suzu
@Joe2k
Senzorul NOx (G295) este sub masina dupa catalizator
Mai mult ca sigur ca ai un contact imperfect la acel senzor din cate spui cum se comporta
Pentru recodare radio: Intri in modulul 56-Radio  -  Coding 07 -  introduci codul ce iti apare in eroare - Do It!  Apoi rescanezi si vezi daca mai apare
( intotdeauna sa iti notezi codul care il vei modifica! )
Bafta!
Modificat de Cristi_VW
ciobanuionutz91
Nu stie nimeni nimic de eroarea asta?
18056   Powertrain Data Bus  Failure
             P 1648 -35- - - 10  Intermitent
Masina tremura la relanti si are unele intreruperi in mers,am verificat bobina si fisele,am zis ca are intreruperi din cauza unei fise sau a bobinei ,dar nu e de acolo,bujiile sunt schimbate recent la fel si toate filtrele,am curatat clapeta am calibrat-o,am curatat EGR,crezand ca de aici ar avea tremuratul de la relanti,dar nimic nu sa schimbat dupa toate acestea.
   Ce sa mai verific,si mai ales ce e cu eroarea?dupa fiecare scanare am sterso si nu apare imediat dupa,apare dupa ce parcurg ceva km.
 Multumesc anticipat!
De pe net culese:
18056 P 1648-35-10  powertrain data bus failure or INTERMITENTProbleme la cutia automata sau modulul de ABS.Possible symptoms:    Disturbances in behavior (switching shock, jerky rotation)    No ESP    No ASR    No MSRPossible causes:    Fault in the data cables to the controller or automatic gearbox. ABS control unit    Fault in system: Automatic transmission, respectively. ABSPossible solutions:    Check the terminating resistor in the engine control module (VAG special tools required)    Terminating resistor gives incorrect value: replace engine control module    Terminating resistor gives good value: Check flowchartsAdditional info:    The ECU talks to all control modules via the CAN databusaansluiting. All these control modules with two twisted inelkaar databuskabels (High and Low) are linked together and exchange information. If that databuskabels information is missing (fails) is shown on each line module as fault appears. A terminating resistor in the motor control unit ensures that the data bus can operate error-free.Vezi daca ai stocate erori pe ABS.verifica sigurante.
ciobanuionutz91
Merci B4DY, am gasit si eu asta,dar unde este rezistența terminală în modulul de comandă a motorului,in ECU?masina  nu are cutie automata,si ABS functioneaza.am mai gasit ceva legat de eroare si spune ca simptomele eroarii ar fi ''mers sacadat,smucituri si tremurat la relanti,exact cu se comporta si masina mea.
  Am fost la cineva are se ocumpa cu scanari,reparatii ECU si a spus ca eroarea este o eroare de comunicare si ca nu are legatura cu comportamentul pe care il are masina,a facut o diagnoza s-a uitat pe acolo dar nimic nu s-a schimbat,ori nu se pricepe prea bine ori nu stie despre ce e vorba ca a zis ca nu a mai intalnit eroarea asta.ce ma sfatuiti sa fac mai departe?
Am scanat azi din nou masina si iar am alarme. De la ce ar putea fi?
Motorul trage bine si nici nu sa mai oprit dar in schimb mi-a aparut alarma check engine
Address 01: Engine        Labels: Redir Fail!
   Part No: 03D 906 032 C
   Component: 1,2l/2V SIMOS3  00HS2501
   Coding: 00031
   Shop #: WSC 00788
   VCID: 1E39C0A19AACF49
   WVWZZZ9NZ2Y045985     VWZ7Z0A4524822
8 Faults Found:
16556 - Fuel Trim; Bank 1
            P0172 - 35-10 - System Too Rich - Intermittent
17987 - Throttle Actuator (J338)
            P1579 - 35-10 - Adaptation Not Started - Intermittent
17972 - Throttle Actuator (J338)
            P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
            P0106 - 35-10 - Implausible Signal - Intermittent
17973 - Throttle Actuator (J338)
            P1565 - 35-10 - Lower Stop not Reached - Intermittent
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
            P1171 - 35-10 -  - Intermittent
17950 - Angle Sensor 1 for Throttle Actuator (G187)
            P1542 - 35-10 - Implausible Signal - Intermittent
17953 - Throttle Valve Controller
            P1545 - 35-10 - Malfunction - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ABS2.lbl
   Part No: 6Q0 907 379 E
   Component: ABS FRONT MK60      0103
   Coding: 0001097
   Shop #: WSC 00788 785 00200
   VCID: 3F875D256D669D1
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
Ai incercat sa faci adaptarea clapetei ?
