Proceduri VCDS
Seby19
silviu_catalin
se poate ca ventilatorul de la racire lichid instalatie sa fie pornit tot timpul prin procedura vcds ?
@ silviu_catalin
Exact eroarea asta mi-o dadea si mie cand era dusa goarna de la alarma. Am gasit una pe ebay cu 36 eur parca si am schimbat-o. Acum alarma merge (nu doar luminile). La VW pretul uneia noi era peste 600 ron parca ... asa ca ebay. Ca idee e pozitionata undeva in aripa partea dreapta. Am montat-o la VW, circa 100 ron manopera.
Succes.
Modificat de adrian buzas
ma poate ajuta cineva cu descifrarea erorilor si cum se poate coda "Park assist" pe masina din semnatura ?
VIN: WVWZZZ3CZ9E
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
37-Navigation -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
76-Park Assist -- Status: Cannot be reached 1100
77-Telephone -- Status: OK 0000
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 H HW: 1T0 919 475
Component: PARKHILFE PLA H07 0110
Revision: -------- Serial number: 88520929000428
Coding: 300006
Shop #: WSC 05314 000 12345 ............. aici valorile 00000, insa eu le-am modificat in 12345
VCID: 4084425E2CD9D51C
1 Fault Found
03113 - Parallel Parking Assistance Indicator Lamp (K241)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 181069 km
Time Indication: 0
Freeze Frame:
Temperature: 32.0°C
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 M HW: 3C0 907 951
Component: J533__Gateway H14 0158
Revision: H14 Serial number: 0721G08A310265
Coding: F9A07F0E400603042002
Shop #: WSC 05314 000 00000
VCID: 2B5E05F2B55F2644
1 Fault Found
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 193
Mileage: 181069 km
Time Indication: 0
Address 76: Park Assist
Cannot be reached
Modificat de cridaia
Pai tu ai pe masina ambele module? adica si cel de parcare laterala cu spatele?
daca nu, codeaza can gateway fara adresa 75.
am schimbat modulul vechi SW: 3C8 919 475, cu cel nou SW: 1T0 919 475 H care stie si parcarea asistata.
acum, pe adress 10 park/steer assist il citeste, iar pe adress 76 park assist nu.
Sigur e problema de codare insa nu stiu care anume......si ce este adresa 75 ? pentru ca la mine nu apare.
adresa 75 este Telematics. Cristi cred ca a vrut sa spuna 76,
am ambele sisteme de ieri....si senzori de parcare si parcare asistata.
76 am vrut sa spun. Tu ai schimbat un modul cu altul, nu ai instalat un modul in plus, asa ca codeaza cangateway fara 76.
zis si facut.........am scos adresa76, a disparut eroarea de pe CAN, insa a ramas aceasta pe adresa10:
Coding: 300006
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 181069 km
Time Indication: 0
Freeze Frame:
Temperature: 32.0°C
ce am gresit oare ?
Aia se refera la un martor pe care posibil sa nu-l ai. Ai montat si butonul aferent? Ai tras fir la el ?
Modificat de Al Bundy
montajul l-am facut ca in acest link....... http://bronken.de/pa...-b6-nachrusten/
mai pe scurt: senzorii noi i-am alimentat de la cel mai apropiat senzor de fiecare. firele laterale din conector ( 1 si 3 ) le-am conectat intre senzori, iar firul 2 de la cei doi senzori noi le-am tras pana la noul calculator in mufa mica maro si anume, firul de la senzorul din stanga la pinul 9 iar cel din dreapta la pinul 10.
Modificarile la noul buton au fost: in prima faza, am scos firele 1 si 4 de culoare maro. Am scos si firul albastru/gri din 2 si l-am introdus in 4. Unul din cele doua fire maro vine introdus acum in locul ramas in 2 si mai ramane un singur loc gol cu un fir maro. La acest fir maro se lipeste un fir nou de el si se introduce in locul ramas gol, adica 1. Celalalt capat al firului nou vine tras la modul-ul nou instalat in mufa mare maro cu 16 pini in pozitia 9......si gata.
Acum ce a ramas a fost sa codez modulul pentru masina mea........iar aici au aparut erorile.
daca nu este locul potrivit, rog un moderator sa mute postul in aria corespunzatoare, insa am vrut sa explic cat mai bine ce am facut si "probabil" unde am gresit.
banuiesc ca ai verificat daca modulul ABS, suporta functia....
Firul care vine din mufa cu 16 pini, poz 9 se leaga doar in pinul 1 de la buton, nu si de firul maro dde masa, ala maro se taie sau ramane in aer, de aici ai eroarea short to ground. Desfa legatura dintre acest fir si cel maro si totul o sa fie OK. vechiul buton are 3 fire de masa, asta nou doar 2.
exact asta a fost problema.....firul maro din pinul 1 se taie si ramane liber....am verificat acum si toate erorile au disparut.
stiam de aceasta chestie, insa cel care mi-a tradus in momentul lucrarii a uitat sa traduca iar eu am uitat de acest amanunt "important".
Mai ramane dupa masa cand ies de la servici sa fac o proba....va tin la curent.
L.E. am fost acum afara sa fac proba si nu merge...imi apare pe CB mesaj: "Park assist - speed to low" dar eu aveam aprox. 30km/h
putin mai tarziu voi scana iarasi sa vad daca sunt erori.
Am impresia ca trebuie sa treci de 40km/h apoi sa activezi functia
nu cred sa aibe relevanta.........mi se pare prea mare viteza de deplasare ca sa poata citi distanta, iar pe youtube daca nu gresesc am vazut parcari si la viteze mai mici.
legat de modul-ul de ABS este cel care trebuie ca sa suporte functia.
m-am jucat si eu cu cateva... si nu cu viteze mari.
Parcare o faci cu viteza mica dar ca functia sa fie activa trebuie sa depasesti 40km/h si sa dai semnal pe parte care vrei sa parchezi, cel putin asa era la golful cu care am mers eu
nu, merge si mai jos - garantat - la B6 si CC-urile - cred ca aveam in jur de 20km/h, cand am apasat butonul
si nu se poate selecta partea pe care vrei sa parchezi.......trebuie sa fi la o distanta laterala "oarecare" pe partea pe care vrei sa parchezi.
am mai gasit ceva interesant zic eu:
in link-ul de mai jos face referire ca la adresa 44 pe canalul 4 trebuie modificata valoarea din 2 in 1....problema e la mine ca nu este activ nici un canal, in special 4 ( vezi foto ).
http://forums.kilometermagazine.com/showthread.php?4978579-Tiguan-Park-Assist-coding
post-84251-0-90542400-1346664349_thumb.j
fa login pe modul - iti cere codul de securitate - baga 89753 - pt asistenta la parcare
L.E. dupa care se modifica valoarea din campul 004, in 0 (daca masina e 2009) sau 1 (daca e 2010)
am rezolvat...........functioneaza....trebuia introdus pe adresa44 la canalul4, in cazul meu valoarea 0....sper sa ma bucur la maxim de acest "upgrade".
Ba se poate selecta partea. Implicit considera ca parcarea se face pe dreapta. Daca vrei sa parchezi pe stanga semnalizezi stanga si va face parcarea.
  • Marian a închis acest topic
