia scade, pierde puterea, daca reduci pedala, motorul se opreste. Dupa racire UNEORI mai porneste, de cele mai multe ori nu.
Masina are filtru sport conic, iar evacuarea e teava intre catalizator si finala.
Din siguranta de 10A apar 3101, 1441 si 1252 daca o scoti. Motorul nu se opreste.
Din sig nr 40 (de 30 A) s-a oprit. O data s-a aprins dupa pornire becul "exhaust", de doua ori nu.
O schema electrica se gaseste?
S-au verificat si curatat mufele, inclusiv mufa ECU.
Sa vedem comportamentul in timp.
Conform "Vivid" acea siguranta de 30 A trebuia sa fie de 10A..e vorba de sig. 40.
S-a ajuns la concluzia "ECU defect, te costa 250 euro reparatia lui".
E corect pretul sau..se mai poate negocia?
