zorg
Eu vad ca poti sa-l accesezi.
Erorile am reusit sa le scanez saptamana trecuta dupa vreo 10-15 incercari. Acum nu ma mai lasa nici dupa o ora de incercari si imi da chestia asta "  DTCs not supported by controller or a communication error occurred " pe ABS
vlahdacoroman
Verifica continuitatea firelor,adica tot traseul....
Apoi verifica daca J104 primeste 12 V.
Buna ziua!Astazi din greseala am reusit sa activez acest test si acum nu se mai stinge becul la ABS.Ma poate ajuta cineva?
Log-WVWZZZ1KZBW012468.txt
vlahdacoroman
Fa procedura asta:
Prerequisites
The ONLY fault that should be stored in the 03-ABS controller is 01486 and the 44-Steering Assist module should be fault-free.
VCDS should NOT need to be connected while performing the Function Test!
Vehicle stationary
Ignition ON, Engine ON (Running)
Perform the Test Drive on an enclosed Site (i.e. a Parking Lot)
Make sure to Complete the Function Test within 50 Seconds after pressing the Brake Pedal
Instructions
Firmly press the Brake Pedal until a certain Brake Pressure (usually right above 30 bar) is reached.
Brake Pressure Sensor (G201) Plausibility will be confirmed by a Change in the Brake Electronics Warning Lights.
On Bosch, the ASR/ESP Warning Light (K155) will switch OFF and the ABS Warning Light (K47) will switch ON.
On Continental/Teves, the ABS Warning Light (K47) will switch OFF and the ASR/ESP Warning Light (K155) switch ON.
Start Driving straight with a steady Speed of ~20 km/h (~13 mph).
Turn the Steering Wheel either Left or Right between a 90° Angle (1/4 Turn) to 180° Angle (1/2 Turn) and keep it steady.
Lateral Acceleration Sensor (G200) and Rotation Rate Sensor (G202) Plausibility is confirmed
once the remaining Brake Electronics Warning Light(s) switch OFF.
The Function Test is now completed.
Notes
When Driving, make sure the general Speed is between 15 to 30 kph (9 to 18 mph).
The Turn should be done at a Rotation/Turn Rate of ~10 °/s which can be achieved with a
Turning Radius of 10 to 12 Meters (30 to 40 feet) with a Speed between 15 to 30 kph (9 to 18 mph).
You may experience Variations in the Warning Light Behavior depending on the individual Brake System Generation,
this is no Reason to be concerned as long as you follow the General Procedure.
Am reusit in cele din urma,va multumesc!Cu stima!
vlahdacoroman
Ai urmat procedura sau cum?
Da,am mers in poligon si am reusit.
Salut! Am si eu 2-3 erori, daca ma poate ajuta cineva sa-mi spuna mai exact despre ce-ar putea fi vorba.
1 Fault Found:
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [032] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
2 Faults Found:
9481988 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 38
                    Reset counter: 81
                    Mileage: 166798 km
                    Date: 2060.14.18
                    Time: 10:42:45
9479699 - Control Circuit for Front Left Seat Heater
          B10A6 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 7
                    Reset counter: 79
                    Mileage: 167791 km
                    Date: 2061.14.12
                    Time: 10:04:25
vlahdacoroman
Prima eroare este de la imobilizator,motorul a fost oprit...posibil nu a recunoscut cheia.
Eroare la senzorul de calitate al aerului de la HVAC,verifica mufa....fire,apoi inlocuit.
Apoi mai ai o eroare la incalzirea din scaun stg fata...verifica mufa fire si siguranta.
Ai idee unde e locat?
acolo unde este gura de admisie de aer proaspat in masina.
Buna seara. De 2 zile mi-au aparut aceste erori. Erorile apar imediat dupa ce sunt sterse. In ambele cazuri masina functioneaza ok. Se mai poate circula cu masina avand acea eroare de la ABS pana ajung la un service ? nu as vrea sa stric ceva mai rau. Va multumesc si va urez o seara placuta tuturor !
Probleme cu senzorul abs stinga fata-de verificat conector/cablaj si ceva probleme cu contactul(partea electrica) si butonul de incuiere de pe usa soferului.
M am uitat pe acolo, n am gasit nimic. Ma poti ajuta cu o poza ceva? Multam
Salut. Am un golf 6 2010, CR, 140 CP, DPF, cred, ca, codul de motor ii CFFB si sta turata in relanti la 900 sau 980 rtoatii pe min. Si am si o eroare pe dpf.
