suzu
Fa un test de actuatoare cu VagCom (01-Engine-Output Tests-03).Daca EGR nu se aude tacanind verifica conexiunile la N18 (EGR).post-10189-1254062009_thumb.png
:salut:
Postez si eu erorile aparute la scanarea cu Vag-Com, mentionez ca am ramas fara baterie intr-o zi, dupa ce am lasat avariile pornite pentru cateva ore. In plus, acum cateva zile s-a aprins martorul ECU galben la bord, iar pedala de acceleratie nu mai functiona. Martorul s-a stins dupa ce am oprit motorul si l-am pornit iar, odata cu rezolvarea problemei.
Eroarea cu Throttle Valve Controller e legata de clapeta de acceleratie?
Control Module Part Number: 036 906 034 KC
Component and/or Version: MARELLI 4TV 7449
Software Coding: 00071
Work Shop Code: WSC 06402
Additional Info: VSSZZZ6LZ6R542656 SEZ5Z0F2141025
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 01: Engine
Part No: 036 906 034 KC
Component: MARELLI 4TV 7449
Coding: 00071
Shop #: WSC 06402
No fault code found.
Readiness: 0110 0101
Address 03: ABS Brakes
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H04 0002
Coding: 0002118
Shop #: WSC 06402
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 60
Mileage: 81504 km
Time Indication: 0
18265 - Load Signal: Error Message from ECU
P1857 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 60
Mileage: 81504 km
Time Indication: 0
Address 08: Auto HVAC
Part No: 6L0 820 043 E
Component: CLIMAtronic PQ24 3805
01273 - Fresh Air Blower (V2)
Address 09: Cent. Elect.
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 16396
Shop #: WSC 06402
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Ti le-am listat pe fiecare in parte :
17953/P1545/005445 - Throttle Valve Controller: Malfunction
Possible Symptoms
Increased Idle Speed
Bucking at Load Change
Possible Causes
Throttle Body dirty
Throttle Body Wiring faulty
Throttle Body faulty
Possible Solutions
Clean Throttle Body
Check Throttle Body Wiring
Check Throttle Body
Special Notes
Use Meas. Blocks & Basic Setting for testing
01314 - Engine Control Module: Check DTC Memory
Possible Causes
Fault(s) stored in Engine Control Module
Possible Solutions
Check Engine Control Module for Fault Codes
Special Notes
Engine Control Module stored a Code which influences other Control Modules Functionality.
To clear this Fault Code you will need to correct the Problem in the Engine Control Module first
18265/P1857/006231 - Load Signal: Error Message from ECU
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Fault Code(s) stored in Engine Control Unit (ECU)
Possible Solutions
Check Engine Control Unit for Fault Code(s)
Possible Causes
Fresh Air Blower (V2) defective
Control Module for Fresh Air Blower (J126) defective
Short of open circuit in wiring to Fresh Air Blower (V2)
Climatronic Control Module (J255) malfunctioning
Possible Solutions
Check Fresh Air Blower (V2)
Perform Output Test (Check Air Vents while Blower is active)
Check Meas. Blocks while Blower is active
Check Control Module for Fresh Air Blower (J126)
Check wiring and connectors
01598 - Drive Battery Voltage: Signal to Low
Possible Symptoms
Engine not starting
Possible Causes
Battery low
Battery faulty
Possible Solutions
Charge Battery
Check/Replace Battery
Salutare. Am un Polo 1.2 12v din 2002 motor 9N. Problema destul de enervanta si care persista de ceva timp este urmatoarea:
-acum ceva timp, circa 6 luni s-a aprins check engine si m-am dus la mecanic (dupa aprinderea martorului masina a mai mers 1-2 zile dupa care nu
puteam s-o turez mai mult de 2000 rpm)....probleme: bobine 2 si 3.......schimbat bujii, inlocuit toate bobinele
-dupa circa 1 luna de la servisarea de mai sus se aprinde iar check engine, merg o zi sau 2 si fenomenul cu turatia reapare (nu se poate tura peste 2000rpm),
iar merg la mecanic, iar problema la o bobina.....o inlocuiesc si iar nu mai am probleme
-o perioada sta masina pe loc....circa 2-3 luni
-acum vreo 10 zile am nevoie de masina, merg cu ea 3-4 zile fara probleme dupa care se aprinde check engine, merg mai departe si dupa 2 zile iar nu se mai
tureaza peste 2000rpm
Astept sa vina masina sa vad ce cod mai apare (acum am cablu si soft). Nu stiu ce sa-i mai fac....m-a terminat cu aceasta problema. Ce poate fi?
