suzu
Aici zice Faulty !
01336 - Data Bus for Comfort System: Faulty
Possible Causes
CAN-Data Bus faulty
Wiring/Connectors from/to Control Modules
Control Module in CAN Data Bus Comfort faulty
Possible Solutions
Check CAN-Gateway Coding
Check Measuring Value Blocks (MVB)
Check Wiring/Connectors from/to Control Modules
01336 - Data Bus for Comfort System: Single-Wire Operation
Possible Symptoms
Data Bus Comfort working in Single-Wire Mode
Possible Causes
Possible Solutions
Special Notes
When found in VW Passat (3B): Comfort System, check Comfort Control Module and Door Control Modules.
Wiring/Connectors from/to Door Control Modules faulty
Comfort Control Modules flooded/faulty
salutare,
am urmatoarea eroare:
001089 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 88420 km
Time Indication: 0
Date: 2000.00.00
Time: 16:18:07
Freeze Frame:
RPM: 720 /min
Load: 28.2 %
Speed: 0.0 km/h
Temperature: 85.0
Am si eu urmatoarea eroare in memoria masinii.
Address 01 -------------------------------------------------------
Controller: 03E 906 033
Component: 1,2l/4V SIMOS3 00HS4340
17811 - EGR System: Regulation Divergence
P1403 - 35-10 - - - Intermittent
Readiness: 0000 0000
As dorii sa aflu ce inseamna. E ceva legat de EGR dar ce anume.
Multumesc..
@ Chuchy:
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
@ netsonic:
17811/P1403/005123 - EGR System: Regulation Deviation
Possible Causes
Exhaust Gas Recirculation (EGR) faulty
Exhaust Gas Recirculation (EGR) Valve (N18) faulty
Possible Solutions
Check Exhaust Gas Recirculation (EGR)
Check Exhaust Gas Recirculation (EGR) Valve (N18)
Perform Output Test
P0420-35-00
16804-Catalyst System Bank 1: Efficiency Below Threshold;
acest cod mi-a iesit astazi in urma unui test, despre ce e vorba ? e dusa sonda lambda?
16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
Possible Causes
Leakage in Intake and/or Exhaust System
Catalyst faulty
Oxygen Sensor(s) faulty
Oxygen Sensor(s) Control faulty
Possible Solutions
Check Intake and Exhaust System for Leaks
Check Catalyst
Check Oxygen Sensor(s)
Check Oxygen Sensor(s) Control
Perform Oxygen Sensor(s) Aging Check
intre timp am gasit aceasta explicatie si am editat postul, UNDE se afla OXIGEN SENSOR ? sau acesta este chiar SONDA LAMBDA ?
Modificat de CATYON
@ CATYON:
Possible Causes
Catalyst faulty
Possible Solutions
Check Catalyst
Special Notes
For 1.8T's experiencing this fault code, this thread may be useful: http://forums.vwvortex.com/zerothread?id=663057
vezi aici: http://forums.vwvortex.com/zerothread?id=2798484
sau aici: http://forums.vwvortex.com/zerothread?id=990129
Modificat de pronet
PRONET, cred ca am scris in acelasi timp, nu vazusem raspunsul tau, senzorul de oxigen este cumva sonda lambda ?
@ Chuchy:
Possible Symptoms
am gasit si eu toate astea la care tu ai dat paste.
dar intrebam daca in caz ca eroarea
@ Chuchy:
Possible Symptoms
am gasit si eu toate astea la care tu ai dat copy/paste.
eu intrebam daca in caz ca eroarea pe care o am ar fi de la faptul ca am incarcat prea mult rezervorul.. ar disparea dupa o curatare de erori sau va ramane.
rog de data sa-mi raspunda doar cineva care stie....
imi cer scuze pentru post-ul de dinaintea acestuia (un click aiurea).
@pronet: multam! Am cautat pe net si am gasit informatia care mi-ai dat-o pe wiki de la rosstech. (http://wiki.ross-tech.com/index.php/17811/P1403/005123)
Eram doar curios pentru ca este singura eroare care se afla in memoria masinii. O sa cer mecanicilor la urmatoarea revizie sa curete EGR-ul sau clapeta aia. Sper sa se remedieze cu toate ca nu simt nimic ciudat la masina si nu se aprinde nimic in bord.
coseru ionut bogdan
neatza...
aseara am facut un test cu VAG COM-u si mi-am gasit problemele la masina.
foarte util forumul si in special topicurile de aici
multumirile se duc catre TURBOCIP care a fost dragut sa ma ajute cu o constatare rapida si eficienta.
o zi buna tuturor.
