Steering column defective
adrian73ran
Din pacate, la tine ELV-ul facea probleme.
Am si eu recent eroarea cu blocatorul volanului. Prima data mi-a aparut dupa ce am lasat masina vreo 3 zile in frig. Imi apare din cand in cand "Steering Lock...." la pornire.
Pana sa ma duc la reprezentanta VW sa fac revizia (in aprox 2 saptamani ca expira si ITP) as dori sa imi spuneti o parere despre erorile stocate:
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QC    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  6208
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 83968 026 591431
   VCID: 76E9977C01DC22E
001299 - Incorrect Immobilizer Key
               P0513 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 180578 km
                    Time Indication: 0
                    Date: 2017.14.22
                    Time: 08:11:11
             Freeze Frame:
                    RPM: 1196 /min
                    Speed: 0.0 km/h
                    Voltage: 10.94 V
                    Absolute Pres.: 958.8 mbar
                    Absolute Pres.: 918.0 mbar
                    Temperature: -13.5°C
                    Temperature: -4.5°C
Readiness: 0 0 0 0 0
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433 AM    HW: 3C0 959 433 AM
   Component:    IMMO         052 0383
   Revision: 00052000    Serial number: VWZCZ000000000
   Shop #: WSC 46612 133 99611
   VCID: 75EB90701CDA296
   Part No: 3C0 905 861 J
   Component:    ELV          029 0380
   3C0905861J     ELV          029 0380
2 Faults Found:
02823 - Requirements for Locking the Steering Column Lock not met
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 2
                    Reset counter: 115
                    Mileage: 180530 km
                    Time Indication: 0
                    Date: 2017.14.13
                    Time: 11:21:17
02861 - Electronic Steering Column Lock Check Sum Error
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 4
                    Fault Frequency: 8
                    Reset counter: 115
                    Mileage: 180518 km
                    Time Indication: 0
                    Date: 2017.14.11
                    Time: 16:53:38
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.075 0502
   Revision: 1AH02240    Serial number: 00082050114902
   Coding: 0000258
   Shop #: WSC 20346 133 174564
   VCID: 39735C4070428D6
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 115
                    Mileage: 180600 km
                    Time Indication: 0
                    Date: 2017.14.25
                    Time: 08:07:28
             Freeze Frame:
                    Voltage: 0.10 V
                    Voltage: 10.60 V
                    Voltage: 3.50 V
                        Not Occup.
                        Not Occup.
Multumesc anticipat.
verifica/schimba bateria, in cazul tau
Este vreo modalitate sa verific bateria cu VCDS? Sau trebuie tester ptr baterie?
tester pentru baterie  = voltmetru.
din vag poti vedea la fel valoarea indicata de un voltmetru.
No, sunt testere speciale pentru acumulatori, generatie noua - care iti verifica puterea ramasa, puterea la pornire, capacitatea de incarcare, etc... vb de amperaj - intrucat numai testarea voltajului, nu este elocventa.
Cam asta imi indica la voltaj baterie cu vcds (motor oprit, doar contact fara consumatori). E prea putin?
rK4CDAg.jpg?2
Modificat de sandreuta
Baterie e ok, testata cu voltmetru dimineata 12.3-12.4V, la pornire nu scade sub 10V. Probabil e totusi problema cu blocator volan. Voi vedea cand ajung la reprezentanta.
masuratoarea efectuata de tine nu este suficienta pt a afla daca bateria e buna, pt ca ai masurat doar voltajul, nu si amperajul, care este cel mai important in astfel de situatii!!!
eu iti garantez 99% ca problema e legata de baterie si inca eu nu ma pricep. Insa. ti-a spus si FLORIN acelasi lucru. Exact asta scrie si in mesajele de eroare postate de tine.
Inainte sa mergi la service, citeste mesajele astea:
http://vwforum.ro/topic/52163-steering-column-defective/page-30
Pe 19.01, colegul cu a revenit si a recunoscut ca problema era de la baterie si din pacate se pare ca a platit bateria la un pret de 10 ori mai mare.
Bateria nu are suficienta putere, chiar daca iti indica ca are 12V.
Modificat de OT79LAU
Am patit sa apara mesajul "steering-column-defective" la doua porniri la distanta de 2 saptamani.
Dupa avertizare la urmatoarea porinire totul mergea normal.
