zorg
pentru o eroare de asta am inlocuit acum ceva vreme, tot EGR.. 17 mil si demontezi 1 zi intreaga la el.... este tot ansamblul EGR, in spatele motorului
Modificat de andrei_221
Am o problema mai ciudata cu inchiderea centralizata, daca incerc sa inchid masina din telecomanda incepe sa se auda o alarma din partea dreapta a masinii si nu se inchide.
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0658135465
   Coding: 0013569
   Shop #: WSC 10175 599 88958
   VCID: 2F66A4D6BECA5A6626F
1 Fault Found
00474 - Control Module for Immobilizer
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 210072 km
                    Time Indication: 0
                    Date: 2013.12.05
                    Time: 22:00:02
Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
   Part No SW: 3C0 953 549 A    HW: 3C0 953 549 A
   Component: Lenksäulenmodul 005 0010
   Revision: 00005000    Serial number: 3C5953507C
   Coding: 0000013
   Shop #: WSC 00028 028 00001
   VCID: 2A50B5C285283F4EF11
1 Fault Found
01299 - Diagnostic Interface for Data Bus (J533)
Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
   Part No SW: 3C0 920 870 G    HW: 3C0 920 870 G
   Component: KOMBIINSTRUMENT VD1 4038
   Revision: V0033000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 00011 888 96745
   VCID: 27564CF6963A0226EEF
1 Fault Found
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 22
                    Mileage: 210072 km
                    Time Indication: 0
                    Date: 2013.12.05
                    Time: 22:01:05
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Component: Tuer-SG         024 2365
   Coding: 0000180
   VCID: 37769CB6469A92A67EF
1 Fault Found
01330 - Central Control Module for Central Convenience (J393)
Address 62: Door, Rear Left
Cannot be reached
de ce nu postezi intregul autoscan ?
salutare.am facut o scanare cu vag com si mi-au aparut urmatoarele erori: 2 Faults Found:
17672 - PD Unit Injector: Cylinder 2 (N241)
            P1264 - 006 - Regulation Range Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 8
                    Reset counter: 126
                    Mileage: 172151 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:41:58
             Freeze Frame:
                    RPM: 2176 /min
                    Text:    216    Nm
                    Speed: 0.0 km/h
                    Load: 77.6 %
                    Text:  5.000    uF
                    Text: 13.75    mJ
                    Text:      9    mJ
                    Raw, Form. N/A: 000 000 000
16618 - Boost Pressure Regulation
            P0234 - 006 - Limit Exceeded (Overboost Condition) - Intermittent
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 163
                    Mileage: 172918 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:31:33
             Freeze Frame:
                    RPM: 3168 /min
                    Text:    360    Nm
                    Speed: 122.0 km/h
                    Text: 59.4    %
                    Voltage: 14.35 V
                    Text:   2038    hPa
                    Text:   2377    hPa
Readiness: N/A
am un passat din 2006 motor de 2000 ,140 cp,BKP la care am schimbat toate injectoarele.
ma poti ajuta cu un cod de piesa ? ca nu o gasesc. multumesc
Salutare ! Am un prieten cu un Golf 5 care nu-i porneste. Cat am stat sa-i fac scanul au clipocit niste relee-n bord. Cand dau cheie clipesc martorii, i-am dat curent cu cabluri sanatoase facute de mine, parca invarte cam greu electromotorul si continua sa clipeasca luminile.
Poate va dati cu parerea la scanul de mai jos.
Tuesday,17,December,2013,16:38:42:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ1KZ7B079427   License Plate: 12GTY
Mileage: 155920km-96884mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 76 7D
VIN: WVWZZZ1KZ7B079427   Mileage: 155920km/96884miles
02-Auto Trans -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 043     HW: 02E 927 770 AE
   Component: GSG DSG         070 1106
   Revision: 04507000    Serial number: 00000609140015
   Coding: 0000020
   Shop #: WSC 00046 412 1900544
   VCID: D1A913CF481C6196CBD-8084
17252 - Transmission Fluid Pressure Adaptation at Limit
            P0868 - 001 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 2
                    Mileage: 145963 km
                    Time Indication: 0
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004462262
   Coding: 00890F2700041500001400001400000000097B075C
   Shop #: WSC 00046 412 1908736
   VCID: 2A5BE423850AF24EEA7-807F
   Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 101006 020  0501
   Coding: 00038805
   Shop #: WSC 00046
01497 - Bulb for Blinkers; Front Right (M7)
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 130
                    Mileage: 153541 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.40 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K0 920 863 B    HW: 1K0 920 863 B
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F7151422
   Coding: 0003103
   Shop #: WSC 65536 645 977737
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 161
                    Mileage: 155922 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:36:28
scanarea nu este completa.
verifica-i alimentarile, deoarece nu-ti vede nici ECU, deci nu are cum sa porneasca
Salut.
