zorg
Am incercat sa fac unele teste pe modulul de control pentru motor folosind VAG-COM 3.12.
Nu pot citi decat pana la blocul 027.
Ma incercat sa testez MAF-ul (http://vwforum.ro/index.php?showtopic=9945) si am nevoie sa citesc blocurile 30, 32, 33,...
Cum pot ajung la acestea?
PASSAT motor 1.8T 20V AEB 1999.
Mii de scuze daca am gresit locul, dar este ceva urgent ptr. un prieten care pleaca peste 2 sapt . in Romania(suntem in Irlanda), si-a cumparat deja bilet la feribot si azi sa intamplat beleaua:
Vw passat 2002 TDI sport AVF. Motorul a inceput sa trepideze(merge in 3), si s-au aprins becurile de la ESP fara a apasa butonul. I-am facut o scanare cu Vag-com-ul cu motorul la relanti,sunt incepator am interfata de vreo cateva zile, si mi-a dat urmatoarea diagnoza :
VAG-COM
Windows Based VAG/VAS Emulator
Version: Release 311.2-N
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000
Self-Diagnosis Log
Thursday, 01 June 2006, 16:04:32
VIN Number: WVWZZZ3BZ2P300952 License Plate: 02wh4499
Mileage: 60000 Repair Order: 5644
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 038 906 019 EP
Component: 1,9l R4 EDC 0000SG 1464
Coding: 00002
Shop #: WSC 00028
WVWZZZ3BZ2P300952 VWZ7Z0A4581283
3 Faults Found:
18090 - Powertrain Data Bus: Implausible Message from ABS Controller
P1682 - 35-10 - - - Intermittent
18074 - Valve for Pump-Jet: Cylinder 1 (N240): Electrical Malfunction
P1666 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 04255
Shop #: WSC 00028
2 Faults Found:
00283 - Front Left ABS Wheel Speed Sensor (G47)
30-10 - Open or Short to B+ - Intermittent
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
Address 08 -------------------------------------------------------
Controller: 3B2 907 044 J
Component: CLIMATRONIC B5GP 0004
Coding: 17000
Shop #: WSC 00028
00792 - A/C Pressure Switch (F129)
35-00 - -
Skipping Address 15-Airbags
VAG-COM
Self-Diagnosis Log
Page 2
Address 17 -------------------------------------------------------
Controller: 3B0 920 927 A
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 05415
Shop #: WSC 00000
No fault code found.
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 6T Komfortger
Dar este imposibil, la acest motor nu ai decat urmatoarele grupe de masura:0,1,2,3,4,5,6,7,8,9,10,11,14,15,16,18,19,20,21,24,25,26,95,98 si 99. Atat.
Multumesc pentru raspuns.
Pentru a afla starea MAF-ul ce blocuri trebuie sa citesc?
Display group 4 -Idling stabilisation-
Read measured value block 4 ⇒ [ltrif ] Indicated on display
x <
Sal,
Cine ma poate ajuta si pe mine cu o scanare? Mi-a intrat in limp mode si dupa aia si-a revenit. Plec in concediu si nu as vrea sa raman pe drum.
Datele le aveti in profil.
10x,
V
salutare.care dintre cei ce scriu aici si-au "construit" ei singuri un VAG-COM pot sa spuna sau sa descrie procedura prin care l-au facut?pariez ca e mai multa lume interesata sa isi faca un tester si nu are toate informatiile necesare.mii de multumiri si scuze de e OFFTOPIC. :(
Salut. Am nevoie de un test cu vag-com-ul, nasol insa e ca nu pot sa ma deplasez cu masina (Golf 4 TDi, 1,9 ALH, 2002). Stau in zona Turda-1 Mai. Ma poate ajuta cineva?
Am scanat astazi cu vag-com (multumiri lui alexandru) si iata rezultatele:
VAG-COM Version: Release 311.2-N
Chassis Type: 9N1 - VW Polo
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Controller: 03E 906 033
Component: 1,2l/4V SIMOS3 00HS4649
Coding: 00071
Shop #: WSC 40631
WVWZZZ9NZ2Y017529 VWZ7Z0A4374604
2 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
Readiness: 0010 0001
Controller: 6Q0 907 379 E
Component: ABS FRONT MK60 0103
Coding: 0001097
Shop #: WSC 00788
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
Controller: 6Q0 820 045
Component: Klimaanlage X0840
5 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
29-10 - Short to Ground - Intermittent
28-10 - Short to B+ - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 17708
Shop #: WSC 00788
Controller: 6Q0 920 800 PX
Component: KOMBI+WEGFAHRSP VDO V19
Coding: 01131
Shop #: WSC 10103
Controller: 6N0909901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 00788
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00140
Shop #: WSC 00788
End -------------------------------------------------------
Ma poate ajuta cineva cu interpretarea acestor rezultate si bineinteles ce ma puteti sfatui in legatura cu erorile aparute, ce anume pot face sa rezolv problemele. Astept raspuns de la voi.
