zorg
Dupa erorile de acolo n-ar trebui sa porneasca deloc.
Verifică ce scrie pe aici
http://wiki.ross-tech.com/wiki/index.php/01117
http://wiki.ross-tech.com/wiki/index.php/65535
http://wiki.ross-tech.com/wiki/index.php/16485/P0101/000257
În primul rând verifică şi curăţă cu spray de contacte mufa de la ECU.
Si la mine tot pe injectorul 1 valoarea e mai mare. Da nu stiu daca valorile sunt in limite normale?
094   Engine speed 2434 /min
  147   Injection amount deviation cylinder 1 0.66 mg/stroke
  148   Injection amount deviation cylinder 2 -0.17 mg/stroke
  149   Injection amount deviation cylinder 3 -0.30 mg/stroke
  150   Injection amount deviation cylinder 4 -0.19 mg/stroke
094   Engine speed 777 /min
  147   Injection amount deviation cylinder 1 1.04 mg/stroke
  148   Injection amount deviation cylinder 2 -0.31 mg/stroke
  149   Injection amount deviation cylinder 3 -0.48 mg/stroke
  150   Injection amount deviation cylinder 4 -0.24 mg/stroke
Alta problema ar fi ca de cateva ori dimineata a pornit greu invartind cam 3 secunde
Ce am gasit ca erori
00883 - Ignition Switch (D) Terminal S
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 4
                    Fault Frequency: 175
                    Reset counter: 183
                    Mileage: 160864 km
                    Time Indication: 0
                    Date: 2049.14.08
                    Time: 18:57:06
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.95 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
5 Faults Found:
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
00457 - Control Module for Network (J519)
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 200
                    Mileage: 170481 km
                    Time Indication: 0
                    Date: 2051.14.25
                    Time: 08:55:02
             Freeze Frame:
                    Voltage: 9.50 V
                    Count: 141
                    Speed: 0.0 km/h
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Ce ar putea fi ?  Merci
Modificat de radurdu
defecta partea electrica de la contact.
in rest, injectorul e inca in regula.
Compensarea pe injectorul 1 este ceva mai mare fata de celelalte trei.
Semnifica ceva, o posibila viitoare inlocuire de injector?
Care sunt limitele acceptate de compensare la CR-uri?
Motor CAYC, 1.6CR TDI 105CP, 27.000Km.
Intreb de valorile limita ale injectoarelor pentru ca in stationare, daca cresc turatia motorului de la 768rot/min la 1.100rot/min, motorul vibreaza scurt, exact cand iese din turatia de relanti si nu stiu in ce "parte" sa ma uit pentru problema.
Modificat de Dolfin
Ma puteti ajuta cu interpretarea erorii de pe CAN din logul de mai jos?
PS: Am facut upgrade la CAN.
Multumesc frumos.
Imi cer scuze ca revin, dar nici pana in momentul de fata nu am gasit vreo solutie.
Log-B163SEL-WVWZZZ3CZ6P005947-163680km-101706mi.txt
Modificat de illusions
atata timp cat vechiul CAN vedea unitatea radio neoriginala si noul CAN nu o vede, nu prea ai ce solutie sa gasesti decat fie un update CAN pentru gateway , fie un update pentru radio
Si o rugaciune sa se rezolve pe calea asta.
Modificat de andrei_221
la can-ul lui, nu are de ce sa-i faca nimic... chinezaria e de vina - la ea trebuie vazut ce se poate face.