Revin cu loguriile in mers ,facute corect si 2 erori de scanare .
Problema totala e un consum care din cate am citit aici nu e foarte normal si al meu e destul de mare.
Cine ma poate ajuta raman dator cu o bere.
Atasate is loguriile in mers.
Mersi mult anticipat.
Ps : erori de scan. :
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 000 - Signal too High (Rich) - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 141027 km
Time Indication: 0
Date: 2120.14.27
Time: 18:26:15
Freeze Frame:
RPM: 2093 /min
Speed: 68.0 km/h
Lambda: 51.3 %
Mass Air / Rev.: 585.0 mg/str
Voltage: 0.825 V
(no units): 16.0
Voltage: 0.975 V
Readiness: 0 0 0 0 0
eroarea nr 2:
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
PartNoSW:3C0920871T HW:3C0920871T
Component: KOMBI         X04 0107
Coding: 160F00
Shop #: WSC 00028 028 00165
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
VCID: 356B3F0D945A571
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [137] - Internal electronic failure
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1Mileage: 119919 km
Date: 2047.14.09
Time: 20:11:45
Address 18: Aux. Heat
Modificat de makavellu
Am sters din logul postat modulele fara erori ca sa fie postul mai scurt.
Astazi i-am pus din nou cablurile si a pornit cu spray (cheie lunga). Dupa aceea a pornit normal.
daca vede si Engine si restul, plus ca nu ai erori pe engine - e posibil sa fie de  la alimentare - mai ales ca a pornit la spray.
oringuri injectoare, pompa tandem.....
Ok, Mersi, desi e cam ciudat la km si anii care-i are.
km...ceva relativ....
daca electromotorul nu invarte cum trebuie, nu porneste.....
La elecromotor ma gandesc si eu pt. ca ia curent mare cand dau cheie...
As avea o intrebare.sunt corecte aceste valori la webasto? Ca webasto se pare ca nu mai vrea sa functioneze pt ca apate permanent aceasta eroare pe care o sterg si apare din nou.
17946/P1538 - Fuel Shutoff Solenoid (N109)
17946/P1538 - Fuel Shutoff Solenoid (N109): Open or Short to Ground
Possible Causes
  • Fuel Shutoff Solenoid (N109) Faulty
  • Wiring to / from Fuel Shutoff Solenoid (N109) Faulty
  • Engine Control Module Faulty
Possible Solutions
  • Check Fuel Shutoff Solenoid (N109) using Output Tests
  • Check wiring to/from Fuel Shutoff Solenoid (N109)
din cate am citit ar fi doar din cauza cablului, mai trebuie verificat ceva?
masina porneste foarte bine, doar ce am schimbat bujiile incandescente, la oprire am trepidati decat
Modificat de allyn87
salutare cine ma ajuta cu explicatii aici...,masina merge ok nu am probleme dar am gasit erorile astea:VCDS Version: Beta 12.10.3
Data version: 20130228
Thursday,26,December,2013,15:27:23:55062
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBJY16Y533862150   Mileage: 142100km/88296miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 03E 906 033 A
   Component: 1.2l/4V SIMOS3  00HS4672
   Coding: 00061
   Shop #: WSC 13765
   VCID: 1E3869129A60C3EE9D9
   TMBJY16Y533862150     SKZ7Z0C2051534
5 Faults Found
17925 - Power Supply Relay for ECU (J271 or J363)
            P1517 - 35-10 - Electrical Malfunction - Intermittent
16804 - Catalyst System; Bank 1
            P0420 - 35-00 - Efficiency Below Threshold
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
            P1103 - 35-10 - Performance too Low - Intermittent
18043 - Powertrain Data Bus
            P1635 - 35-10 - Missing Message from A/C Controller - Intermittent
18058 - Powertrain Data Bus
            P1650 - 35-10 - Missing Message from Instrument Cluster - Intermittent
Readiness: 0000 0001
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Y0 820 045
   Component: Klimaanlage        X0830
   VCID: F2E0EDA2BE78B78E091
4 Faults Found
01596 - Motor for Outside/Recirculated Air Flap (V154)
            30-10 - Open or Short to Plus - Intermittent
            29-10 - Short to Ground - Intermittent
            09-00 - Adaptation Limit Surpassed
            55-00 - Adaptation Not Successful
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 C
   Component: 00 BN-SG.           1S33
   Coding: 25610
   Shop #: WSC 13765
   VCID: 3B7E808629B2B6C69A7
4 Faults Found
00975 - Heated Rear Window (Z1)
            28-10 - Short to Plus - Intermittent
01598 - Drive Battery Voltage
            07-10 - Signal too Low - Intermittent
00906 - Horn (H1)
01054 - Power Supply Relay; Terminal 30 (J317)
            28-00 - Short to Plus
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 601 A
   Component: 0T AIRBAG VW51      0008
   Coding: 12372
   Shop #: WSC 13765
2 Faults Found
00532 - Supply Voltage B+
01317 - Control Module in Instrument Cluster (J285)
Address 17: Instruments        Labels: 6Y0-920-xx0-17.lbl
   Part No: 6Y0 920 880 M
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 00102
   Shop #: WSC 13765
   VCID: 4796EC76657AE2260EF
No fault code found.
