zorg
F l o r i n
Nu-i panica, doar am corectat, ca info sa fie ok.
Buna ziua. Ma puteti ajuta cu o parere pentru codurile de eroare pe engine si airbag?
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Sunday,29,May,2022,15:15:02:65217
Chassis Type: 3R (3R - Seat Exeo (2010 >))
Scan: 01 02 03 08 09 10 15 16 17 25 37 36 45 46 4C 55 56 77
 Mileage: 236960km/147240miles
Address 01: Engine (J623-CAHA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 019 A    HW: 03L 906 022 GE
   Component: R4 2.0l TDI   H05 9978
   Revision: 11H05---    Serial number:
   Coding: 0304002C18072118
   Shop #: WSC 00971 002 1048576
   ASAM Dataset: EV_ECM20TDI03L906019A A01005
   ROD: EV_ECM20TDI03L906019A.rod
   VCID: 2953E5E44807E356E3D-807C
2 Faults Found:
4527 - Coolant Fan Control Circuit 1
          P0480 00 [032] - Electrical Malfunction
          Intermittent - Not Confirmed - Tested Since Memory Clear
8623 - Sensor for Ambient Air Temperature (G17)
          P0071 00 [032] - Implausible Signal
Readiness: 0 0 0 0 0
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat    O33
   Coding: 00001
   Shop #: WSC 06441
   VCID: 6DDBD1F4276F3F764F5-5072
No fault code found.
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 11021
   Shop #: WSC 06441
   VCID: 3D7B21B4378F6FF6BF5-4A3A
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 3R0 919 475     HW: 3R0 919 475
   Component: PARKHILFE 4K  H07 0004
   Revision: --------    Serial number: 19731029501414
   Coding: 000002
   Shop #: WSC 04941 000 00000
   VCID: F8F570A04B2D0ADE2C3-80AD
Address 15: Airbags        Labels: 3R0-959-655.clb
   Part No SW: 3R0 959 655     HW: 3R0 959 655
   Component: 02 Airbag 9.41  H15 0010
   Revision: 91H15001    Serial number: 003E9001AB6B
   Coding: 0012338
   Shop #: WSC 06441 785 00200
   VCID: FCFD6CB0BF1526FE48B-80A9
   Subsystem 1 - Serial number: 6332DRB40CA2898B0
   Subsystem 2 - Serial number: 6342DRB40CDC4BB6A
   Subsystem 3 - Serial number: 6352ARB405D0151EL
   Subsystem 4 - Serial number: 6362ARB405D00B7AT
   Subsystem 5 - Serial number: 63747RB405DAA3AD4
   Subsystem 6 - Serial number: 63847RB405DA784C0
3 Faults Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 21
                    Reset counter: 39
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 39
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 39
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
Address 16: Steering wheel        Labels: 8E0-953-549.lbl
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0801
   Coding: 02042
   Shop #: WSC 06441
   VCID: 41835D444B770B16DBD-4A3A
Address 17: Instruments        Labels: 3R0-920-xxx-17.clb
   Part No SW: 3R0 920 800 H    HW: 3R0 920 800 H
   Component: KOMBI+WFS 4     H04 0030
   Revision: 0030        Serial number: 00000000000000
   Coding: 0006018
   Shop #: WSC 80093 222 69422
   VCID: 30650880A0DD929E243-5000
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0006018
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 CL
   Component: Komfortgerát T01    4336
   Coding: 23408
   Shop #: WSC 06441
   VCID: 7DFBE1B4770FAFF6FF5-4A9C
   Subsystem 1 - Part No: 8E1959801G
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
   Subsystem 3 - Part No: 8E0959801E
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
Address 4C: Tire Pressure II        Labels: 3R0-907-274.clb
   Part No SW: 3R0 907 274     HW: 3R0 907 274
   Component: J793  RKA+      H02 0002
   Revision: 00000311    Serial number: 00003110003155
   Coding: 0000065
   VCID: F2E14288ED51608E127-80A7
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 D    HW: 5M0 907 357 D
   Component: AFS-Steuergeraet    0144
   Revision: 00H04000    Serial number:
   Coding: 2753613
   VCID: 356B39945CBFB7B6775-8060
   Subsystem 1 - Part No: 7L6 941 329 A
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000042
   Subsystem 2 - Part No: 7L6 941 329 A
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000042
2 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 40
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 11.79 V
                    Speed: 0.0 km/h
                        ABS 1
02234 - Right Headlight Power Output Stage (J668)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 40
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 11.79 V
                    Speed: 0.0 km/h
                        ABS 1
Address 56: Radio        Labels: 8J0-035-1xx-56.clb
   Part No SW: 3R0 035 186 B    HW: 3R0 035 186 B
   Component: R Concert2+     H02 0004
   Revision: 00H02000    Serial number: SEZ1Z3K1431331
   Coding: 0310311
   VCID: 2E5916F8BAE9846E36F-5000
1 Fault Found:
00875 - Treble Speaker Front Right (R22)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 39
                    Time Indication: 15
End   ---------------------------------------------------------------------
Pare ca masina a fost lovita in fata ,verifica cablaje ventilatoare,senz temp,senz airbag...