                    Fault Frequency: 2
                    Mileage: 252023 km
                    Date: 2017.06.08
                    Time: 07:49:53
                    Engine speed: 2383.00 /min
                    Normed load value: 31.0 %
                    Vehicle speed: 41 km/h
                    Coolant temperature: 76 °C
                    Intake air temperature: 20 °C
                    Ambient air pressure: 960 mbar
                    Voltage terminal 30: 14.280 V
                    Unlearning counter according OBD: 40
                    Sensor for particle filter differential press: raw value: 1046 hPa
                    Particle filter: difference pressure: 1045 hPa
                    Particle filter: offset for differential press.: 64 hPa
                    Particle filter: differential pressure: dynamic offset: 0 hPa
                    Outside air temperature: 16.5 °C
                    Particle filter: soot mass measured: 25.07 g
                    Particle filter: soot mass calculated: 18.84 g
Puteti  sa ma ajutati cu o interpretare si cu ce ar fi de facut. E dus senzorul respectiv? sta tot asa turata la 900, 980.
DPF, Senzor cu probleme.txt
Multumesc, cu intarziere.
Salutari dragilor,
De ceva timp ma confrunt cu doua erori ce nu stiu cum sa le intepretez si sa le rezolv.
Pe scurt: am avut eroare la elementul incalzitor din rezervorul de adblue, am schimbat acest element am scapat si de eroare , dar la putin timp (apox. doua saptamani) m-am pricopsit cu altele doua. Orice informatie sau sugestie este bine venita
Salut.
Ma poate ajuta cineva cu interpretarea erorilor de pe climatronic,si ce trebuie sa fac?
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 H
   Component: CLIMATRONIC B5GP    0004
   Coding: 17000
   Shop #: WSC 05311
   VCID: 26439CFEC2262772FA-515E
2 Faults Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
            30-10 - Open or Short to Plus - Intermittent
00792 - A/C Pressure Switch (F129)
            35-10 -  -  - Intermittent
ai verificat daca ai freon in instalatie ?
Va salut
Am o problema la panoramic, iar in scanare apare asa
1 cod a gasit:
01512 - Modul comandã pentru trapa glisantã
            005 - lipsã setareDeBazã/eºuatã/adaptare
             împrejurãri cod:
                    Stare defect: 01100101
                    Priorit.defect: 2
                    Frecv. defect: 1
                    Resetare contor: 92
                    rulaj: 191511 km
                    Indicator de timp: 0
                    Data: 2011.10.27
                    timp: 17:06:05
Panoramicul nu se mai plimba la impuls (buton) sau la confort (telecomanda-cheie). Se plimba doar cat tin tras sau rotit de buton.
Am incercat sa vad la ce se refera "setare de baza". Dar la codare este bifat cam tot.
Astept niste pareri sau ceva sfaturi de la voi
Mentine-o cateva sec in poz inchisa, respectiv deschisa. La fel ca la geamuri-tii butonul apasat cateva sec in poz max sus, respectiv maxim jos.
Inteleg, probabil ca sa isi invete pozitia.
La deschis ar merge incercat, o fac maine dimineata. Dar la pozitia inchis nu merge tinut pozitia inchis, pentru ca nu sta mai mult de o secunda si reia ciclul deschidere. Dar E interesant de incercat pe deschis la maxim. Sa vad daca are ceva efect.
Pana revin, cu un rezultat, mai astept sfaturi sau pareri (bune sau rele). Le incerc pe toate.
ps
Oare ar merge debifat tot ce e acolo in coding, si dupa memorare, sa incerc sa le rebifez exact cum au fost?
Si a doua intrebare ar fi: Ce inseamna "setare de baza"? Cu se face?
Ma puteti ajuta cu o explicatie si cine se baga la repararea acestor erorii. Precizez ca masina am achizitionat-o de curand si vreau sa o pun la punct din toate punctele de vedere
Tuesday,13,June,2017,22:28:13:53699
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.3.0
Data version: 20151216
www.Ross-Tech.com
VIN: WVWZZZ3CZ7P094123   License Plate: CATALIN
Mileage: 232140km-144245mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 53 55 56 5D 62 69
          72 76 77
VIN: WVWZZZ3CZ7P094123   Mileage: 232140km-144245miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5D-Operations -- Status: OK 0000
69-Trailer -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 CE    HW: 03G 906 018 CE
   Component: R4 2.0l PPD1.5 G    9707
   Revision: --H35---    Serial number: VWZCZ000000000
   Coding: 0000172
   Shop #: WSC 00028 028 00001
   VCID: 6AD0121645AE2A6ECF-803E
4 Faults Found:
005269 - Switch-Over Valve for EGR Cooler (N345)
               P1495 - 009 - Open or Short to Ground - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100100
                    Fault Priority: 1
                    Fault Frequency: 18
                    Reset counter: 40
                    Mileage: 232073 km
                    Time Indication: 0
                    Date: 2017.06.11
                    Time: 13:03:59
             Freeze Frame:
                    RPM: 320 /min
                    Torque: 120.0 Nm
                    Speed: 0.0 km/h
                        0.00 %
                    Voltage: 10.51 V
                    Mass Air / Rev.: 910.2 mg/str
                    Mass Air / Rev.: 414.2 mg/str
004711 - PD Unit Injector: Cylinder 3 (N242)
               P1267 - 006 - Regulation Range Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 6
                    Reset counter: 38
                    Mileage: 231994 km
                    Time Indication: 0
                    Date: 2017.06.09
                    Time: 08:28:16
             Freeze Frame:
                    RPM: 800 /min
                    Torque: 24.0 Nm
                    Speed: 0.0 km/h
                        76.05 %
                    Text:  4.875    uF
                    Text: 14.50    mJ
