Start/stop nefunctional dupa retrofit carlig de remorcare
Snake_Aiz
Am montat un carlig de remorcare SVC manual cu tot cu modul.
Dupa retrofit, in afara de faptul ca in momentul connectarii sunt dezactivate cateva functii, care din cate am inteles e normal... A mai aparut o problema.
Nu mai fuctioneaza start/stop chiar si fara remorca conectata.
Dava postez aici un autoscan ma poate ajuta cineva sa ii dau de cap?
Posteaza, sa vedem ce erori ai, etc
Trebuie codate corespunzator toate modulele de pe masina ce ai treaba cu carligul:" ecu, ACC, senzori parcare, camera, etc....
Da, se vad la scanare pe care nu le-a codat, o sa fie erori pe modulele respective
Acesta este autoscanul:
Monday,20,June,2022,21:07:36:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2  HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WVWZZZ3CZJE229705   License Plate:
Mileage: 82428km-51218mi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 4B 52 5F 69 6C
          6D A5 BB BC CF D6 D7
VIN: WVWZZZ3CZJE229705   Mileage: 82428km-51218miles
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DFGA)       Labels: None
   Part No SW: 04L 906 026 LQ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 5172
   Revision: B4H25---    CVN: A0D6DC66B866C2ADB866C2AD
   Coding: 01190412034405083000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906026LQ 005003
   ROD: EV_ECM20TDI01104L906026KC_005.rod
   VCID: 04518C0D2E98E1FB839-8050
   VINID: 9E69EAAAA0D3A9A5420891C01423A4739C
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CT    HW: 5Q0 614 517 AG
   Component: ESC           H62 0653
   Revision: 00000000    Serial number: 61568000000067
   Coding: 0FEC6A8F34220B75477E060060C849F0562CD0E2600692713460F078C0A2420B00000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 0557910925A2D8F3947-8050
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0482967025
   Coding: 1F20000623
   Shop #: WSC 05311 115 00311
   ASAM Dataset: EV_KessyHellaMQBAB 004041
   ROD: EV_KessyHellaMQBAB_004_VW37.rod
   VCID: 3E253EE500F44B2B95D-806A
   Rear lid opener control module:
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 12020104202110011115100000101822
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 78A9E8FD6250B51B9F1-802C
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
   Humidity sensor: exterior:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: 8658090618027U
   ASAM Dataset: EV_BodyContrModul1UDSBosc 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0655960518A4D3EB9DD-8052
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    180421  042 0607
   Serial number:         180514182545
   Coding: 0E4DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  050 0107
   Serial number: S8Y18M06D07H13M31S31
   Coding: 05A8DD
   Light switch:
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Component: E1 - LDS MQB  H01 0032
   Serial number: 07 03 2018  10000086
   Humidity sensor: interior:
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 E    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0443
   Serial number: 000308418018155
   Coding: 0471155901
   Shop #: WSC 05311 115 00060
   ASAM Dataset: EV_EPHVA18AU3700000 009035
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4EC56E25B054DBAB65D-801A
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Coding: 2A04605A51FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 353721C935C28873447-8060
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W6PAWZRZX
   Coding: 98FCC0C0000000005C5400CF000800000065
   Shop #: WSC 05311 000 08193
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0849983D12B0C59BEF1-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 A    HW: 4M0 980 945 A
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705 0152S01331
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 A    HW: 4M0 980 946 A
   Component: BeltPretRevFR  106 1040
   Serial number: 3G0857706 0152S00117
   Coding: 80000D
   Crash sensor for side airbag: driver side:
   Subsystem 3 - Part No SW: -----------    HW: 454 002 405 18
   Component: SideSensor_Df  008 0887
   Serial number: 35700000000B7228F03K
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 4 - Part No SW: -----------    HW: 454 002 505 18
   Component: SideSensor_Pf  008 0887
   Serial number: 35800000000D2518F03K
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 5 - Part No SW: -----------    HW: 454 802 305 18
   Component: SideSensor_Dr  301 0148