Bateria a fost shimbata recent(acum 5 luni).
Are cineva vreo sugestie?
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QF    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  6211
   Revision: 13H02---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 84736 681 682792
   VCID: 79FDE9D74B19
2 Faults Found:
009754 - Coolant Pump 2: Open Circuit
               P261A - 000 -  -  - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 18
                    Mileage: 145702 km
                    Time Indication: 0
                    Date: 2011.14.13
                    Time: 17:35:48
             Freeze Frame:
                    RPM: 782 /min
                    Speed: 0.0 km/h
                    Voltage: 12.08 V
                    Lambda: 79.7 %
                    Bin. Bits: 10011001
                    Bin. Bits: 00000000
                    Temperature: 20.7°C
               P0513 - 000 -  -  - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 145195 km
                    Time Indication: 0
                    Date: 2010.14.18
                    Time: 11:47:53
             Freeze Frame:
                    RPM: 1104 /min
                    Speed: 0.0 km/h
                    Voltage: 11.25 V
                    Absolute Pres.: 979.2 mbar
                    Absolute Pres.: 938.4 mbar
                    Temperature: 1.8°C
                    Temperature: 2.7°C
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: 7AFFF6DB4E1F
   Part No: 3C0 905 861 G
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 22
                    Mileage: 145715 km
                    Time Indication: 0
                    Date: 2011.14.14
                    Time: 08:22:12
02827 - Wake-Up request via ESP
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 22
                    Mileage: 145715 km
                    Time Indication: 0
                    Date: 2011.14.14
                    Time: 08:22:40
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 22
                    Mileage: 145195 km
                    Time Indication: 0
                    Date: 2010.14.18
                    Time: 11:47:46
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 043 0612
   Coding: 00900A00D1034E76300294157008CF0E707C01
   Shop #: WSC 05311 000 00000
   VCID: 7AFFF6DB4E1F
   Part No: 1K8 951 605
   Component: LIN BACKUP HORN H09 9002
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
01134 - Alarm Horn (H12)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 11
                    Reset counter: 22
                    Time Indication: 0
Cam din toamna am inceput sa primesc erori legate de " Steering column defective, sau steering column lock defective, rareori urmate de start/stop failure " . Am mai primit una sau doua erori iarna trecuta, nici o eroare pe timpul verii. Iarna aceasta am primit eroarea de vreo 7-8 ori, de fiecare data am scos cheia, am reintrodus`o si a pornit masina fara nici o problema ( deci tot timpul a disparut eroare si a pornit din a doua incercare ). Mentionez ca daca motorul ii cald nu da niciodata eroare . Ii ceva grav, cineva a zis ca posibil sa fie "senzorul" care citeste cheia, se poate verifica? Ce legatura poate avea frigul? Masina a pornit perfect si la -18 grade, erorile au aparut aleator, intre -14 si +5 grade.
Scuze pt. postarile succesive, a dat serverul timeout de mai multe ori si apoi au aparut toate deodata.
Modificat de Spyd3r
Duplicate post
Problema des intalnita la immobilizator.Trebuie reparat/inlocuit blocatorul de coloana
Am facut o scanare la masina, se intelege care ar fi componenta defecta? As vrea sa caut dupa cod sa vad cat costa de noua, daca nu`i exagerat de scumpa as prefera sa o iau noua. Mersi .
Wednesday,03,February,2016,10:09:03:37412
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Chassis Type: 3C0
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 62
          72 77
VIN: WVWZZZ3CZAE183008
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 GL    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 9972
   Revision: --H23---    Serial number: 00000000000000
   Coding: 00114036032401080000
   Shop #: WSC 99999 1023 2097151
   ASAM Dataset: EV_ECM16TDI02103L906023GL 003013
   ROD: EV_ECM16TDI02103L906023GL.rod
   VCID: 76E9977CC9DC22E
6260 - Engine Start Blocked by Immobilizer
          P1570 00 [032] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 214929 km
                    Date: 2063.14.12
                    Time: 08:27:30
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AK    HW: 3C0 614 109 AK
   Component: J104    C4 440 V2   0027
   Revision: --026---    Serial number: 00000705856727
   Coding: 0033263
   VCID: 67D7CA385676CB6
No fault code found.
