Mama Omide
asta nu e factory reset....
On 05.11.2016 at 22:06, andrei_221 a scris:
cum ai dat tu reset de fabrica ?
intri pe lista de activari de pe can si ai optiune acolo
da factory reset eate maine revin cu o scanare totala inca nu am scapat de P clipacind de pe ceasuri..
We could not locate the item you are trying to view.
Error code: 2S328/1
Park si steering assist not registred am rezolvat le-am bifat dar tot am eroare pe Can -module incoret codat
Bundy acea eroare te referi la mine.nu o gasesc
Modificat de CiprianChiriac
nu putem descarca fisierul pus de tine cu autoscanul, aia e eroarea mai .....
48 minute în urmă, CiprianChiriac a scris:
Log-WVWZZZ3CZAE151041-226260km-140591mi.txt
Sper ca va merge de data asta
Sunday,06,November,2016,15:30:10:04550 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64 VCDS Version: 15.7.0.2 Data version: 20150820 www.Ross-Tech.com VIN: WVWZZZ3CZAE151041 License Plate: Mileage: 226260km-140591mi Repair Order: Chassis Type: 3C (3C0) Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 62 72 77 VIN: WVWZZZ3CZAE151041 Mileage: 226260km-140591miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: Not registered 0001 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Not registered 0001 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Not registered 0001 46-Central Conv. -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb Part No SW: 03L 906 019 AC HW: 03L 907 309 F Component: R4 2,0L EDC G000SG 5874 Revision: 22H28--- Serial number: VWZCZ000000000 Coding: 0000072 Shop #: WSC 05311 000 00000 VCID: 6CCFD35BD68B0262D358725-8038 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb Part No SW: 3C0 614 109 AH HW: 3C0 614 109 AH Component: J104 C4 440 V2 0024 Revision: --025--- Serial number: 00000705631808 Coding: 0035323 Shop #: WSC 05311 000 00000 VCID: 64DFBB7B3E5B4A229B889A5-8030 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS Component: Climatronic H15 0709 Revision: 00003001 Coding: 0000000003 Shop #: WSC 05311 115 00000 ASAM Dataset: EV_Climatronic A01006 ROD: EV_ClimaAutoBasis_VW36.rod VCID: 7DE9EE1FBDF1976A7486B79-8028 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl Part No SW: 3C8 937 049 AB HW: 3C8 937 049 AB Component: Bordnetz-SG H57 3204 Revision: 00H57000 Serial number: 00000003948411 Coding: E7980F0700041A00470000000F00000099615D435C00012C000308000000 Shop #: WSC 05124 123 12345 VCID: 71F1C22FF1A9EF8AE00E0B9-8024 Subsystem 1 - Part No: 3C1 955 419 B Labels: 1KX-955-119.CLB Component: Wischer 040510 006 0208 Coding: 00046997 Shop #: WSC 05124 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 270510 054 0403 Coding: 00208936 Shop #: WSC 05124 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb Part No SW: 3C8 919 475 A HW: 3C8 919 475 Component: PARKHILFE 8K H07 0009 Revision: -------- Serial number: 08791013040026 Coding: 100002 Shop #: WSC 05314 123 12345 VCID: 32730D23342F9892D994FCD-8066 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 5N0 959 655 N HW: 5N0 959 655 N Component: J234__005 VW10 HI 1916 Revision: 21014000 Serial number: 003GHP9VUW7+ Coding: 0012341 Shop #: WSC 05311 000 00000 VCID: 48874FCBA2B30E4297B0CE5-801C Subsystem 1 - Serial number: 6332MTS611171110 Subsystem 2 - Serial number: 6342MTS623171260 Subsystem 3 - Serial number: 6351HTS6JL6G89KR Subsystem 4 - Serial number: 6361HTS6LNPG89KR Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb Part No SW: 3C9 953 501 BN HW: 5K0 953 569 AB Component: LENKS.MODUL 009 0135 Revision: FF010036 Serial number: 20100519301140 Coding: 118A270002 Shop #: WSC 05311 115 12345 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 76FBF13398C7C43235FCC0D-8022 Multi Function Steering Wheel Control Module: Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Component: E221__MFL-TK6 H06 0022 Coding: E20000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb Part No SW: 3C0 920 872 G HW: 3C0 920 872 G Component: KOMBI H03 0305 Serial number: 00000000000000 Coding: 161D00 Shop #: WSC 05314 115 12345 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052 ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod VCID: 2941EA4F19F9DBCA68FE139-807C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb Part No SW: 3C0 907 530 N HW: 3C0 907 951 Component: J533 Gateway H14 0172 Revision: H14 Serial number: 1021G105250014 Coding: 99807F06400603042002 Shop #: WSC 05314 123 12345 VCID: 2C4F135B160BC26293D8325-8078 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 191 Mileage: 226262 km Time Indication: 0 Date: 2011.03.29 Time: 23:42:22 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR Component: IMMO 043 0383 Revision: 00043000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 7AE3E503ACDFACD251A494D-802E Subsystem 1 - Part No: 3C0 905 