zorg
Bad post.
Modificat de spido
vlahdacoroman
de aceea am zis sa scoti pe rand senzorii din mufa si sa vezi cand trece in pasiv eroarea!
incepe cu senzorul MAP!!!
Modificat de vlahdacoroman
On 8/4/2020 at 12:52 PM, Johnny said:
O interpretare pentru erorile de mai jos va rog. Ca si simptoma majora ... cand are ea chef ramane fara baterie ... se descarca complet.
Tuesday,04,August,2020,11:36:46:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ7MZ2V010341   License Plate: COSMIN
Mileage: 269940km-167732mi   Repair Order:
Chassis Type: 7M (7M - VW Sharan (1996 > 2010))
Scan: 25 01 02 03 08 09 15 16 17 18 19 22 29 35 36 37 39 45 55 56
          76
VIN: WVWZZZ7MZ2V010341   Mileage: 269940km-167732miles
Address 25: Immobilizer        Labels: 7M3-953-257.lbl
   Part No: 7M3 953 257
   Component: IMMO                0008
   Coding: 00003
   Shop #: WSC 00000
   VCID: 76E353DF52C734FF8D-4B32
   WVWZZZ7MZ2V010341     VWZ1Z0A1574350
No fault code found.
Address 01: Engine        Labels: 038-906-019-AJM.lbl
   Part No: 038 906 019 FC
   Component: 1,9l R4 EDC G001SG  1455
   Coding: 00002
   Shop #: WSC 00020
   VCID: 5DB12C73D73187A7EC-4B18
1 Fault Found:
18080 - Coolant Fan Control 1
            P1672 - 35-00 - Open or Short to Ground
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 1J0-907-37x-ESP-F.lbl
   Part No: 7M3 907 379 B
   Component: ESP     20    CAN  V005
   Coding: 18952
   Shop #: WSC 02314
   VCID: 3C7781F72C6BAEAFBB-4B18
1 Fault Found:
01423 - Lateral Acceleration Sensor (G200)
            57-00 - Electric Circuit Failure
Address 08: Auto HVAC        Labels: 7M3-907-040.clb
   Part No: 7M3 907 040 B
   Component: CLIMATRONIC MPV GP  0003
   Coding: 00010
   Shop #: WSC 02314
   VCID: 2D51BCB3E71137273C-25A4
2 Faults Found:
00576 - Terminal 15
            07-10 - Signal too Low - Intermittent
00792 - A/C Pressure Switch (F129)
            35-00 - -
Address 09: Cent. Elect.        Labels: 7M3-962-258.lbl
   Part No: 7M3 962 258 M
   Component:    Multifunkt.Einh  0001
   Coding: 04097
   Shop #: WSC 02314
   VCID: 4487F917549BD66FC3-50E6
3 Faults Found:
01146 - Central Locking Motors; Front Passenger and Rear Doors Locked
            29-10 - Short to Ground - Intermittent
01148 - Activation of Safety/Deadbolt Locks in Doors
01149 - Deactivation of Safety/Deadbolt Locks in Doors
            28-10 - Short to Plus - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605
   Component: 0Q AIRBAG VW51 0G     01
   Coding: 12369
   Shop #: WSC 02314
   VCID: 61C91083EB49A347C8-513C
1 Fault Found:
00532 - Supply Voltage B+
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 B
   Component: Lenkradelektronik   0002
   Coding: 00008
   Shop #: WSC 02314
   VCID: 306FA5C7F0235ACF17-5248
Address 17: Instruments        Labels: 7Mx-920-xxx-17.lbl
   Part No: 7M3 920 840 K
   Component: KOMBIINSTRUMENT VDO V40
   Coding: 29111
   Shop #: WSC 11111
   VCID: 397998E323599B87A0-515A
Address 18: Aux. Heat        Labels: 7M3-815-071.clb
   Part No: 7M3 815 071
   Component: HEIZG. B/D5W       0001
   VCID: 6DD17CB32791F7277C-5196
5 Faults Found:
00668 - Supply Voltage Terminal 30
            07-00 - Signal too Low
01414 - Combustion-Air Blower (V6)
            36-00 - Open Circuit
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 02314
   VCID: 70EF65C730A31ACF57-513C
Address 76: Park Assist        Labels: 7M3-919-283.clb
   Part No: 7M3 919 283
   Component: Parkingsyst. SH RDW D02
   Coding: 00117
   Shop #: WSC 00020
   VCID: 77FD5EDB55CD4DF796-515A
1 Fault Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
            37-10 - Faulty - Intermittent
End-------------------------(Elapsed Time: 04:40)--------------------------
Ceva pareri si pentru errorile mele va rog ...
Modificat de Johnny
Postare Dubla ... Netul Prost ...
Sterge toate erorile vezi ce ramane ...
Revin... sterge tot ca ai erori de la bateria descarcata si dupa vezi ce erori reapar
Modificat de iahimmihai
A ramas pe Engine pe ABS pe HVAC, Central Electric si Park Assist.
