zorg
Buna seara. Imi cer scuze pentru dublu post in primul rand, va rog putin  ajutor (sau mai mult daca e cazul).
Problema principala e legata de nefunctionarea electroventilatoarelor (in stationare si cu clima pornita lichidul de racier trece de 110 grade Celsius), iar referitor la servomotoare din ce am realizat eu pana acum desi am erori atat pe v71 cat si pe v113 pe masina e instalat un singur motor care actioneaza clapetele de recirculare aer (v425 cred). Multumesc pentru rabdare in cazul celor care au citit si va rog ajutor.
Tuesday,26,June,2018,20:40:48:31824
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WVWZZZ3CZ9E023094 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ9E023094 Mileage: 239040km-148532miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
  Part No SW: 03L 906 022 CL HW: 03L 907 309
  Component: R4 2,0L EDC G000AG 3107
  Revision: 13H01--- Serial number: VWZCZ000000000
  Coding: 0000078
  Shop #: WSC 78131 146 06697
  VCID: 71BF29E85DAEDF8F8E9-8024
3 Faults Found:
006480 - Radiator Fan (V7)
  P1950 - 000 - Movement Restricted / Jammed - Intermittent
  Freeze Frame:
  Fault Status: 00100000
  Fault Priority: 2
  Fault Frequency: 1
  Reset counter: 255
  Mileage: 238995 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 02:51:13
  Freeze Frame:
  RPM: 1288 /min
  Speed: 66.0 km/h
  Temperature: 38.7°C
  Temperature: 87.3°C
  Temperature: 22.5°C
  Lambda: 15.8 %
  Lambda: 0.0 %
000135 - Fuel Rail/System Pressure
  P0087 - 000 - Too Low - Intermittent
  Freeze Frame:
  Fault Priority: 2
  Fault Frequency: 1
  Reset counter: 255
  Mileage: 239007 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 03:49:36
  Freeze Frame:
  RPM: 1104 /min
  Speed: 60.0 km/h
  Mass Air / Rev.: 330.0 mg/str
  (no units): 2.89
  Inj. Quantity: 9.6 mg/str
  Temperature: 40.5°C
  Temperature: 45.0°C
000136 - Fuel Rail/System Pressure
  P0088 - 000 - Too High
  Freeze Frame:
  Fault Status: 01100000
  Fault Priority: 2
  Fault Frequency: 1
  Reset counter: 255
  Mileage: 239039 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 04:26:56
  Freeze Frame:
  RPM: 1403 /min
  Speed: 43.0 km/h
  Inj. Quantity: 13.2 mg/str
  Temperature: 42.3°C
  Pressure: 904.0 bar
  (no units): 5.0
  Bin. Bits: 0111000
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
  Part No SW: 02E 300 051 HW: 02E 927 770 AJ
  Component: GSG DSG AG6 431 1818
  Revision: 04843012 Serial number: 00000806231176
  Coding: 0000020
  Shop #: WSC 05311 000 00000
  VCID: 50F98C6CF6E4F687A17-8004
No fault code found.