   Serial number: 351006EA9CD14000000Z
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 6 - Part No SW: -----------    HW: 454 802 305 18
   Component: SideSensor_Pr  301 0148
   Serial number: 352005AB7CD14000000U
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 7 - Part No SW: -----------    HW: 454 802 105 18
   Component: FrontSensor_D  304 0149
   Serial number: 355005F83D414000000N
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0235
   Revision: FF033033    Serial number: 20180609301829
   Coding: 0C00
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73B3DFD17B36D643AA3-8026
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI3
   Part No SW: 3G0 920 751 C    HW: 3G0 920 751 C
   Component: KOMBI         302 0310
   Coding: 07A509106F8C000801887F0B1001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009060
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2517F1898562F8F3F47-8070
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5323
   Serial number: 23051810803347
   Coding: 080300045F087300FB00025E080F00010001070000000000000000000000
   GVL: 01563C0008000600C0CC80000002480000040000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF_VW37.rod
   VCID: 382928FD22D0751B5F1-806C
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
   Component: E221__MFL-DC1  H17 0040
   Serial number: 39180000960250018216
   Coding: 2CFFFF
   Analog clock:
   Subsystem 2 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 2505201800011031
2 Faults Found
197225 - Voltage Converter with Outlet
          U1109 00 [009] - No Communications
          [DCAC (LIN#1) Timeout]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 62
                    Mileage: 82428 km
                    Date: 2022.06.20
                    Time: 20:08:52
                    Terminal 30 power supply: 11.7 V
                    Terminal 15: On
67072 - Local Databus
          U1125 00 [009] - Additional Installations Detected
          [Subsystem Mehrverbau erkannt]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 62
                    Mileage: 82428 km
                    Date: 2022.06.20
                    Time: 20:08:52
                    Terminal 15: On
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 18000192421009
   Coding: 0000000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 33331FD13BB696436A3-8066
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0510
   Revision: --------
   Coding: 14C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001007
   ROD: EV_RearRadarS1BoschVW48X.rod
   VCID: 3A2D32F51CDC670BA95-806E
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 160518EEG00771
   Coding: 003F1B20D000028000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 43D34F116B1626C3FA3-8016
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 853013 00
   Coding: 0100001100400010
   Shop #: WSC 00015 115 00311
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2.rod
   VCID: 2B0307B1E386CE83223-807E
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 31051810801185
   Coding: 000000060100034A00000F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 001010
   ROD: EV_MultiModulContiVW48X_001.rod
   VCID: 72BDDAD5042CDF4BA15-8026
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 270518EER00374
   Coding: 003F1120DE00028000001000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 42DD4A15740C2FCBF15-8016
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 846 B    HW: 3Q0 035 846 B
   Component: MU-S-N-ER     851 0891
   Serial number:
   Coding: 02840201FF0000005111000100080A031F0007C4012001008F
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 303910DDCAA0AD5B171-8064
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV1162629
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 BG    HW: -----------
   Component: ECE AS 2021  --- 1520
   Serial number: --------------------
1 Fault Found
1555 - Check Software Version Management
          B201A 00 [009] - -
          [Check software version management]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 62
                    Mileage: 82428 km
                    Date: 2022.06.20
                    Time: 20:08:52
                    Voltage terminal 30: 11.8 V
                    Status_Software_Version_Management-module_name: C
Address 69: Trailer (J345)       Labels:* None
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anheanger     H21 0203
   Serial number: 00006789,,+''.
