Probleme generale geamuri electrice Fabia
charisman
nu, doar speram sa aiba legatura cu problema mea... Cred ca ma apuc de demontat usile.
Am mai facut o scanare dupa ce am inlocuit o siguranta arsa:
VAG-COM Version: Release 409.1-USChassis Type: 6Y - Skoda FabiaScan: 01,02,03,08,09,15,17,19,37,44,46,56,69 -------------------------------------------------------------------------------Address 01: Engine   Controller: 047 906 033 E   Component: 1,4l SIMOS3PA   00HSSJ34   Coding: 00031   Shop #: WSC 13765   TMBNH46Y013251670     SKZ7Z0A08971742 Faults Found:17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit            P1118 - 35-00 - -16524 - Oxygen (Lambda) Sensor B1 S2: No Activity            P0140 - 35-10 - - - IntermittentReadiness: 0010 0001-------------------------------------------------------------------------------Address 03: ABS Brakes   Controller: 6Q0 907 379 C   Component: ABS 5.7     FRONT   V00   Coding: 00044   Shop #: WSC 13765No fault code found.-------------------------------------------------------------------------------Address 09: Cent. Elect.   Controller: 6Q1 937 049    Component: BORDNETZ-SG.        1S30   Coding: 09234   Shop #: WSC 137654 Faults Found:01336 - Data Bus for Comfort System            49-10 - No Communications - Intermittent00966 - Fuse for Blinkers (S151)            37-10 - Faulty - Intermittent00900 - Fuse for Signal Horn (S194)            37-10 - Faulty - Intermittent00969 - Fuse for Heated Rear Window (S41)            37-10 - Faulty - Intermittent-------------------------------------------------------------------------------Skipping Address 15-Airbags-------------------------------------------------------------------------------Address 17: Instruments   Controller: 6Y1 919 880 C   Component: KOMBIINSTRUMENT VDO V09   Coding: 16141   Shop #: WSC 13765   TMBNH46Y013251670     SKZ7Z0A0897174No fault code found.-------------------------------------------------------------------------------Address 19: CAN Gateway   Controller: 6N0 909 901    Component: Gateway K<->CAN    1S30   Coding: 00014   Shop #: WSC 137651 Fault Found:01336 - Data Bus for Comfort System            49-10 - No Communications - Intermittent-------------------------------------------------------------------------------Address 44: Steering Assist   Controller: 6Q0 423 156 G   Component: Lenkhilfe           0004   Coding: 00110   Shop #: WSC 000001 Fault Found:00816 - Power Steering Sensor (G250)            30-10 - Open or Short to B+ - Intermittent-------------------------------------------------------------------------------Address 46: Central Conv.   Controller: 6Q0 959 433 A   Component: 04 Komfortgerát     0002   Coding: 00067   Shop #: WSC 13765No fault code found.End   --------------------------------------------------------------------------------------------------
Banuiesc ca problema ar fi descrisa in partea cu confort bus etc, dar ce anume trebuie facut in continuare? Merci mult ptr promptitudine!
Daca se poate o intrebare. La masina mea ( Skoda fabia din 2003 ) cumparata anul trecut am o mica nelamurire. Cand pornesc motorul se incuie usile si se blocheaza geamurile - nu mereu -. Am vorbit cu fostul proprietar de aceasta problema si mi-a spus ca asa face masina cand e frig ( probabil de la o anumita temperatura in jos ), si daca vreau sa nu se mai blocheze, sa poresc motorul dupa ce se incalzeste masina si cand o sa-l pornesc cu masina calda nu se mai blocheaza usile si geamurile. Am incercat si a mers, dar e normal, si daca da nu se poate deafecta aceasta setare?
Esti prima persoana la care aud de acest lucru, respectiv comfortul sa reactioneze la temperaturi scazute by default. Parerea mea este ca e o setare a alarmei aftermarket daca ai asa ceva, sau o problema in modulul comfort
Cand am fost la RAR ca sa verifice gazele, etc. si sa pot plati timbrul de mediu, cand mi-a returnat-o, inspectorul a zis: "sa va reparati inchiderea electrica a geamului, ca nu se inchide". Pentru ca oprise motorul si se "resetase" chestia cu geamul ( ramasese deschis) doar am apasat pe buton si sa inchis geamul. Sa vezi ce fata a facut...
