Tunning Passat CC
R_a_z_v_a_n
  On 30.05.2014 at 6:05, F l o r i n a scris:
Trebuie sa faci o scanare, sa vedem ce componente ai acum pe masina - si sa vedem daca sunt compatibile cu asa ceva.
pentru documentare http://jimmy-cbx.blogspot.sg/p/tire-pressure-monitoring.html
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QC    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  6208
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 83968 026 591431
   VCID: 76E9977C01DC22E
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000786344257
   Coding: 0000274
   Shop #: WSC 05311 000 00000
   VCID: 2B5F76088A1E2F6
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 AN    HW: 5K0 907 044 AN
   Component: Climatronic   130 0303
   Revision: 00002001
   Coding: 0000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_Climatronic_VW46.rod
   VCID: 77F79A78CED65B6
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 F    HW: 3C8 937 049 F
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000009001412
   Coding: E7E28F8B00041A0047978F0017000000000FFB4764400165170000000000
   Shop #: WSC 05124 000 08193
   VCID: 346D6D74572070E
   Subsystem 1 - Part No: 3C8 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 151008 022  0602
   Coding: 00046997
   Shop #: WSC 05124
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     061108 054  0402
   Coding: 00209133
   Shop #: WSC 05124
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 3C8 919 475     HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0007
   Revision: --------    Serial number: 97540830906924
   Coding: 100001
   Shop #: WSC 05314 000 00000
   VCID: F1E3246028B2856
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
   Component: J234__304 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPMJCDQD
   Coding: 0012340
   VCID: 3B7F46487A7EBF6
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AK    HW: 3C0 953 549 AK
   Component: J0527               0030
   Revision: 00032000    Serial number: 3C5953507CP
   Coding: 0000711
   VCID: 75EB90701CDA296
   Subsystem 1 - Part No: 3C8 959 537 B
   Component: E221__MFL-TAP   H4ÿ 0021
   Coding: 00000226
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 870 C    HW: 3C8 920 870 C
   Component: KOMBI         H04 Y107
   Serial number: 00000000000000
   Coding: 140F00
   Shop #: WSC 05311 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
   VCID: 2B5F7608421E2F6
Address 19: CAN Gateway        Labels: 3C0-907-530.lbl
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P08A240011
   Coding: F9A17F07500602009002
   VCID: 2A51730C85E436E
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433 AM    HW: 3C0 959 433 AM
   Component:    IMMO         052 0383
   Revision: 00052000    Serial number: VWZCZ000000000
   Shop #: WSC 46612 133 99611
   Part No: 3C0 905 861 J
   Component:    ELV          029 0380
   3C0905861J     ELV          029 0380
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 B    HW: 1T0 035 680 B
   Component: RNS-MID       H03 1200
   Revision: AB001001    Serial number: VWZ6Z7H4311131
   Coding: 04010000010000A200
   Shop #: WSC 20346 133 96313
   ASAM Dataset: ------------------------- ------
   VCID: 2D5B7810740A216
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1533
   Revision: 71009005    Serial number: 00000791088917
   Coding: 0004351
   VCID: 408531A41398DCE
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.075 0502
   Revision: 1AH02240    Serial number: 00082050114902
   Coding: 0000258
   Shop #: WSC 20346 133 174564
   VCID: 39735C4070428D6
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 RDK 052 0412
   Coding: 00910A0001860E763604941570084F0B605C01
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No: 5K0 035 456
   Component: KonzernAmp 8K H06 0316
   Revision: --------    Serial number: BP218187344138
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst8KanalBNO2.rod
   VCID: E7D74A381E764B6
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1533
   Revision: 71009005    Serial number: 00000771488928
   Coding: 0004350
   VCID: 418334A01892D56
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000363998
   Coding: 0021057
   VCID: 336F6E68522E776
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0136
   Revision: 00H04000    Serial number:
   Coding: 3490952
   Subsystem 1 - Part No: 1K0 941 329
   Component: AFS-Lst.-Modul l    0003
   Coding: 00000053
   Subsystem 2 - Part No: 1K0 941 329
   Component: AFS-Lst.-Modul r    0003
   Coding: 00000053
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
   Component: J388   TUER-SG HL   0309
   Revision: 43004101    Serial number: 00000000688049
   Coding: 0000152
   VCID: 31636460A832456
Address 65: Tire Pressure        Labels: 3C0-959-433-65.lbl
   Component:    RDK              0453
   Coding: 0161211
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
   Component: J388   TUER-SG HR   0309
   Revision: 43004101    Serial number: 00000000660687
   Coding: 0000152
   VCID: 32616B6CAD347EE
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 5N0 035 730 B    HW: 5N0 035 730 B
   Component: J412                8502
   Revision: 00015000    Serial number: 0000B7A119890
   Coding: 0010045
   VCID: 27578A3896F60B6
End   ---------------------------------------------------------------------
  On 31.05.2014 at 6:26, CristianMarin a scris:
Uite aici cum se face retrofit-ul.
http://bronken.de/b7rdk/
Eu am sistemul pe masina, dar nu stiu ce imi trebuie ca sa pot vedea pe display presiunea rotilor.
CristianMarin
Si eu il am. Iti trebuie ce gasesti in link. Inclusiv alte emitatoare in roti care transmit si sensul de rotatie, pentru stanga/dreapta. De asemena, receptorul care se afla in bara din spate. Asta ca sa faca diferenta intre fata si spate. In functie de puterea semnalului. Totul dupa ce schimbi CAN-ul si cluster-ul. Prea mare "deranjul".