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000003
   Shop #: WSC 05311 115 00000
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_Climatronic_VW46.rod
   VCID: 7DFB8850ECEA716
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 AB    HW: 3C8 937 049 AB
   Component: Bordnetz-SG     H57 3204
   Revision: 00H57000    Serial number: 00000003978127
   Coding: F1980F0700041A14470000000F00000000115D433200012C000308000000
   Shop #: WSC 05124 123 12345
   VCID: 71E3A46068B2056
   Subsystem 1 - Part No: 3C1 955 419 B  Labels: 1KX-955-119.CLB
   Component: Wischer 180610 006  0208
   Coding: 00046997
   Shop #: WSC 05124
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     041209 054  0402
   Coding: 00471080
   Shop #: WSC 05124
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revision: --------    Serial number: 08791015951757
   Coding: 100002
   Shop #: WSC 05314 000 00000
   VCID: 32616B6C6D347EE
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 N    HW: 5N0 959 655 N
   Component: J234__005 VW10 HI   1916
   Revision: 21014000    Serial number: 003GHPC1NS1/
   Coding: 0012341
   VCID: 489529843BA8E4E
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 569 T    HW: 5K0 953 569 T
   Component: LENKS.MODUL   016 0140
   Revision: --X01---    Serial number: 20130527101024
   Coding: 118A270002
   Shop #: WSC 31525 123 104857
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   ROD: EV_VW360SteerWheelUDS_VW46.rod
   VCID: 49932C80E8A21D6
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H06 0022
   Coding: E20000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 872 G    HW: 3C0 920 872 G
   Component: KOMBI         H03 0305
   Coding: 161D00
   Shop #: WSC 05314 115 12345
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
   VCID: 29538C0048E23D6
Address 19: CAN Gateway        Labels: 3C0-907-530.lbl
   Part No SW: 3C0 907 530 N    HW: 3C0 907 951
   Component: J533  Gateway   H14 0172
   Revision:   H14       Serial number: 1021G10616003B
   Coding: F9A07F06400603042002
   VCID: 2C5D75148F1028E
   VCID: 7AF1834C35C446E
   Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 3
                    Reset counter: 26
                    Mileage: 214348 km
                    Time Indication: 0
                    Date: 2127.14.01
                    Time: 13:31:38
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 6
                    Reset counter: 28
                    Mileage: 214348 km
                    Time Indication: 0
                    Date: 2127.14.01
                    Time: 13:31:28
Address 37: Navigation (J794)       Labels: 3C0-035-270.clb
   Part No SW: 3C0 035 270 B    HW: 3C0 035 270
   Component: RNS310        H15 0357
   Revision: 10000000    Serial number: VWZ1Z2K6271808
   Coding: 020004010400000000000000
   ASAM Dataset: VW_RNS310 A02005
   ROD: VW_RNS310_VW46.rod
   VCID: 1933BCC01882AD6
Address 42: Door Elect, Driver (J386)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 3C0 959 701     HW: 3C0 959 793
   Component: TUER-SG FT    002 0305
   Revision: 13101005    Serial number: 0001034465
   Coding: 0204B5
   ASAM Dataset: EV_DCU42BroseDriveSide A03004
   ROD: EV_DCU42BroseDriveSide_VW46.rod
   VCID: E5CB4030E47A596
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 3C0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000001535707
   Coding: 000490
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.204 0802
   Revision: 1AH03729    Serial number: 00101600003001
   Coding: 0000258
   Shop #: WSC 31525 000 1048576
   VCID: 3B7F46487A7EBF6
00750 - Warning Lamp
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 29
                    Mileage: 215053 km
                    Time Indication: 0
                    Date: 2127.14.18
                    Time: 17:37:21
             Freeze Frame:
                        Term 15 On
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    (no units): 4.0
                    Voltage: 11.40 V
   Coding: 0391028051034E7630069C1D70084FCE707C01
   Shop #: WSC 05311 123 12345
   Part No: 1K8 951 605 A
   Component: LIN BACKUP HORN H11 9004
   Part No: 3C0 951 171 C
   Component: Neigungssensor  004 0611
   Component: Innenraumueberw.004 0611
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 5
                    Reset counter: 3
                    Time Indication: 0
Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 3C0 907 951
