suzu
Si asta cum o remediez sau verific?
Verifica furtunul de vacum de la servofrana (crapa langa supapa unisens), electrovalva N80 de la canistra cu carbon activ (se infunda cu parf de carbune, se poate spala). Mai uitata-te cu VCDS pe engine, canal 32, camp 1, daca valoarea amestecului se apropie de 10 e clar ca ai aer fals, reprezinta imbogatirea amestecului la relanti.
Modificat de SergiuD
Salut baieti, dupa un drum de 600 km mi s-a aprins check engine in bord, am puso pe tester si mi-a dat urmatoarele erori. Mi-au spus cei de la service ca e sonda lambda cea de dinainte de catalizator.As vrea sa stiu sigur daca asta e si daca ma puteti ajuta cu un cod de piesa. (mk4 16 16v AZD)
P0171 Sistem combustibil banc 1
           Amestec prea sarac
P0420 Sistem catalizator ( banc 1)
           efect insuficient
Salut inainte de a schimba sonda lambda verifica :
16555/P0171/000369
Contents
 [hide
16555/P0171/000369 - Fuel Trim; Bank 1: System Too Lean
Possible Causes
  • Mass Air Flow Sensor (G70) defective
Intake System Leak(s)
Possible Solutions
  • Check Mass Air Flow Sensor (G70)
Check Fuel Pressure Regulation
Check Fuel Pump
Check Injectors
Check Intake System for Leaks
Check Exhaust System for Leaks
Check Secondary Air System for Leaks
Check Vacuum Pipes for Leaks
16804/P0420/001056
Contents
 [hide
16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
Possible Causes
  • Leakage in Intake and/or Exhaust System
Catalyst faulty
Oxygen Sensor(s) faulty
Oxygen Sensor(s) Control faulty
Possible Solutions
  • Check Intake and Exhaust System for Leaks
Check Catalyst
Check Oxygen Sensor(s)
Check Oxygen Sensor(s) Control
  • Perform Oxygen Sensor(s) Aging Check
Special Notes
va rog ma ajutai cu urmatoarele erori :
VCDS Version: Release 12.12.0
Data version: 20130910
Friday,24,April,2015,19:03:59:40973
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
          67 69 75 76 77
VIN: WAUZZZ8E95A404639   Mileage: 117140km/72787miles
Address 01: Engine        Labels: 03G-906-016-BLB.clb
   Part No SW: 03G 906 016 GN    HW: 028 101 211 3
   Component: R4 2,0L EDC G010SG  9618
   Revision: 12345678    Serial number: XXXXXXXXXXXXXX
   Coding: 0000072
   Shop #: WSC 40436 150 58017
   VCID: 75E107561C613BB6B75-8020
5 Faults Found:
16618 - Boost Pressure Regulation
            P0234 - 000 - Limit Exceeded (Overboost Condition)
             Freeze Frame:
                    RPM: 2898 /min
                    Torque: 280.0 Nm
                    Speed: 142.0 km/h
                    Load: 100.0 %
                    Voltage: 13.98 V
                    Bin. Bits: 00101000
                    Absolute Pres.: 2295.0 mbar
                    Absolute Pres.: 2590.8 mbar
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 840 /min
                    Torque: 38.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.06 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
            P0672 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 840 /min
                    Torque: 38.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.06 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 840 /min
                    Torque: 38.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.06 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
            P0674 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 840 /min
                    Torque: 38.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.06 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Am cumparat de 2 saptamani masina e un audi a4 2005 motor 2000 140 cp
multumesc
stie cineva de ce imi scrie la "Labels: redir fail!" ?
Address 01: Engine        Labels: Redir Fail!
   Part No: 036 906 034 CP
   Component:  MARELLI 4MV       3956
   Coding: 00031
   Shop #: WSC 06441
   VCID: 62CB4C03EEBA6A0EE27-4A3A
   VSSZZZ1MZ2R030747     SEZ7Z0A1225805
No fault code found.
