Codari VCDS
NTZ
Posibil motoras din broasca dus, se desface si se reconditioneaza.
Modificat de Al Bundy
salut baieti . Am si eu cateva probleme majore cred ,am cumparat un Golf 5 accidentat usor la prima vedere dar la o scanare cu vag com am gasit un dezastru . Calculatorul de confort si modulele din usi prajite , pompa de Abs daca pun siguranta de la motor merge continuu ,lumina de int ,semnale  ,stergatoare,inchidere si geamuri fata nu merg doar cele spate . Am luat pe coduri cele 3 module si le am montat . Apoi am citit din nou erorile si am urmatoarele  Thursday,30,October,2014,22:25:11:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ1KZ6W139998   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ6W139998   Mileage: 80700km/50144miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Cannot be reached 1100
17-Instruments -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 CG    HW: Hardware No
   Component: MED9.5.10        00 7964
   Revision: --H08---    Serial number: VWZ7Z0F3365996
   Coding: 0000072
   Shop #: WSC 01392 785 00200
   VCID: 6ADB2423458A324E2A7-803F
2 Faults Found:
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 80707 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:02:42
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 48.0°C
049446 - No Communications with Steering Angle Sender (G85)
               U0126 - 008 -
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 80707 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:02:42
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 48.0°C
Readiness: 1110 0101
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 BD
   Component: ClimatronicPQ35 090 0808
   Shop #: WSC 00000 000 00000
2 Faults Found:
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
01316 - ABS Control Module
            004 - No Signal/Communication
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003812002
   Coding: 008D0F2700041500001400001400000000097B075C
   Shop #: WSC 00000 785 00200
   VCID: 2A5BE423850AF24EEA7-807F
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00063445
   Shop #: WSC 00000
2 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 62
                    Mileage: 80707 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.75 V
                        ON
                        OFF
                        OFF
                        OFF
                        OFF
00059 - Terminal 30 for Interior Lighting
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 62
                    Mileage: 80707 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.75 V
                        ON
                        OFF
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: 37 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD07GNTZ
   Coding: 0013111
   Shop #: WSC 01373 785 00200
   VCID: 3B75D1677A907BC6811-806E
   Subsystem 1 - Serial number: 6332MSME0F59366FU
   Subsystem 2 - Serial number: 6342MSME0D1C6978S
   Subsystem 3 - Serial number: 6352QSME09723E6DV
   Subsystem 4 - Serial number: 6362QSME080736417
No fault code found.
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 853 A
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0003103
   Shop #: WSC 10125 599 69511
   VCID: 285F1E2B9B06C05EFC3-807D
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001062020A46
   Coding: 3D3F0340070002
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 62
                    Mileage: 80707 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 05:56:32
00778 - Steering Angle Sensor (G85)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 62
                    Mileage: 80707 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 05:56:32
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 62
                    Mileage: 80707 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 05:56:33
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 4312
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2345
   Coding: 0000246
   Shop #: WSC 73430 790 00000
   VCID: 3663C05341B2A6AE7EF-8063
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 3365F94752C0B386591-8066
2 Faults Found:
00625 - Vehicle Speed Signal
            004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Mileage: 680 km
                    Temperature: 22.0°C
                    Voltage: 12.60 V
                    Voltage: 12.20 V
             Freeze Frame:
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 00C800087F3F8505484F010000C4
   Shop #: WSC 30516 264 02543
   VCID: 79F90B6F302C89D6D3D-802C
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
2 Faults Found:
01312 - Powertrain Data Bus
            013 - Check DTC Memory
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Component: Tuer-SG         024 2802
   Coding: 0000564
   Shop #: WSC 00028 028 00001
   VCID: 377DCD5746B85FA6659-8062
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 P
   Component: Radio BVX       016 0023
   Coding: 0040400
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2429
   Coding: 0000144
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 3467FA5B57CEB4BE40B-8061
Intrebarea este dupa ce le am montat trebuie sa fac vreo codare a lor sau mai ar fi ceva ars ? Motorul este 1.6 fsi si porneste ,pozitii,faza scurta,avarii,radio,geamuri spate,bordul , merg .  Mersi
Si mai vreau sa adaug ceva masina nu a avut surubul de prindere al bateriei si cred ca ea a facut tot acest scurt puternic la impact ,asadar cand puteti verificati cat de bine este fixata .
Da trebuie codat fiecare modul in parte incepind cu can gateway.De acolo apar cele mai multe erori...
Off.topic.
@spido, ti am trimis ceva pe WathsApp.
