suzu
Merg toate functiile de pe masina?
La intermitent, poate sa aiba noroc sa ii mearga
coelgii, unde pot vizualiza in program daca e montata corect distributia?
Modificat de iuliu1984
Vezi avans in canal 04 pe engine .
Distributia o verifica mecanic cine ti-a facut-o .
Salut imi  dati va rog asistenta la urmatoarele erori:
VCDS Version: Release 12.12.0
Data version: 20130910
Sunday,05,April,2015,17:24:09:40973
Chassis Type: 1M (1M - Seat Leon (2000 > 2005))
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ2R009421   Mileage: 209010km/129872miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 036 906 034 CP
   Component:  MARELLI 4MV       4376
   Coding: 00031
   Shop #: WSC 03259
   VCID: 62CB4C0AEEEFBC0EE27-4B82
   VSSZZZ1MZ2R009421     SEZ7Z0A1236550
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 -  - Intermittent
17972 - Throttle Actuator (J338)
            P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 C
   Component: ABS FRONT MK60      0103
   Coding: 0001025
   Shop #: WSC 00001 001 00001
   VCID: 2A5BE42A865F244EEA7-517A
01314 - Engine Control Module
Address 08: Auto HVAC        Labels: 1M0-820-043.lbl
   Part No: 1M0 820 043 D
   Component: 1M-CLIMATRONIC    X0605
   Coding: 00040
   Shop #: WSC 06441
   VCID: 2345090EB175F506A91-25A8
01206 - Signal for Duration of Ignition Off Time
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 A
   Component: 1L AIRBAG VW51 0A     01
   Coding: 12620
   Shop #: WSC 06441
   VCID: 224B0C0AAE6FFC0EA27-515E
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1M0-920-xx2-17.lbl
   Part No: 1M0 920 802 A
   Component: KOMBI+WEGFAHRSP VDO V01
   Coding: 04106
   Shop #: WSC 00000
   VCID: 24470A12B47BF23ED0B-517A
3 Faults Found:
01176 - Key
01316 - ABS Control Module
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 06441
   VCID: F0EFB642B0039E9EE43-517A
2 Faults Found:
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 F
   Component: 3K Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 06402
   VCID: 3A7BD46A26FF94CE9A7-4B36
   Subsystem 1 - Part No: 1C0959801B
   Component: 3K Tõrsteuer.FS KLO 0002
   Subsystem 2 - Part No: 1C0959802C
   Component: 3K Tõrsteuer.BF KLO 0002
   Subsystem 3 - Part No: 1C0959811A
   Component: 3K Tõrsteuer.HL KLO 0002
   Subsystem 4 - Part No: 1C0959812A
   Component: 3K Tõrsteuer.HR     0001
6 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
            53-10 - Supply Voltage Too Low - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
            25-00 - Unknown Switch Condition
00912 - Window Regulator Switch; Front Left (E40)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            27-00 - Implausible Signal
01359 - Internal Central Locking Switch; Passenger Side (E198)
00931 - Locking Module for Central Locking; Rear Right (F223)
End   ---------------------------------------------------------------------
multumesc
Sterge si revino dupa , cu erorile ce iti raman
imi merg toate functiile nu am nicio problema, doar erorile le-am gasit
nu mai apare eroarea data de imobilizator in rest toate , vreo sugestie ?
La airbag cum se rezolva am observat ca e des intanita problema aceasta?
La airbag ai mesaj de eroare ca ai avut tensiune slaba la baterie
nu, doar  pe can , module usi  si centrala electrica, mentionez ca acum dupa un drum de 100 km nu au mai aparut erorile
poate sa fie de la baterie ? sa fie defecta?
dragomiricacristinel
Este cineva din Constanta care ma poate ajuta si pe mine cu rezolvarea a 2 coduri de eroare?
ja o jetta 1,6 td am urmatoarea eroare pe partea motor
7337 - ROD - Unknown Error Code
          - 00 [096]
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 72169 km
                    Date: 2051.14.09
                    Time: 13:48:01
Ma poate ajuta cineva? Mentionez ca eroarea dispare dupa ce repornesc motorul dar reapare dupa un timp
Modificat de mitubisi75
FA o diagnoza cu o interfata "buna"/
Interfata e acceptabila dar doream sa stiu eroarea, cred ca e de la egr si nu stiu daca se poate rezolva din soft sau trebuie intervenit mecanic la fata locului.