Pentru un tiguan 2012 2.0 TDI 140 CP 4 Motion si DSG as putea sa fac urmatoarele setari in VCDS?  (nu stiu daca este posibil dar am zis totusi sa intreb)
- activare o avertizare sonora atunci cand sunt in modul parking si am oprit motorul ca sa ma avertizeze ca nu am activat frana electronica;
Stie cineva la ce se refera eroarea asta? e permanenta o sterg dar reapare imediat:
Address 37: Navigation (J794)       Labels:| 1K0-035-27x-37.clb
   Part No SW: 3C0 035 279 H    HW: 3C0 035 279 H
   Component: RNS315-EU   H35 0263
   Serial number: VWZAZ2M3922840
   Coding: 0400041104000C0000009001
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 285F4EA253F31D0470-807C
   Data medium:
   Subsystem 1 - Part No: 3AA 919 866
   Component: EUR_W_0038  0038
1 Fault Found:
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [009] - General memory failure
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Mileage: 168537 km
                    Date: 2018.10.10
                    Time: 17:13:26
Multumesc anticipat!
Vlad
Lucian Vatamanu
Buna!
Am un tester VCDS si astazi la un "auto-scan" pentru un passat cc al unui coleg de munca mi-a aparut eroarea "Function is not supported by the gateway". A mai intalnit cineva eroarea? Stiti de la ce ar putea fi?
Interfata e clona ?
Lucian Vatamanu
da
Modificat de lupo_bv
eliminare quote postare anterioară
F l o r i n
Selecteaza manual masina vw...passat cc...si vezi daca merge
Lucian Vatamanu
Am încercat și așa. Tot nu functioneaza. Am încercat cu alt laptop la alte 2 mașini ale colegilor și nici așa. Încep sa cred ca e problema ce tine de electronica
16 hours ago, Lucian Vatamanu said:
da
Si atunci de ce discutam de ea aici ?
F l o r i n
S-a stricat chinezaria, din pacate.
Lucian Vatamanu
Imi voi achiziționa una originala in cazul asta, sa fiu sigur ca nu mai sunt probleme
On 12/4/2017 at 10:40 PM, at0m said:
Acceasi greșeală am făcut o și eu limitând doar cursa minima. Trebuie limitat în ambele sensuri. Respectiv 0.760V minim 4.256V maxim. Aceste valori se obțin cu limitatorul dieselgeek (mulțumiri lui EEXCALADE) . Eu am găsit o soluție mai ușoară și totodată gratis. Am limitat cursa in interiorul motorașului.
Vezi DIY (trebuie sa completez și valoarea maxima pentru a preveni și erorile P2004 / P2006)
Legat tot de aceasta problema. Am intampinat eroare p2015, pe care am stopat-o cu un anulator dieselgeek…acum, dupa aproape 1 an, primesc eroare p2004 si p2006. Ce ar fi de facut? Mentionez ca in vcds nu am modificat valori.
Eroare noua ...sau cel putin asa cred :vaidecapulmeu:
De ce am un voltaj diferit la injectorul nr. 4? Daca are cineva o explicatie il rog sa imi spuna si mie.
vlahdacoroman
Fiindca atat considera ECM ca trebuie sa fie pe injectorul ala care cu siguranta e un injector piezo!
Spune mai bine ce problema ai sau ce te framanta...nu este o "eroare".
Vcds fara cunostinte este egal cu zero!