Am scanat acum masina si am urmatoarele:
16804 - Catalyst System Bank1: Efficiency below Threshold
P0420-35-00
17511 - Shareware Version To Decode all DTCs
P1103-35-10 Please Register/Activate-Intermitent
16825 - Shareware Version To Decode all DTCs
P0441-35-10 Please Register/Activate-Intermitent
Din pacate, faptul ca ai mers cu bobinele de inductie arse ti-a afectat catalizatorul.
Am sters codurile. Sper sa nu fi afectat major catalizatorul.
Merge bine. Cand i-am dat prima cheie parca intrerupea putin, dar dupa ce l-am turat in 5-6000 ture si-a revenit si merge bine. Acum e ok, nu mai am nicio eroare.
Poate se dezamorseaza pompa peste noapte!
Domnilor cine ma poate ajuta si pe mine cu niste coduri de eroare ce ar putea fi!? ms mult
Pe scurt este vb de un golf 4 din 99 1.4
Acum 2 zile a inceput din senin sa scoata fum alb, motorul parca nu merge rotund.Am vag com 908 la scan a dat urmatorul rezultat.
Address 01: Engine Labels: 036-906-014-AHW.LBL
Control Module Part Number: 036 906 014 CG
Component and/or Version: MARELLI 4AV 2594
Software Coding: 00000
Work Shop Code: WSC 00000
01265 - Exhaust Gas Recirculation Valve (N18)
26-00 - Output Open
Readiness: N/A
Un prieten ma sfatuit sa dau la engine setarile de baza 000 035 074 075 nici o schimbare in bine afuma la fel parca merge si mai rau motorul la relanti.
Dar acum am la scanare.
Mileage: 132590km/82387miles
Address 01: Engine Labels: 036-906-014-AHW.lbl
Part No: 036 906 014 CG
Component: MARELLI 4AV 2594
Coding: 00000
Shop #: WSC 00000
01087 - Basic Setting Not Performed
35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 G
Component: ABS 20 IE CAN 0001
Coding: 03604
Shop #: WSC 01317
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: A AIRBAG VW3 SG 0002
Coding: 00065
Shop #: WSC 01317
Address 17: Instruments Labels: 1J0-919-xxx-17.lbl
Part No: 1J0 919 861
Component: A4-KOMBIINSTR. VDO V01
Coding: 00141
Shop #: WSC 00000
Part No: IMMO
Component: IDENTNR: VWZ7Z0X1247161
IMMO-IDENTNR: VWZ7Z0X1247161
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 Q
Component: 4C Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
Part No: 1J1959801C
Component: 4C T
26-00 - Output Open
Readiness: N/A
Coding: 00000
Shop #: WSC 00000
35-00 - -
Readiness: N/A
Coding: 03604
Shop #: WSC 01317
Coding: 00065
Shop #: WSC 01317
Coding: 00141
Shop #: WSC 00000
Part No: IMMO
Coding: 04097
Shop #: WSC 01317
Part No: 1J1959801C
Component: 4C T
Possible Symptoms
Function Limitation
Possible Causes
Possible Solutions
Perform Basic Setting
00849 - S-Contact at Ignition/Starter Switch (D)
00849 - S-Contact at Ignition/Starter Switch (D): Unknown Switch Condition
Possible Causes
Terminal 15 OK, but Terminal S not OK
Fuse(s) faulty
Wiring/Connector(s) from/to Ignition/Starter Switch (D) faulty
Possible Solutions
Check Terminal S
Check Fuse(s)
Check/Repair Wiring/Connector(s) from/to Ignition/Starter Switch (D)
Check/Replace Ignition/Starter Switch (D)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00928 - Locking Module for Central Locking; Front Driver Side (F220): Implausible Signal
Possible Symptoms
Door Locks not working properly
Possible Causes
Wiring/Connectors from/to Locking Module for Central Locking; Front Driver Side (F220) faulty
Voltage Supply for Locking Module for Central Locking; Front Driver Side (F220) faulty
Door Lock Mechanics are stiff/partially seized
Possible Solutions