Mai mult alea cu usile ma intereseaza. De acolo cred ca vine problema cu descarcatul bateriei. Se poate sa fie defecta centrala ? Si sa am probleme doar cu usile ? Geamurie si restul lumini etc. merg ok.
Nu..nu au treaba erorile. Se masoara consumul cu un ampermetru,se decupleaza pe rand cate o componenta pina se identifica ce anume produce consumul.
Este de preferat sa masor la baterie sa las aparatul si sa incep sa scot pe rand din sigurante pana scade consumul ? Sau exista o varianta mai buna ?
Si mai este si chestia ca nu tot timpul descarca bateria ... deci am sanse sa masor si consumul sa fie ok pe baterie ... in felul asta o sa fie mai greu de depistat. O sa ma uit totusi si la usi ... nu prea imi place acel Short to Plus cum suna.
Modificat de Johnny
nu, nu exista alta varianta mai buna
Salut. Aveti idee ce poate fi? Am incercat sa efectuez o regenerare fortata dar primesc eroare ca nu poate incepe procedura in sesiunea activa..
Mulțumesc!
Ps: cu motorul pornit presiunea diferentiala este cu minus iar temperatura de iesire din filtru - 40g. Am schimbat si senzorii de presiune de la filtru dar fara rezultat.
vlahdacoroman
Pana nu faci ca valorile senzorilor de la dpf sa fie plauzibile regen nu va porni.
Vezi ca ai pus senzorul de presiune diferenteala invers la furtunase.
Trebuie schimbat urgent? Este G450? Nu am avut martor aprins in bord, am descoperit întâmplător la o scanare azi. Am stres eroarea si nu a mai aparut.
De un timp imi apare aceasta eroare, o sterg dar apare din nou dupa 50-60 km:
"Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    KSG PQ47 ELV 043 0634
   Revision: 00043000    Serial number: VWZCZ000000000
   Coding: 19910A000286403E7F021C1CFC0E4FC6505C01
   Shop #: WSC 00028 028 00001
   VCID: 76B51A3A44CF030B79E-8022
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H05 1501
   Subsystem 2 - Part No: 3C0 951 171 C
   Component: Neigungssensor  004 0611
   Subsystem 3 - Part No: 3C0 951 171 C
   Component: Innenraumueberw.004 0611
1 Fault Found:
00332 - Control Circuit for Tank Flap
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 4
                    Fault Frequency: 144
                    Reset counter: 226
                    Mileage: 134602 km
                    Time Indication: 0
                    Date: 2014.11.03
                    Time: 11:52:11"
Am demontat tapiteria din dreapta portbagaj (B7 berlina), am verificat firele care merg la actuator, am izolat portiunea de 10-15 cm care nu era izolata, de la toronul de fire la mufa, totul functioneaza bine dar dupa 60 km eroarea a aparut din nou (data nu e concludenta, era la inceputul lui august 2020). Unde sa mai caut?
Modificat de CristianH
Completare informatii
@RLine 2009
Pregateste-te de inlocuit G450. Daca a disparut momentan..e bine. Dar reapare,cu siguranta.
@CristianH
Schimba actuatorul.
Am inteles ca cel de SUA are probleme. Sa caut cu alta fabricatie in afara de SUA?
Original! Saptamana trecuta m-am chinuit cu 2 senzori Bosch noi, luati pe cod. Ambii defecti. Masina a plecat cu un senzor SH original ce il aveam in trusa ptr teste..merge bine mersi.
Trebuie neapărat sa fie de euro 5 si 170cp cum am eu?
@spido Oare nu pot sa-l repar? Cred ca problema a aparut iarna trecuta dupa o spalare cu temperaturi negative afara. Am gasit si "Incuietoarea" de pe clapeta ce acopera rezervorul  crapata, probabil gheata in acea gaurica...
Poti incerca..dar cred ca la inlocuire se ajunge.
kosmyn_aurel89
Vw Touran 2007
2.0tdi Bmm
Martorul Esp din bord nu se aprinde la punerea contactului, si nici butonul nu se aprinde pe galben la apasarea/deconectarea lui.
Pe modulul abs/esp 1k0 907 379 Ac, am gasit 2 erori:
-00495- Esp sensor unit (g419), supply voltage -012 electrical fault in circuit-intermitent.
-00493 -Esp sensor unit g419 -004 no signal/communication
Ce am mai observat uitandu-ma pe vcds, e  ca senzorul g200 nu misca deloc si era blocat pe 0 indiferent daca balansam/miscam masina.
Modificat de kosmyn_aurel89
Verifica cablajul senzorului. Daca e ok, se inlocuieste senzorul.Senzorul este in spatele torpedoului care trebuie demontat ptr acces la el.
Modificat de spido
Vw Golf 7 1.6 TDI DSG
In urma scanari am gasit aceste doua erori pe cutia de viteze:
P177B 00 (072) - Tolerance Limit Reached
P189A 00 (072) - Clearance top Small
O părere va rog?
Daca postezi in 2 locuri diferite,crezi ca primesti raspuns mai repede?
Abreiaje uzate.
  • Aerofan pinned this topic
    • rabbit85