                    Text:      7    mJ
                    Voltage: 0.40 V
000801 - Engine Speed Sensor (G28)
               P0321 - 006 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 33
                    Mileage: 232042 km
                    Time Indication: 0
                    Date: 2017.06.10
                    Time: 16:03:48
             Freeze Frame:
                    RPM: 192 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Time: 0.00 s
                    Angle: 0.0 °
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
012600 - Intake Manifold Runner Control
               P3138 - 006 - Regulation Deviation - Intermittent
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 37
                    Mileage: 232105 km
                    Time Indication: 0
                    Date: 2017.06.13
                    Time: 08:33:08
             Freeze Frame:
                    RPM: 832 /min
                    Torque: 56.0 Nm
                    Speed: 73.0 km/h
                    Mass Air / Rev.: 0.0 mg/str
                    Lambda: 64.1 %
                    Text: Kein Messwert verfuegbar
Readiness: N/A
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AH    HW: 3C0 907 044 AH
   Component: ClimatronicPQ46 050 0505
   Revision: 00050005    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 67D66B2256BC1706D0-8032
3 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
            000 -  -
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 3
                    Fault Frequency: 64
                    Reset counter: 165
                    Mileage: 231792 km
                    Time Indication: 0
                    Date: 2017.06.08
                    Time: 11:35:23
00716 - Air recirculation Flap Positioning Motor (V113)
            000 -  -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 64
                    Reset counter: 165
                    Mileage: 231792 km
                    Time Indication: 0
                    Date: 2017.06.08
                    Time: 11:35:23
01274 - Air Flow Flap Positioning Motor (V71)
            000 -  -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 63
                    Reset counter: 165
                    Mileage: 231792 km
                    Time Indication: 0
                    Date: 2017.06.08
                    Time: 11:35:23
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 P    HW: 1K0 959 793 L
   Component: J386  TUER-SG FT    1123
   Revision: 32008001    Serial number: 00000022869107
   Coding: 0000245
   VCID: 3B7EE7527AB463E664-806E
1 Fault Found:
00109 - Left Mirror Turn Signal Lamp (L131)
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 5
                    Fault Frequency: 7
                    Reset counter: 199
                    Mileage: 232070 km
                    Time Indication: 0
                    Date: 2017.06.10
                    Time: 22:48:02
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 E    HW: 3C0 907 801 E
   Component: EPB  VC8HC003   013 0003
   Revision:   013
   Coding: 0000012
   Shop #: WSC 131071 1023 2097151
   VCID: 244C3C2EE70A3C1E35-8070
1 Fault Found:
02442 - Function Lamp in Control Head
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 231976 km
                    Time Indication: 0
                    Date: 2017.06.08
                    Time: 18:14:52
             Freeze Frame:
                    Voltage: 13.87 V
                    Count: 65
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 B    HW: 3C0 919 283 B
   Component: Parkhilfe 8-Kan 004 0011
   Revision: 00004000    Serial number: 82930630506845
   Coding: 0010014
   VCID: 2854281E9B22D87E19-807C
5 Faults Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 161
                    Mileage: 232097 km
                    Time Indication: 0
                    Date: 2017.06.12
                    Time: 12:22:41
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 161
                    Mileage: 232097 km
                    Time Indication: 0
                    Date: 2017.06.12
                    Time: 12:22:42
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 161
                    Mileage: 232097 km
                    Time Indication: 0
                    Date: 2017.06.12
                    Time: 12:22:42
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 3
                    Fault Frequency: 9
                    Reset counter: 200
                    Mileage: 231794 km
                    Time Indication: 0
                    Date: 2017.06.08
                    Time: 12:00:25
02070 - Rear Parking Aid Sensors
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 153
                    Mileage: 231794 km
                    Time Indication: 0
                    Date: 2017.06.08
                    Time: 12:00:26
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 3C0 035 730 B    HW: 3C0 035 730 B
   Component: Telefon             2609
   Revision: 00010000    Serial number: 0000000022612
   Coding: 0020035
   VCID: 1A3002D6D54E7AEE9F-804E
2 Faults Found:
00385 - Positive Output Audio Channel for Speech/Telephone
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 153
                    Mileage: 231794 km
                    Time Indication: 0
                    Date: 2017.06.08
                    Time: 12:01:30
00386 - Negative Output Audio Channel for Speech/Telephone
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 153
                    Mileage: 231794 km
                    Time Indication: 0
                    Date: 2017.06.08
                    Time: 12:01:30
End-------------------------(Elapsed Time: 02:41)--------------------------
Multumesc anticipat
  • Aerofan pinned this topic
    • spido