Toata aceasta agitatie cu update-ul CAN-ului am facuto pt ca unitatea dedicata se stinge dupa 10 minute, cand opresc motorul (dar cu cheia inca in contact). La prima vedere pare o protectie binevenita, dar.. Geo (colegul nostru de forum) are aceesi unitate dedicata ca si mine si patea la fel, cu stinsul asta. Dupa ce si-a facut update la CAN, exact ca si mine.. de la A la Q, a scapat de stinsul asta, iar eu nu. E iritant, stiind ca avem aceeasi masina, acelasi an, acelasi nivel de echipare.. aceesi unitate dedicata, acelasi CAN.. Ma deranja eroarea pt ca credeam ca are de a face cu faptul ca unitatea dedicata inca se stinge.
la mine era mai rau ;) se inchidea se aprindea.......
dupa ce am schimbat can-ul(Q) 0 problem
nu stiu ce poti sa faci ;(
upgrade, nu update.... update e cand se schimba soft-ul la unitatea existenta. Upgrade - cand o inlocuiesti si treci la ceva mai nou.
verificati versiunile la SW de la can gateway precum si la unitatile AM.
Buna dimineata colegii,
Va rog sa ma ajutati cu o interpretare la erorile aparute astazi la masina. Masina porneste greu, invarte foarte mult electromotorul. Erorile sunt urmatoarele:
 Address 01: Engine       Labels: 038-906-019-AJM.lbl
Control Module Part Number: 038 906 019 FC
  Component and/or Version: 1,9l R4 EDC G001SG  1458
           Software Coding: 00002
            Work Shop Code: WSC 00020
           Additional Info: WVWZZZ7MZ2V032039     VWZ1Z0A1887023
                      VCID: 5DBA9B2ABB6B98F4
5 Faults Found
17964 - Charge Pressure Control: Negative Deviation
        P1556 - 35-10 -  -  - Intermittent
19463 - Camshaft Position Sensor (G40): No Signal
        P3007 - 35-00 -  -
19561 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
        P3105 - 35-10 -  -  - Intermittent
18027 - Glow Plug Relay (J52): Open or Short to Ground
        P1619 - 35-10 -  -  - Intermittent
16955 - Brake Switch (F): Implausible Signal
        P0571 - 35-00 -  -
Readiness: 0 0 X X X
 Va multumesc si drumuri bune sa aveti colegii.
Schimba/verifica senzorul de la axa cu came.
Salutare! La fosta mea masina passat AJM, pe care am vandut-o unui prieten, a aparut de cateva zile,urmatoarea problema: De cateva zile la pornire, dar nu mereu, se tureaza ptr cateva secunde pe la 3500 ture si tremura toata, dupa care revine la normal. Sa fie de la senzorul de temperatura G62?
3500 rpm ? cam mult.... oricum, asa este - sa faca o scanare, sa vedem daca are eroare, daca nu, sa comparati valorile de pe Engine cu cele de pe Instruments. Daca diferenta e mai mare de cateva grade, atunci mai mult ca sigur, are probleme
Da, mufa de la g62 nu facea contact cum trebuie. Sa rezolvat prin curatarea contactelor.
In timpul mersului s-a aprins doar indicatorul de Check Engine urmata de mesajul "mergeti in service" , dupa  care am oprit si ulterior masina refuza sa porneasca. Invarte dar nu porneste si nu mai este nici un indicator in bord.
Cine ma poate ajuta cu sfaturi legate de interpretarea urmatorului log:
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ16ZBM114909
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: A43B40F8092300FE251402E490220042210000
   Shop #: WSC 00066 000 00000
   VCID: 7BFFE935FAFE411
No fault code found.
