suzu
La scanarea unei Skoda Octavia 2 din 2006, 1.6 FSI a aparut urmatoarea eroare :
Address 01: Engine Labels: Redir Fail!
Part No SW: 03C 906 056 CM HW: Hardware No
Component: MED9.5.10 00 7001
Revision: --H01--- Serial number: SKZ7Z0E3242107
Coding: 0000071
Shop #: WSC 10164 599 58504
1 Fault Found
008851 - Fuel Pressure Regulator Valve (N276): Mechanical Malfunction
P2293 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 31
Mileage: 96677 km
Time Indication: 0
Date: 2000.00.00
Time: 12:27:25
Freeze Frame:
RPM: 680 /min
Load: 25.9 %
Speed: 3.0 km/h
Temperature: 86.0
Possible Symptoms
Power Loss
Possible Causes
Fuel Pressure too Low
Possible Solutions
Check Measuring Values for Fuel Pressure
Check for bent/squeezed Fuel Lines
Check Low Fuel Pressure System for Leaks
Check Fuel Filter & Filter in Fuel Pump
Check the Fuel Quantity supplied by the Fuel Pump
Special Notes
When found in 2.0l TFSI: ( nu stiu daca este aceasi procedura si la 1.6 FSI - cazul tau)
Checking Fuel Pressure
Prerequisites:
Ignition ON
Engine ON (Idle)
System voltage at least 11.0 V.
Coolant Temperature at least 80
Salut, azi am depistat si eu un cod de eroare aparaut ieri, multumiri colegului joky. Mentionez ca inainte alimentam cu petrom 99+ de cand este masina si am mers cu ea cam 8000km cu benzina asta. Zilele trecute am alimentat cu pentrom 95 sa vad cum este iar martorul de check engine a a aparut dupa 300km, posibil sa fie si asta o coincidenta.
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
Readiness: 0000 0000
Oare care sa fie cauza? ms
Salut.
Cine ma poate ajuta cu niste sfaturi la urmatoarele erori pe care mi le da wag-com-ul:
17439 - Manifold Change-Over Valve (N136): Setpoint Not Reached
P1031 - 35-00 - -
17443 - Sensor for Nox (G295): Signal Implausible
P1035 - 35-00 - -
17441 - Sensor for Nox (G295): Signal too Low
P1033 - 35-00 - -
La ultima scanare er. 17443 Signal Implausible a disparut.
VW GOLF IV Variant 2003 1.6 FSI 110CP
17439/P1031/004145 - Intake Manifold Tuning Valve (N136): Setpoint Not Reached
Possible Causes
Intake Manifold Flap blocked/tight
Intake Manifold Tuning Valve (N136) faulty
Intake Manifold Tuning Valve Position Sensor (G336) faulty
Possible Solutions
Check Intake Manifold Tuning Valve (N136)
Check Intake Manifold Tuning Valve Position Sensor (G336)
Check Intake Manifold Flap
Pentru a 2 eroare vezi senzor nox G295 - check or replace
Modificat de turbocip
Unde se afla reperele astea G336, N136, manifold flap?
Pornind de la coada, "Intake Manifold Flap" o gasesti in galeria de admsie. Celelalte, tot in zona; asigura actionarea ei.
P1176 - 35-00 - -
O parere ceva?ms
Possible Causes
Intake Air System leaking
Oxygen Sensor(s) and/or Oxygen Sensor Control faulty
Possible Solutions
Check Intake Air System for Leaks (False Air)
Check Oxygen Sensor(s) and/or Oxygen Sensor Control (all of them!)
Da. Am gasit si eu asa ceva, dar ce sa insemne Intake Air Sistem. Pe unde prinde aer fals?eventual cum pot testa acest senzor. ms
Modificat de xxnelu
Bine. asta stiam si eu. Am vrut sa intreb, la ce componenta se refera(filtru aer sua ce), ca sa stiu unde sa ma uit. ms
Modificat de xxnelu
Zonele filtru de aer si PCV valve ( Positive Crankcase Ventilation valve) - este valva unisens
sal
am scanat cu vagcom intamplato,nu mi sa aprins nimik in bord si mi-au iesit urmatoarele erori:
17526-Oxygen(lambda)sensor heating;B1 S2:open circuit
P1118-35-00
17524-Oxygen(lambda)sensor heating;B1 S1:open circuit
P1116-35-00
Am scos cateva relee,le-am zgariat putin si chiar una din erori disparuse,
iar cand pornesc masina simt un miros de gaze,in afara ei.