Modificat de lucian.1950
  On 27.01.2015 at 16:57, Piticot7000 a scris:
de setare nu poate sa fie vorba, din pacate.
o problema pe la modulul confort - da, poate sa fie.
fa o scanare si vezi ce erori gasesti stocate
Doamne nu-mi vine sa cred! Am dezmembrat usile: in stanga la sofer totul in regula desi nefunctional. Curent vine prin firele groase (rosu/maro). In cealalta mufa nu am gasit curent pe vreun fir. Bun... In usa dreapta am patit la fel ca un coleg mai sus: motorasul, macaraua, sufa si ce mai trebuia sa fie lipseau cu desavarsire! Evident geamul sprijinit de lemnul vietii. Cineva spunea ca ar dispune de toate piesele necesare. Cam care ar fi acelea si care ar fi motivul din cauza caruia in dreapta nu functioneaza butoanele? Multumesc!
Salut! Exista vreo posibilitate prin care pot proba geamurile electrice sa imi dau seama daca defectiunea este din calculatorul din usa soferului?
salut, ai cumva alarma viper? eu am avut probleme cu alarma in ideea ca mi se intampla exact ce ai descris tu (mai putin treaba cu geamurile). am oprit functia alarmei de a incuia usile cand pui contactul si s-a rezolvat.
  On 27.03.2015 at 12:58, Iulian94 a scris:
Subscriu!
alarma e maat si nu cred ca merge sa dezactivez functia de inchidere automata.
Da, exista.
Va trebui demontat motorasul de pe panou, departezi urechiusele care fixeaza calculatorul usii de motoras, scoti placa electronica, iar in interior unde intra placa vei observa 2 pini care alimenteaza motorasul.
  On 29.03.2015 at 16:42, carmina a scris:
Da, exista.
Din nou evaziv... Faptul ca le observam rezolva problema? Exista un +/- acolo sau le alimentam la intamplare?
LE alimentezi la intamplare, nu e evaziv raspunsul.
Inyr-un sens urca, in celalalt coboara. E o masina de c.c. se poate alimenta oricum.
Ok, va multumesc cu scuzele de rigoare!
Multumesc. Unde pot sa fac o scanare ( stau in sectorul 6 ) si cam cat ar costa?
Salutare. Am si eu o problema mica cu blocul comutator geamuri electrice pe partea soferului, mai exact , trebuie sa apas butonul foarte usor (mai cu simt
Ca de obicei foarte punctuală si de mare ajutor. Am desfăcut blocul de comutatoare, am curatat contactele, acum totul funcționează ca la carte. Mulțumesc.
Salut. Am o problema cu geamurile electrice la o fabia si am fost la electrician , a verificat cam tot iar concluzia a fost ca trebui sa schimb calculatorul din usa soferului , insa nu am gasit. Am sunat la 12-13 firme de dezmembrari si nu am gasit. Are cineva idee unde as putea gasi sau daca se poate repara si unde?  Acesta cred ca este codul http://imgur.com/wvXbfay
e mai util sa spui ce problema ai....
Nu imi merg geamurile...doar cel de pe dreapta , cand bag cheia in iala si invart, functioneaza geamul chiar si fara cheie in contact , dar asta doar pana cand pornesc motorul si llec de pe loc. Dupa , numai merge nici acesta.
este foarte posibil sa fie de la calculatorul de usa - daca electricianul ti-a verificat bine, nu ramane decat sa cauti altul in dezmembrari sau nou - destul de scump
il gasesti de cumparat cu tot cu motorasul de la geam - cauta-l dupa codul acestuia.
S-a rezolvat. Am gasit la dezmembrari un calculator , l-am montat si acum functioneaza.Sper sa tina fiindca nu stiu motivul pentru care primul s-a defectat. Ms frumos de ajutor.
Modificat de Iulian94