Interfata e jalnica si eroarea e : Unknown Error Code .
Mi-a "murit" claxonul odata cu luminile din interior dupa ce am montat un bec. La lumini am depistat o siguranta arsa, schimbata, si functioneaza ok. La claxon nu reusesc. Stie cineva unde este siguranta exact la VW Golf 6? Ce altceva ar putea fi?
Aceasta este scanarea:
Tuesday,07,April,2015,17:32:21:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
VIN: WVWZZZ1KZ9P412305   License Plate: B123RED
                Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 1K0 937 087 AB    HW: 1K0 937 087 AB
  Component and/or Version: BCM PQ35  H+  110 0651
           Software Coding: 48180A3A9025F3C0400800801400892445550288536D8960648000000000
            Work Shop Code: WSC 01973 973 01973
                      VCID: 71E9334FA85CC1966BD-8024
3 Faults Found:
01134 - Alarm Horn (H12)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 142
                    Mileage: 110488 km
                    Time Indication: 0
                    Date: 2006.14.12
                    Time: 17:27:16
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.00 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
03156 - Sensor for Anti-Theft System (G578)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 142
                    Mileage: 110488 km
                    Time Indication: 0
                    Date: 2006.14.12
                    Time: 17:27:16
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.00 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
03266 - Control Circuit for Signal Horn
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 142
                    Mileage: 110488 km
                    Time Indication: 0
                    Date: 2006.14.12
                    Time: 17:27:17
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.00 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Asculta ce ti se spune, interfata de diagnoza e praf, fa diagnoza cu interfata originala
De curand mi-a aparut aceasta eroare la Golf 6 1.4 TSI 160cp. Atunci cand se aprinde martorul si apare aceasta eroare, nu se mai tureaza peste 3000rpm si e foarte agasant. Face cand vrea, am sters erori, schimbat  combustibil etc.
Stie cineva ce ar putea fi?
Atasez si eroarea din log
_________________________________________________
004260 - Intake Air Regulating Flap
               P10A4 - 000 - Mechanical Malfunction
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 54613 km
                    Time Indication: 0
                    Date: 2021.14.14
                    Time: 19:58:10
             Freeze Frame:
                    RPM: 3009 /min
                    Load: 9.8 %
                    Speed: 0.0 km/h
                    Temperature: 84.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
Readiness: 1110 0101
Am rezolvat cu siguranta.
Si Revin cu aceasta problema. Se poate sa fi aparut ca nu a fost clapeta reglata la o interventie service?
Modificat de redeye
nu, e defect mecanic acolo
Scriu aici in speranta ca ma poate lamuri cineva cu urmatoarea problema.
1 bucata Polo 6N2 cu EPC aprins cu eroarea :
16492 - Manifold / Barometric Pressure Sensor (G71) / (F96): Signal too High
P0108 - 35-00 - -
Dat jos si curatat senzor MAP fara succes.
Masina se manifesta astfel : trage foarte bine cand este aprins EPC-ul iar cand se stinge motorul da in nas si nu trage cum trebuie cand nu mai este aprins EPC-ul in bord.
Epc ul se stinge si se aprinde intermitent.
Intrebarea este senzorul este defect si necesita schimbare sau exista o alta problema ?
Multumesc anticipat.
Fa o proba cu un sensor de proba , imprumutat daca poti si care stii tu ca e bun.
Nu am de unde sa iau unul de proba.Daca aveam , spuneam de la bun inceput ca am probat senzorul si e bun.
P0108 - 35-00 - -
Altcineva va poate ajuta cu o parere?
Salut !  Erorile de la check engine ... Imi apare Emission Workshop ...ce ar trebui verificat in primul rand la mine? Golf 4 2.0 benzinar an20001607d5v.jpg
Modificat de alexandruph
Aer fals,bujii, fise, bobine...apa pe langa ele etc
  • Aerofan pinned this topic