Check Wiring/Connectors from/to Locking Module for Central Locking; Front Driver Side (F220)
Check Voltage Supply for Locking Module for Central Locking; Front Driver Side (F220)
Check Door Lock Mechanics/Operation
Check Locking Module for Central Locking; Front Driver Side (F220)
00943 - Heated Exterior Mirror Driver Side (Z4)
Possible Symptoms
Mirror Heating doesn't work
Possible Causes
Wiring/Connectors from/to Heated Exterior Mirror Driver Side (Z4) faulty
Possible Solutions
Check Wiring/Connectors from/to Heated Exterior Mirror Driver Side (Z4)
Check/Replace Heated Exterior Mirror Driver Side (Z4)
Special Notes
Sometimes the switch button for the mirror has 'L', 'R' and '0'. When switched on '0' the mirror heating is on!
00944 - Heated Exterior Mirror: Passenger Side (Z5)
Possible Symptoms
Possible Causes
Wiring and/or connections faulty
Mirror Heating faulty
Possible Solutions
Check if 12V on mirror connections is present
Replace Mirror (Z5)
Special Notes
00913 - Window Regulator Switch; Front Right Driver (E81)
00913 - Window Regulator Switch; Front Right Driver (E81) : Implausible Signal
Possible Causes
Wiring/Connector(s) to Window Regulator Switch; Front Right Driver (E81) faulty
Window Regulator Switch; Front Right Driver (E81) stuck
Possible Solutions
Check Wiring/Connector(s) to Window Regulator Switch; Front Right Driver (E81)
Check Window Regulator Switch; Front Right Driver (E81)
Check Meas. Value Blocks (MVB) for Plausibility
00930 - Locking Module for Central Locking; Rear Left (F222)
Possible Solutions
Check Door Contact Switch (F10)
Check Central Locking Module Rear Left (F222)
Check Central Locking Motor (V115) with Actuator (Lock) Rear Left (F133)
Check Central Locking Motor (V163) with Actuator (Safe) Rear Left (F245)
Check Child Safety Motor Rear Left (V142)
00930 - Locking Module for Central Locking; Rear Left (F222): Implausible Signal
Possible Symptoms
Possible Causes
Wiring/Connectors from/to Locking Module for Central Locking; Rear Left (F222) faulty
Voltage Supply for Locking Module for Central Locking; Rear Left (F222) faulty
Possible Solutions
Check Wiring/Connectors from/to Locking Module for Central Locking; Rear Left (F222)
Check Voltage Supply for Locking Module for Central Locking; Rear Left (F222)
Check Locking Module for Central Locking; Rear Left (F222)
Revin dupa o vreme indelungata :
Address 01: Engine Labels: None
Part No SW: 036 997 032 D HW: xxxxxxxxxxx
Component: BOSCH ME7.5.10 9736
Coding: 0000071
Shop #: WSC 10103
2 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 008 - Implausible Signal - Intermittent
AM avut eroarea asta la masina din semnatura. Am schimbat mai intai bujiile, dupa care o bobina, aceasta din urma fiind cauza. Am postat in ideea ca poate cineva se va confrunta cu aceeasi problema. Spor la rezolvat problemele !
Salutari!
Am si eu un Golf V 1,9 TDI 2005 la care nu-mi merge asistenta la parcare. Masina e sh iar senzorii nu mi-au mers de la inceput. Am fost astazi la un service pentru o diagnoza. A dat o eroare 052F in care spunea ca modulul nu primeste curent. Aveti idee despre ce e vorba. O fi de la siguranta?
buna,
In urma cu ceva zile, la pornire s-a aprins martorul de servodirectie, iar volanul mergea foarte greu. Am mers cu ea avand directia greoaie, insa dupa ce am oprit masina si am plecat din nou, martorul de servo s-a stins si directia a mers normal (a inceput sa functioneze servodirectia).