... si la EGR
Am facut adaptarea la clapeta. La EGR ce trebuie facut?
Buna seara,
Am scanat acum putin timp masina unei rude, un Tiguan din 2008 1.6 - 140cp (daca  zic bine) si acum gasit urmatoarele erori:
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 1C 22 25 42 44 46 52 53 55 56 62 72
VIN: WVGZZZ5NZ8W032933   Mileage: 125630km/78062miles
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
1C-Position Sensing -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: None
   Part No SW: 03C 906 032 T    HW: 03C 906 032 C
   Component: MED17.5.1           2253
   Revision: 96H07---    Serial number: VWX7Z0H13N805A
   Coding: 0000172
   Shop #: WSC 01324 785 00200
   VCID: 2E591061B90C649
2 Faults Found:
008803 - Turbo/Super Charger Boost System
               P2263 - 000 - Performance
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 124312 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:15:07
             Freeze Frame:
                    RPM: 3367 /min
                    Load: 58.0 %
                    Speed: 129.0 km/h
                    Temperature: 93.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.589 V
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 0
                    Fault Frequency: 3
                    Mileage: 125490 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:04:02
             Freeze Frame:
                    RPM: 830 /min
                    Load: 16.9 %
                    Speed: 0.0 km/h
                    Temperature: 87.0°C
                    Temperature: 54.0°C
                    Voltage: 13.462 V
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 DD    HW: 1K0 907 044 DD
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 6CDDDA694F90D69
00716 - Air recirculation Flap Positioning Motor (V113)
            000 -  -  - Intermittent
Address 1C: Position Sensing        Labels: 1Kx-919-xxx-1C.lbl
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T2R1K03
   VCID: FDFB672DA4EACF1
2 Faults Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 191
                    Mileage: 68746 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:36:21
00466 - Control Module for Steering Column Electronics (J527)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 187
                    Mileage: 0 km
                    Time Indication: 0
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 81800A0052830C7F3F02840570084FC6F0FC00
   Shop #: WSC 10169 599 82131
   VCID: 830F11D5C20EB91
   Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Component: Innenraumueberw.003 0203
2 Faults Found:
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 4
                    Fault Frequency: 252
                    Reset counter: 103
                    Time Indication: 0
01038 - Central Locking Thermal Protection
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 4
                    Fault Frequency: 65
                    Reset counter: 112
                    Mileage: 124555 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:26:31
Ma poate ajuta cineva cu un raspuns, va rog?
Multumesc anticipat.
Probleme turbo si clapeta admisie - aste a sunt probleleme cele mai importante
Ok, mersi frumos. Am sa-i transmit ce mi-ai raspuns ca vrea sa se duca si la reprezentanta si nu stia ce sa le zica celor de acolo.
Mersi din nou.
Buna, la un Polo 1.4 din 2000, am urmatoarea eroare 16712 - Knock Sensor 1 (G61): Signal too High P0328 - 35-10 - - - Intermittent, am inlocuit senzorul, curatat mufa si firele par a fi ok, ce ar mai putea fi ? se stinge, iar dupa 2-3 zile reapare eroare cu martor motor. multumesc anticipat
a fost strans cu cheie dinamometrica?
buna seara, la test a aparut eroarea de mai jos ( cu chek engine), curatat clapeta, maf, schimbat filtre, uleiul, polen ,aer , adaptat clapeta si sters eroarea..., am verificat si cablul si mufa senzorului, e ok, ... dupa cativa km a aparut iarasi eroarea (si martorul in bord)...maine schimb bujiile ... este senzorul dus?
am si simulator sonda lambda, daca il pun mai apare vreo eroare?
va multumesc anticipat
VCDS Version: Release 11.11.3
Data version: 20120401
Monday,08,July,2013,19:05:49:32264
Chassis Type: 1U - Skoda Octavia I
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
VIN: TMBCX41U342870613   Mileage: 150210km/93336miles
Address 01: Engine        Labels: 06A-906-033-AVU.lbl
   Part No: 06A 906 033 BG
   Component: SIMOS33 1.6l 2VG00HS4600
   Coding: 00231
   Shop #: WSC 31480
   VCID: 65CBAF4DFF7AE71
   TMBCX41U342870613     SKZ7Z0C2173720
2 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating; B1 S2
            P1118 - 35-00 - Open Circuit
16524 - Oxygen (Lambda) Sensor B1 S2
            P0140 - 35-10 - No Activity - Intermittent
Readiness: 0010 0001
simulatorul te ajuta pt aceasta eroare,adica daca sunt probleme cu catalizatorul.dar se pare ca sunt probleme cu sonda.