Sa scot sondele sa le curat contactele ?
Mc
dupa cum "zice" si erorile, este vorba de circuitele de incalzire a celor doua sonde ...cred ca s-au intrerupt chiar in sonda (verivica totusi si mufele).
Ar trebui sa faci un test (In basic settings grupurile 034 si 036 parca) ca sa vezi daca sunt bune sondele.
Buna ziua,
legat de valva solenoid va rog sa ma ajutati cu interpretarea unei erori de pe un Audi A4(2002) ,1.9 tdi, 74 kw,AVF:
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E72A255806 Mileage: 161030km/100059miles
Address 01: Engine Labels: 038-906-019-AVB.lbl
Part No: 038 906 019 GG
Component: 1,9l R4 EDC 0000SG 1498
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E72A255806 AUZ6Z0B0028124
1 Fault Found
17996 - Engine Mount Solenoid Valves (N144/N145): Open Circuit
P1588 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Va multumesc anticipat.
P.S.
Precizez ca la masina a fost schimbata recent distributia, bateria si bujiile insa are pornirea grea si la cald si la rece.
Sunt electrovalvele de la suportii hidraulici ai motorului.
Modificat de xxnelu
Se poate ca din cauza acestei erori 17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached sa imi scoata fum dimineata la dupa cateva secunde la pornire?
Salutare!
Probleme la Octavia 2 an 2005 1,9 TDI BJB:
cod eroare VAG-COM: 16621 mainfold pressure boost sensor g31 signal too low
Absolute 183.6 mbar
2182.8 mbar
ok.. cum s-a intamplat: s-a aprins becul ucigas galben, a taiat turbina si acum am sdi in loc de tdi: ajung la 80km/h in 1,5 km... :-(
bineinteles ca m-am dus la service (service-urile pline de inghetati si care nu mai pornesc), mi-au zis sa-mi comand senzorul de presiune de la intercooler, l-am comandat, schimbat si.. surpriza (sau poate nu).. in continuare acelasi cod de eroare si acelasi comportament. baietii de la service s-au scarpinat in cap si mi-au aruncat ca trebuie curatata clapeta de acceleratie!?!?!?
are cineva idee ce poate fi cu adevarat?
merci.
Modificat de dbmaster
Nu are clapeta de acceleratie. Totusi au masurat firele intre ECU si senzor?Si totusi mutati aceasta discutie la TDI.
Modificat de Al Bundy
asa stiam si eu... nu au masurat nimik, desi si eu am gasit ca metode de diagnosticare masurarea firelor si am incercat sa le sugerez... da' ei erau destul de nereceptivi la parerea clientului (desi le-am dat codul de eroare, nu m-au crezut si am mai platit 50 de ron diagnosticarea). si nici alti parametri nu au contat... bad luck
Mergi la cineva care sa iti masoare
conectica ECU-Senzor
[012600 - Intake Manifold Runner Control: Regulation Deviation
P3138 - 006 - short to plus- Intermittent
ce cum pot rezolva aceasta eroare? ce ar trebui inlocuit, reparat?
Polo din 2002 , motor 1.6 benzina
Address 01: Engine Labels: 032-906-030-AEE.lbl
Part No: 6K0 906 030 E
Component: MARELLI 1AV S078
1 Fault Found
00525 - Oxygen (Lambda) Sensor (G39)
07-10 - Signal too Low - Intermittent
Readiness: N/A
Masina se oprise in mers. Am pus testerul pe ea, am sters eroarea mai sus afisata, si a pornit. Dar totusi, ce este ? Rog daca se poate o explicatie in romana :vinemosul:
00525 - Oxygen (Lambda) Sensor (G39): Signal too Low
Possible Causes
* Oxygen (Lambda) Sensor (G39) faulty
* Wiring/Connectors from/to Oxygen (Lambda) Sensor (G39) faulty
Possible Solutions
* Check/Replace Oxygen (Lambda) Sensor (G39)
* Check/Repair Wiring/Connectors from/to Oxygen (Lambda) Sensor (G39)
...si in romana ar fi : sa verifici sonda lambda, mufa sau cablurile
vezi mai sus cum se testeaza sondele...
  • Aerofan pinned this topic
    • Edy87