Modificat de vlahdacoroman
Ma framanta faptul ca, cand e motorul cald si accelerez pana la 1200rpm, apoi iau piciorul, masina vibreaza (se misca toata) pana ajunge inapoi la 800rpm. Lucru asta l-am observat si cand am mers la munte, desi apa era sub 90C. Vorbim de masina scoasa din viteza (selectorul pus in N), in sarcina nu pot testa, dar nu am simtit sa vibreze. Singura chestie e cand e cald si scade turatia, vibreaza.. are oare legatura cu distributia ca nu este pusa “la punct” ? Am verificat si am niste valori cam mari, adica valorile nominale erau -1,5 — -2.5 grade iar eu eu + 2,4 pentru aprindere.
Ce am mai observat este ca atunci cand scade turatie si se apropie de 800rpm (cand fac testul) parca face cumva “pfu pfu pfu” - scuzati traducerea 😅
Modificat de Dan.MDLL
Va salut cu respect,am o problema cu frana de mana electrica la un tiguan 5n 2011,eroare este de cand am cumparat masina acum 1 an de zile,mai exact imi apare in bord de fiecare data cand pornesc masina acel "P" taiat cu galben,am dat o scanare cu vcds imi spune ca este ceva legat de tensiune,probleme cu frana de mana sau auto hold nu sunt doar ca imi apare de fiecare data aceasta eroare,ma gandesc ca este din cauza ca se pune automat frana de mana chiar daca eu nu cuplez butonul dupa ce opresc masina,si cand pun contactul sesizeaza tensiunea putin mica.Specific ca bateria este noua,sigurantele le-am verificat,m-am uitat si la mufa unde este modulul de parking brake,recent a "murit" motoras spate stanga,l-am inlocuit totul este oke.
Las mai jos un pdf atasat cu codul de eroare spus de vcds,mentionez ca este o copie vcds-ul meu nu un original poate afecteaza si asta cumva ? eroare o sterg dar reapare..
Va multumesc,o zi buna va doresc!
VCDS DTC Printout.pdf
Modificat de Denis227
Probleme cu alimentarea modulului frana parcare. Cablaj deteriorat,conector sau in cazuri extreme,modul defect.
Salutare! Am un Touran Cross 2008 2.0 TDI, 103Kw. Masina functioneaza foarte bine, am pus VCDS sa vad si eu daca am ceva erori si au aparut astea... Mi-ar fi de ajutor daca as primi o parere, va multumesc!
01-Motor -- Status: OK 0000
03-ABS frâne -- Status: OK 0000
04-Senzor unghi volan -- Status: OK 0000
08-Clima automata -- Status: OK 0000
09-Electr. centrala -- Status: OK 0000
10-Asist.direct./parc. -- Status: OK 0000
15-Airbaguri -- Status: OK 0000
16-Electronica volan -- Status: Malfunctie 0010
17-Instrumente bord -- Status: OK 0000
18-Încalzire aux. -- Status: OK 0000
19-Poarta CAN  -- Status: Malfunctie 0010
25-Blocare pornire -- Status: Malfunctie 0010
42-Electr. usa sofer -- Status: OK 0000
44-Asistenta directie -- Status: OK 0000
46-Confort -- Status: OK 0000
52-Electr. usa pasag -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Usa SS -- Status: OK 0000
69-Tractare -- Status: Neautorizat 0001
72-Usa DS -- Status: OK 0000
Adresa 16: Electronica volan        Etichete: ROJ\1K0-953-549-MY8.lbl
   Numar VAG SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 636 0070
   Codare: 0000042
   Atelier: WSC 01324 785 00200
   VCID: 74E769D717BB262BD7-8020
1 cod a gasit:
00883 - Contact pornire (D); terminal S
            012 - defect circuit electric - intermitent
Adresa 19: Poarta CAN         Etichete:. ROJ\1K0-907-530-V3.clb
   Numar VAG SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revizie:   H07 01    Numar serial: 240807F2000015
   Codare: E9A07F06000A028002
   VCID: 306FA5C7A3235A0B73-8064
1 cod a gasit:
01044 - Modul comandã codare incorectã
            000 - Elaborare coduri necunoscuta
             împrejurari cod:
                    Stare defect: 01100000
                    Prioritate defect: 1
                    Frecventa defect: 254
                    Resetare contor: 255
                    rulaj: 239375 km
                    Indicator de timp: 0
                    Data: 2000.00.00
                    timp: 14:58:09
Adresa 25: Blocare pornire        Etichete: ROJ\1K0-920-xxx-25.clb
   Numar VAG SW: 1T0 920 864 A    HW: 1T0 920 864 A
   Component: IMMO            VDD 1212
   Revizie: V0002000    Numar serial: VWX7Z0G73NL0IO
   Atelier: WSC 20785 142 79038
   VCID: 3365AACB523561130E-8066
1 cod a gasit:
00003 - Modul comandã
            014 - defect
             împrejurari cod:
                    Stare defect: 01101110
                    Prioritate defect: 2
                    Frecventa defect: 1
                    rulaj: 0 km
Adresa 69: Tractare (J345)       Etichete:. 1K0-907-383-V2.clb
   Numar VAG SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H09 0100
   Revizie: 3A001001    Numar serial: 00000164379545
   Codare: 0100000000000000
   Atelier: WSC 00000 000 00000
   VCID: 306FA5C763235A0B73-8064
Nu a gasit coduri.
