Codari VCDS
NTZ
Hai sa scriu si eu: la noi...aka G V nu se poate, nu suporta centrala.
De se putea, faceam si eu, ca nu imi place (convine) pe xenon.
Modificat de janos
salut sunt nou pe aici si proaspat posesor a unui golf 5....am facut o scanare cu un vcds si am urmatoarele eroari si daca ma putei lamuri voi ce sunt cu el(macar cateva care is mai grave :(  ) ...
2 Faults Found:
00797 - Sunlight Photo Sensor (G107)
            010 - Open or Short to Plus - Intermittent
00709 - Sunlight Photosensor 2 (G134)
01064 - Terminal 58d; Interior Dimming
            012 - Electrical Fault in Circuit
02401 - Terminal 75x
            006 - Short to Plus - Intermittent
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
01314 - Engine Control Module
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 5
                    Mileage: 227646 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:14:56
00474 - Control Module for Immobilizer
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 25
                    Reset counter: 45
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:17:40
01330 - Central Control Module for Central Convenience (J393)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 38
                    Reset counter: 45
                    Mileage: 228426 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:37:05
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 45
                    Mileage: 228486 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:25:20
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 228490 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:27:02
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
01813 - Supply Voltage for Door Controller; Rear Left (J388)
01814 - Supply Voltage for Door Controller; Rear Right (J389)
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 45
                    Mileage: 228450 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:20:13
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 45
                    Mileage: 228450 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:20:59
00870 - Bass Speaker Front Left (R21)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 228649 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:02:46
00871 - Bass Speaker Front Right (R23)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 228649 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:02:46
00856 - Radio Antenna
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 227646 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:14:29
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 5
                    Mileage: 228486 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:14:58
02244 - Button in Control Head is Stuck
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 228622 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:40:28
             Freeze Frame:
                    Bin. Bits: 01000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 227646 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:14:24
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
Da-i un clear all dtc si pe urma posteaza scanul complet,nu asa.
plus ca eroarea 02244 nu are ce cauta pe un golf.
de fapt, mai incearca si cu alta interfata.... asta e cam dubioasa.
rezistenta suplimentara pt incalzire in habitaclu - Z35 - trebuie reparata.
multumesc frumos ...am refacut un alt test si am ramas doar cu eroarile astea.....
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 2100103808C08E
   Coding: 3D3F0B40070002
   Shop #: WSC 01279 785 00200
   VCID: 275D1D179618CF26F59-8072
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 228668 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:49:28
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 C    HW: 1K0 963 235 C
   Component: PTC-Element         0404
   Revision: 00600000    Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 2B55E1278AF0EB46111-807E
            014 - Defective
repara rezistenta Z35 si vezi de ce nu comunica cu radio.
salut baieti am un golf 5 de ce nu nu pot activa semnalizarile gen usa cind dau do it i-mi da o erore si nu se activeaza procentul de 25%
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006966231
   Coding: E78B8F2700041500471400001400000000097F075C0001
   Shop #: WSC 00028 028 00001
   VCID: 6CDDDA694F90D69
   Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 100407 021  0501
   Coding: 00038805
   Shop #: WSC 00028
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     130407 020  0105
   Coding: 00208933
   Shop #: WSC 00028
No fault code found.
pentru ca folosesti o clona si nu poate sa salveze codarea noua - foloseste o alta interfata - originala.
Salut. Am si eu o mica problema. Masina e un G5 GTI. Am pus un RCD 510. Aveam un Can cu K in coada so ca sa evit vreo neplacere, l-am schimbat cu unul cu S in coada de pe un G6. Can-ul l-am codat, e in regula. Problema e ca si inainte de schimbare, cat si acum dupa, imi apare o eroare la sectiunea radio: 01042 control module not coded. Codarea e numai cu 00000...etc. daca incerc sa schimb ORICE in codare si sa salvez, imi zice request out of range. Daca sterg eroarea, apare instant la loc. Aveti vreo idee pt rezolvare? Multumesc
Nu neaparat. Posibil sa trebuiasca setat wsc si toare cele la niste valori fixe. Am patit asa ceva cu interfata originala tot la platforma golf v. S-a rezolvat prin support-ul de la ross tech care mi-a transmis valorile respective.
Cazurile mi-au zis atunci sunt destul de rare, dar exista.
Nu a specificat.Da,daca are Wsc 000000 atunci trebuie setata o valoare.12345 de ex.
interfata este originala Ross Tech ?
Nu, Florin, nu este originala. Nu m-am uitat la wsc..numai cei de la ross-tech pot sa mi-l dea?
nu, il poti introduce si la a ta... schimbi 00000 cu 12345... sa nu vada ea 00000
Florine am intalnit aceasi pb la un golf v. Nu mergea nici cu 00000 nici cu 12345. Mi-au trimi atunci alte valori.
Golful era de italia.
posibil - si ce cod ti-au trimis... 054xx.. ?
Are wsc 01286. Nici el nici ce mai e in fereastra respectiva nu se poate schimba.nu ma lasa sa urc poza de pe tel, se opreste la 70%. Altceva ma streseaza, pe langa simpla eroare. E posibil, chiar daca am CAN cu S in coada, din cauza ca e 000000...pe codare, sa nu il vada cum trebuie si sa imi manance bateria? Si inca ceva: la advanced id, la programming status, programming attempts(application) si succesful atempts, amandoua au valoarea 1 in loc de 0. Inseamna ca si-a bagat cineva nasu prin el?
da, corect - a avut parte de update.
nu conteaza ca e codat sau nu, nu trebuia sa descarce bateria....
Rcd l-am avut montat cateva zile cu cel cu K in coada. Am lasat masina la service pt un schimb de piese si cand am luat-o de la ei, nu mai mergeau becurile din plafoniera, bord si portbagaj. Dupa ce am lasat un pic motorul pornit, si-au revenit, dupa care iar nu mai mergeau. Dupa o tura mai lunga cu masina, nu s-a mai intamplat. Asa ca am presupus ca e pe gata bateria(care apropo e noua, cateva saptamani are) si am schimbat can-ul. Cat despre update...casetofonul se presupunea a fi nou cand l-am luat...era absolut impecabil, cica luat pe casco, era in cutie de la vw, dar nu sigilat. Sa fi facut cei de la vw un update inainte sa il dea? In cat timp se mananca bateria daca e sa se intample?
update la can gateway.... ca banuiesc ca acolo ai verificat... sau nu am inteles eu bine ?
  • Aerofan pinned this topic
