Cutie De Viteze Automata - Probleme & Intretinere (Touareg 7L)
Bobbym
cam astea cred ca ar fi mai importante
4 Faults Found:
18049 - Please check DTC Memory of A/C Controller
            P1641 - 000 -
             Freeze Frame:
                    RPM: 756 /min
                    Torque: 58.6 Nm
                    Speed: 41.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00001111
                    Temperature: 82.8°C
                    (no units): 128.0
  Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 E
   Component: ESP ALLRAD MK25     0202
   Coding: 0006402
   Shop #: WSC 31414 000 00000
   VCID: 3B7581ED7965A792C0-5178
02054 - Control Module for Differential Locks (J647)
            013 - Check DTC Memory - Intermittent
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 K
   Component:                     2703
   Coding: 0103652
   VCID: 4487FA11049BD86AB1-515A
2 Faults Found:
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
00907 - Intervention load Management
            000 -  -
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000031
   VCID: 408FF6011083C44A95-5178
2 Faults Found:
01750 - Multi-Function Switch in Steering Wheel (E440); Left
            008 - Implausible Signal
01317 - Control Module in Instrument
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 815 071 B
   Component: Standheizung  E1MAC 0235
   Coding: 0000000
   Shop #: WSC 00000 000 00000
   VCID: 3169A3C5AB295DC26A-515A
4 Faults Found:
00664 - Fuel gauge
            002 - Lower Limit Exceeded - Intermittent
00667 - Ambient Temperature Signal
01126 - Engine Speed Signal
00455 - Control Module for Access and Start Control; Comfort CAN
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879
   Component: JCI PathPoint       1700
   VCID: 04073A11441B186AF1-515A
2 Faults Found:
00480 - Control Module in Instruments for Infotainment CAN (J285)
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Address 22: AWD        Labels: None
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F0DB5FD2DFD7BB2AC-515A
No fault code found.
Address 32: Differential Locks        Labels: None
   Part No: 0AC 927 771 B
   Component: SG-Quersperre       5018
   VCID: 377D9DDD454D83F224-515A
2 Faults Found:
02412 - Differential Lock Rear
            003 - Mechanical Failure
01317 - Control Module in Instrument Cluster (J285)
Modificat de Andrei_72
Regulamentul interzice citarea postului anterior!
aici clar avem o problema...de aceea ai stocata si eroarea pe cutie
O altă părere ar fi că este posibil să fie blocul hidrauluc
  • 9 months later...
Salutare am și eu ceva probleme la un Touareg V6 225cp a început cutia de viteze sa smuceasca când schimba in alta treapta indiferent ca e in superioară sau inferioară are cineva idee de la ce pote fi ?
Detin un Touareg 7L R5 TDI din 2005, cutie automata tiptronic, la care ma bate gandul sa-i fac retrofit la padele schimbator volan. Padelele le-am gasit, insa nu si cablajul de la modulul steering wheel pana la modulul transmisiei de sub scaunul pasagerului (am citit despre acest retrofit pe forumuri din US, unde aceasta optiune nu a fost disponibila).
Intrebarea mea este daca exista vreo sansa ca masinile cumparate din Europa sa aiba deja cablajul sau daca nu-l are, unde il pot gasi/produce?
Stima!
@Psgeorge : Baga un scan prima oara, apoi ar trebui sa verifici uleiul,grupul de valve
Modificat de ovydik
salut. am facut retrofit-ul acesta in urma cu aproximativ 2 luni. cablajul nu exista pe masina, daca aceasta nu a avut optiunea respectiva.eu am procedat in felul urmator: pt pinii care intra in modulul de sub scaunul pasagerului, am cumparat 2 seturi de reparatie fire, de aici: https://www.ebay.com/itm/Audi-VW-Skoda-Seat-repair-wire-000979019E/171380860992?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 . a durat cam 1 saptamana jumate parca, pana a ajuns. au 30 cm. am cumparat si conductor electric de 0,5 mm, in jur de 3,5 metri. am ales sa tai mufa padelelor, si sa pun o mufa din aceea comuna, cu 2 pini.: https://componenteonline.ro/Cablu-alimentare-DC-2-pini-lungime-30cm-400341
nu mai stiu exact in ce loc din modul trebuie fiecare din cele 2 fire, parca rosu la pinul 13, si negru la 17.daca e absolut necesar, pot sa sap dupa instructiunile ce le-am foslosit eu, gasite pe un site rusesc. atentie , dupa modificare, e necesar sa se schimbe codarea transmisiei cu VCDS. dupa schimbare codare, poti schimba cu padelele in drive, in tiptronic si parca si in sport(nu am incercat inca).daca schimbi in drive, si nu le folosesti foarte mult, cutia revine la schimbarea automata. daca vrei sa folosesti doar padelele, cel mai bine pui cutia in mod tiptronic.
