Codare Polo 9N
tzontzolino
Oare imi cum pot verifica daca e codarea ok mai ales la Adress 09 (la 19 pare ok 00014) , ca nu-i dau de cap.
Masina : polo 9n, 1.2 AZQ, geamuri electrice f+s; onglinzi electrice, abs, servo, cutie manuala, AC.
Ca si probleme : vitezometrul nu functioneaza (Sau are momente cand functioneaza scurt timp) ; iar nivelul de benzina "piuie" la curbe daca e sub jumatate.
Interventii recente: schimbat pompa servo. (PS. daca motorul vibreaza - posibil un tampon motor? )
Ca erori doar ce e mai jos
Quote
 Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: 32 GATEWAY CAN 1S31
Coding: 00014
Shop #: WSC 31414
3 Faults Found:
00511 - Selector Lever (E313)
49-00 - No Communications
00778 - Steering Angle Sensor (G85)
01324 - Control Module for All Wheel Drive (J492)
Address 09: Cent. Elect. Labels: None
Part No: 6Q1 937 049 B
Component: 00 BN-SG. 1S31
Coding: 17566
Shop #: WSC 31414
4 Faults Found:
00907-Intervention Load Management
35-00
Ms anticipat de ajutor
Codeaza manuala, fara awd
Pai si cat sa pun la 09 ? Ca nu mi da socoteala
