Codari VCDS probate [Arteon]
raven2k1
Deoarece sunt inca foarte putine site-uri unde sunt puse codari functionale, adaug mai jos ce am testat pe Arteon-ul meu:
Tema GTI pe AID (320km/h, cifre viteza si rpm luminate mai mult atunci cand acul este in dreptul lor)
  • Dash Board (17) ->
  • Adaption ->
  • Tube_version ->
  • Variant 4 (Default for me was Variant_2)
Daca vreti sa adaugati si puncte care au efect de animatie pe AID:
  • Module 17 dash board
  • Adaptation
  • Display depiction
  • Modifica in  3 (default e 1)
HighBeam Assist (trecere automata pe faza lunga atunci cand din fata nu vin alte masini):
  • Select Control unit 09 (Central Electrics)
  • Security access
  • Access Code 31347
  • Adaptation
  • 1. Fernlicht_assistent – Menuesteuerung Fernlichtassistent – Change to ‘Present’  -> sunt pe la ENG141650
  • 2. Fernlicht_assistent – Erweiterte_Frenlichtsteuerung – Change to ‘AFS, FLA, Fernlicht ueber AFS’
  • Enter Coding
  • Byte 2 – Tick Bit 0 and Bit 1
  • Select Control Unit Front Sensor Driver Assist System (A5)
  • Enter Coding
  • Byte 21 – Tick Bit 5
  • Reboot Headunit. Option will now appear under ‘Light Settings’ and pushing the high beam stalk forward will reveal the symbol with an ‘A’ within it.
Hill stat assist
  • Select STG 03 (brake electronics)
  • STG adaptation -> function 10
  • Select hill-start assist
  • adjust value accordingly -  eu am pus early la mine - plecarea parca este mult mai lina acum(abia ating pedala).
Confirmare armare/dezarmare cu claxon:
  • Select STG 09 (vehicle electrical system)
  • STG access authorization -> function 16
  • Enter release code 31347
  • ·  (1) Rückmeldungssignale-Akustische Rückmeldung entriegeln auswählen·  Value to yes
    ·  (2) Rückmeldungssignale-Akustische Rückmeldung verriegeln auswählen·  Value to yes
    ·  (8)-Rückmeldungssignale-Akustische Rückmeldung global ·  Adjust Value on active
  • Adjust Value to active
  • activare functie din interfata multimediei:
    • (7)-Rückmeldungssignale-Menuesteuerung akustische Rückmeldung
    • Adjust Value on active
  • If desired, the duration of the acoustic feedback can be shortened:
    • (3)-Rückmeldungssignale-Dauer der akustischen Rückmeldung vom Einfachhorn
    • Adjust value to short
Start-up assist
  • Select dynamic approach assistant          Berganfahrassistent auswählen
  • Adjust value accordingly (early = ideal)
Modificare numar semnalizari comfort:
  • (2) Turn signal control -   Komfortblinken Blinkzyklen auswählen
  • Adjust value as required Default value: 3
  • After adjustment, the menu item Factory setting -> Light must be executed in the vehicle settings
Automatic lock la iesirea din masina cu cheia in buzunar:
  • Select STG 05 (access / start authorization)
  • Deposit login code 20103
  • STG Long Coding -> Function 07
  • Bye 2
  • Activate bit 4
  • Select channel byte1 - passive_exit_door_slam_lock           Kanal byte1 - passive_exit_door_slam_lock auswählen
  • Set value to active
ATENTIE: nu lasati motorul pornit sau contactul pus si iesiti din masina cu cheia in buzunar. By default, buoanele de pe telecomanda nu functioneaza cand contactul este pus !!!!!
Masina se va bloca si, daca nu aveti urmatorul mod facut, o sa va chinuiti cum m-am chinuit si eu la Victoriei cu sarma  bagata pe langa cheder sa lasati un geam jos a.i. sa puteti deschide masina din interior.