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 34 GATEWAY  CAN    1S33
   Coding: 00012
   Shop #: WSC 13765
   VCID: F0E4E7AAB074859EFF5
Address 44: Steering Assist        Labels: None
   Part No: 6Q0 423 156 R
   Component: LenkhilfeKYO        V913
   Coding: 10140
   Shop #: WSC 13765
   VCID: 3E7889923AA0A3EEBD9
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 H
   Component: 2Q Komfortgerát     0002
   Coding: 00067
   Shop #: WSC 13765
   VCID: 4084F76A4054D51ECF5
   Subsystem 1 - Part No: 6Q1959801A
   Component: 2Q Tõrsteuer.FS TFK 0004
   Subsystem 2 - Part No: 6Q1959802A
   Component: 2Q Tõrsteuer.BF TFK 0004
End   ---------------------------------------------------------------------
Dupa ce le stergi, ce mai apar la prima pornire ?
nimiC nu a mai aparut,eu sant plecat cam 3 luni din tara si in acest timp sotia mai porneste masina la relatiu..ca nu are carnet,oricum nu incarca corect bateria,si a fost bateria moarta de 2 ori ...a fost pornita cu cabluri 1 data si o data a fost data jos de fratele meu si pusa la redresor,ma gandesc ca toate aceste erori se obtin dupa cauza acestui fapt..voi merge cu ea azi kam 300km si maine o scanez iar si revin...sa vedem daca vor mai fi toate acele erori..multumesc colegu pt raspuns,LA MULTI ANI!!
Nu e neaparat o problema cu incarcarea daca moare bateria. Poate sa fie bateria slaba sau timpul in carea stat la ralanti sa fi fost prea scurt incat nu a reusit alternatorul sa incarce complet bateria.
Sent from my MID705 using Tapatalk
Salut. Ma poate lamuri si pe mine cineva de ce nu mai pot scana golful meu cu Vag-Com-ul desi in vara a mers? In vara mi-am sters eroarea la airbag dar acum nu mai recunoaste masina. Sigurantele le-am verificat iar casetofonul nu e original dar in vara cand i-am srers eroarea la airbag nu a fost nevoie sa deconectez casetofonul. Multumesc
Se alimentează interfaţa?
Mai demult am găsit pe net poza ataşată despre cum să verifici tensiunile de alimentare. Se poate verifica şi cu instrumentul de măsură, nu trebuie făcut neapărat montajul ăla.
post-40889-0-09078100-1388250258_thumb.g
revin cu noile erori...am facut ieri vreo 350 km...acum am erorile astea binenteles am bagat in valcea bezina de la nenorocitii de la petrom,de obicei bag de la rompetrol...si se aprinsase check engine....dar astea sant noile erori.....
Sunday,29,December,2013,08:40:27:55062
VIN: TMBJY16Y533862150   Mileage: 142600km/88607miles
   Coding: 00061
   Shop #: WSC 13765
2 Faults Found
16555 - Fuel Trim; Bank 1
            P0171 - 35-10 - System Too Lean - Intermittent
Readiness: 0000 0000
8 Faults Found
01271 - Positioning Motor for Temperature Flap (V68)
            41-10 - Blocked or No Voltage - Intermittent
   Coding: 25610
   Shop #: WSC 13765
1 Fault Found
   Coding: 12372
   Shop #: WSC 13765
   Coding: 00102
   Shop #: WSC 13765
   Coding: 00012
   Shop #: WSC 13765
   Coding: 10140
   Shop #: WSC 13765
   Coding: 00067
   Shop #: WSC 13765
ce parere ave-ti?multumesc
cum pot coda MDF2 DVD ? aceasta este eroarea
Address 56: Radio        Labels: 1K0-035-095.lbl
   Part No: 1K0 035 095 E
   Component:        Radio        0030
   Coding: 0040400
1 Fault Found
01044 - Control Module Incorrectly Coded
            000 - -
  • Aerofan pinned this topic
    • Parpalici
