radiator/termostat
radur
Salut, vine iarna, vin sarbatorile si Fabia mea s-a gandit sa-si crape radiatorul si sa-si blocheze termostatul :D (poate cu un pic de ajutor si din partea mea)
Ideea este ca vreau sa le schimb insa nu stiu ce exact sa cumpar, modelul este AQW 1.4MPI 50kW. De termostat am inteles (din ce am citit pe internet) ca nu e foarte mare problema, adica modelele comercializate cu sau fara carcasa se potrivesc ... insa la radiator am gasit mai multe dimensiuni si n-am nici un COD de produs nimic care sa ma ghideze, orice ajutor este de apreciat.
  • Replies 55
  • BMA
    12
  • dic
    8
  • Carmina
    8
  • lucrac
    3
1 6Q0121253J
radiator / for vehicles with manually regulated heater
430X413MM / AUB,BBZ,
(1) 6Q0121253J radiator / for trailer towing
430X413MM / ARV,AQV,AZE, AZF,AME,AQW, ATZ,AUA,BBY,
(1) 6Q0121253J
radiator / for vehicles without trailers / F >> 6Y-3-647 001 / F >> 6Y-3X045 096
430X413MM / AZE,AZF,AME, AQW,AWY,
(1) 6Q0121253J
radiator / for vehicle use in warm climates / F >> 6Y-3-647 001 / F >> 6Y-3X045 096
430X413MM / AWY,
(1) 6Q0121253L
radiator / for trailer towing / F 6Y-3-647 002>> / F 6Y-3X045 097>>
630X413MM / AWY,
(1) 6Q0121253L
radiator / for vehicle use in warm climates / F 6Y-3-647 002>> / F 6Y-3X045 097>>
630X413MM / AWY,
(1) 6Q0121253Q
radiator / for vehicles with air condit. / F >> 6Y-3-647 001 / F >> 6Y-3X045 096
630X413MM / ARV,AQV,AZE, AZF,AME,AQW, ATZ,AWY,AZQ, AUA,BBY,AUB, BBZ,ASY,
(1) 6Q0121253Q
radiator / for vehicles with manually regulated heater / F >> 6Y-3-647 001 / F >> 6Y-3X045 096
630X413MM / ATD,
(1) 6Q0121253Q
radiator / F >> 6Y-3-647 001 / F >> 6Y-3X045 096
630X413MM / ASY
(1) 6Q0121253Q
630X413MM / ATD
(1) 6Q0121253L
radiator / for vehicles with air condit. / F 6Y-3-647 002>> / F 6Y-3X045 097>>
(1) 6Q0121253L
radiator / for vehicles with manually regulated heater / F 6Y-3-647 002>> / F 6Y-3X045 097>>
630X413MM / ATD
(1) 6Q0121253L
radiator / F 6Y-3-647 002>> / F 6Y-3X045 097>>
630X413MM / ASY,
(1) 6Q0121253L
630X413MM / ATD,
(1) 6Q0121201BT
radiator / electric fan / for vehicles without trailers / F 6Y-3-647 001>>
430X414MM / ARV,AQV,AZE, AZF,AME,AQW, AUA,BBY,AUB, BBZ,AWY,AZQ,
(1) 6Q0121253R
radiator / for automatic gearbox
632X414MM / AUA,BBY,
(1) 6Q0121253R
radiator
632X414MM / manual- gearbox: AZL,AMF,
(1) 6Q0121253R
radiator / for air conditioner
632X414MM / ATD,
(1) 6Q0121253AD
radiator
630X408MM / ASZ,
Ar fi bine daca ne-ai spune din ce an e masina! Cred ca asta este lista completa cu radiatoarele de pe Fabii produse in 2003. Sper sa iti fie de folos!
Modificat de lucrac
Nu vreau sa fac reclama ci vreau doar sa te ajut . Am vazut recent unul pe okazii care vindea 2 radiatoare pt fabia . Poate se potrivesc la tine :lol:
Masina este din 2002 acum nu stiu daca este 630X413 sau 632X414, evident daca nu-l iau bun nu se potriveste si arunc banii pe geam ;)
1 6Q0121253J
(1) 6Q0121253J
(1) 6Q0121253J
(1) 6Q0121253J
430X413MM / AWY,
(1) 6Q0121253L
630X413MM / AWY,
(1) 6Q0121253L
630X413MM / AWY,
(1) 6Q0121253Q
(1) 6Q0121253Q
630X413MM / ATD,
(1) 6Q0121253Q
630X413MM / ASY
(1) 6Q0121253Q
630X413MM / ATD
(1) 6Q0121253L
(1) 6Q0121253L
630X413MM / ATD
(1) 6Q0121253L
630X413MM / ASY,
(1) 6Q0121253L
630X413MM / ATD,
(1) 6Q0121201BT
(1) 6Q0121253R
(1) 6Q0121253R
radiator
(1) 6Q0121253R
632X414MM / ATD,
(1) 6Q0121253AD
radiator
630X408MM / ASZ,
Asta e lista pentru 2002.