Locking/Unlocking a keyless-access equipped car while engine running using remote:
  • 09 - Central Electronics
  • 16 – Security Access (use 31347 code)
  • 10 – Adaptation:
  • (1) Access control-Funk bei Klemme 15 ein      change to: "active" (factory state "inactive")
Memorie incalzire scaune dupa repornire:
  • Select STG 08 (climate)
  • Channel Storing the seat heating level Select driver     Kanal Speicherung der Sitzheizungsstufe Fahrer auswählen
  • Adjust value to active
  • (default value: not active)
  • Selecting the memory of the seat heating level Passenger       Kanal Speicherung der Sitzheizungsstufe Beifahrer auswählen
Modificare durata spalare faruri:
  • (2) Windshield Wiper SRA Select delay time
  • Adjust value as required Default value: 0 ms
  • Sample value : 1500 ms
Lumini de zi active doar cand comutatorul este pe auto:
  • Enter access code 31347
  • Channel (9) - Select daytime running light only in switch position Auto        Kanal (9) - Tagfahrlicht nur in Schalterstellung Auto auswählen
Lumini de zi activate de pe interfata multimediei:
  • Select STG 09 (Cent. Elect.)
  • Select STG 16 (Security Access)
  • Enter Code 31347
  • click "Do it!" tab
  • Select STG 10 (Adaption)
  • -Select (2)-Daytime Running Lights- Tagfahrlicht Aktivierung durch BAP oder Bedienfolge möglich
DLA - Activare lumini dinamice ( masina trece automat pe faza lunga cand nu sunt masini din sensul opus - daca incep sa apara masini, aceasta izoleaza partial locul unde sunt masinile si trece farul partial pe faza scurta). Am incercat pe masina mea - functioneza dar cred ca nu sunt reglate corect farurile. Cateodata, cei din fata imi dau flash-uri... Daca pana acum toate codarile de mai sus se puteau face cu orice fel de interfata minim 17.8.1, pentru acest mod aveti nevoie de vag-hex v2 NEAPARAT - NU EXISTA CLONE, chiar daca scriu pe ele ca sunt hex v2 - puteti face acest mod doar cu interfata originala! Va recomand pe colegul @Al Bundy. Dupa fiecare codare alegeti optiunea de reset !
  • intrati pe stg 09
    • security access 31347
    • tot pe la eng141650
      • cautati Erweiterte Fernlichtsteuerung. Modificati in AFS;FLA; Fernlicht (GLW:MDF)
      • Menuesteuerung Fernlichtassistent: present
      • Menuesteuerung Fernlichtassistent werkseinstellung: present
      • Ar trebui sa aveti in meniul multimedia, sub light - Dynamic light assist - nu il bifati inca fiindca o sa va dea eroare.
      • Dati factory reset pentru lights.
  • Intrati pe A5
    • long coding
      • byte21: bit 5-7 : 40 Dynamicher Lichtassistent (DLA)
      • byte19: bit 0-3 : 00
      • byte19: bit 4-7 : 30
  • armati masina si lasati-o 5 minute fara sa ii faceti nimic.
  • intrati pe 4B:
    • setati Byte 10: bit 6 on - mdf_activation
  • masina da erori de lumine - stergeti toate erorile - daca nu merge, iesiti si reintrati pe 4B.
  • dupa ce le stergeti, intrati in Basic settings si faceti Headlights adjustment (Start - o sa scrie ca nu ruleaza, dati stop). Apoi faceti save position (este urmatoarea optiune de la Basic settings; la fel, dati start, o sa zica ca nu ruleaza si apoi dati stop). Stergeti din nou toate erorile(daca au reaparut).
  • teoretic, acum, pe lumini Auto, impingerea manetei in fata ar trebui sa activeze DLA !
  • La mine a mers - pe unele forumuri scrie ca, daca sunt erori in 4B ar trebui setata valoarea pentru byte 08 = 03, byte 09=10,  byte 10 dezactivat bit 5(all weather lights) si byte 11 activare bit 2.
Pentru DLA nu trebuie si alte faruri?
nu. arteonul are tot ce trebuie din fabrica - nu inteleg de ce nu le activeaza by default sau de ce nu cer bani pentru optiune...
Incepand cu MY2019 optiunea e in standard.
Asa stiam si eu, ca ar mai fi nevoie si de niste chestii prin far, ca sa mascheze partial fascicolul de lumina, nu numai camera aia ce o foloseste si la Lane Assist
clar nu e numai camera. Farurile actuale au si ele chestiile alea care obtureaza partial lumina - cel putin la ce am luat eu acum 3 luni.