16804 - Catalyst System: Bank 1: Efficiency Below Threshold P0420 - 35-00 - -
Sper sa nu deranjez pe nimeni, dar postez si aici log-ul facut la Polo in speranta unor raspunsuri/pareri:
Chassis Type: 6N - VW Polo
Scan: 01 02 03 08 15 17 19 25 41 45 46 55 56
   Part No: 030 906 027 E
   Component: MOTRONIC MP 9.0    2126
   Shop #: 1037355854
   VCID: 1025AE995078529
3 Faults Found:
00625 - Vehicle Speed Signal
            27-00 - Implausible Signal
00561 - Mixture Adaptation
            15-00 - Adaptation Limit (Add) Not Reached
00525 - Oxygen (Lambda) Sensor (G39)
            03-10 - No Signal - Intermittent
Readiness: N/A
Address 15: Airbags        Labels: 6N0-909-60x-VW2.lbl
   Part No: 6N0 909 603 T
   Component: AIRBAG VW2          V00
   Coding: 00084
   Shop #: WSC 01236
   VCID: 438F51D5518EF91
2 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
            32-00 - Resistance too High
            07-10 - Signal too Low - Intermittent
17961 - Barometric / Manifold Pressure Signals: Implausible Correlation
P1553 - 35-10 - - - Intermittent
Apare mereu, motorul a fost segmentat, 150k km...masina e o Ibiza 2004 , nu stiu ce sa ii mai fac... Bujiile sunt noi, toate bobinele dau scantei...Care sa fie problema? Cateodata merge..cateodata merge parca in 3 cilindri, nu o pot accelera rareori... si se opreste in mers..
s'a umblat la distributie?sigur e la punct?
@ R Z F - da, sa strans cu dinamometrica
Modificat de ghitaTSI
salut cine ma poate ajuta cu erorile astea?
Tip sasiu: 1J - VW Golf/Bora IV
Adrese de scanat: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
rulaj: 227560km
Adresa 01: Motor Eticheta: ROJ\06A-906-019-AEH.clb
Numar VAG: 06A 906 019 BF
Componenta comandata: 1.6l R4/2V SIMOS HS2439
Codare: 04000
Atelier: WSC 00046
VCID: 68D4565308E3DD58897
2 coduri de defecte
00537 - Reglare lambda -senzor oxigen-
18-00 - Limita superioarã
00516 - Contact ralanti -F60--clapeta închisa
30-10 - Circ.deschis sau scurt la plus - intermitent
Starea -Gata de functie-: N/A
Adresa 03: ABS frâne Eticheta: ROJ\1J0-907-37x-ABS.lbl
Numar VAG: 1J0 907 379 G
Componenta comandata: ABS 20 IE CAN 0001
Codare: 03504
Atelier: WSC 01317
VCID: 356ACF270FD170B0C21
Nu a gasit coduri.
Adresa 08: Clima automata Eticheta: 3Bx-907-044.lbl
Numar VAG: 3B1 907 044 A
Componenta comandata: CLIMATRONIC S 9.0
Codare: 01000
Atelier: WSC 01317
VCID: 1F460D8F9D2DDAE038D
1 cod a gasit
01274 - Servomotor pozitionare clapeta -V71-
35-10 - - - intermitent
Adresa 15: Airbaguri Eticheta: 1J0-909-60x-VW3.lbl
Numar VAG: 1J0 909 609
Componenta comandata: A AIRBAG VW3 SG 0002
Codare: 00065
Atelier: WSC 01317
VCID: ECDCAA439C1B71786DF
Nu a gasit coduri.
