Cheie contact - procedura de recodare
robert r.
mai sus spunea gokey ca nu merge cu vag-comu' :D
Pentru programarea transponderului (chip) iti trebuie acel PIN cu care te loghezi in vagcom.
gokey se referea la aflarea acelui cod PIN care, intr-adevar, nu se poate face cu vagcom ci, cu una din interfatele pe care le-am enumerat eu mai sus
Cred ca asta e procedura cu vagcom:
[select]
[17 - Instruments]
[Meas. Blocks - 08]
Select Block 022.
[Go!]
The value in field 3 must be 1. If value is not 1, the key is not capable of being adapted to Immobilizer.
You can check each key in this manner.
Select Block 024.
[Go!]
Make sure the shown lock times in field 1, 2 and 3 are 0 (each field represents a time in minutes).
* If the lock times are NOT 0:
o Do NOT switch off the ignition!
o Allow the car to sit for AT LEAST the number of minutes that were indicated by the fields 1-3.
[Done, Go Back]
[Login - 11]
There are 2 possibilities how to enter a PIN, choose the one that applies for you.
* 4-digit PIN
o Enter zero followed by the 4-digit PIN. For example, if your PIN is 1234, enter 01234.
* 7-digit PIN
o [use 7-digit PIN/SKC]
o Enter the 7-digit PIN, Date on which the PIN was generated by the dealer, along with the Workshop Code (WSC) and the Importer number of the dealer that generated the code.
o [OK]
o VAG-COM will validate the data you have entered and return you to the Login screen, where the Login Code will show as "XXXXX".
[Do it!]
[Adaptation - 10]
Enter 21 in "Channel Number".
[Read]
The "Stored Value" is the number of keys currently matched.
Enter a "new value" corresponding to the total number of keys to be matched, including any existing keys.
The old keys are automatically beeing cleared.
[save]
[Done, Go Back]
[Close Controller, Go Back - 06]
* Repeat the following steps until all keys have been matched:
o Switch ignition off and remove key.
o Insert next key to ignition and switch ignition on again.
o The warning light for the Immobilizer will light up for ~2 seconds, then go out Switch ignition off and remove key.
Note: The above steps after saving the adaptation, should not exceed 60 seconds!
Modificat de cuiuda
avand in vedere ca nu multi stapanesc engleza la perfectie(mai ales noi cei din vechime)
se poate descrie aceasta procedura in romana?
cu vag-com nu poti afla codul pin, dar daca il ai poti adapta cheile
cu vag tacho poti afla codul pin si poti si adapta cheile
de aceea am spus de ambele interfete
va multumesc
Modificat de joky
Exista google translate
[selecteaza]
[17 - Instruments]
[Măsuri. Blocheaza - 08]
Selectaţi Bloc 022.
[Du-te!]
Valoarea
mersi
stiam cu google translate
eram nelamurit de faza finala
in care spune sa introduci cheile,
cand introduci cheile se opreste motorul
nu se deconecteaza si interfata in acel moment?
asta vroiam eu sa stiu un pic mai in detaliu
operatiunea de codare nu se face cu motorul pornit !!!
Eu am acel plastic, livrat odata cu cheile din fabrica.
Am numai o cheie, cealalata inca nu functioneaza, tre adaptat cipul. Am fost mai demult la un atelier de confectionat chei, a facut lamela, mai trebuie adaptat cipul, care zicea nenea de acolo ca se poate rescrie, dupa ce a bagat cheia intr-un aparat.
Are cineva procedura de invatare a telecomenzi(cheie briceag) ?
@misu
Intri in modulul confort [46] apoi in adaptari [10] si :
Adaptation
Channel 00: Remote Control Clearing
Channel 01: Remote Control Adaptation
L.E. daca ai si acel plastic inseamna ca poti programa si cipul din cheie
Modificat de cuiuda
cu conditia sa fie pe el codul din 4 cifre !
Doar atit, la adaptarea telecomenzi ?
Cheia trebuie sa fie in usa ?
Eu am atasat un cartonas la cheia din plastic pe care este trecut un cod din 6 cifre.
Ma poate ajuta sa memorez una din chei ?
nu , acel cod nu te ajuta
trebuie sa fie un copd dim 4 cifre
sau un cod din 7 cifre
acesta imsa trebuie convertit in tr-o combinatie de 4 cifre
pentru asta insa ai nevoie de ziua/ luna / anul emiterii codului + cod dealer + cod importator
Am rezolvat.Cu cheia in broasca se face cel putin la mine.
Asta a fost procedura:
1.Inchide usile si geamurile
2.Cheia in broasca (la sofer)
3.Descuie mecanic de 3 ori (0,5 sec fiecare rasucire)
4.Scoate cheia (se aprinde LED-ul de la usa)
5.Apasa si tine apasat max 5 sec. but."incuiat"
si simultan apasa "descuiat" de 3 ori
6.Elibereaza butonul "incuiat"
7.Incuie manual ca sa termini operatia
8.Asteapta 15 sec.
Operatia era pt modelul vechi de cheie(nu asta briceag) dar a mers.
vezi si asa :
1. apesi pe butonul de deschis usa
2. pui contact
3. cum se stinge immo iei contactul
4. scoti cheia
5. apesi iara pe butonul de deschis usa
cheia e gata !
Salutare tuturor!! Cred ca si ce va scriu eu acum este o problema serioasa!!!!! Am pierdut un rand de chei la masina, am sunat la Craiova si au zis ca se rezolva problema in doua saptamani!!! Exista alta solutie pt a face rost de o cheie!!!
Cu respect!!!!
masina este cea din semnatura, fab. 2007
Modificat de horias
Trimite-i un PM lui gokey, Nu e asa departe de tine si te poate rezolva.
Se mai pot afla altfel urmatoarele 2 : 4-digit PIN
7-digit PIN
[OK]
De unde determin :"Date on which the PIN was generated by the dealer, along with the Workshop Code (WSC) and the Importer number of the dealer that generated the code."
Se pare ca pe cheia de plastic am codul din 7 digiti. (am un cod pe doua randuri, care cred ca e pinul. Pe primul rand 2 cifre si pe al doilea restul de 5, iar pe cealalta parte a cheii am un cod de 7 cifre care incepe cu W. Cel care incepe cu W nu e acceptat ca pin, ramanand doar primul.)
Am introdus tot dar imi da "bad combination" in wag com.
Daca aveti habar cum aflu Data la care s-a generat pinul, WSC si Importer number spuneti-mi si mie va rog.
Modificat de Ace2
La reprezentanta, daca ai noroc sa iti dea aia codul. Tre sa faci dovada ca tu esti proprietarul.
Si eu sint in acest caz ca tine. Tre sa merg la reprezentanta, sa vad ce rezolv.
Mi- a cerut la un atelier 150 ron, sa imi programeze o cheie noua.Eu cheia o am, cip, telecomanda, doar tre programata.
Vorbeste cu un coleg sa iti citeasca PIN-ul si sa iti reprogrameze noua cheie !
Bafta !
cautati pe cine are vag tacho 2.5
cu asta se poate citi, evident si cu alte softuri specializate