   Coding: 0100000202000000
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_VW26.rod
   VCID: 3B2337F113E65E03B23-806E
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H12 0231
   Coding: 0184020143002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
   VCID: 392F2DF919DA6C13A0F-806C
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0266
   Revision: --------    Serial number: 31959946400000
   Coding: 0288
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   ROD: EV_DeckLidCONTIAU736_VW37.rod
   VCID: 45D75109652218F3D47-8010
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 27041812K10964
   Coding: 0004080200000401002213478140A90094000E300000
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB_001_VW36.rod
   VCID: 3C2134ED16E8593BBB9-8068
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 595 E    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0041
   Serial number: 180518EEI04078
   Coding: 000E11200100028000001000
   ASAM Dataset: EV_DCURearDriveMAXKLO 006003
   ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      020 0041
   Serial number: 180518EEI0903B
   ASAM Dataset: EV_DCURearPasseMAXKLO 006003
   ROD: EV_DCURearPasseMAXCONT.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
   ROD: EV_RearRadarS2BoschVW48X.rod
   VCID: 372B2BC12FCE7A6356B-8062
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_VW37.rod
   VCID: 1675C6454804636B6DD-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H09 0003
   ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----------(Elapsed Time: 01:45, VBatt start/end: 12.0V/12.0V)-----------
La un moment dat am avut eroare pe 13:
2 Faults Found:
1218 - Databus
 U1121 00 [008] - Missing Message
 [FAULT_TIMEOUT_PSD_05]
 Intermittent - Confirmed - Tested Since Memory Clear
 Freeze Frame:
 Fault Priority: 6
 Fault Frequency: 1
 Reset counter: 102
 Mileage: 82428 km
 Date: 2022.06.20
 Time: 21:33:36
 Control Module temperature: 39 °C
 Voltage terminal 15: 11.7 V
 Velocity_vehicle_reference: 0.00 m/s
 Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
 Status_ACC_System: ACC_StandBy
1219 - Databus
 [FAULT_TIMEOUT_PSD_06]
 Freeze Frame:
 Fault Priority: 6
 Fault Frequency: 1
 Reset counter: 102
 Mileage: 82428 km
 Date: 2022.06.20
 Time: 21:33:36
 Voltage terminal 15: 11.6 V
Am masurat bateria azi dimineata si avea un voltaj de 12.5 V
Codeaza 19 can gateway cu modul 69 trailer instalat. In lista cu instalari, bifeaza
Salut Florin, Stiam ca am adaugat modulul 69 in CAN si am verificat acum. Modulul este codat in CAN.
Daca nu era codat imi aparea in autoscan?
ASAM Dataset: EV_TrailFunctGener2Hella 001008 ROD: EV_TrailFunctGener2Hella_VW26.rod VCID: 3B2337F113E65E03B23-806E
CAnul spune ca nu este adaugat, asa reiese din scanarea ta.
Sigur ca da....apare. Tot asa, trebuia sa apara ca Not registred....in dreptul lui...la tine nu apare asa.
Trebuie sa verifici de ce nu ii place can ului.... de genereaza acest DTC
Si cum as putea verifica acest lucru?
O sa incerc sa il sterg din lista si sa il readaug. Eventual sa folosesc alta interfata si apoi repostez scanul. Cum vad ca nu este adaugat modulul in CAN? Sau mai bine zis cum ma.asigur ca il adaug corect? Multumesc
Trebuie sa dispara DTC ul de pe modul 19 can gateway
Am debifat 69... Rebifat eroarea ramane acolo. Ma poate ajuta cineva remote? Sunt in afara Romaniei
Eu zic ca a acceptat codarea... acum care e problema nu inteleg:
Codare modul 19 in data de 12.05.2022 - inainte de a monta carligul:
   Coding: 030300045F087300FB00025E080F00010001070000000000000000000000
   GVL: 01563C000800060040CC80000002480000040000000200000000000000000000
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
   Coding: 2CFFFF
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 J    HW: 5Q0 915 181 J
   Component: J367-BDMConti  H03 1050
   Serial number: 758860000018053100D6
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
Codarea de azi:
   Coding: 2CFFFF
   Analog clock:
2 Faults Found
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 69
                    Mileage: 82612 km
                    Date: 2022.06.23
                    Time: 20:22:05
                    Terminal 30 power supply: 11.9 V
                    Terminal 15: On
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 69
                    Mileage: 82612 km
                    Date: 2022.06.23
                    Time: 20:22:05
                    Terminal 15: On