Adresa 17: Instrumente bord Eticheta: 1J0-919-xxx-17.lbl
Numar VAG: 1J0 919 860 D
Componenta comandata: KOMBI+WEGFAHRS. MM0 V11
Codare: 04143
Atelier: WSC 25275
VCID: 3064FE33F0B35598917
Subsistem 1 - Numar VAG: Ident
Componenta comandata: Nr. WEGFAHRS.:VWZ6Z0W0284358
Ident.-Nr. WEGFAHRS.:VWZ6Z0W0284358
Nu a gasit coduri.
Adresa 46: Confort Eticheta: 1J0-959-799.lbl
Numar VAG: 1J0 959 799 H
Componenta comandata: 04 Zentral-SG Komf.0002
Codare: 00257
Atelier: WSC 01317
VCID: 438EA1FF5105DE007C5
Subsistem 1 - Numar VAG: 1J1959801C
Componenta comandata: 04 Tõrsteuerger. FS0001
Subsistem 2 - Numar VAG: 1J1959802D
Componenta comandata: 04 Tõrsteuerger. BF0001
4 coduri de defecte
00949 - Motor inchidere centrala haion-V53- incuiat
25-10 - Pozitie comutator necun. - intermitent
00928 - Unitate inchidere centrala-F220-sofer
27-00 - semnal neplauzibil
00943 - Oglinda incalzita sofer -Z4-
35-00 - -
00944 - Oglinda incalzita pasager-Z5-
ma poate ajuta si pe mine cineva cu descifrarea celor 4 erori aparuta la scanarea unui golf 5 1.6 FSI 2005.
Merci
19-CAN Gateway -- Status: OK 0000a
42-Door Elect, Driver -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 BP    HW: Hardware No
   Component: MED9.5.10       G00 9266
   Revision: 00000000    Serial number: VWZ7Z0D9941761
   Coding: 0000072
   Shop #: WSC 10103 599 96735
   VCID: 72EFDEFB9E3
2 Faults Found:
18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
            P1951 - 002 - Lower Limit Exceeded - Intermittent
18358 - Radiator Fan (V7): Movement Restricted / Jammed
            P1950 - 002 - Lower Limit Exceeded - Intermittent
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 N
   Component: ASR FRONT MK70      0103
   Coding: 0017025
   Shop #: WSC 00028 028 00001
   VCID: 3D753DC797D
No fault code found.
   Part No: 1K0 907 044 K
   Component: ClimatronicPQ35 061 0201
   VCID: 2F69178F4D1
01810 - Actuating Motor for Temperature Flap; Right (V159)
            000 -  -
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000700297
   Coding: E58D0F0600041800001400001400000000
   VCID: 408B4433E0F
   Subsystem 1 - Part No: 1K1 955 119 B
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 M
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 D    HW: 1K0 909 605 D
   Component: 01 AIRBAG VW8   022 0600
   Revision: 05022000    Serial number: 0033JD0DL9C7
   Coding: 0012337
   VCID: 2D550D8747D
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000022
   VCID: 306B14F350F
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 851 NX
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0003103
   VCID: 8B11231F199
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 21001044281212
   Coding: 3D3F0340070002
   VCID: 2759FFAF651
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.lbl
   Component: IMMO            VDD 0814
   Shop #: WSC 10103 599 96538
   VCID: 8B11231F199
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0147
   Coding: 0000052
   VCID: 306B14F350F
00943 - Heated Exterior Mirror; Driver Side (Z4)
            012 - Electrical Fault in Circuit
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K1 909 144 G
   Component: EPS_ZFLS Kl.1       1401
   VCID: 2F69178F4D1
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 80C802087F2D8404084F01E010
   VCID: 7BF1F3DFC99
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 316D11F75B5
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 J
   Component: Radio GR0           0014
   Revision: 0001002S    Serial number: VWZ2Z2D1774735
   Coding: 0020200
   VCID: 2D550D8747D
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0202
   Coding: 0000016
   VCID: 306B14F350F
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   VCID: 316D11F75B5
00935 - Electric Window Motor; Rear Right (V27)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
End   ---------------------------------------------------------------------
raulraymond
1-a +2-a - electroventilatorul de la radiator -probabil blocat(gripat sau ceva ce-l impiedica sa se invarta)
3-a    -incalzirea oglinzii exterioare partea soferului  -fir intrerupt sau arsa
4-a    -motorasul geam usa spate pasager  - fire intrerupte sau "incorect codat"
Modificat de floro_st205
  • Aerofan pinned this topic