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 DT    HW: 5K0 907 044 DT
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00066 000 00146
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_Climatronic_VW36.rod
   VCID: 80051ED91B18A29
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0046
   Revision: BC011001
   Coding: 08000A3A802DE3C040080080100081E403010088708081605CC000000040
   VCID: 3B7F2935BA7E811
   Subsystem 1 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Subsystem 2 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Coding: 000000
6 Faults Found:
00984 - Left Tail Light (M4)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 21
                    Reset counter: 222
                    Mileage: 60433 km
                    Time Indication: 0
                    Date: 2100.14.04
                    Time: 11:56:56
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.85 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
00985 - Right Tail Light (M2)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 60
                    Reset counter: 222
                    Mileage: 58334 km
                    Time Indication: 0
                    Date: 2099.14.06
                    Time: 19:06:04
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.75 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01495 - Bulb for High-Beams; Left (M30)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 188
                    Mileage: 62092 km
                    Time Indication: 0
                    Date: 2100.14.21
                    Time: 01:28:47
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
01499 - Bulb for High-Beams; Right (M32)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 148
                    Mileage: 60161 km
                    Time Indication: 0
                    Date: 2100.14.03
                    Time: 10:09:51
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.40 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01500 - Bulb for Fog-Lamps; Right (L23)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 253
                    Mileage: 56551 km
                    Time Indication: 0
                    Date: 2097.14.20
                    Time: 18:15:19
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02394 - Parking Light Left Front (M1)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 172
                    Reset counter: 233
                    Mileage: 56765 km
                    Time Indication: 0
                    Date: 2097.14.26
                    Time: 18:28:37
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    013 0613
   Serial number: 003G6RA1ENX4
   Coding: 00003242
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360_VW32.rod
   VCID: 326104116534409
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME0F1A555EZZZ5
   Crash sensor for side airbag; passenger side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME1572615DZZZY
   Crash sensor for side airbag; rear driver side:
   Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Fahr.H  H02 ----
   Serial number: 3516KSME7D4F4110ZZZY
   Crash sensor for side airbag; rear passenger side:
   Subsystem 4 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Beif.H  H02 ----
   Serial number: 3526KSME28673F10ZZZW
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110331201826
   Coding: 0082140000
   Shop #: WSC 00066 000 00196
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWSXS_VW36.rod
   VCID: 76E9F801C9DC1C9
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H07 0013
   Coding: 820000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5C6 920 870 A    HW: 5C6 920 870 A
   Component: KOMBI         H20 0420
   Serial number: 00000000000000
   Coding: 171F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_VW32.rod
   VCID: 2953E37D48E2031
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 12051101210051
   Coding: 351002
   VCID: 30650E196338729
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H20 0420
   Serial number:
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
   VCID: EAD15C710D64489
Address 42: Door Elect, Driver (J386)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 561 959 701     HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: 0002273559
   Coding: 0000B5
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: DBBF09B5D23E211
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R  Labels: 3C0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1409
   Serial number: 00000005672740
   Coding: 000090
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 346D020957204E9
Address 52: Door Elect, Pass. (J387)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 561 959 702     HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: 0002367161
   Coding: 0000B4
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
   ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
   VCID: DCBD0AA9D730269
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R  Labels: 3C0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1409
   Serial number: 00000005685269
   Coding: 000090
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  041 0166
   Revision: 00000001    Serial number: VWZ1Z3L7123413
   Coding: 0500040004
   VCID: E5CB2F4DEC7A671
End   ---------------------------------------------------------------------
Modificat de kathalin
Pai nu comunica cu ECU - vezi sigurantele din comportamentul motor si conectivitatea catre ECU.
Am verificat sigurantele vizual si sunt ok.
Multumesc pronet, altceva sa veriic?
Scoti grila de la stergatoare, ajungi la ECU si masori sa vezi daca ai continuitate. Daca ai, sa nu se fi dus ECU.
Se pare ca nu porneste pt ca pompa de înalta presiune nu creează presiune si încă se încearcă sa se determine cauza....
Revin cu vesti triste, se pare ca s-a găsit pilitura si trebuie înlocuit tot sistemul de alimentare, vreo 5000eur.
Ma puteți ajuta cu ceva service care sa verifice circuitul si sa imi înlocuiască doar componentele defecte +eventuala recondiționată a injectoareleor.
daca e pilitura in sistem, problema este destul de complicata.
Nu este nicio reteta sa inlocuiesti doar componentele defecte.  Sunt contaminate cam toate.....
DIn eroarea poastata de tine, reiese ca ECU nu e alimentat sau este busit cum ti-ai zis si colegii mai sus. Treaba cu pilitura e o "galusca" pe care o arunca mecanicii cand nu stiu sa-i dea de cap la o masina. Parerea mea este sa mai ceri parerea si altor mecanici.
Modificat de hremus
  • Aerofan pinned this topic