   Component: EZE_2         H14 0172
   Revision: --------    Serial number: 1021G10616003B
   Coding: 00000000
   VCID: E6C9473C117C52E
Address 52: Door Elect, Pass. (J387)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 3C0 959 702     HW: 3C0 959 792
   Component: TUER-SG BT    002 0305
   Revision: 15101005    Serial number: 0001039343
   Coding: 0204B4
   ASAM Dataset: EV_DCU52BrosePasseSide A03004
   ROD: EV_DCU52BrosePasseSide_VW46.rod
   VCID: E6C9473C197C52E
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 3C0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000001522426
   Coding: 000490
Address 53: Parking Brake        Labels: 5N0-907-801.clb
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   011       Serial number: 00000000323615
   Coding: 0000056
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 1K0 907 534     HW: 3C0 907 951
   Component: Batt.regelung H14 0172
   Coding: 030B085A
   VCID: E8D549041B6844E
   Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0125
Address 77: Telephone (J412)       Labels: None
   Part No SW: 3C8 035 730 C    HW: 3C8 035 730 C
   Component: Telefon       012 0822
   Revision: --------    Serial number: 35909603486827
   Coding: 020004000100010000000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_UHVPremi A02705
   ROD: EV_UHVPremi_VW46.rod
   VCID: 234F9E282ACEE76
9458451 - Cellular Antenna
          B1053 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 198919 km
                    Date: 2053.14.24
                    Time: 17:32:24
End   ---------------------------------------------------------------------
de obicei este blocatorul / ELV-ul.
Immobilizer - 3C0905861H ?  Legat de faptul ca nu a dat niciodata eroare cand afara era cald, sau ca nu da nici o eroare dupa ce am mers cu masina, opresc si repornesc sa zicem dupa 10-30 min... nu poate fi ceva senzor? NU am treaba sa schimb Immobilizerul daca acela ar fi... costa 500 RON nou, ii irelevant costul, vreau doar sa se rezolve problema :)
Modificat de Spyd3r
cam 1000 lei te duce cu tot cu inlocuirea lui.
nu pot sa iti zic daca e rece/cald... de ce face asa, cam greu cand nu ai masina sa verifici - poate sa fie si o problema la calculator colona, contact, etc... din pacate asa cum ti-am scris mai sus, nu se poate garanta de la tastatura, care piesa e 100% de vina, in cazul tau.
bateria ai zis ca e perfecta - daca da, o eliminam din calcul.
Ce am uitat sa mentionez, cand ii rece afara, cand bag prima data cheia in contact, face primul click ( se aprinde volanul galben ) dupa care o apas la al doilea click ( cand se aprind becurile din bord ) este cand dureaza vreo 5 secunde pana se aprind becurile din bord. Daca ii cald afara sau am umblat ceva cu masina sau aleator si cand ii rece daca bag cheia becurile se aprind instant. Ii normal delay`ul respectiv? Banuiesc ca se leaga si de eroarea de column defective intr`un fel.
Exact asa face si la mine, daca e frig sau a stat masina nepornita ceva timp dureaza cateva 2-3 secunde. In rest se se deblocheaza volanul (cred) aproape instantaneu.
e posibil - au fost si cazuri fericite, cand au scapat doar cu inlocuirea bateriei.
Am gasit si eu eroarea magica cu VCDS, dar nu mi s-a intamplat ceva deosebit in mers sau sa imi ramana in bord vreun volan aprins.
Credeti ca este vreun warning sa ma astept la ce e mai rau?
   Part No SW: 3C0 959 433     HW: 3C0 959 433
   Component:    IMMO         038 0347
   Revision: 00038000    Serial number: VWZCZ000000000
   Shop #: WSC 62971 000 1048576
   VCID: E7DDDD17D6988F26B59-80B2
   Subsystem 1 - Part No: 3C0 905 861 J
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 7
                    Fault Frequency: 2
                    Reset counter: 186
                    Mileage: 171527 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:49:03
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 M    HW: 3C0 614 095 M
   Component: ESP 440 C2     H015 0001
   Revision:  H015       Serial number: 0657655365
   Coding: 0013569
   Shop #: WSC 00028 028 00001
   VCID: 2C57E23B8FFEEC7E18B-8079
02840 - Wake-Up Line from Central Convenience Module
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 186
                    Time Indication: 0
Da, posibil sa te lase blocatorul de coloana de volan.
verifica si bateria masinii, sa nu fie obosita/descarcata.
Bateria are 6 luni si nu cred sa aiba vreo problema.