Lurac, dupa parerea mea NU ai facut nimic altceva decat sa iti bati joc de radur. Adica daca tot ai acces la Etka puteai sa iti dai usor seama ca daca are motor 1.4 MPi atunci codul poate fi usor filtrat, cel mai probabil AZE, AZF, AME.
Cel mai probabil codul este
(1) 6Q0121201BT
dar verific maine si confirm.
Cheers!
Blitz, nu incerc sa imi bat joc de nimeni. Nu am acces la Etka, lista prezentata este de pe vagcat.com. si nu o puteam filtra pentru ca nu am informatii despre masina (serie caroserie, dotari ...). Am pus la dipozitie niste date din care radur sa poata folosi ceva, nu inteleg unde e bataia de joc! :(
Buna dimineata tuturor. M-a lovit o problema, ieri cand am ajuns acasa am constatat ca pierd lichid de racire pe undeva in partea de jos a radiatorului, cam unde e cotul ala catre robinet. Si pierd bine, in sensul ca azi dimineata a trebuit sa pun 0.5 l de apa distilata ca sa fie la nivel. Aveti idee daca se pot repara astfel de radiatoare sau cat costa unul nou si de unde pot comanda?
Salut, sunt membru de curand pe forum (sper cat mai lunga apartenenta la acest forum), si detin o Fabiutza de 1.9 TDI din 2002. Incalzirea imi face feste, adica cand baga aer ffff cald de trebuie sa stau in tricou :blink: , cand fara sa umblu la butonul pt reglarea temperaturii, incepe sa bage aer rece (nu la temperatura de afara) :huh: . Si nici recircularea aerului nu merge. Any help, plssssssss!!!!
Sper ca nu sunt in afara topicului. Multumiri anticipate. :salut:
asa patesc si eu...numai ca eu am fabia 1.4mpi AZF..ce sa fie oare? :banghead: :banghead: :rolleyes:
Mai bine cititi ce e aici
Modificat de b1ade
Stiu ca dateaza de mult, dar azi in service am observat unde mi se prelinge usor un pic de antigel.
In locul mentionat de urinel, mai bine zis la imbinarea partii de plastic cu corpul radiatorului. Nu pierd mult, dar e roz acolo si umed.
Ce pot face? Sa incerc ceva solutie de etansare radioatoare?
Daca ai posibilitatea de acces acolo foloseste cu incredere POXIPOL gri dupa ce cureti bine inainte suprafata.
Daca e aceasi formula ca acum 7 ani te asigur ca va tine fara probleme si la presiune si la temperatura.
Eu am lipit radiatorul de Al la 120L si a tinut pina am dat automobilul !
(1) 6Q0121253AD
radiator
630X408MM / ASZ,
Buna,
Se poate o lista si pt 2000? Ma intereseaza pt o Skodia Fabia I combi din 2000, 1.4 TDI, 51KW, 70CP. Masina este a unui var si mi-a zis ca radiatorul ar fi ceva de genul 2 in 1 (ar avea si componenta pt aerul conditionat pe el :blink: - nu cunosc detalii tehnice :D asa ca scuzati-mi nepriceperea :D)
Multumesc anticipat
Modificat de Catiusca
Salul. AM si eu o problema cu radiatorul meu , de cateva luni imi curge prin dreapta jos antigelul . Acum iimi curge din ce in ce mai mult , ce ma sfatuiti sa fac
daca curge dreapta jos, cum stai in fata masinii, acolo ai un robinet de golire a instalatiei, ....sa inteleg ca nu mai inchide?....sau pur si simplu in partea dreapta jos e spart?....daca e robinetul se poate repara, daca e spart radiatorul ....parerea mea, depinde de cum stai cu bugetul......eu as merge pe unul nou......daca strange buzunarul, da-l jos ca se poate repara, banuiesc ca gasesti in Arad, o firma care se ocupa cu reparat radiatoare auto..... :icon_thumleft:
Modificat de carmina
carmina, in dreapta jos este locasul unde este infiletata termocupla. Iar acea asamblare filetata are prostul obicei sa devina neetansa in timp. Trebuie identificat exact locul iar daca e ce-am spus atunci trebuie golita instalatia, demontata termocupla, banda de teflon de instalatii peste filet si remontata.
