Probleme Cu Inchiderea Centralizata
bluewave
8 hours ago, Sebisebi said:
Deci...am inteles bine? Pot sa iau o alta cheie sh si sa invat telecomanda aceea sa functioneze la centralizarea mea
Da
Nu stiu daca este inchis acest topic si sincer nu prea am inteles eu foarte bine unele raspunsuri. Vreau sa va arat si eu rezultatul de la diagnoza facuta pe masinuta mea.
Audi A3 8P1 Sportsback 2009 1.4 TFSI 125CP
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K093240F71
   Coding: E9A17F06100602002102
   Shop #: WSC 06314 000 00000
   VCID: 377DCD5746B85FA6659-8062
00470 - Combination comfort Databus in Single Wire
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 20
                    Mileage: 184167 km
                    Time Indication: 0
                    Date: 2019.12.03
                    Time: 11:45:07
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 8P0 959 802 J    HW: 8P0 959 802 J
   Component: Tuer-SG         H03 0060
   Coding: 0004348
   VCID: 4385A98702600306C91-8016
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
            008 - Implausible Signal
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000216
   Shop #: WSC 06314 000 1012544
   VCID: 4189A38F187C1116DBD-8014
00930 - Locking Module for Central Locking; Rear Left (F222)
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000216
   VCID: 428BAC831D7A0A0EC27-8017
2 Faults Found:
01554 - Motors for Central Locking; Rear Doors; Lock
00931 - Locking Module for Central Locking; Rear Right (F223)
Inchizatorile de usi, merg cand vor ele. Usa dreapta fata merge cand doreste la fel ca si cea stanga spate. Problema lor e ca se deschid doar din interior si apoi functioneaza perfect pana la urmatoarea blocare.
Considerati ca e o problema mecanica sau una electrica? Daca este o problema electrica cum as putea sa o rezolv?
Va multumesc mult.
Modificat de cogdao
Off topic
Legat de incuietori, ca doar despre asta se vorbeste aici, ai o problema cu broastele, trebuie date jos si reconditionate.
Salut @Al Bundy, poti sa dai detalii despre metoda de reconditionare? Eu am schimbat o broasca si m-a tinut cateva luni pana a inceput sa faca la fel cum a descris @claudiulu.
O scriem pe forum,de foarte mulți ani.... Jos yala, desfăcut, refăcut lipituri placa electrica, curățat colector motoraș /motorașe, înlocuit switch cu altul tot saia burgess.... Și o sa fie ca noua.
LA A3 nu avem lipituri pe placa electronica si nici switch de inlocuit, doar curatare colector motorase.
La A3 8P....nu. La altele, da. Depinde despre ce mașina este vb, important e ca informația exista pe topicul /topicurile fiecărui model, era suficient sa o caute.
Sper ca lămurirea nu era pt mine....
BMNcelMaiReusitMotor
Am si eu o problema cu inchiderea centralizata la A3.. initial nu se mai descuia doar usa stanga fata, acum nici cea din dreapta fata nu se mai deschide decat pe interior..
Aveti vreo idee care ar putea fi problema? Si eventual o recomandare unde se poate repara prin Targoviste/ Bucuresti?
Problema este de la broaste , se reconditioneaza.
Rog puneti mana si cititi topicul inainte de a pune intrebari la care s-a mai raspuns!
Cea mai banala treaba e sa incercati cu un spray de degripare sa dati in interiorul broastei, de cele mai multe ori se aduna mizerie si nu mai lucreaza, ideal ar fi sa o degripati temporar si cand aveti timp totusi sa o desfaceti pentru ca de curatat curatati cu spray-ul dar are nevoie si de vaselina
La A3 8P? Nu... Nu ajuta. Problema este la colectoarele motoraselor. Deci, pana nu desfaci, degeaba.
Salut,am si eu o mica problema.
Am schimbat modul de inchidere la un audi a3 8l din 2000,1.6 benzina,modul nou este acelasi cod cu cel stricat,toate bune si fruoase
Singura problema este dupa ce pornesc masina la un interval de 5 min se aude modulu cum bazaie si se aprind plafonierele,
Trebuie facute ceva codari desi modul nou este cu acel cod ca si cel vechi,cod modul este  8L0 862 257 L
F l o r i n
Folosesti codarea pompei vechi
Pompa vechie s-a ars nu se poate recupera codarea...O alta varianta sa o codez exista??
F l o r i n
Ba da, ii refaci codarea in functie de masina, etc
Salut,am schimbat pompa vacum inchidere centralizata cu cod 8L0 862 257 L cu o pompa cu acelasi cod si la codare surpriza
Nu raman codarile si cu modul nou am eroarea asta
Incearca sa cureti mufa cu spray de contacte.
Am curatat si mufele, pe modul airbag nu am nici o eroare..eroarea din poza de mai sus aia ar sugere.. Poate a mai patit cineva asa ceva si ma poate ajuta cu un sfat, imformatie...
Florin am incercat asta, cu modul vechi nu dadea eroarea asta. Problema este ca nu merge codat modulu.. Din cauza la eroarea asta imi descuie usile si plafonierele raman aprinse. Este posibil ca modulu sa aive probleme?
F l o r i n
Posibil. Incearca sa scoti firul care duce de la pompa la modul airbag. E adevărat,  in caz de impact nu itinva descuia automat usile, etc
Am comandat alt modul,sper ca sa nu mai am prob cu el ca ma costat mai mut scanari codari etc decat modulu in sine......
Si totusi daca sti care e firu ce duce la modul airbag sa incerc in caz ca si pe al 2 modul am aceiasi problema:))
F l o r i n
trebuie sa ma.uit pe.diagrame,.nu-l stiu din cap, mai ales la modele asa vechi, care le mai fac foarte rar.... daca nu se rezolva cu celalalt modul, imi dai an fabricație , cod motor....si iti verific
Ok o sa revin cu raspuns cand pun modul nou,teoretic ar trebui sa mearga eu nu aveam prob de genu asta pana sa se strice modulu vechi...
Eroarea aia de modul airbag o da doar cu modul bagat si pe modul airbag scanat nu da nici o problema pe el..