Zi frumoasa tuturor.
Am incercat dar posibil sa fie coduri diferite sau nu fac ceva bine de ex la can gateway Coding: 3D3F0340070002 e ok?
Vezi la lista de instalari in can sa ai bifate componentele de pe masina.
Si care sunt problemele , ca nu inteleg? In afara de cea de la ABS.
probleme nu am semalizari ,nu merg stergatoare , nu merg geamuri fata ,iluminare interior ,inchidere , faza lunga ,
poate sa fie ceva la cel de pe colana volan pt ca daca le comand din vag semnaliz ,indica,faza lunga ,motorasul de strop gel
este nevoie cumva sa pun calc de conf cel vechi pt a vedea vreun cod anterior ?
PAi intra cu VCDS pe centrala electrica si vezi daca primeste comenzile.
modulul vechi este 1K0 959 433 AK marca kiekert iar cel nou acelasi cod tot cu 4tuerer dar hella
pe centrala el apar urmat eroriSaturday,01,November,2014,19:03:22:62939
Control Module Part Number: 3C0 937 049 D    HW: 3C0 937 049 D
  Component and/or Version: Bordnetz-SG     H37 1002
           Software Coding: 008D0F2700041000001400001400000000097B075C
            Work Shop Code: WSC 12345 785 00200
           Additional Info: 1K1955119C  Wischer VW350  013  0402
3 Faults Found:
02399 - Control Circuit for Terminal 30 for Interior Illumination
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 64
                    Mileage: 80707 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.35 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 11
                    Reset counter: 64
                    Mileage: 80707 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.65 V
                        ON
                        OFF
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 64
                    Mileage: 80707 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.60 V
                        ON
                        OFF
                        OFF
                        OFF
                        OFF
le am sters si apar doar ultimele 2
pe centrala nu merge ilum de int si la semnal stg se apr si dr doar pe oglinda si sterg sp nu funct
scuze de prescurtari pe centrala nu merge lumina de interoir si la semnalizarea stanga se aprinde si dreapta doar pe oglinda si stergator spate nu functioneaza
NU merge semnalizarea ca nu comunica cu calc de coloana de volan.
Am si eu o problema la Golf 5-ul meu.
Ieri, dupa 2 ore de mers cu masina mi s-a aprins martorul de la airbag din mers si mi-a aratat in bord "airbag fault"
Am pus mai devreme vcds-ul la investigat si asta este ce a gasit:
Control Module Part Number: 1K0 909 605 N    HW: 1K0 909 605 N
  Component and/or Version: 07 AIRBAG VW8   015 2100
           Software Coding: 0012343
            Work Shop Code: WSC 00028 028 00001
                      VCID: 3776C52F46DD82A0D0F
1 Fault Found
01218 - Side Airbag Igniter; Passenger Side (N200)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
Am sters eroarea, becul s-a stins, toate bune.
Nu am mai rulat cu masina, dar am pornit / oprit motorul de cateva ori si nu s-a mai aprins martorul respectiv.
Ce ar fi  putut cauza eroarea?
Multumesc frumos!
Modificat de Alexandrinos
Contacte imperfecte in cele 2 mufe de la airbagul de la scaunul pasagerului.
Am mers astazi cu masina si nu s-a mai aprins.
Ce ar trebui sa fac? Sa curat mufele, sa le schimb? Care este cea mai buna varianta?
Daca iti mai face , elimini mufa si legi pe direct
Am scos din 17-Instruments "Seatbelt warning" - nu mai apare nici pictograma si nici nu mai suna. Se poate face sa dispara beep-ul si sa ramana doar pictograma?
Modificat de b-66-six
salut ! am si eu o problema , nu pot sa imi fac sa stea semnalizarea fata stil usa , ce pot sa fac ? nu e acelasi bit .. la 7 apare altcv
post-139241-0-02108500-1418740300_thumb.
Modificat de danutz1z
cauta mai incolo, la becuri semnaliare ca pozitii (turn signal light as pozition lights) si pui un 20-25%.
Vezi ca e procedura exacta cu ce trebuie sa faci .
Centrala electrica - long codding si apoi ceea ce ti-a spus Bundy
Daa nu stii ce faci , documenteaza-te bine inainte.
MosCraciunRevine
Uite pdf asta:),ai aici mai multe codari pentru masina printre care si ce vrei tu.Testate si functionale pe masina mea toate in afara de cornering si de instruments(zice ceva acolo de Login,eu nu am reusit)
codari vag 2013.pdf
  • Aerofan pinned this topic