Salutare la toti pasionatii de VW. De curand am cumparat si eu un Passat din 2003 (sunt foarte mandru de el :blink: ) si am facut o scanare cu Vag-Com. Poate cineva sa ma ajute cu interpretarea erorilor?
Address 08
Controller: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0009
Coding: 17000
Shop #: WSC 00028
3 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
Presupun ca din acesta cauza da caldura cand vrea ea...
Address 17
Controller: 3B0 920 847 E
Component: KOMBI+WEGFAHRSP VDO V08
Coding: 21115
Shop #: WSC 00000
WVWZZZ3BZ3P206383 VWZ7Z0B6067491
00562 - Sensor for Oil Level/Temperature (G266)
Address 56
Controller: 3B0 035 186 D
Component: Radio BNO 0304
Coding: 04405
Shop #: WSC 00028
2 Faults Found:
00852 - Loudspeaker(s): Front
36-10 - Open Circuit - Intermittent
00853 - Loudspeaker(s): Rear
Va multumesc si astept un raspuns.
Desi vad ca pe acest forum nu tare se raspunde la problemele celor care scriu, in sperantza unui ajutor,imi postez si eu anuntul:stie careva ce inseamna erorile aparute la mine?iata 3:
17911-load signal from alternator term.DF:implausibile signal
p1503 -35-10----intermitent
17664-engine coolant temp senzor(g62):open or short to +
p1256-35-10--- intermitent
16955-brake switch:implausibile signal
p0571-35-11--
mersi mult.PS:"intermitent".....ce simbolizeaza asta?sau "35-10 , 35-11 , 35-00 "?ce coduri sunt astea?
Modificat de calin_bm
Erorile tale de la climatonic sunt oarecum uzuale pentru cei care nu inchid climatronicul inainte de a opri motorul (si eu fac la fel). Nu e nimic grav, inseamna ca niste flapsuri de directionare a aerului si-au pierdut pozitia. Daca inchizi climatronicul din buton si il deschizi din nou s-a rezolvat. Daca nu-ti face suficient de rece, probabil trebuie sa incarci instalatia cu freon.
Celelalte erori nu le cunosc.
Modificat de *bmf*
p0571-35-11--
pt. 17664-este destul de clar; fie un contact prost fie un scurt (intermitent) verifica circuitul electric al senzorului cu pricina.
pt. 16955- 90% schimbi switch-ul. Bafta!
Iata semnificatia :16955 P0571 Brake light switch -F
Implausible signal
- Brake light switch -F or brake pedal switch -F47 defective
- Glow period warning lamp -K29 flashes
- No brake light function
- Test -F and -F47 => Page 23-63
Test brake lights
006
Read measured value block 6 Switch positions 1 2 3 4
1= Road speed
2= Pedal monitoring:positions
X X 1 :Brake light switch -F closed
X 1 X :Brake pedal switch -F47 open
1 X X :Clutch pedal switch -F36 open
3 = Accelerator pedal position
4 = Operating status of cruise control system (CCS):
si de foarte multe ori ambele becuri de frana spate erau arse, functiona doar cel cu LED-uri de sus. Dar acest lucru se poate verifica foarte usor si cu Vag-com-ul. Succes!
E adevarat ce zici tu aici dar intrebarea si rugamintea mea e:imi poti da si mie sursa -adica de unde ai citit ce mi-ai scris mie aici?ma refer la document.M-ar interesa o mai detaliata exprimare a erorilor,ceva in genul in care ai scris tu.Ms.
[edit]16955/P0411/001393 - Brake Switch (F): Implausible Signal
[edit]Possible Causes
Brake Switch (F) defective
[edit]Possible Solutions
Check/Replace Brake Switch (F)
Retrieved from "http://wiki.ross-tech.com/index.php/16955/P0571/001393"
Categories: Fault Codes
Da o geana prin zona si poate te luminezi :)
Modificat de xxleeus
Am tras eu cu geana dar nu am gasit decat o parte din coduri.Oricum,sunt folositoare.Speram ca mai adauga baietii.
Se numeste ElsaWin 2.5/2.6/3.0/3.1/3.2/3.3, oricare din variante, este manualul de reparatii Audi-VW.
Rog foarte mult pe cineva care cunoaste sa explice care este asemanarea sau diferenta intre Vag-Com si Vas
multumesc
Chiar nu stie nimeni-sau e secret.