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
  Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
  Component: J104 C4 440 V2 0011
  Revision: --025--- Serial number: 00000785865897
  Coding: 0000277
  VCID: 2B03FB80BF02F55FF45-807E
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
  Part No SW: 3C0 907 044 AJ HW: 3C0 907 044 AJ
  Component: ClimatronicPQ46 050 0505
  Revision: 00050005 Serial number: 00000000000000
  Shop #: WSC 00000 000 00000
  VCID: 698F4188757E274FC69-803C
3 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
  000 - -
  Freeze Frame:
  Fault Status: 01110000
  Fault Priority: 3
  Fault Frequency: 5
  Reset counter: 129
  Mileage: 238993 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 02:40:22
00716 - Air recirculation Flap Positioning Motor (V113)
  000 - -
  Freeze Frame:
  Fault Priority: 3
  Fault Frequency: 5
  Reset counter: 129
  Mileage: 238993 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 02:40:22
  000 - -
  Freeze Frame:
  Fault Priority: 3
  Fault Frequency: 5
  Reset counter: 129
  Mileage: 238993 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 02:40:22
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
  Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
  Component: Bordnetz-SG H54 2602
  Revision: 00H54000 Serial number: 00000008634187
  Coding: A9880F0700041A00470000000F00000000095D432800010C000000000000
  Shop #: WSC 05124 123 12345
  VCID: 3333E3E06732AD9FBC5-8066
  Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
  Component: Wischer 270508 003 0205
  Coding: 00046997
  Shop #: WSC 05124
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
  Part No SW: 3C8 919 475 A HW: 3C8 919 475
  Component: PARKHILFE 8K H07 0009
  Revision: -------- Serial number: 08791010931616
  Coding: 100103
  Shop #: WSC 78131 146 86971
  VCID: 323DE6E49428A497B73-8066
Address 15: Airbags Labels: 5N0-959-655.lbl
  Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
  Component: J234__005 VW10 HI 1815
  Revision: 19013000 Serial number: 0039DPD5BPM/
  Coding: 0012341
  VCID: 3B23CBC04F6265DF645-806E
  Subsystem 1 - Serial number: 6333FTS637191548
  Subsystem 2 - Serial number: 6343FTS625801708
  Subsystem 3 - Serial number: 6353ETS6VE13UVNH
  Subsystem 4 - Serial number: 6363ETS6HMV2UVNH
  Subsystem 5 - Serial number: 00000000000000000
  Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
  Part No SW: 3C0 953 549 AC HW: 3C0 953 549 AC
  Component: J0527 0020
  Revision: 00026000 Serial number: 3C9953507AR
  Coding: 0001112
  VCID: 6D87359841963B6FAA1-8038
  Subsystem 1 - Part No: XXXXXXXXXXX
  Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
  Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
  Component: KOMBIINSTRUMENT VD1 2416
  Revision: V0002000 Serial number: 00000000000000
  Coding: 0007105
  Shop #: WSC 11111 111 11111
  VCID: 26150AB4A4E0C8372BB-8072
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
  Part No SW: 3C0 907 530 H HW: 3C0 907 951
  Component: J533__Gateway H13 0142
  Revision: H13 Serial number: 2600P086210428
  Coding: FDA07F060002022002
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
  Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
  Component: IMMO 042 0383
  Revision: 00042000 Serial number: VWZCZ000000000
  Shop #: WSC 131071 1023 2097151
  VCID: 392FD1C8455E57CF769-806C
  Subsystem 1 - Part No: 3C0 905 861 G
  Component: ELV 027 0380
  3C0905861G ELV 027 0380
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
  Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
  Component: J386 TUER-SG FT 1517
  Revision: 71009005 Serial number: 00000001688625
  Coding: 0004279
Address 44: Steering Assist Labels: 5N1-909-144.clb
  Part No SW: 5N1 909 144 G HW: 5N1 909 148 F
  Component: J500__APA-BS KL.082 0401
  Revision: 1AH02234 Serial number: 00081350121302
  Coding: 0000258
  VCID: 3635DAF47440B8B79BB-8062
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
  Component: KSG PQ46 ELV 042 0472
  Coding: 0091020051030E763004941570084F0B607801
  Subsystem 1 - Component: Sounder n.mounted
  Subsystem 2 - Component: NGS n.mounted
  Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
  Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
  Component: J387 TUER-SG BT 1517
  Revision: 71009005 Serial number: 00000813388626
  Coding: 0004278
  VCID: 72BD26E458A8E497773-8026
Address 53: Parking Brake Labels: 5N0-907-801.clb
  Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
  Component: J540 EPB3 VW-10498 0003
  Revision: 009 Serial number: 00000000068833
  Coding: 0000057
  VCID: 2809048CAEF4DE47197-807C
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
  Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
  Component: Radio RCD310 012 0029
  Revision: 00000000 Serial number: VWZ1Z2H5340469
  Coding: 0500040004
  Shop #: WSC 05314 000 00000
  VCID: 65974DB89566032FE21-8030
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
  Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
  Component: J388 TUER-SG HL 0307
  Revision: 41004101 Serial number: 00000000504035
  Coding: 0000144
  VCID: 70B92CEC56A4D687817-8024
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
  Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
  Component: J389 TUER-SG HR 0307
  Revision: 41004101 Serial number: 00000000495013
  Coding: 0000144
End----------(Elapsed Time: 01:31, VBatt start/end: 12.7V/12.6V)-----------
www.Ross-Tech.com
  Coding: 0000078
3 Faults Found:
  Freeze Frame:
  Fault Priority: 2
  Fault Frequency: 1
  Reset counter: 255
  Mileage: 238995 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 02:51:13
  Freeze Frame:
  RPM: 1288 /min
  Speed: 66.0 km/h
  Temperature: 38.7°C
  Temperature: 87.3°C
  Temperature: 22.5°C
  Lambda: 15.8 %
  Lambda: 0.0 %
  Freeze Frame:
  Fault Priority: 2
  Fault Frequency: 1
  Reset counter: 255
  Mileage: 239007 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 03:49:36
  Freeze Frame:
  RPM: 1104 /min
  Speed: 60.0 km/h
  (no units): 2.89
  Temperature: 40.5°C
  Temperature: 45.0°C
  Freeze Frame:
  Fault Priority: 2
  Fault Frequency: 1
  Reset counter: 255
  Mileage: 239039 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 04:26:56
  Freeze Frame:
  RPM: 1403 /min
  Speed: 43.0 km/h
  Temperature: 42.3°C
  Pressure: 904.0 bar
  (no units): 5.0
  Bin. Bits: 0111000
  Coding: 0000020
  Coding: 0000277
3 Faults Found:
  000 - -
  Freeze Frame:
  Fault Priority: 3
  Fault Frequency: 5
  Reset counter: 129
  Mileage: 238993 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 02:40:22
  000 - -
  Freeze Frame:
  Fault Priority: 3
  Fault Frequency: 5
  Reset counter: 129
  Mileage: 238993 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 02:40:22
  000 - -
  Freeze Frame:
  Fault Priority: 3
  Fault Frequency: 5
  Reset counter: 129
  Mileage: 238993 km
  Time Indication: 0
  Date: 2018.06.26
  Time: 02:40:22
  Coding: 00046997
  Shop #: WSC 05124
  Coding: 100103
  Coding: 0012341
  Coding: 0001112
  Coding: 0007105
  Coding: 0004279
  Coding: 0000258
  Coding: 0004278
  Coding: 0000057
  Coding: 0500040004
  Coding: 0000144
  Coding: 0000144
Pana la clima....inlocuieste urgent Radiator Fan (V7) si verifica daca este span in pompa de inalte
Se inlocuieste doar V7 sau trebuie inlocuite ambele ventilatoare?
Referitor la pompa de inalte trebuie sa recunosc ca ma depaseste problema. Erorile legate de alimentarea cu carburant le-am sters si nu au mai revenit la o noua scanare. Poti sa detaliezi putin procedura de verificare a spanului?
Se inlocuieste doar v7.
Spanul se verifica la valva metering de pe pompa si in filtru de combusibil
In urma sfaturilor primite de la colegul Eexcalade am inlocuit azi ventilatorul V7, rezultatul fiind functionarea corecta a ventilatoarelor (cu clima pornita merg ambele la aceeasi turatie, iar in output test functioneaza de asemenea ambele corect).
Referitor la verificarile privind pompa si filtrul de combustibil am facut cateva poze si o verificare a functionarii sistemului in vcds (am atasat un pdf). Rog una sau mai multe pareri avizate.
Acelasi subiect
Masuratori
New_TextMaker_document.pdf
Modificat de juice_kk
On 3/9/2018 at 9:11 AM, EEXCALADE said:
Se inlocuieste egr-ul si se curata clapeta.
Problema trebuie remediata urgent altfel se colmateaza dpf-ul
Despre ce clapeta este vorba? Mie mi-au schimbat supapa cu una noua cod DQ si tot am eroare P0403 N18. Multumesc!
Modificat de Tunelos
@juice_kk Scoate mizeria cea neagra din pompa , parca sclipeste ceva metalic pe filtru.
@Tunelos Posteaza eroarea
Am curatat mizeria din pompa. Am facut amorsarea cu vcds, masina a pornit relativ repede.