  • 7 months later...
Buna
La masina din semnatura vreau sa-i schimb antigelul. Ce trebuie sa desfac sa curga tot antigelul vechi? E adevarat ca antigelul trebuie sa fie fierbinte ca sa treaca de termostat?
Desfaci de jos de la radiator robinetul de golire al instalatiei si scoti si capacul vasului de expansiune , ca sa cuprind si intrebarea cealalta, dai drumu cand lichidul de racire are 90 de grade si e termostatu deschis, si va curge tot lichidul...sau ma rog cat o mai ramane.... :icon_cheesygrin:
Buna
Urmare la postarea 18.
Anul trecut mi-am schimbat antigelul. Intre timp am avut un accident si dupa reparatie am gasit apa. Vreau sa o schimb. La noul radiator nu mai gasesc robinetul unde stiam ca este. Unde poate fi? Exista mai multe radiatoare pentru fabia cu robinetul in alta parte? Am dat roata radiatorului si nu l-am gasit. Radiatorul e de la dezmembrari si mecanicul parca a specificat ca ar fi de la un motorinar. Sunt diferente? O sa-l mai caut daca nu-mi da cineva o idee.
Robinetul de golire nu e montat pe radiator, intr-adevar in partea de jos a radiatorului, dar e pe furtunul cel gros care vine si il vei cupla pe mufa radiatorului.
Sunt diferente intre radiatoare, cum sa nu fie? Un exemplu: daca ai AC pe masina, radiatorul de racire are alte dimensiuni, nu ai.....e alta dimensiune. Trebuia sa masori radiatorul si dupa aia la cumparaturi, acum cum ti-a fi norocul.
post-25544-0-44454900-1338115562_thumb.j
Multumesc de ajutor. Am schimbat apa cu antigel. Din 5,1 L cat e plinul, dupa golire am introdus doar 4. Am luat in calcul ca nu o sa curga toata apa asa ca 1 L l-am introdus pur. Cu prima ocazie (pana la iarna) trebuie sa-i masor concentratia.
  • 5 months later...
Am descoperit scurgeri de lichid racire exact unde spune Blitz. Curge pe la conexinea TS-ului pe radiator undeva deasupra robinetului de golire. Pun poza si sper sa se vada. Sper ca daca demontez TS-ul si il etansez la filet voi rezolva problema. Dar e problema cu accesul la termocupla, plus ca va trebui sa drenez circuitul. Daca nu tine va trebui sa inlocuiesc termocupla si sa ma asigur ca nu e vreo problema cu filetul interior de pe radiator.Asta inseamna din nou golire/umplere. Vreo sugestie ?
PS:: azi am descoperit si la a doua masina o scurgere de lichid servo--BLACK sATURDAY
post-11261-0-86163300-1353780911_thumb.j
post-11261-0-65088200-1353780923_thumb.j
post-11261-0-88102600-1353780935_thumb.j
Nu este o problema cu accesul la termocupla...demontezi de deasupra ventilatorului acea ,,gura de aer", dupa care demontezi ventilatorul mare, il scoti pe sus, si vei avea spatiu de manevra. Stii care va fi problema? Demontarea termocontactului....si daca filetul din radiator va suporta acea etansare de care ai pomenit....fiind ,,copt" s-ar putea sa ai o surpriza la strangerea termocontactului.....deci grija mare, altfel va trebui inlocuit radiatorul daca se invarte cu totul....
Da, asta inseamna golire/umplere, altfel cum? Cand ai demontat termocontactul va curge antigelul....
Ce sa faci BD77...mai sunt si zile din astea....
Trebuie lucrat cu mare grija. Merge si fara ventilator dat jos dar trebuie sa cam ai sculele potrivite ca daca incerci "tiganii" s-ar putea sa se sparga radiatorul.
Dac-ai reusit sa dai termocupla jos atunci cureti frumos zona, dai o banda de teflon pe filetul termocuplei (mare grija CATA banda pui, sa nu dai prea multa, si cum o pui) si strangi la loc. Nu strangi tare ca plezneste tot pe-acolo.
Succes.
P.S. sau apelezi la servicii profesionale.