Readiness: 0000 0000
sigur..12.12, la celelalte module nu imi scrie asa
Saturday,21,March,2015,17:17:38:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
VIN: VSSZZZ1MZ2R030747   License Plate:
Mileage: 180630km-112238mi   Repair Order:
Chassis Type: 1M (1M - Seat Leon (2000 > 2005))
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ2R030747   Mileage: 180630km/112238miles
   Coding: 00031
   Shop #: WSC 06441
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 J
   Component: ABS FRONT MK60      0103
   Coding: 0001025
   Shop #: WSC 00001 001 00001
   VCID: 3169F34FABDC81962BD-5000
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 A
   Component: 1L AIRBAG VW51 0A     02
   Coding: 12620
   Shop #: WSC 06441
   VCID: 224B0C03AE3A2A0EA27-5000
Address 17: Instruments        Labels: 1M0-920-xx2-17.lbl
   Part No: 1M0 920 822 A
   Component: KOMBI+WEGFAHRSP VDO V02
   Coding: 04106
   Shop #: WSC 00000
   VCID: 26431013C212D62ECEF-5000
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 06441
   VCID: F0EFB64BB056489EE43-5000
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 F
   Component: 3K Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 06441
   VCID: 3A7BD46326AA42CE9A7-49D8
   Subsystem 1 - Part No: 1C0959801B
   Component: 3K Tőrsteuer.FS KLO 0002
   Subsystem 2 - Part No: 1C0959802C
   Component: 3K Tőrsteuer.BF KLO 0002
   Subsystem 3 - Part No: 1C0959811A
   Component: 3K Tőrsteuer.HL KLO 0002
   Subsystem 4 - Part No: 1C0959812A
   Component: 3K Tőrsteuer.HR KLO 0002
3 Faults Found:
00912 - Window Regulator Switch; Front Left (E40)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            27-00 - Implausible Signal
00935 - Electric Window Motor; Rear Right (V27)
            35-00 - -
End   ---------------------------------------------------------------------
Vezi ca ai clona , nu originala !
Originala e Release 14.10
totul e posibil!! o sa ii fac o poza zilele astea si o sa postez!!
cam asa arata
post-143203-0-42320800-1430073392_thumb.
post-143203-0-28693800-1430073414_thumb.
Pune softul 14.10 si daca e originala nunse strica , daca e clona - nu discutam de clone pe forum.
E 100 % clona ce ai tu , de aici si problema ta .
din punctul meu de vedere, pana in momentul in care o sa fiu eu 100% sigur ca e clona inca discut de ea ca si cum ar fi originala :D
te inteleg si aproape ca te cred, dar nu ar trebui sa arate si la celelalte "Labels" la fel ?
 cu 14.10 nu s a stricat dar nu se conecteaza! si totusi daca e facuta pentru 12.12 si nu suporta 14.10 ?
Modificat de pustiulica2
Colegu' ce nu ai inteles din ce ti-a scris Iulian(turbocip). Interfata e o clona. Daca era originala iti mergea ultimul release sau beta version disponibile pe site-ul ross tech. Interfata ta nu are label-ul ptr acel modul. Asta face diferenta dintre o clona si cea originala. La cea originala daca nu ai label faci un channel map si support-ul dezvoltatorului va rezolva acest issue.
"Daca era originala iti mergea ultimul release sau beta version disponibile pe site-ul ross tech. Interfata ta nu are label-ul ptr acel modul. Asta face diferenta dintre o clona si cea originala. La cea originala daca nu ai label faci un channel map si support-ul dezvoltatorului va rezolva acest issue.
Am inteles acum colegu`!! mersi
Cu placere. Ca sfat-daca imi permiti-foloseste interfata cu softul dat de vanzator, altfel risti sa ii razi firmware-ul si te uiti la ea dupa aia. Nu pune alt soft ca nu va merge.
Modificat de pronet
pai am incercat 14.10 de pe site ul ross-tech si nu merge...doar cu soft ul versiunea 12.12 cu care am cumparat-o!! oricum mersi, asteptam mai multe pareri: stii cum  e, trebuie sa auzi de la mai multi acelasi cuvant inainte sa il iei ca atare! :D
acum, trebuie vazut daca mai merge ... posibil sa nu.
Ce pot face in legatura cu eroarea:
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H10 2620
   Revision: 91H10262    Serial number: 0036M0005575
   Coding: 0033622
   Shop #: WSC 06335 000 00000
   VCID: 3B75D16E7AC5ADC6811-806E
   Subsystem 1 - Serial number: 6332DRB400E60BB2R
   Subsystem 2 - Serial number: 6342DRB400E08EAA/
   Subsystem 3 - Serial number: 6352ARB4002C26EAS
   Subsystem 4 - Serial number: 6362ARB4002C263BJ
   Subsystem 5 - Serial number: 63729RB4002C535DN
   Subsystem 6 - Serial number: 63829RB4002C522EL
01794 - Control Module - Incorrect Chassis (VIN) Number
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 99
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
Il indrumi gresit.
Intra pe airbag - apoi adaptari - canal 80/81 - read - iti da codul ajutator pe care il introduci si Do IT !
Modulul e ok acum .
Nu bagi nicaieri serie de sasiu , etc .
Posteaza rezultatul
E audi a4B7 , da ?
Buna ziua. Pentru vcds scan vag com trebuie sa cumpar mufa aceea si cu cd soft sau ce anume? Exista vreun tutorial? Sunt in anglia si am gasit pe ebay mufa cu cd pentru 20 de lire mi.e sa nu o cumpar degeaba cand altii o vand cu 200. Am laptop cu windows 8 pe el
Respectiva interfata e o clona. Merge doar cu soft-ul furnizat de vanzator. Una originala este la 350 usd direct in US.
  • Aerofan pinned this topic