Vag-Com-ul este un scaner specializat pe familia Audi-VW ca si VAS 5052, intre cele doua exista asemanari dar si diferente. Asemanarea este ca amandoua folosesc codurile de eroare, codul grupelor/canalelor de masurare ca si in manualul de reparatie, dar afisajul pe ecran este la fiecare altfel. Vag-com mult mai flexibil si usor de folosit decat VAS, iar in ultima versiune 607.2 are mai multe functii de masura decat VAS.
Dar in VAS apar lucruri care nu se mai regasesc in ELSA decat superficial: airbag,eps,abs,coduri login etc, se poate spune ca este un manual de reparatie in completarea ELSA.
Ma macina si pe mine o intrebare si astept daca se poate niste lamuriri...mi s-a intamplat azi sa merg normal cu masina din semnatura si dintr-o data mi-a dat un mesaj pe com de bord : "Emision workshop" si a ramas aprins si un martor in bord (motorul) . S-a repetat figura de cateva ori...dupa ce stau cateva zeci de minute cu motrorul oprit dupa ce pornesc iar nu mai apare...dar dupa ce merg si mai ales daca o fac mai agresiv se aprinde iar ;) Pot fii emisii de gaze ?? Pote oare sa fie din cauza amanarii schimbului de ulei cu vreo 1500km ? e ceva grav ? astept sugestii pana merg la service sa o bag pe VAG-COM...
Cine ma poate ajuta cu un VAG COM in focsani va rog
In plus VAS-ul, daca nu ma insel, iti da (afiseaza) procedurile pt. efectuarea unor teste .
Salutare! Am facut de curand si eu o scanare a motorului. Nu au aprut erori, asta ma multumescte. Iata insa un log facut pt "compresie". Rog pe cineva care are timp si bunavointa sa arunce o privire si sa dea o interpretare. Multumesc.
Saturday,02,September,2006,14:43:42
038 906 019 AT ,,1.9l R4 EDC G000SG 1513,
,Group A:,'013,,,,Group B:, Not Running,,,,Group C:, Not Running
,, Cyl 1, Cyl 2, Cyl 3, Cyl 4,,,,,,,,,,
,TIME, -2.8 to +2.8 mg/H, -2.8 to +2.8 mg/H, -2.8 to +2.8 mg/H, -2.8 to +2.8 mg/H,TIME,,,,,TIME,,,,
MARKER,STAMP, mg/R, mg/R, mg/R, mg/R, STAMP,,,,,STAMP,,,,
,0.00, -0.16, -0.26, -0.02, 0.47,,,,,,,,,,
,0.37, -0.21, -0.28, 0.00, 0.47,,,,,,,,,,
,0.77, -0.21, -0.31, 0.00, 0.47,,,,,,,,,,
,1.17, -0.19, -0.31, 0.00, 0.45,,,,,,,,,,
,1.57, -0.16, -0.33, 0.02, 0.42,,,,,,,,,,
,1.95, -0.14, -0.31, 0.00, 0.40,,,,,,,,,,
,2.35, -0.14, -0.28, 0.00, 0.42,,,,,,,,,,
,2.75, -0.16, -0.28, 0.00, 0.42,,,,,,,,,,
,3.15, -0.19, -0.26, 0.00, 0.42,,,,,,,,,,
,3.55, -0.19, -0.26, 0.00, 0.42,,,,,,,,,,
,3.94, -0.16, -0.24, 0.00, 0.42,,,,,,,,,,
,4.34, -0.12, -0.26, 0.00, 0.40,,,,,,,,,,
,4.74, -0.09, -0.26, -0.02, 0.35,,,,,,,,,,
,5.14, -0.05, -0.26, -0.05, 0.33,,,,,,,,,,
,5.54, 0.00, -0.26, -0.05, 0.35,,,,,,,,,,
,5.92, 0.00, -0.31, -0.05, 0.35,,,,,,,,,,
,6.32, 0.00, -0.33, -0.07, 0.38,,,,,,,,,,
,6.72, 0.00, -0.33, -0.05, 0.38,,,,,,,,,,
,7.12, 0.00, -0.31, -0.09, 0.38,,,,,,,,,,
,7.52, 0.00, -0.21, -0.16, 0.31,,,,,,,,,,
,7.91, 0.05, -0.14, -0.26, 0.28,,,,,,,,,,
,8.31, 0.07, -0.09, -0.28, 0.24,,,,,,,,,,
,8.71, 0.09, -0.05, -0.26, 0.21,,,,,,,,,,
,9.11, 0.09, -0.05, -0.26, 0.19,,,,,,,,,,
,9.51, 0.07, -0.02, -0.26, 0.19,,,,,,,,,,
  • Aerofan pinned this topic
    • EEXCALADE
