Tremor In Pedala De Ambreiaj
mihaintz
Citat COPY-PASTE
Clutch pedal switch F36
The clutch pedal switch F36 is installed directly at the
clutch pedal. The current position of the clutch pedal is
signalled to the electronic control unit by means of this
switch. The switch is designed as an N.C. contact.
Analysis of signal
The signal of the clutch pedal switch is used to influence
the injected quantity control. The quantity of fuel
injected is reduced for a short time in order to improve
smooth running during a gear change.
Substitute function
If there is a fault in the signal, this reduction of the
quantity of fuel injected is not carried out.
Self-diagnosis
Malfunction of the clutch pedal switch F36 is not
stored by the electronic control unit.
Pe scurt: Switch-ul pedalei de ambreiaj are rolul de a transmite informatia la ECU, marind alimentarea cu scopul mentinerii motorului in turatie, in timpul schimbarii vitezei.
Eu inteleg ca scade pt. o perioada scurta, daca ar fi cum spui tu ar trebui sa nu scada turatia la schimbarea vitezelor.
The quantity of fuel injected is reduced for a short time in order to improve smooth running during a gear change. o traducere aproximativa,
Cantitatea de conbustibil injectata pt o perioada scurta de timp este redusa pt. a imbunatati functionarea corecta a motorului la schimbarea vitezelor.
*reduce...da....scuzati! :cool:
