zorg
Multumesc pentru raspuns , ai vreo idee de unde pot achizitiona mai ieftin un EGR? Stima
Ieftin...nu prea. Doar sa gasesti unul SH bun...
Salut.
Am urmatoarea problema: la o perioada de timp, daca dau faza lunga si dupa scurta sau daca dau flash-uri imi apare martorul de bec ars.
Farurile merg normal, totul functioneaza, reglajul etc.
Cand descui masina si se aprind pozitiile palpaie putin, daca le aprind din masina merg normal.
In urma scanarii:
Tuesday,28,July,2015,20:37:59:55062
VCDS Version: Release 11.11.4
Data version: 20120807
                Address 09: Cent. Elect.       Labels: 3C0-937-049-23-H.lbl
Control Module Part Number: 3C0 937 049 AE    HW: 3C0 937 049 AE
  Component and/or Version: Bordnetz-SG     H52 2002
           Software Coding: 83800F0700041A00470A00000F00000000095D435C0001
            Work Shop Code: WSC 00028 028 00001
           Additional Info: 3C1955419A  Wischer 210407 003  0205
                      VCID: 6CDC73DA4F5CE178EDD
3 Faults Found
02498 - Left Low Beam Reflector Motor (V294)
            012 - Electrical Fault in Circuit
             Freeze Frame
                    Fault Status: 01111100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 252
                    Mileage: 188273 km
                    Time Indication: 0
                    Date: 2015.07.04
                    Time: 08:56:00
             Freeze Frame
                        ON
                    Voltage: 14.15 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
02499 - Right Low Beam Reflector Motor (V295)
             Freeze Frame
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 252
                    Mileage: 188273 km
                    Time Indication: 0
                    Date: 2015.07.04
                    Time: 08:56:00
             Freeze Frame
                        ON
                    Voltage: 14.15 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
01800 - Light Switch (E1)
            008 - Implausible Signal - Intermittent
             Freeze Frame
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 33
                    Mileage: 189669 km
                    Time Indication: 0
                    Date: 2015.07.26
                    Time: 16:16:00
             Freeze Frame
                        OFF
                    Voltage: 12.45 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Multumesc anticipat pentru ajutor.
In principiu pare sa fie blocul de lumini, gaseste un coleg cu B6 si fa o proba cu al lui pe masina ta operatiunea e foarte simpla mai mult de 5-10 min nu are cum sa dureze
svg_gabriel10
Blocul de lumini sau maneta de semnalizare...contact imperfect
sunt probleme la faruri... sau codari incorecte....
ce sistem ai? halogen sau xenon de fabrica?
nu are treaba cu maneta.
blocul de lumini - trebuie vazut daca acolo are o problema sau a fost dat jos de pe masina..... ori avem o problema la centrala electrica
Farurile sunt halogen, aseara am sters erorile si m-am uitat prin codarile centralei - se pare ca era codata ca avand xenon masina, am debifat casuta si astept sa vad daca mai apare acea erorare.
Blocul de lumini - a fost dat jos si agresat de fostul propietar (care nu a stiut sa il scoata) - e crapat capacul cu martori si cred ca e posibil sa fie busit ceva in el.
Maneta semnalizare face un zgomot foarte mare cand pun semnalizarea si cand sare singura - cred ca si pe acolo s-a umblat...nu e normal sa faca acel click asa puternic.
Multumesc pentru raspunsuri.
Daca aveai halogen si era codata cu xenon, de aici aveai cele 2 erori cu reflectoarele.
Eroarea la blocul de lumini apare cand e dat jos de pe masina si se pune contactul.
Nu e normal sa faca zgomot dar nu cauzeaza erorile de mai sus.
Multumesc pt detalii.
Sper ca acum, ca am codat cu halogen, sa nu mai apara acea eroare cu reflectoarele.
Blocul de lumini o sa il schimb la un moment dat dar deocamdata isi face treaba.
Ramane problema palpaitului pozitiilor cand descui masina, sa fie tot de la bloc? nu am nici o eroare legat de asa ceva.
Maneta de la semnalizare se da jos greu? se poate repara cumva sa numai faca asa urat sau cel mai simplu schimbata? (ce coduri trebuie sa caut sa o schimb au la ce sa fiu atent cand cumpar una noua?)
Cand descui masina palpaie si semnalele?
Daca nu, s-ar putea sa fie setat din VCDS sa se aprinda farurile in loc de semnale la incuiat/descuiat.
Salut.am pun passat b6 2.0 Tdi CR din 2009,cod motor CBAB.am becul de "engine" in bord.am facut o scanare cu vcds-ul si mi-a aparut :
18447/P2015/008213 - Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal
Din ce am citit pe forum ar fi vorba de motorasul v157 de la galeria de admisie.am verificat prima data daca am tensiune pe mufa de la motoras dar am numai pe 2 pini.Poate sa imi explice cineva pe unde ar trebui sa verific cablul acesta ? Pe unde ar trece? Si daca cineva a mai intampinat problrma asta?
Incep sa apara destul de des motoare cu problema asta. :D
Salut. Da palpaie semnalele. pozitiile se aprind ca e activa comminf si follow home...doar ca eu las blocul de lumini pe off. se aprind pozitiile si parca scad in itensitate de cateva ori. asa fac si cele din spate. au o flicareala ciudata...
Poate gresesc, insa follow me home si celalalt nu functioneaza indiferent de pozitia switch-ului de lumini?
svg_gabriel10
Follow me home si leaving home functioneaza si pe pozitia ON si pe Auto a blocului de lumini, dar se aprinde faza scurta, nu pozitia.
...se aprind pozitiile si parca scad in itensitate de cateva ori. asa fac si cele din spate. au o flicareala ciudata...
Ai alarma pe CAN?
 pozitiile care clipesc.. ai cumva LED-uri? daca nu, este defecta centrala electrica.
Modificat de andrei_221
Ce-i drept la poziții pe led nu m-am gândit, deși eu când am luat masina fix din-alea avea și la o saptamana au început sa facă discoteca în faruri.
Pt referință, ledurile ieftine ce le puteți găsi în comerț nu sunt ok fără o siguranță pe circuitul de 12v și se ard nenorocit de repede, "stroboscop" mode fiind primul semn.
Stefan Eusebiu
defapt este coming home & leaving home, atat timp cat este activata, functioneaza indiferent de pozitia blocului de lumini, iar faza scurta nu poate fi aprinsa fara pozitii, eu cel putin nu am vazut passat cu lupele aprinse si fara pozitii
Eu nu am functia auto la faruri. Din ce am citit am inteles ca daca se lasa farurile pe faza scurta, cu aceste functii activate, se vor aprinde pozitiile si faza scurta. daca se lasa farurile stinse se vor aprinde doar pozitiile.
Nu am verificat daca am led-uri...dar nu cred deoarece nu este o lumina prea alba...ciudat este ca fac si cele din spate nu doar fata.
Centrala cum as putea s ao verific cu vcds sa vad daca are ceva probleme? Si cam cat ar costa una daca este defecta?
Nu stiu sa am alrma pe CAN....cum pot verifica?
Multumesc pentru ajutor.
Am vazut clipurile acestea dar cineva zicea pe forum ca sa se verifice si daca ai tensiune pe mufa motorasului respectiv care misca clapetele swirl,inainte de a da jos motorasul si de a ii face limitatorul acela.la mine nu am tensiune pe acea mufa ,decat pe 2 pini din 5 .
Alarma ai? De care?
Daca este aftermarket nu o poti verifica cu vcds-ul...
  • Aerofan pinned this topic