Modificat de Freeps
Ptr 16-parte electrica contact de inlocuit, 25-posibil s-a umblat la km. Ptr eroarea pe 19 can, trebuie recodat cu 69,cui tractare.
Pe 19 can gateway,  bifeaza in Lista de instalari,  69 Tractare. Salveaza. O sa dispara eroarea de pe 19 can.
Parte electrica contact, sa montezi numai originala.
Va multumesc frumos pentru raspunsuri! Mai am un Passat CC 2010, 2.0TDI 103kW, 4motion care este cumparat de 2 saptamani si am cateva erori pe el.
Eroarea cu senzorul de parcare o stiu, ca nu functioneaza senzorul respectiv si urmeaza sa-l schimb.
La erorile de pe navigatie, ar trebuii sa o scot si sa vad daca sta bine cablul de la GPS?
Masina nu are probleme, tocmai ce a plecat tatal prietenei mele cu ea pana in Bulgaria si a spus ca merge ireprosabil de bine si nu consuma asa mult, dar as vrea sa rezolv problemele, sa fie totul "clean".
La faruri a fost o problema... Am iesit intr-o noapte la un drum de cativa km pentru ca si-a facut regenerare dpf-ul si mi-am luat numai flash-uri din sens opus. Am fost cu masina a doua zi la o statie itp sa reglez farurile (Xenon adaptiv) si mi-au spus ca farul din stanga batea foarte mult in partea stanga si ca n-au put sa-l regleze complet si ca era bifat "UK" in vcds si au debifat ei, da' n-au reusit sa-l faca sa bata drept. Ulterior, m-am uitat la inscriptiile de pe farul din stanga si este de Anglia...
01-Motor -- Status: Malfunctie 0010
09-Electr. centrala -- Status: Malfunctie 0010
10-Asist.direct./parc. -- Status: Malfunctie 0010
13-Distanta urmarire -- Status: Malfunctie 0010
37-Navigatie -- Status: Malfunctie 0010
46-Confort -- Status: Malfunctie 0010
55-Bataie far -- Status: Malfunctie 0010
56-Radio -- Status: Malfunctie 0010
Adresa 01: Motor (CBA)       Etichete: ROJ\03L-906-022-CBA.clb
   Numar VAG SW: 03L 906 022 QE    HW: 03L 907 309
   Component: R4 2.0l TDI A000SG  9980
   Revizie: 13H02---    Numar serial: VWZCZ000000000
   Codare: 0000172
   Atelier: WSC 83968 425 739526
   VCID: 78FF5DE70BD3424BFB-802C
1 cod a gasit:
008213 - Senzor poziþie clapetã galerie de admisie/control flux de aer
               P2015 - 000 - semnal neplauzibil - intermitent
             împrejurari cod:
                    Stare defect: 00100000
                    Frecventa defect: 5
                    rulaj: 183498 km
                    Data: 2016.11.29
                    timp: 08:05:59
             împrejurari cod:
                    RPM: 0 /min
                    viteza: 0.0 km/h
                    sarcina: 0.0 %
                    lambda: 11.8 %
                    lambda: 4.7 %
                    tensiune: 0.380 V
                    valori binare: 00000000
Gata de functie: 0 0 0 0 0
Adresa 09: Electr. centrala        Etichete:. ROJ\3C0-937-049-30-H.lbl
   Numar VAG SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revizie: 00H54000    Numar serial: 00000003273860
   Codare: E3E28F8B00041A0047978F0017000000000BFB4764400165170000000000
   Atelier: WSC 05124 000 00000
   Subsistem 1 - Numar VAG: 3C8 955 119   Etichete: ROJ\1KX-955-119.CLB
   Component: Wischer 150709 022  0602
   Codare: 00046997
   Atelier: WSC 05124
   Subsistem 2 - Numar VAG: 1K0 955 559 AF  Etichete: ROJ\1K0-955-559-AF.CLB
   Component: RLS     180809 046  0204
   Codare: 00208933
   Atelier: WSC 05124
1 cod a gasit:
02195 - Buton de reglare lumina bord ºi comutator lumini (E20)
            006 - scurt la plus - intermitent
             împrejurari cod:
                    Stare defect: 00100110
                    Prioritate defect: 5
                    Frecventa defect: 1
                    Resetare contor: 105
                    rulaj: 183538 km
             împrejurari cod:
                        Dec.