Acu de vreo doua zile martorul de servo s-a aprins din nou la plecare dimineata insa de data asta chiar si dupa porniri / opriri repetate datorate drumurilor prin oras, a ramas aprins iar directia merge foarte greu.
Nivelul lichidului de servo este bun.
Apreciez orice sugestie...
Azi am scanat-o si asta este eroarea afisata:
Adresa 09: Electronica centrala Eticheta: 6Qx-937-049-B.lbl
Numar VAG: 6Q1 937 049
Componenta comandata: BORDNETZ-SG. 1S30
Codare: 09362
Atelier: WSC 13765
1 cod de defect:
01309 - Modul comand
01309 - Power Steering Control Module (J500): No Communication
Possible Symptoms
Power Steering not working
Possible Causes
Wiring/Connectors from/to Power Steering Control Module (J500) faulty/loose
Possible Solutions
Check Wiring/Connectors from/to Power Steering Control Module (J500)
Replace Power Steering Control Module (J500)
multumesc.
stii si unde se afla <Modul comand
:icon_thumright:
Am facut test de actuatoare cu VagCom insa nu am auzit niciun tacanit la EGR.Se auzea la pompa de benzina insa la EGR liniste totala.....Conexiunea nu stiu cum sa o verific...sincer nici nu stiu unde se afla...poate ma ajutati voi...(motor 1.2 AZQ)
Am o eroare care nu se poate sterge!Vreau sa stiu cum ati rezolvat-o fara sa schimbati ECU.Care pot fi consecintele daca folosesc in continuare autoturismul cu aceasta eroare?
16985 - INTERNAL CONTROL MODULE
Va multumesc!
P.S. - am dat search dar am gasit numai un tabel cu codurile de eroare
Pentru motorul de 1.8 T ai un link mai jos.
16985/P0601/001537 - Internal Control Module: Memory Check Sum Error
Possible Symptoms
* MIL illuminated
Possible Causes
* Engine Control Unit (ECU) defective
* Flash ROM (used in aftermarket "chips") defective
Possible Solutions
* Replace ECU
* Contact aftermarket chiptuner for repair of their chip
Special Notes
* When found in 1.8T:
o This thread might be useful: http://forums.vwvortex.com/zerothread?id=915672
* When found in 2.0l TFSI:
o Check Engine Control Module Software Version and Update if necessary.
Possible Symptoms
* MIL illuminated
Possible Causes
Possible Solutions
* Replace ECU
Special Notes
Multumesc de raspuns.Sa inteleg ca daca ma adresez unui specialist in remapare,situtia s-ar rezolva cumva.Din link-ul trimis se pare ca ar fi o problema destul de comuna in special la cei care au facut chip tuning.La mine nu este cazul.Poate stiti undeva in apropiere de Botosani pe cineva care sa incerce sa rescrie softul?
Flash-ul / Se desface ECU
Nu stiu daca se poate face pe mufa cu VAG-Commander
Modificat de turbocip
2 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-10 - - - Intermittent
17606 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2: Electrical Malfunction
P1198 - 35-10 - - - Intermittent
Multumesc anticipat!
Am scanat si eu masina si am gasit
VAG-COM Version: Release 704.1
Data version: 20070422
Wednesday,14,October,2009,15:08:10:55371
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: WVWZZZ1JZ4D078422 Mileage: 104890km/65175miles
Address 17: Instruments Labels: 1J0-920-xxx-17.LBL
Part No: 1J0 920 826 A
Component: KOMBI+WEGFAHRSP VDO V20
Coding: 01113
Shop #: WSC 00000
WVWZZZ1JZ4D078422 VWZ7Z0C8524351
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 67610
Am citit pe ross-tech dar nu prea zice mare lucru.
  • Aerofan pinned this topic