@dark_ang3l multumesc mult! Exact raspunsul la care speram! A fost greu sa tragi firele pana la modul? Am gasit pe clubtouareg instructiunile, pare destul de usor. Ma pun pe comandat piesele si ma apuc de treaba. Trebuie sa dau berea cu prima ocazie!
nu a fost greu. trebuie sa dai volanul jos si plasticele ce il inconjoara, sa desfaci cateva plastice de la consola centrala, montezi padelele, conectezi firele la mufa, faci codarea si cam atat. atentie la codare, daca nu ma insel, este diferita la facelift fata de modelul mai vechi. eu am decis sa protejez firele cu tub termocontractil, ca sa stau mai linistit.nu prea imi place sa las fire in aer, neprotejate.  uite inca 2 link-uri pt cei interesati de acest retrofit. sunt in rusa, dar se poate traduce in limba dorita cu google translate:
https://www.drive2.ru/l/489662831579365599/?page=0#comments
https://www.drive2.ru/l/9549099/
succes.
Buna ziua .Am și eu un Touareg 2006 automat  3.0 d
Aceasi problema cu smuciturile am și eu dar la plecarea de pe loc în drive și când merg foarte încet. Daca incepe și schimbă nu are nicio problema doar când plec de pe loc accelerat încet. Aveti idee ce ar putea fi , ulei cutie ,cutie transfer?
pana la urma mi-am instalat singur padelele, insa nu as fi reusit fara ajutorul lui dark_ang3l, caruia ii multumesc maxim pe aceasta cale. Am facut codarea cu ODIS, nu stiu sigur ce cod, a avut optiunea sa bifez Tiptronic Switch si aia a fost. In schimb, am observat un comportament total schimbat al cutiei dupa codare, la 35 km/h e in 4, la aproape 70 e direct in 6 si da cate 2-3 trepte in jos la acceleratie puternica.
ca retrogradeaza 2-3 trepte cand accelerezi puternic este perfect normal altfel la 70km/h respectiv treapta 6 cand vrei sa te bagi in depasire iti trebuie "1km" :)
Stiu ca e perfect normal, dar pana acum daca vedeam a-6-a la 100. acum nici nu plec bine de pe loc ca e a 4-a. Momentan nu ma deranjeaza cu nimic, ba chiar de la 19-20 l/100 am 16-17 acum in Bucuresti, fix aceleasi trasee. Eram mai mult curios daca a mai intampinat cineva, oricum fac un scan si postez aici codarea, stiu sigur ca nu e 0004153  cum recomanda toti pe net.
Modificat de ovydik
  • 10 months later...
Intrebare scurta si la obiect
Cat de fiabila este cutia automata in tractari cu platforma dubla (3500 kg) ?
Salutare. Proaspat posesor de Touareg 2.5 BAC automat. De cateva zile mi se aprine PRND insa nu am niciun simptom la masina. Schimba bine, nu smmceste, nu patineaza. Eroarea este P0841 transmission fluid pressure sensor/switch a circuit range/performance. Mentionez ca eroarea a aparut dupa schimbul de ulei si filtru ale cutiei (preventiv). Daca sterg eroarea PRND se stinge si ramane stins o perioada. Cutia functioneaza normal atat cu PRND aprins cat si stins. Poate a mai patit cineva si imi poate da ceva sfaturi de unde sa incep. Multumesc anticipat.
Vă salut am dat si eu de probleme la cutia de viteze la un touareg v6 3.0l cutie automata am schimbat rulmenți pe față și după ce mi a schimbat mecanicu am plecat cu ea și după 1km nu vrea să mai plece de pe loc inainte de asta cutia nu facea nici o problemă mergea perfect, va rog dacă aveți vreo idee de unde ar fi problema ,pe valiză nu dă nici o eroare va mulțumesc dacă aveți vreo idee
