milika
Daca desfaci potentiometru de pe clapeta poti sa le arunci pe amandoua,nu ti le mai poate nimeni calibra,deci se schimba tot corpul injectorului.
  • Replies 478
  • Tracto
    43
  • mac23
    31
  • floss
    18
  • Al Bundy
    16
Aseara m-a lasat bateria, astazi am schimbat-o. Doar ca la o scanare ulterioara cu vag-com'ul am descoperit mai multe erori, care tind sa scred(si sper) ca au fost datorate bateriei anterioare.
Cam acestea sunt erorile, le-am sters, am mai facut un scan si nu a mai aparut nicio alta eroare:
Address 01: Engine Labels: Redir Fail!
Part No: 036 906 034 CN
Component: MARELLI 4MV G 5164
Coding: 00031
Shop #: WSC 78395
VCID: 60CBA4B3CF67
WVWZZZ1JZ2W073690 VWZ7Z0A3701736
2 Faults Found:
17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
P1564 - 35-10 - - - Intermittent
17793 - Control Module Malfunction - Lambda Sensing Circuit
P1385 - 35-10 - - - Intermittent
Readiness: 0010 0001
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 01000
Shop #: WSC 01317
VCID: 214DE1B784ED
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01206 - Signal for Duration of Ignition Off Time
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 27 AIRBAG VW51 01 01
Coding: 12855
Shop #: WSC 01317
VCID: 224FEEBB81EB
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 846 A
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 21113
Shop #: WSC 00000
VCID: 2E570A8BC533
00667 - Ambient Temperature Signal
30-10 - Open or Short to Plus - Intermittent
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: EB Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 00028
VCID: 366722EB3D63
Subsystem 1 - Part No: 1C1959801A
Component: 18 Tõrsteuer.FS KLO 0003
Subsystem 2 - Part No: 1C1959802A
Component: 18 Tõrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1C0959811A
Component: 18 Tõrsteuer.HL KLO 0002
Subsystem 4 - Part No: 1C0959812A
Component: 18 Tõrsteuer.HR KLO 0002
9 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
01134 - Alarm Horn (H12)
49-00 - No Communications
01135 - Interior Monitoring Sensors
36-00 - Open Circuit
01331 - Door Control Module; Driver Side (J386)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 E
Component: Radio BNO 0005
Coding: 02403
Shop #: WSC 01317
VCID: 2759FFAFEAC9
2 Faults Found:
00852 - Loudspeaker(s); Front
44-10 - Short Circuit - Intermittent
00853 - Loudspeaker(s); Rear
End ---------------------------------------------------------------------
Sa-mi fac griji ? Eventual peste cateva zile voi mai face o scanare, sa fiu sigur...
Stai linistit. Toate sunt de la bateria descarcata.
Nu chiar toate, aia cu senzor temperatura extyerioara nu prea are cum sa fie de la baterie...
Voi mai face o scanare peste 2-3zile si vad atunci daca mai apare...
La eroarea asta :
..mai pot face ceva ? Adica daca e senzorul de bai banuiesc ca doar prin schimbarea lui se rezolva problema.
Modificat de undan
Senzorul sau cablajul pana in ceasuri.
Multumesc. Banuiesc ca este acelasi senzor care indica temperatura atat pentru maxidot cat si pentru climatronic, nu ?
Da.
Postati va rog in aria corespunzatoare. Aici e Golf3 :offtopic:
Daca nu s-a umblat la suruburile de la clapeta de acceleratie (CELE DE LIMITARE DE SUSU SI DE JOS) se poate recalibra potentiometrul la ABD,ABU,ABS,AEA.
E de munca dar am reusit sa aduc in parametri 3 clapete la care au umblat alti mecanici priceputi prin service.(evident cel mai indicat e ca acest lucru sa se realizeze pe masina de pe care s-a luat corpul de acceleratie).
salut. audi 80 b4 20 e motor abk 116 cp , cine imi spune pe ce canalgasesc la vag com injectoarele, ( masina la relanti are mici fluctuatii si cand o accelerez , se tureaza aiurea si la toba daca ma duc in spate parca bolboroseste ) am pus vagom si am gasit doar o eroare la airbag atat,si nu are asa vlaga in ea, care ar fi cauza ????