Referitor la filtru sunt particule foarte mici de pilitura care sclipesc la lumina. In afara de scos toata motorina din carcasa filtrului, inlocuit filtru si curatat carcasa filtrului ce pasi am de facut?
Ai citit cumva si valorile din pdf-ul atasat? Cum arata?
P0403 N18
1.6 tdi cr ,p0403 se rezolva cu inlocuire egr nou ,original.
Asta spuneam. E inlocuit cu original cod DQ de la augsburg
vlahdacoroman
Verifica sigurante si cablaj....
Multumesc mult! Mi-au spus ca au verificat cablajele, iar legat de sigurante mi-au spus ca ar fi dat eroare mult mai devreme si nu dupa ce ies in trafic. :-(. M-au programat pentru o reverificare mecanica si curatare DPF si debitmetru de aer. Si-au pus si intrebarea daca nu trebuie actualizat softul in cazul in care schimb supapa de pe cod CF, cum era initial, pe cea noua cod DQ
vlahdacoroman
Mufa de la ecu a fost verificata?pini care nu fac contact si/sau oxidati
Cum au verificat cablajul?au desfacut mufele de la ecu si au masurat rezistivitatea firelor?
Sincer nu ma pricep. Au spus ca au avut ceva probleme la conexiunea din imagine, dar au rezolvat-o!
Trebuie schimbata pompa si curatat tot sistemul de alimentare combustibil ? Scuze pentru insistenta Catalin.
Valorile injectoarelor sunt ok?
Injectoarele sunt ok (partea electrica).Scoate doar mizeria care se vede in imagine si verifica in filtru de combustibil
Mi-a aparut si mie pe 17 - Instrumente eroarea urmatoare:
VCDS
16776996 - Bus de date;lipsã mesaj
          U1121 00 [009] - -
          Confirmat - Testat de la stergere de memorie
             împrejurari cod:
                    Stare defect: 00000001
                    Prioritate defect: 6
                    Frecventa defect: 1
                    Resetare contor: 170
                    rulaj: 141115 km
                    Data: 2018.06.29
                    timp: 15:59:21
sau OBDeleven
U112100 - Databus missing message static
Eroarea nu poate fi stearsa. De la ce sa fie?
Modificat de ~Aurelian~
S-a facut recent vreun retrofit? Adaugat vreun modul suplimentar,inlocuit..etc?
Erori pe alte adrese ai?
Erori mai am pe 69 - Trailer - modul defect. Eroarea asta o am de cand am luat masina. Nu am schimbat modulul deoarece nu folosesc remorca. Pana acuma pe 17 nu aveam eroarea asta. Module nu au fost schimbate. In ultima perioada m-am mai jucat sa activez unele functii cu vcds sau obdeleven.
Incearca sa scoti conectorii din modulul tractare si dezactiveaza-l din 19 can gateway/instalation list,apoi sterge erorile.
Daca ai senzori parcare trebuie dezactivata tractarea si acolo,si in centrala electrica.
Modificat de spido
P087 si P088 la pachet iar. In bord am doar martorul spirala aprins(clipește). Am verificat, in pompa de înalte nu am span. Erorile au revenit dupa 10 zile. Ați mai văzut cazuri similare( ambele erori la pachet)?
Daca imi puteți da niște sfaturi despre pașii care ar trebui urmați pentru a depista problema va mulțumesc.
O seara faina
vlahdacoroman
Posteaza scanul...
Cauze pot fi pompa inalta,senzor s regulator rampa sau injectoarele.
Trebuie vazuta presiunea din rampa,fa cateva loguri cu presiunea din rampa.
Modificat de vlahdacoroman
Au trecut 4 zile de la patanie si erorile nu au mai revenit. O sa fac loguri cu presiunea in rampa, daca asta e primul pas.
Ma gandeam sa schimb si filtrul de motorina, in prezent am montat Mahle.
Logica ma duce la gatuire a instalatiei (pressure to low urmata de presure to high), sa ma corectati daca gresesc.
vlahdacoroman
Ai vrea tu gatuire....:)))))
Gatuire la ce?conducte de metal?sau pvc?!
  • Aerofan pinned this topic
    • mario75