861 H Component: ELV 028 0380 3C0905861H ELV 028 0380 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 686 E HW: 1T0 035 686 E Component: RNS-MID H27 6270 Revision: AB001001 Serial number: VWZ4Z3K1150547 Coding: 08000402040000910000 Shop #: WSC 31136 677 00001 VCID: 367B3133D84784B2F57C80D-8062 Subsystem 1 - Part No: 1T0 919 859 C Component: EU East V13 8350 1 Fault Found: 02877 - Digital Radio Antenna (R183) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 191 Mileage: 226256 km Time Indication: 0 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb Part No SW: 3C0 959 701 A HW: 3C0 959 793 A Component: TUER-SG FT 002 0305 Revision: 12101005 Serial number: 0000919858 Coding: 0210FE Shop #: WSC 05311 115 12345 ASAM Dataset: EV_DCU42BroseDriveSide A03004 ROD: EV_DCU42BroseDriveSide.rod VCID: 265BE17308E7F4B2451C70D-8072 Slave Driver: Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB Component: J388__TSG-HL 004 0401 Serial number: 00000001483966 Coding: 0000D0 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 5N1-909-144.clb Part No SW: 5N1 909 144 L HW: 5N1 909 148 G Component: J500__APA-BS KL.204 0802 Revision: 1AH03729 Serial number: 00101420286001 Coding: 0000258 Shop #: WSC 05311 000 00000 VCID: 3B6D2007E36555DA0A32591-806E No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR Component: KSG PQ46 ELV 043 0612 Revision: 00043000 Serial number: VWZCZ000000000 Coding: 1E91020051034E763007941560084F0B005D01 Shop #: WSC 05311 123 12345 VCID: 7AE3E503ACDFACD251A494D-802E Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb Part No SW: 1K0 907 532 HW: 3C0 907 951 Component: EZE_2 H14 0172 Revision: -------- Serial number: 1021G105250014 Coding: 00000000 Shop #: WSC 05314 000 00000 VCID: 66DBA173C8673432859CB0D-8032 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb Part No SW: 3C0 959 702 A HW: 3C0 959 792 A Component: TUER-SG BT 002 0305 Revision: 14101005 Serial number: 0000947761 Coding: 0210F6 Shop #: WSC 05311 115 12345 ASAM Dataset: EV_DCU52BrosePasseSide A03004 ROD: EV_DCU52BrosePasseSide.rod VCID: 2745EC770FEDEDBA7EEA651-8072 Slave Passenger: Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB Component: J389__TSG-HR 004 0401 Serial number: 00000001481205 Coding: 0000D0 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 5N0-907-801.clb Part No SW: 3C8 907 801 E HW: 3C8 907 801 E Component: J540 EPB3 VW-15417 0007 Revision: 011 Serial number: 00000000292594 Coding: 0000057 Shop #: WSC 05311 000 00000 VCID: 2C4F135B160BC26293D8325-8078 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 686 E HW: 1T0 035 686 E Component: RNS-MID H27 6270 Revision: AB001001 Serial number: VWZ4Z3K1150547 Coding: 08000402040000910000 Shop #: WSC 31136 677 00001 VCID: 367B3133D84784B2F57C80D-8062 Subsystem 1 - Part No: 1T0 919 859 C Component: EU East V13 8350 1 Fault Found: 02877 - Digital Radio Antenna (R183) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 191 Mileage: 226256 km Time Indication: 0 ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb Part No SW: 1K0 907 534 HW: 3C0 907 951 Component: Batt.regelung H14 0172 Revision: -------- Serial number: 1021G105250014 Coding: 030B085A Shop #: WSC 05314 123 12345 VCID: 68C7AF4BC2732242B770AE5-803C Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A Component: J367-BDM H07 0125 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels: 7P6-035-730.clb Part No SW: 5K0 035 730 F HW: 5K0 035 730 F Component: TELEFON H09 2902 Revision: 1B001001 Serial number: 00007661120198 Coding: 0200000100010110 Shop #: WSC 00015 115 12345 ASAM Dataset: EV_UHVNA A01719 ROD: EV_UHVNA.rod VCID: 2847EF4B02F3E2C277F06E5-807C No fault code found. End-------------------------(Elapsed Time: 02:38)-------------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 19:3C0 907 530 N recoded (Installation List) from 99807F06400603042002 to B9A07F06400603042002 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 19: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 19:3C0 907 530 N recoded (Installation List) from B9A07F06400603042002 to B9A07F06480603042002 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 19: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 19:3C0 907 530 N recoded (Installation List) from B9A07F06480603042002 to B9A07F06400603042002 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 19:3C0 907 530 N recoded (Installation List) from B9A07F06400603042002 to B9A07F06400603042002 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 19: DTCs cleared -------------------------------------------------------------------------------- ---------
nu asa ma, sterge aberatia asta, lasa doar post-ul cu link-ul
codeaza si tu cangateway asa cum trebuie, nu vezi ca ai 3 module care nu sunt definite in cangateway ?