Modificat de denzel
am curatat senzorul ,eroarea s-a sters iar dupa un timp mia aparut din nou ,am atasat eroarea care mia dat-o testerul.
Schimba senzorul sau verifica cablajul.
Modificat de Tracto
cablajul este corp comun cu senzorul ,cel mai probabil voi schimba senzorul.
buna,
un .lbl pentru 032 906 026 D (engines 1,6 AEA) gasesc si eu pe la colegi ?
ma poate ajuta cineva cu urmatoarele erori din log-urile atasate?
Va multumesc,
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8EZ1A007913 Mileage: 194110km/120614miles
Address 01: Engine Labels: 06B-907-557-ALT.lbl
Part No SW: 8E0 907 557 HW:
Component: 2.0L R4/5VS 0005
Coding: 0011501
Shop #: WSC 00999 444 64523
VCID: EED74A8B8257
No fault code found.
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front D620
Coding: 04275
Shop #: WSC 22683
VCID: E5C535A757A1
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043
Component: A4 Klimaautomat 0403
Coding: 00000
Shop #: WSC 63351
VCID: DEB71A4B72F7
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279
Component: int. Lastmodul RDW 0409
Coding: 00001
Shop #: WSC 63351
VCID: EFE9578F855D
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 3001
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: F4E358E3EC7B
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00002
Shop #: WSC 22683
VCID: 3C7330C304AB
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 F
Component: KOMBI+WEGFAHRS. RB4 D10
Coding: 00000
Shop #: WSC 10169
VCID: 2759FFAFED2D
WAUZZZ8EZ1A007913 AUZ6Z0Y0014098
00668 - Supply Voltage Terminal 30
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 J
Component: Komfortgerát T85 0111
Coding: 06720
Shop #: WSC 63351
VCID: 387B2CD33093
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 4.11
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 4.11
01559 - Drivers Door
60-10 - Won't Safe - Intermittent
Control Module Part Number: 8E0 907 557 HW:
Component and/or Version: 2.0L R4/5VS 0005
Software Coding: 0011501
Work Shop Code: WSC 00999 444 64523
VCID: EED74A8B8257
2 Faults Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded - Intermittent - MIL ON
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 001 - Upper Limit Exceeded
Readiness: 0000 0001
@catz
Sterge erorile si vezi cu care mai ramai.
Problema e de la modulul electronic coloana de volan (8E0953549F) situat in spatele celor 2 manete de semnalizare si stergatoare.
Posibil sa ai si ceva probleme la contact (ignition switch)
Ceva explicatii la erori gasesti aici:
http://wiki.ross-tech.com/wiki/index.php?title=Category:Fault_Codes&pagefrom=01279#mw-pages
adrianviperdodge2012
Spuneti-mi si mie va rog ce se poate face in situatia data :
Address15:Airbags
Controller:1H0 959 656
component: Airbags
00588-Airbag igniter Driver side(N95)
32-00 -RESISTANCE TOO HIGH
wiki.ross-tech.com/wiki/index.php/00588 pe romaneste, probleme cu conexiunea, fire intrerupte, contacte oxidate. verifica in special contactul din spatele volanului, acel inel pe care gliseaza mufa airbagului.
presupun ca trebuie sa demontez volanul nu?daca da,nu exista riscul sa sara airbagul?adica nu am asa de multi bani sa cumpar altul si sa ma mai si lovesc :))
  • 9 months later...
Ma poate ajuta cineva, cu interpretarea acestor 2 erori ?
Labels: 1J0-920-xx5-17.LBL
   Controller: 1J0 920
826 C
   Component:
KOMBI+WEGFAHRS. BPV V08
   Coding: 00114
   Shop #: WSC 00046
   WVWZZZ1JZ2B064814     VWZ6Z0A3742021
01039 - Coolant Temperature Sensor
(G2)
  64-10 - Not Currently Testable -
Intermittent
Address 46: Central Conv.       Labels: 1C0-959-799.LBL
   Controller: 1C0 959
799 B
   Component: 1C
Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 00046
01389 - Tailgate Open Switch (F124)
 27-00 - Implausible Signal
Modificat de mariusrizea
