Alarma OEM incepe sa faca probleme
bogdanbacila
Buna seara dragi colegi,
Incerc sa va descriu scurt si la obiect problema cu care ma confrunt, pentru masina personala VW Golf 6 2011 1.4 TSI CAXA 122cp:
- In aceasta seara alarma (originala de fabrica) a inceput sa sune, bineinteles cu becurile de avarii luminand ca un pom de craciun.. Am dechis/inchis din telecomanda, dar dupa 10 secunde pornea din nou.
- Am coborat, deschis/inchis usile, armat masina, dar la fel: dupa 10 secunde alarma pornea..
- Pe moment am oprit alarma apasand butonul de pe stalpul din stanga soferului. Am armat si a fost liniste.
Am coborat cu VCDS-ul, si diagnoza spune asa:
                Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 1K0 937 086 M    HW: 1K0 937 086 M
  Component and/or Version: BCM PQ35  M   110 0651
           Software Coding: 40180A3A8825F3C0400800C8740089E44B554088736D8D20E48400240040
            Work Shop Code: WSC 00028 028 00001
                      VCID: 3A712AA8B5A158CE9A7-806F
3 Faults Found:
03156 - Sensor for Anti-Theft System (G578)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 44
                    Reset counter: 209
                    Mileage: 184481 km
                    Time Indication: 0
                    Date: 2063.14.31
                    Time: 21:28:57
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.50 V
                        OFF
                        OFF
                        Term 50 Off
                        OFF
                        OFF
01134 - Alarm Horn (H12)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 68
                    Reset counter: 209
                    Mileage: 184481 km
                    Time Indication: 0
                    Date: 2063.14.31
                    Time: 21:28:57
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.50 V
                        OFF
                        OFF
                        Term 50 Off
                        OFF
                        OFF
03020 - Local databus 2
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 38
                    Reset counter: 209
                    Mileage: 184481 km
                    Time Indication: 0
                    Date: 2063.14.31
                    Time: 21:29:12
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.30 V
                        OFF
                        OFF
                        Term 50 Off
                        OFF
                        OFF
Am dezactivat pe moment alarma din long coding, bit 0 si bit 6.
Inteleg ca cea mai comuna problema este cea cu sirena, fiind montata in spatele rotii de pe partea pasagerului, intr-o locatie unde apa/umiditatea isi poate face loc mai usor.. coroborat si cu problema bateriilor incorporate ce pot face probleme, dupa niste ani..
Voi trece la schimbarea sirenei, dar inainte de a face asta, am mai citit de o posibila problema, in legatura cu care as dori sa va cer o parere: recent (in urma cu o saptamana) am schimbat ambele becuri Xenon, pentru ca cel de pe partea pasagerului s-a ars (partea unde e si sirena... poate conteaza, poate nu...). Am inteles ca unele lampi Xenon (mai exact balastul lor) pot crea interferente cu partea de alarma.. desi nu am gasit nicunde informatia asta scrisa clar... de asemenea becurile au fost achizitionate identic cu cele de pe masina, si anume "Bec Xenon 85V D1S 4150 K Xenarc, original, OSRAM 66140" - https://www.epiesa.ro/bec-xenon-85v-d1s-4150-k-xenarc-original-osram-66140-cutie-mstrnid-44006.htm
Nu stiu daca este doar o coincidenta, dar inainte de a schimba sirena, as fi vrut sa va rog frumos sa va spuneti o parere.. daca nu cumva ma orientez in directia gresita, cu schimbatul sirenei...
Va multumesc anticipat.
De obicei bateria interna din sirena corodeaza placa si de aici problemele de comunicare cu ea.
Poti sa vezi eventual pe blocurile de masura de ce anume a fost declansata alarma.
Daca stergi erorile, ele revin?
Buna,
Voi ajunge pe weekend sa demontez sirena.
Am incercat sa sterg erorile dar revin de fiecare data. Cateodata revine eroarea 03156 pentru senzorul antifurt si 01134 sirena, cateodata toate trei..
Am inteles ca modulul primeste semnal pe aceeasi linie, atat de la sirena cat si de la senzor (G578).. fara a inlatura sirena din circuit, inca nu pot estima care din aceste doua componente declanseaza mai exact situatia..
Legat de schimbul de lampi Xenon, crezi ca ar avea legatura ? Avand in vedere ca am cumpara OSRAM original ma gandesc ca nu...