Seara buna,
Exista  vreo codare  la Arteon cu Easy Open... dupa ce deschid haionul de la buton din interior...sa mai apas odata butonul si sa se inchida automat haionul...ca sa nu mai cobor sa apas butonul de inchidere de pe haion...?
Salut.  Incearca sa tii "tras" cateva secunde butonul haionului de pe usa soferului.  La mine a inchis.
Modificat de Manuel N.
Nu mai folosi quote. Se sanctioneaza. Citeste regulamentul.
Merci...merge...doar ca nu am tinut eu destul apasat butonul...  :blah:
Vad ca unii (MQB-Coding) au reusit sa activeze Predictive ACC pe Seat Leon 2014 avand la baza aceasta functie de pe Arteon.
Oare va putea fi extinsa si la altele din vag?
  • Edy_77 changed the title to Codari VCDS probate [Arteon]
Multumim , am activat si eu
- Tema GTI pe AID
- puncte care au efect de animatie pe AID
HighBeam Assist il aveam by default
Multumim !
  • 8 months later...
Salutare!
As vrea sa activez si eu pe un Arteon 2017 functiile DLA si tema GTI pe AID.
Stiti cumva cine ma poate ajuta in directia asta in Bucuresti?
Încearcă pe aria de prestări servicii! Aici e doar cum se face nu cine face!
Buna seara!
Detin un VW Arteon din 2017 si de ceva timp incerc sa activez functiile pe care colegul @raven2k1 le-a share-uit insa din pacate nu imi accepta codul 31347.
Va rog sa ma ajutati cu codul pe care trebuie sa il utilizez sa pot sa fac adaptarile.
Interfata pe care am folosit-o este VCDS Hex-Can V2 MQB iar versiunea de soft este 22.9
Orice informatie este bine venita.
Va multumesc!
constantinmarin
Bună seara ma poate ajuta cineva cu un sfat .cum as putea ridica farurile la un arteon 2020 nu am în computer opțiunea ridicarea farurilor și nu am nici altceva de ridicare?multumesc
Se ridica mecanic, din reglaje. Recomand sa faci operatiunea, pe reglofar.
Scriu aici pentru ca eu cred ca tine de codare (si nu am gasit nicaieri :( ): exista vreo posibilitate/codare stiuta de vreun membru care sa modifice ce afiseaza ecranul "Home"?
La mine e impartit in 3 ferestre: navigatie/agenda telefon/radio.
Multumesc frumos. Foarte utile!
Respect.
Stiti cumva cum se face si schimbarea ulorilor luminilor ambientale, din 3 sa fac 10?
Cu VCDS, nu cu ObdEleven
Modificat de Adybv
Intri exact unde e descris in linkul pus de tine.
La un Arteon 2018 daca vreau sa ii pun portbagaj electric original trebuie sa codez ceva?
Si are cineva idee daca Arteonul a avut optiunea cu senzorul de picior sau cu butonul acela cu "A" care iti permite sa inchizi portbagajul dupa ce te îndepărtezi de mașină?  Tiguanul am văzut ca are sigur.
Mulțumesc.
Da, trebuie sa codezi bcm ul,can ul, etc
Da, poti pune si opțiunea cu senzor la bara, pt inchis. Mai ai nevoie de modulul aferent, antena si cablaj
Totodata, masina sa fie echipata cu keyless acces
Florin,
Ca sa înțeleg. Opțiunea 1 cu piciorul funcționează doar pentru INCHIS? Pentru aceasta am nevoie de modul, antena etc?
Pentru optiunea 2 cu Butonul cu "A" sunt necesare alte piese sau sunt cele de mai sus si vin ambele vin la pachet?
Mașina are keyless access. Pot sa aleg doar opțiunea 1 sau 2?
Mulțumesc.
portbajajul electric cu easy open se poate deschide de la butonul de pe telecomanda si se poate inchide tot de acolo. Se poate deschide de la butonul de pe usa soferului si se poate inchide tot de acolo. se poate deschide cu piciorul si se poate inchide cu piciorul. Se poate deschide de la emblema si se poate inchide de la unul din cele 2 butoane de pe portbagaj ( instant sau cu intarziere) .. Sau oricare din combinatiile de mai sus.
