Un alt LUPO
steamroller
Frumos ''bondarul'',modifcicari cu gust,felicitari!
Km multi si drum intins
  • Replies 54
  • steamroller
    23
  • Slick
    8
  • johnyBOY
    5
  • Bogyciu
    2
va multumesc pentru aprecieri !
:) am inteles ,
vorbim defapt de o cheie de Polo 6n2, fratiorul mai maricel un pic a lui Lupo, masina sotiei... da e o idee sa vad de procedura aia pe forum pe unde e !
iti multumesc mult
procedura de adaptare a telecomenzii se gaseste pe ross-tech.com la sectiunea "wiki" pentru polo nu o stiu exact dar uite ce scrie pe pagina celor de la ross-tech/wiki , pe de alta parte poti intreba in sectiunea POLO daca are cineva pe polo 6n2 cheie briceag din fabrica sa vezi de care este , sau poti incerca invatarea unei telecomenzi de golf 4 de la cineva cunoscut si daca o invata stii ce cheie sa procuri (daca o invata sa nu uiti sa o si dezveti) .
citat:
Procedure for matching radio-frequency remote controls to many VW & Audi vehicles:
Check the Ross-Tech wiki under Diagnostic Procedures for instructions specific to your vehicle.
Gather ALL the remotes you would like to match. Insert one key in the ignition and turn it ON.
[select]
[46 - Cent. Conv.] or [35 - Cent. Locking] (whichever is applicable to =he car, as found he=e)
[Adaptation - 10]
Enter channel "01" (May be =hannel "21" in some Audi models).
[Read]
This will display the number of currently stored =emotes in "Stored Value".
Enter your total number of =eys up to a maximum of 4(including any existing keys) in =New Value"
[Test]
Verify that the number in "Test Value" is =orrect.
[save]
Then press and hold (for at least one =econd) the UNLOCK button on the fob, at which time it =ill be learned. If you're programming more than one fob =ress and hold the UNLOCK button on the second fob for one =econd, press and hold the UNLOCK button on the third fob =or one second, etc. You have a total of 15 seconds =o do them all.
The car may give you some sort of acknowledgement as each key =s learned (lights flash, horn beep, etc.)
If the above procedure does not work =neither Channel 01 nor Channel 21 are available), follow =his procedure:
Insert a working (old) key in the ignition and turn to the =N position (do not start car).
[select]
[Meas. Blocks - 08]
Enter group "003" (may be group "007" in some =ehicles)
[Go!]
The value in field 2 shows how many remotes have been matched =nd in which memory positions (for example, "0001" =ndicates 1 transmitter in position 1).
Lock the car from outside using the new, unmatched key in the driver-side door lock. You may need to hold the =ey in the unlock position while you do the next step. =/FONT>
Press the UNLOCK button on the new key within 5 seconds =ften enough to reach next memory position (so, if the value in =ield 2 was 0001, you should press the new key's unlock =utton twice, to put the new key in memory position 2)..
The car may give you some sort of acknowledgement as the =utton is pressed (lights flash, horn beep, etc.)
Wait 5 seconds and press the unlock button on the new key to =nlock the door.
Turn the ignition key to OFF and remove the old key. =BR>
Press LOCK and UNLOCK with the new key.
Insert the new key in the ignition and turn to the ON position =do not start car).
[select]
[Meas. Blocks - 08]
Enter group "003"
[Go!]
The value in field 2 should now indicate 0011 in the example =sed, showing the old key still matched in position 1 =nd the new key matched in position 2.
Make sure =hat new keys are always coded into free memory positions =where there is a zero in Group 003, field 2). If =ccupied positions (distinguishable by a "1") are used, the = transmitter previously coded to this position will =o longer work.
In some cases, it may be necessary to =lear out existing matched remotes using the following procedure:
[select]
[Adaptation - 10]
Enter channel "00"
[Read]
[save]
When the prompt asks if you are sure you want to save a value of 0 =o Channel 00, click [Yes]
After doing so, no remotes will be matched. You'll need to follow =he appropriate above procedure to match all of the remotes.
Modificat de steamroller
  • 7 months later...
Salutare ... am si eu un lupo 1.4i open air si nu stiu ce difuzoare sa ii pun pe fata ....am consola originala de la vw caseta + cd si nu stiu cum ar trebui sa procedez ca nu as vrea sa schimb consola originala .....m-ar interesa sa schimb cu ceva mult mai puternic cum ar trebui sa procedez? :RO flag:
ca sa ai sunet mult mai puternic nu te ajuta cu nimic schimbarea difuzoarelor eventual schimbi difuzoarele originale , mai adaugi altele si schimbi casetofonul cu ceva cu amplificare mai mare sau adaugi statie...
