Adaugare ulei 2T in motorina
alex_pescaru
Go to solution Solved by Bogdamn,
Ce ulei adaugati?
381 voturi
  1. 1. Ce ulei adaugati?
    • Castrol Act Evo 2T FC
      46
    • MOL Dynamic Sprint 2T verde FD
      158
    • K-Classic (bidonul galben din Kaufland) FC
      35
    • Mobil Extra 2T FD
      28
    • Ravenol Scooter 2-Takt Teilsynthetic
      16
    • Aral 2T, FC
      29
    • Hexol 2T rosu
      42
    • Liqui Moly 1052
      32
    • Wolf Synth 2T
      7
    • Shell Advance VSX 2T
      2
    • Shell Advance Ultra 2T
      3
Apropo de catalizatoare...
Citat:
Besides this, the 2-stroke oil will keep the diesel engine clean, as it burnes cleaner as the diesel itself.
In other words, the 2-stroke oil has a much lower ash-content as diesel, when burned. This proven fact delays the DPF (diesel particulate (soot) filter) to clogg, and the "burn free" process of the DPF will be much less.
One more information: in Germany we have to present our cars every 2 years to the TUV -Technical Supervision Organisation - who will check, amongs others, the pollution of petrol and diesel engines.
The measured cloud-factor of a diesel engine without use of 2-stroke oil has been 0,95.
The same factor with the use of 2-stroke oil has been 0,47 - reduction of nearly half of the soot particles.
Sursa: http://www.freel2.com/forum/topic878.html
Si inca o chestie.
Iaca fisa de catalog a unui ulei 2T.
O sa vedeti la compozitie ca nu are nimic ce poate dauna. Produsi derivati de petrol (a se vedea ca altii aditiveaza motorina cu benzina) si produsi pe baza de calciu, ca la unsori.
Am sa pun si eu, 2T, cand "umblu" la rezervor, sa vedem cum se comporta.
Am citit si eu posturile alea... sa fiu sincer, nu stiu cat ajuta. Autorul a avut o remarca pertinenta legata de cenusa:
"Important is, that those 2T-oils should comply with JASCO "FC" or ISO L-E "GC" or "GD", which should be written on the bottle. All 2T-oils as per these norms burn with an ash content of less than 0,05%."
Mai e o chestie interesanta - legata de cresterea indicelui Cetanic cu 3-5 puncte. M-ar uimi, mai ales in concentratii atat de mici.
Cred ca intrebarea e cu cat ii creste viscozitatea uleiului, si cat de bine rezista la presiuni extreme si forfecare. Oricum ar fi, amestecuri de 1:200 (adica 0.5%) nu prea au cum sa faca rau.
Poate o sa incerc pe una din masini...
Ce vrei sa spui cu 'cu cat creste vascozitatea uleiului'?
A vrut sa spuna "cu cat de mult ar creste uleiul vascozitatea combustibilului " prin aditivarea motorinei cu ulei .
Eu folosesc de cca 3 ani amestec 1l ulei/ 80l motorina, in acest fel protejez pompa de injectie. Verificat cu vag com motorul este in parametrii.
...si pompa de motorina din rezervor.
Folosesti sintetic sau mineral?
Nu are pompa electrica in rezervor..........
@floriand, folosesti ulei de motor sau pt motoare in 2 timpi, de amestec ?
La motoarele P.D. ar fi indicat? NU STIU dar eu am PD Euro 3, si de cand alimentez cu motorina E5 am observat ca a crescut consumul cu peste o jumatate de litru la suta de km . am mai auzit ca daca pui ulei de amastec consumul ar mai scade. Si totusi cu 6 -7 sute de mll nar fi o problema mare tinand cont ca motorului E3 ii dai sa pape ceva mai curat .?????
generalul - daca vrei sa pui ulei in motorina, ideea este sa iti protejeze pompa, injectoarele, nu pentru consum...
Ca vine si asta cu celelalte, e alta poveste, dar principalul este sa protejam motoarele. Si eu sunt interesat de ideea asta, insa nu sunt foarte documentat pe problema, asa ca mai citesc un pic, si apoi imi dau parerea.
hbogdan, nu vreau sa scap un porumbel, dar parerea mea este ca ar trebui bagat ulei mineral. E posibil sa ma insel, insa uleiul sintetic, este obtinut... sintetic, si are proprietatile diferite fata de cel mineral. Daca am zis prost, dati si voi cu ceva moale dupa mine, sa nu doara.
Generale, cred ca motorul tau nu e PD. Merge sa ii dai ulei 2T.
@gHapciu: arderea e completa la uleiurile sintetice (uleiuri de amestec, sa nu fiu extras din context de vreun coleg).
La cele minerale nu prea. Mai e folosita si notiunea de 'low-smoke', e clar ce inseamna.
AJM e un motor PD (115/116cp), parerile sunt impartite dpdv al folosirii uleiului de amestec in ele. Eu am pus. Nu vad modificari in rau pe canalul 13 de la grupul Engine, au ramas tot echilibrate 2 cate 2.
Daca ar fi fost motor PD, nu e indicat?
Am citit ce a scris hbogdan (ca e motor PD), dar intreb pt as vrea sa stiu daca nu se recomanda uleiul in motorica pt motoarele PD.