                    tensiune: 10.65 V
                        Dec.
                        Dec.
                        Dec.
                        Dec.
                        Dec.
Adresa 10: Asist.direct./parc. (J446)       Etichete:. ROJ\3C8-919-475.clb
   Numar VAG SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revizie: --------    Numar serial: 08740921504283
   Codare: 100001
   Atelier: WSC 05314 000 00000
   VCID: 326BAFCF6D2F681B05-8066
1 cod a gasit:
01547 - Senzor asistenþã parcare centru-dreapta spate (G205)
            014 - defect - intermitent
             împrejurari cod:
                    Stare defect: 00101110
                    Prioritate defect: 3
                    Frecventa defect: 2
                    Resetare contor: 125
                    rulaj: 184033 km
                    Data: 2016.11.29
                    timp: 14:11:46
             împrejurari cod:
                    temperatura: 28.0*C
Adresa 13: Distanta urmarire        Etichete: ROJ\3C0-907-567.clb
   Numar VAG SW: 3C0 907 567 M    HW: 3C0 907 567 M
   Component: AC201  RDW M    031 0243
   Revizie: 00031000    Numar serial: 00000000043528
   Codare: 0010100
   Atelier: WSC 05311 000 00000
   VCID: 356194D35C417F2320-8060
2  coduri de defecte:
00532 - Tensiune de alimentare
            002 - valoare limita inferioarã depãºitã - intermitent
             împrejurari cod:
                    Stare defect: 00100010
                    Frecventa defect: 3
                    rulaj: 180391 km
                    Data: 2016.11.29
                    timp: 17:19:10
             împrejurari cod:
                    contor: 91
00473 - Modul comandã frânã de mânã/parcare electricã (J540)
            004 - lipsã semnal/comunicaþie - intermitent
             împrejurari cod:
                    Stare defect: 00100100
                    Frecventa defect: 1
             împrejurari cod:
                    contor: 38
Adresa 37: Navigatie (J0506)       Etichete:. ROJ\1T0-035-680.clb
   Numar VAG SW: 1T0 035 680 B    HW: 1T0 035 680 B
   Component: RNS-MID       H11 1120
   Revizie: AB001001    Numar serial: VWZ6Z7J8229051
   Codare: 04010000010000A200
   VCID: 2D51BCB3741137E358-8078
1 cod a gasit:
00862 - Antena pentru navigaþie (GPS) (R50)/(R52)
            007 - scurt la masã - intermitent
             împrejurari cod:
                    Frecventa defect: 2
                    Resetare contor: 126
                    rulaj: 161903 km
                    Data: 2016.06.01
                    timp: 01:31:20
Adresa 46: Confort        Etichete:. ROJ\3C0-959-433-46.clb
   Numar VAG SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    KSG PQ46 ELV 043 0612
   Revizie: 00043000    Numar serial: VWZCZ000000000
   Codare: 00910A0001860E763604941570084FCE707C01
   VCID: 7AFB47EF35DF505B8D-802E
   Subsistem 1 - Numar VAG: 1K8 951 605
   Component: LIN BACKUP HORN H09 9002
   Subsistem 2 - Numar VAG: 3C0 951 171 C
   Component: Neigungssensor  004 0611
   Subsistem 3 - Numar VAG: 3C0 951 171 C
   Component: Innenraumueberw.004 0611
00323 - Senzor pentru înclinare vehicul (G384)
            008 - semnal neplauzibil - intermitent
             împrejurari cod:
                    Stare defect: 00101000
                    Prioritate defect: 4
                    Frecventa defect: 1
                    Resetare contor: 92
                    rulaj: 183416 km
                    Data: 2016.11.29
                    timp: 14:11:14
00457 - Modul comandã electronica centralã (J519)