Am nevoie de ajutorul celor cu benzinare.
FAbia 1 cu motor 1.4 16v cu martor motor aprins in bord. LA diagnoza, surpriza nici o eroare pe motor si nici pe alte sisteme. Se aprinde la punerea contactului, se stinge la pornirea masinii pentru 1 sec dupa care se aprinde. Ce sa fie?
Din cate stiu eu aprinderea martorului in bord ar trebui sa coincida cu stocarea unui cod de eroare.Motorul merge bine sau prezinta vreo simptoma? Incearca sa simulezi un defect sa vezi daca se va stoca codul de eroare corespunzator. :icon_bounce:
Incearca sa mergi putin( pe proba) cu mufa de la debitmetru ...scoasa!Daca merge mai bine decat inainte, este de vina debitmetrul tau...daca nu se imbunatateste nimic...ramane de gasit adevarata problema!
P.S. Sa scoti mufa de alimentare la debitmetru, nu te costa nimic!Nu cred ca scoaterea mufeI debitmetrului iti aprinde becul de motor in bord!
Modificat de wolfvw
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
01039 - Coolant Temperature Sensor (G2)
30-00 - Open or Short to Plus
Le-am sters, au reaparut, iar acum arata doar numarul de eroare si zice can`t decode.
Am schimbat senzorul de temperatura si tot indica temperatura cand vrea, in momentul cand merg si cade acul de la temperatura apare becul check engine si da in nas. Posibil sa fie termostatul ? Solutii? Multumesc!
BA da, cu mufa scoasa se aprinde becul si genereaza eroarea specifica.
dupa un log in mers ce a confirmat ca nu e nimic in neregula(inca), am scos si eu mufa aia sa vad cum trage masina si mi s-a parut ca merge mai prost; in urma scoaterii mufei la mine nu s-a aprins nici un bec, dar eroarea a fost stocata :)
o mica problema am si eu cu martorul de motor aprins. Cand pornesc masina (rece fiind) primele 20 sec. variaza turatia la motor uneori chiar moare. Am fost la un tester si mi-a gasit urmatoarele erori:
17604
17598
Poate cineva sa ma ajute in identificarea lor.
Cheers.
Nu am gasit codurile de eroare, insa simptomele pe care le reclami tu sunt aproape sigur ca sunt din cauza clapetei de acceleratie murdare. Trebuie curatata si facuta adaptare cu Vag-Com.
17604
17598
Cheers.
Erorile tale se refera la "incalzirea sondei lambda" ... 1 (daca bine retin). Nu stiu la ce "tester" ai fost dar, cu siguranta nu a fost unul dedicat VAG (VCDS(Vag-Com)/VAS). Nu stiu daca aceste erori pot fi, cauza acelor variatii ale turatiei. Este posibil sa fie si ce a spus CristiN.
clapeta de acceleratie e curatata. si acel meserias mi-a spus tot ceva in genul dar ceva ma retinea sa-l cred. Cum se poate verifica daca intradevar este acea sonda lambda nu de alta dar e cam scumpa. cat se mai poate merge cu eroarea asta fara sa afecteze catalizatorul?
multumesc.
Modificat de xxnelu
Te rog sa nu mai dai QUOTE/REPLY la mesajul anterior. Foloseste Add Reply.
Cum se poate verifica daca intradevar este acea sonda lambda ?
Pai...tocmai ai verificat :icon_thumright: . Daca nu este intrerupt vreun fir (partea de alimentare a circuitului de incalzire al sondei), atunci, trebuie sa schimbi sonda.
eu chiar am nevoie de ajutor.
va rog sa redirectionati postul meu in alta parte daca credeti de cuviinta, am cercat cu searc "Vag-Com" si nu m-ia dat nici un rezultat.
am gasit subiectul cautandu-l cu gugal.
am un MK4, benzina, 1.6 74kw din 1999, motor AKL.
imi doresc si eu un aparat de diagnostica dar nu inteleg nimic din KKl sau Can-bus sau Vag-com.
cineva imi poate explica macar daca pe masina mea se poate aplica unul dintre aceste aparate saucare dintre ele?
17987/P1579/005497 - Throttle Actuator (J338): Adaptation Not Started
ce poate insemna acest lucru daca se poate mai pe romaneste
dupa ce am gasit acest cod, fara sa am becuri aprinse prin bord, l-am sters si nu a mai aparut
Possible Symptoms
Possible Causes
Throttle Body Alignment (TBA) not performed
Possible Solutions
Perform Throttle Body Alignment (TBA)
si aici Adaptarea
  • Aerofan pinned this topic
    • Edy87