Au facut americanii un test - rudimentar, e adevarat, dar e acceptat si e mai mult decat am gasit la altii. Au testat 19 aditivi in motorina si... mare supriza supriza :Driver: Biodiesel (in proportie de 2%) ajuta extraordinar de mult la reducerea uzurii.
http://www.dieselplace.com/forum/showthread.php?t=177728
La noi, tot carburantul diesel contine min 5% Bio, asa ca... problema e rezolvata. Nota - Bio obtinut din RAPITA are deosebite proprietati de ungere. Sper ca la noi tot din ulei de rapita fac Bio...
Uleiul 2T dupa parerea mea nu prea ar avea cum sa strice daca:
1. Este amestecat bine in combustibil
2. Este in proportie mica - 1:200 mi se pare, totusi, mult.
Iarasi, in opinia mea, ce poate sa strice uleiul 2T este:
1. Uzura mai mare a duzelor - daca uleiul nu este bine amestecat in carburant
2. Contaminarea catalizatorului - daca e prea mult ulei. Cred ca o limita de ordinul 2L ulei/10.000Km ar fi max admisibil (la un consum de 7L/100Km, asta inseamna 1:350 concentratie).
De observat ca studiul de mai sus nu a evaluat si combinatii de aditivi - de ex Bio + Ulei. Oricum, efectul uleiului a fost de 3x mai slab decat al Bio. De mentionat ca si Bio a fost de 4x mai mult decat ulei (1:200 ulei vs 1:50 Bio). Asa ca e posibil ca la concentratii similare, rezultatul sa fie comparabil.
De asemenea, testul de uzura nu adreseaza deloc modul de funtionare ale unui injector PD. Este un "test cu bile" pt lubricitatea uleiului. S-a dovedit deja ca nu da intotdeauna rezultate corecte.
In ultimul rand - si asta a fost principala mea invatatura - S-a zis cu Power Service pentru mine. Nu il mai cumpar, pt ca mi se par bani aruncati. Este, desigur, numai parerea mea... de amator.
E contraindicat pentru motoarele PD sa se adauge ulei de 2T in rezervor?
Am gasit un topic care cica ar fi benefic,multi folosesc aceasta metoda pentru a compensa lipsa de sulf din motorina ULSD ( EURO 4 si EURO 5).
Pe scurt,se pare ca arderea motorinei ar fi completa si s-ar efectua o ungere corespunzatoare a pieselor din mecanismul de injectie.
Interesant. Ma gandesc sa citesc tot thread-ul. Dupa citirea a catorva pagini pare incitant, doar un gand ma bate: oare, cum ar suporta motoarele noastre PD-TDI (cu niste caracteristici specifice fata de CR) acest "aditiv"...?
O sa revin dupa ce am parcurs thread-ul.
De aseara pana acum am citit tot topicul indicat din primul link.
Avand in vedere ca toti cei care-l folosesc erau incantati de descopreire (inclusiv un tip cu TS TDI din UK) am purces azi la cautat ulei 2T sintetic cu o anumita norma.
Dupa vreo ora de cautari am gasit la o benzinarie.
Nevrand sa fac vreo boacana am bagat cam 50 ml de ulei si motorina de 50 lei (acul era aproape sa intre pe rosu).
Pe drum spre casa (vreo 2 km) n-am simtit nici o diferenta in mersul motorului. Daca nu explodeaza pana se termina motorina asta o sa adaug in cantitate mai mare la urmatoarea alimentare.
La Trabant parca se punea 2% in benzina...si la moto pirtiitorile pe 2 roti...
La motorina banui ca un 0.5% ar fi de ajuns pt ajutarea ungerii...
Am vazut ca se recomanda un raport de 200 la 1 motorina-ulei. Din ce ziceau pe forumul ala primele 2 plinuri poti pune chiar putin mai mult sa se curete mai repede instalatia...
Am facut 20 km de cand am facut amestecul minune in rezervor. Deocamdata nu s-a inamplat nimic nici in bine dar nici in rau :)
200 la 1 e cam mult , eu zic ca 0.5% ar fi ceva mai bine... :))
Nu ai ce observa cu "ochiul liber" , ce simti...e o chestie pe termen lung..daca e ceva...
Dupa citirea postului de pe forumul ROVER un priten bun de-al meu a inceput de ieri sa "aditiveze" motorina cu ulei de 2T dupa reteta de acolo(are Ford Mondeo TDCI 2003).
Primele impresii:nu se simte nici o schimbare in mersul motorului,dar a scapat de codita de fum negru care aparea la accelerarile bruste.
Am initiat acest topic in speranta ca voi gasi posesori de motoare PD care au utilizat aceasta metoda de "aditivare" o perioada mai lunga de timp si care ar putea confirma utilitatea/inutilitatea acestei metode de "aditivare".
Printre cunoscutii mei am mai gasit un posesor de HDI care folosea de 2 ani ulei de 2T si facuse pana acum 60000 de km fara sa aiba vreo problema la motor.
Nu de alta,dar presiunea in injectoarele PD este de 2-3 ori mai mare decat la restul motoarelor..... n-as vrea sa-l stric pe al meu,e atat de tanar,are doar 35000 KM :Driver:
Eu folosesc ulei 2T la fiecare alimentare....La un plin pun cam 200ml si pot sa zic ca sunt multumit.Ca si schimbare se simte la motor care zic eu este mai silentios si a disparut fumul negru de pe teava de esapament...Am un prieten care foloseste acest ulei la un X3 de mult timp si nu are probleme cu motorul.
Am inceput sa pun ulei de cca 3 luni.