Modificat de CristianMarin
  On 31.05.2014 at 16:10, CristianMarin a scris:
Multumesc. M-am "dezumflat".
hallucinogen
Doar cele 2 "radare" + oglinzi + cablaje costa cam 2000 / 2500 RON fara transport la care mai adaugi si manopera
CristianMarin
Ma rog, noi vorbeam de monitorizarea presiunii in cauciucuri...
hallucinogen
Sorry - am postat greșit. Ce am scris eu este pentru side assist. Pentru TPMS cam tot pe acolo duce - sunt scumpi senzorii care se pun pe valva jantei.
CristianMarin
Problema e ca trebuie schimbat si CAN-ul + cluster si la side assist. Si am citit ca sunt probleme cu keyless-ul si imobilizatorul
  On 02.06.2014 at 14:02, CristianMarin a scris:
Apropo de keyless, e dificil un retrofit cu sistemul KESSY?
La o prima trecere in revista  :
- manere usi + unul in spoiler;
- 2 senzori interior cabina + unul in portbagaj(detectie e cheii in habitaclu);
- chei compatibile Kessy.
Nu am gasit nicaieri un kit pentru retrofit.
Modificat de AlexutuS
Modulul, plus scrierea cheilor noi in immo, etc
Si ca sa nu mai spun de toate cablurile noi care trebuie trase prin toata masina :)
asta e cea mai mica problema.... de meritat - sincer nu cred ca merita.... costurile finale fiind mari...
Am uitat ce era mai importatnt: modulul electronic de blocare a coloanei de directie.
Am eu asa ceva pe masina din semnatura si nu prea il folosesc inchiderea si deschiderea la usi doar cateodata, ce este folositor la sisyem ca nu trebuie a mai bagi cheia in contact. Se gasesc sisteme complete pe ebay dar scumpe si trebuie desfacuta jumate de masina
La achizitionarea masinii, chiar am vrut sa aibe acest sistem "Kessy key". In prezent cheia o tin ca un brelog, intr-o husa din piele, astfel protejand-o de apa, scapari, zgarieturi, etc, iar deschiderea, pornirea, inchiderea masinii, cat si deschiderea portbagajului, le fac fara a mai scoate cheia din buzunar. Jumatate de an, nu am mai putut deschide portbagajul de la semn, ci doar din cheie, si din portiera, pana mi-am facut timp si I-am gasit buba. In tot acest timp trebuia sa las tot din mana, si sa caut cheile prin buzunar pentru a deschide portbagajul. Din pacate, nu am acel sistem cu trecerea piciorului pe sub bara :) Oricum, mi se pare la indemana sistemul
da, se poate face retrofit si la acela....
kessy - imi pare foarte util....practic - dar scump - cel putin sa montezi tot sistemul, cap-coada - te costa foarte mult.
 salut... a facut cineva remmaping la motorul 1.8TSI?
Modificat de GP-05-GB
  On 23.05.2014 at 11:07, cristi511 a scris:
Ultimul off topic:
@ gabi: daca tu reusesti sa pui bec xenon pe masina fara instalatia aferenta...eu o sa mi dau palaria jos in fata ta.
Sunt un milion de masini cu instalatie xenon...
1% din ele o au din fabrica..restul le au care si cum au nimerit..cu lupa sau fara, cu autoleveling sau fara :)
Nu stiu cum sa zic, dar eu pe fosta masina ( E90 FL ) am avut faruri dayline montate de mine si dupa vanzare, noul proprietar a trecut RAR-ul cu acele faruri.
Afirmatia mea inca ramane in picioare. Nu stiu sa poti pune bec cu descarcare in gaze rare ( xenon) pe instalatia de halogen, fara balasti/drosere ( cu le spune la unitatile declansatoare) samd.
Exemplul dat de Nighty e egal cu 0. Asa si ce daca sunt multi cu xenon aftermarket neomologat? Stim cum se ia RAR-ul la noi.
Improvizatii romanesti care raman nesanctionate de autoritati. Asta nu le face bune de ceva.
Orbesc pe ceilalti soferi si nu va doresc sa va orbeasca chiar un coleg de-al vostru cu xenon AM fix inainte de o trecere de pietoni cu pietonul pe ea.
Sper sa nu apara povesti cu "ale mele nu deranjeaza, eu le reglez" si alte justificari care nu isi au rostul.
Reglarea manuala dupa fiecare pornire a motorului? :))
Modificat de The_Ego
Deh, tara asta e plina de "smekeri de sezon" care se mandresc ca fenteaza sistemul pe care noi, restul fraierilor, il respectam din bun simt.
Daca are far cu lupa nu orbeste pe nimeni
stii ca lupele alea sunt diferite la masinile care au halogen pe lupa din fabrica, repectiv xenon (bineinteles, cu lupa) din fabrica - cauta detalii despre cut off samd.
va rog mult, dragi colegi, nu incercati sa fiti mai destepti decat niste oameni competenti in materie care au fost platiti sa gandeasca daca e sau nu ok sa puna lumea xenon cu 700 de mii la un nea ion in garaju' din spatele blocului; riscati mult sa cadeti in penibil.
exista becuri halogen mai puternice, nu e nevoie sa va montati o mini supernova in faruri.
multumesc.
Modificat de mike.