Alea unde scrie NOT registered....
Salut! Am un B6 din 2009 CR si as vrea sa fac retrofit la autohold. Stiti cumva cum imi pot da seama daca masina e compatibila inainte sa cumpar butonul si cablajul? Am inteles ca sunt unele pompe ABS care nu suporta AH.
LE: codul pompei ABS 3C0 614 109 S
Modificat de DDsix
added more info
în urmă cu 3 ore, Al Bundy a scris:
le-am bifat dupa ce am facut scan dar nu a disparut eroarea
Inseamna ca ai o interfata de kko, incearca cu una originala.
Am reusit sa scap de eroarile de pe can si de pe stering assist. parallel parking brake si can incorect codat .Nu reusesc sa scap de P de pe clastare culoare galbena clipoceste de la punerea contactului si nu se opreste deloc nici in mers.Am si o scanare actuala .poate ajuta cu ceva  un sfat va rog.
Log-WVWZZZ3CZAE151041-226420km-140690mi.txt
On 10.11.2016 at 9:35, Al Bundy a scris:
Am rezolvat pe Can nu mai am eroare acum tot clipoceste P pe ceasuri bord si am pe steering assist eroarea postata o sterg si imediat reapare.Ma gandesc poate nu am introdusa sigutanta dar m-am uitat si toate care au 2 pini au siguranta .Siguranta arsa sau lipsa ei da pe tester?
Nu mai am nici o eroare dar totusi P de pe ceasuri clipind nu a disparut
-am verificat toate sigurantele sunt ok
-am facut scanare cu alt vcds tot nu am erori
toata treaba asta sa intamplat dupa ce am scos o siguranta din bord si am pus-o inapoi .atunci sa aprins esp abs si acest "p"celelalte sau stins "p" inca nu.
Functioneaza frana de deget ok .numai ca nu se mai deblocheaza singura cu centura pusa.
Un sfat va rog ce sa mai incerc sa scap de "p"care este foarte stresant clipeste neincetat
Am incercat am dat fara parcare laterala codat cu 1 cu 2 toate metodele de pe basic seting ..nici o schimbare
Am dat si pe output test am deschis etrirul si inchis nimic.
Am scos borna baterie..
NU vad eroare pe steering assist, ce eroare ai ?
daca esti sigur ca ai verificat tot si nu scapi de P - clipind - e posibil sa ajungi la inlocuirea calculatorului franei de mana
Este bine asa ?? imi da caa nu vede butonul de frana si cand apas pe el imi arata "pushed" deci il recunoaste?
da, lucreaza - incearca si cu alt calculator de frana de mana - inainte sa il schimbi, sa faci un autoscan sa iti salvezi codarile - o sa ai nevoie de ele la inlocuirea calculatorului franei de mana.
Salutare grup, Si eu am problema cu frana de mana, la mine apare numa P-ul taiat galben, si cate-o data dispare in mers si reapare dupa cateva secunde, mi frica sa folosesc frana de mana ca exista riscul de a mi se bloca. am schimbat butonul (este nou-original) am schimbat calculatorul de frana de mana (care se afla sub cotiera) acuma nu mai stiu ce sa mai fac :| ce solutii imi dati ? multumesc !
P.S. Cand ii fac diagnoza, imi da ca ar fi de vina butonul, dar 100% nu este de la buton, este nou, original, am incercat si cu alt buton de la un prieten care are tot un passat b6 si nici cu ala nu a mers.
Modificat de goro89
goro - original, de la reprezenta/magazin sau de pe olx, etc ?
butonul comunica cu calculatorul franei de mana - daca ai schimbat tot, verifica cablajul
Totodata, posteaza logul cu eroarea, exact asa cum apare ea
    • Wolf2016