            013 - citiþi vã rog memoria de defecte - intermitent
             împrejurari cod:
                    Stare defect: 00101101
                    Frecventa defect: 1
                    rulaj: 183538 km
                    Data: 2016.11.29
                    timp: 04:56:25
Adresa 55: Bataie far        Etichete: ROJ\5M0-907-357-V2.clb
   Numar VAG SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0142
   Revizie: 00H04000    Numar serial:
   Codare: 3523784
   Atelier: WSC 12345 111 45725
   VCID: 3467A9D7573B662B17-8060
   Subsistem 1 - Numar VAG: 1K0 941 329   Etichete: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0003
   Codare: 00000053
   Subsistem 2 - Numar VAG: 1K0 941 329   Etichete: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0003
   Codare: 00000053
1 cod a gasit:
02988 - Comutare regim trafic stânga/dreapta activã
             împrejurari cod:
                    Prioritate defect: 6
                    Frecventa defect: 1
                    Resetare contor: 83
                    rulaj: 183977 km
                    Data: 2016.11.29
                    timp: 11:11:05
             împrejurari cod:
                    tensiune: 11.79 V
                    viteza: 0.0 km/h
                        ABS 1
Adresa 56: Radio (J0506)       Etichete:. ROJ\1T0-035-680.clb
1 cod a gasit:
             împrejurari cod:
                    Frecventa defect: 2
                    rulaj: 161903 km
                    Data: 2016.06.01
                    timp: 01:31:20
Masina cand a fost cumparata nu functiona functia de Auto-hold si stiam 100% ca a fost dezactivata din VCDS, asa ca ieri cand am pus diagnoza am activat auto-hold si am primit aceasta eroare:
Adresa 53: Frâna de parcare       Etichete: ROJ\5N0-907-801.clb
    Numar piesa modul comanda: 3C8 907 801 C    HW: 3C8 907 801 C
    Component si/sau versiune: J540 EPB3  VW-13618 0005
                  Codare soft: 0000057
                Numar atelier: WSC 05311 000 00000
                      VCID: 2A5BB7AF85FF20DBBD-807E
1 cod a gasit:
02844 - Lampa pentru funcþiile de parcare automatã
            009 - întrerupere/scurt la masã - MIL aprins
             împrejurari cod:
                    Stare defect: 11111001
                    Frecventa defect: 1
                    Resetare contor: 86
                    rulaj: 184062 km
                    Data: 2016.11.29
                    timp: 19:06:17
             împrejurari cod:
                    tensiune: 11.70 V
                    contor: 83
                    viteza: 0.0 km/h
                    valoare Hex: 0x1261
                    valoare Hex: 0x0001
                    valoare Hex: 0x1010
Va multumesc frumos ca ma ajutati!
Modificat de Freeps
Incep cu sfarsitul:
53-buton auto hold defect(de fapt becul din el) sau cablaj deteriorat. Pe 55 dezactivare tourist mode.
46-senzor inclinatie auto defect,o componenta a alarmei oem. 10- un senzor parcare defect 13- sterge erorile,vezi daca revin 01-clapeta galerie admisie defecta. Aici se poate monta limitator galerie. E topic dedicat ptr asta.
La 13 tot apare, chiar daca sterg eroarea. Ma gandesc ca 13 e senzorul pentru Cruise Control cand masina urmareste masina din fata si tine distanta fata de ea. Tin sa mentionez ca functioneaza foarte bine la toate treptele setate.
Sper doar ca la eroarea de la 01 sa poata sa ajunga acasa cu masina din Bulgaria, sa nu se strice si altceva...
Modificat de Freeps
Da,e radarul din emblema. Verifica conector,cablaj.
    • sorin0235
